Hi,
I have been struggling with this fault code on my 2008 Audi S4. It comes on and off, mostly on. I have searched the forum and have seen some post/threads but no clear solution that have fixed my issue.
Some info on the car:
- 2008 Aud S4 Avant
- 6MT conversion (problem exist when it was Tip)
Previous owner:
- replaced accelerator pedal
- replaced throttle body
- re-wired (overlay) accelearator pedal wiring harness to ECU (done by dealer)
- stock ECU and JHM tuned issue have same issue
What i've done:
- replaced O2 sensors. (theres's a mention in Ross-tech wiki about O2 sensor/wiring can cause the issue)
- checked ECU box/area for evidence of water, none, dry and clean
- checked connector s for corrosion, none
Have not checked:
- wiring harness from O2 sensors plug to ECU. What's the best way to do this?
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E2 910 560 HW: 8E2907560
Component: 5.0+ V8JHM 91+ G 0030
Revision: --H01--- Serial Number:
Coding: 0007711
Shop #: WSC 78131 538 452198
VCID: E48BBF9354042FBAD8F9E1-80B1
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
Reset Counter: 255
Mileage: 177823 km
RPM: 0
Load: 0.0
Speed: 0.0
Temperature: 99.0
Temperature: 46.0
Absolute Pres.: 1000.0
Voltage: 12.192
I appreciate any help/info anyone may have.
Jerome
- 2008 Aud S4 Avant
Previous owner:
What i've done:
Have not checked:
Coding: 0007711
Reset Counter: 255
Mileage: 177823 km
RPM: 0
Load: 0.0
Speed: 0.0
Temperature: 99.0
Temperature: 46.0
Voltage: 12.192
Jerome
