Another lost abs (MK60EC1) coding thread..
   #21
iichel
Netherlands, Operation Market Garden
C?ID=284912
i suppose the best way is to get a caddy vin in both ECU and immo and we'll make a caddy abs coding for it. if the abs is caddy compatible. which it seems to be.
   #22
franken.fab
South wales
HUC-2H
As I wish to do a couple more of these in the near future & keep things as ‘stock’ as possible, Presumably this would mean the info held on the MCU & being immo4c this would require specialist programming tools in order to change the vin within these areas? If my ODIS account is granted, I’m assuming half would be possible within the offboard diag and the other would require eeprom or ‘bench’ tools to do so, or am I going a little over the top with it..?
I know this doesn’t really matter in this grand scheme of things I just want things to be right and be as factory (or as) as possible with full immobilisation intact.
Had I kept the clocks and ecu in assuming this would had been easier as I’d only have changed one of the triangle, which from memory, you can recode but not if you have changed two of the three?
   #23
cristo_844
Portugal
C?ID=412536
Your going to need a lot more than Odis and eeprom bench tools to solve that mess!
franken.fab
South wales
HUC-2H
No, it is from a Vw golf mk5. Mk5 golf engine & ecu, scirocco clocks (easily changed to golf mk5 too) and Vw caddy chassis.
   #25
franken.fab
South wales
HUC-2H
Any other input on how to gain the coding for the abs? I have access to be able to input the vin into both clocks and immo / ecu but ideally would like to iron out the issues asap so the vehicle can be driven.
Thanks guys.
   #26
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Based on which VIN number should we calculate the coding?
   #27
franken.fab
South wales
HUC-2H
The original vehicle VIN: WV1ZZZ2KZDX057590 - Vw caddy 2k
The donor vehicle VIN (ecu and engine planted into above):WVWZZZ13ZBV002252
   #29
franken.fab
South wales
HUC-2H
Thank you Boki, I will see if I can input the coding in the next day or two and report back. Hopefully the controller will accept coding.
   #30
franken.fab
South wales
HUC-2H
Evening Boki, Please see new scan (Electrical items have cropped up which is a 12v feed issue - please ignore these. Communication errors have popped up now with the new ABS coding:
Tuesday,03,December,2024,15:19:32:64646
VCDS Version: 24.7.1.0 (x64)
VIN: WVWZZZ13ZBV002252   License Plate: SCAN2
Mileage: 146240km-90869mi   Repair Order:
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WVWZZZ13ZBV002252   Mileage: 146240km-90869miles
03-ABS Brakes -- Status: Not registered 0011
37-Navigation -- Status: Not registered 0001
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH14---    Serial number: VWZ7Z0F8106410
   Coding: 0403000318030060
   Shop #: WSC 00810 067 57207
   VCID: 2D57469CB4EDB8FE50-8078
   VINID: 9E69EAAAA043A9298000208508D79D5E86
16 Faults Found:
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
                    RPM: 768 /min
                    Load: 22.7 %
                    Temperature: 54.0 C
                    Temperature: 11.0 C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.351 V
012423 - Voltage Supply Relay for Engine Components
               P3087 - 004 - Electrical Malfunction
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
                    RPM: 768 /min
                    Load: 22.7 %
                    Temperature: 54.0 C
                    Temperature: 11.0 C
                    Voltage: 14.351 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 004 - Circuit Open
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
005425 - Camshaft Timing Adjustment
               P1531 - 004 - Open Circuit
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
000579 - Solenoid Valve  for Boost Pressure Control (N75)
               P0243 - 004 - Malfunction
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
009728 - Coolant Pump Control Circuit
               P2600 - 004 - Open
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 002 - Signal too High
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
000306 - Oxygen (Lambda) Sensor B1 S1
               P0132 - 001 - Signal too High
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
049489 - No Communications with Airbag Control Module
               U0151 - 008 -  - Intermittent
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
               U0155 - 008 -  - Intermittent
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
049472 - Body Control Module (Central Electric)
               U0140 - 008 - No Communications - Intermittent
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
049478 - No Communication with Diagnostic Gateway
               U0146 - 008 -  - Intermittent
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:22:34
Readiness: 0110 0101
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: 763B80F5492280FC6E0D01E9921B0181300000
   Shop #: WSC 35110 377 08192
   VCID: 7CF1BBD8FF17E17697-8028
7 Faults Found:
                    Fault Status: 01100101
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
                    Count: 3
                    Count: 13056
                    Count: 279
                    Count: 45056
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
                    Count: 3
                    Count: 13056
                    Count: 295
                    Count: 45056
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
                    Count: 3
                    Count: 13056
                    Count: 270
                    Count: 45056
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
                    Count: 3
                    Count: 13056
                    Count: 8193
                    Count: 45056
03095 - Diagnostic interface for databus (J533) implausible messa.:
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
                    Count: 3
                    Count: 13056
                    Count: 8256
                    Count: 45056
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
                    Count: 3
                    Count: 13056
                    Count: 8201
                    Count: 45056
                    Fault Status: 01101100
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
                    Count: 3
                    Count: 13056
                    Count: 80
                    Count: 45056
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0068
   Revision: BB021001
   Coding: 411A583A8027182A088000829000006403017288424F0160648000000040
   VCID: 428D0520DD7357869D-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 28091  26  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:26:04
                    Voltage: 12.40 V
   Component: VW10Airbag02A H07 0013
   Revision: --------    Serial number: 003HL00E4RLL Dataset Number: 2KC003v____ 0259
   Coding: 000000000000000000000000000000003241
   Shop #: WSC 35110 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35676EFC94BDF03E28-8060
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Revision: --------    Serial number:  90440KAB00192 Dataset Number: 1K5953507M  D005
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 3B7378C4B299264EDE-806E
   Part No SW: 1K8 920 962     HW: 1K8 920 962
   Component: KOMBI         H03 0405
   Coding: 460801
   Shop #: WSC 12345 123 61029
   VCID: 70E99FE8AB5F95163B-8024
9453074 - Fuel Level Sensor 1
          B103E 1B [00001001] - Resistance Too High
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2024.12.03.
                    Time: 00:25:58
   Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
   Component: J533  Gateway H47 1633
   Revision:   H47       Serial number: 041012F1000738
   Coding: 007401
   VCID: 70E99FE8A35F95163B-8024
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:60
   Component: IMMO          H03 0405
   VCID: 6ADD8D808D836FC675-803E
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 F
   Component:      Navigation     0030
   Coding: 0000101
   Shop #: WSC 01279 785 00200
   VCID: 3C717BD87F972176D7-8068
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 489917083B4F7DD643-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 377B64F446B1022E3A-8062
                    Fault Status: 11101101
                    Reset counter: 3
                    Mileage: 146247 km
                    Date: 2019.04.26.
                    Time: 00:25:59
                    Voltage: 12.50 V
                        DD
                    Temperature: 19.0 C
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 479B1434365172AE4A-8012
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 G
   Component:        Radio        0030
   Coding: 0040402
   VCID: 295FB28C8005A4DEBC-807C
9 Faults Found:
00877 - Treble Speaker Rear Right (R16)
00856 - Radio Antenna
00857 - CD Changer Unit (R41)
End-------------------------(Elapsed Time: 02:04)--------------------------
