USDM Lights Seat Leon 5F Coding
smurf
C?ID=598961
Hi,
I'm trying to code USDM indicator front lights on a seat leon 5F.
I am following this guide:
Log on to the car.
1/ Select control unit 09 Central Electrics
First change left side
2/ Select Leuchte 0 BLK VL B36-Lichtfunktion C 0
3/ Change to Standlicht allgemein (Schlusslitch; Positionslicht; Begrenzungslicht) - Parking light in general (tail lamp, position light, marker light)
4/ Save with green tick and when asked enter security code 31347
5/ Select Dimmwert CD 0 and change to a number between 0 - 100 (100 being brightest) and tick green box
6/ Select Lichtfunktion E 0 and change to Blinken links Dunkelphase and tick green box
7/ Select Dimming Direction EF 0 and change to minimize and tick green box
Left side is complete, go outside and look at your indicator.
Now on to the right side
8/ Select Leuchte1BLK VRB20
9/ Select Lichtfunktion C 1 and change to Standlicht allgemein (Schlusslitch; Positionslicht; Begrenzungslicht) - translation above
10/ Save the change using green tick and enter security code 31347 when asked.
11/ Select Dimmwert CD 1 and change to a number between 0 - 100 (100 being brightest) and tick green box
12/ Select Lichtfunktion E 0 and change to Blinken links Dunkelphase and tick green box
13/ Dimming Direction EF 0 and change to minimize then tick green box to save change
Now i have got the left side working but the instructions on the right side i noticed steps 12, 13 is the same as steps 6, 7?
Surely, this should be different? Anyone know the correct steps for 12,13 as not working on the right.
Thank you.
Westbury, UK
Really hard to know if those instructions are correct for your Leon until you post an Auto-Scan.
smurf
C?ID=598961
Tuesday,12,November,2024,19:56:44:22719
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: VSSZZZ5FZDR031879   License Plate: KN13XNJ
Mileage: 260746km-162020mi   Repair Order: ZAF
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZDR031879   Mileage: 260746km-162020miles
Address 01: Engine (J623-CKFC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H83 4941
   Revision: 00H83H22    CVN: 5CB944E2
   Coding: 01190012032501090000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79A49EE9895CD932185-802C
   VINID: 9A38EAAAA156A948800C1207242DEE370D
13871 - Coolant Pump for Intercooler
          P023B 00 [00100000] - Short to GND
                    Fault Frequency: 9
                    Mileage: 258301 km
                    Date: 2024.11.02
                    Time: 13:40:39
                    Engine RPM: 0.00 /min
                    Coolant temperature: 55 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 12.400 V
                    Unlearning counter according OBD: 16
13865 - Coolant Pump for Intercooler
          P023A 00 [00100000] - Open Circuit
                    Fault Frequency: 15
                    Mileage: 258301 km
                    Date: 2024.11.02
                    Time: 13:47:36
                    Engine RPM: 992.50 /min
                    Normed load value: 54.9 %
                    Vehicle speed: 4 km/h
                    Coolant temperature: 62 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 13.400 V
21125 - Implausible Data Received from Airbag Control Module
          U0452 00 [00100000] - -
                    Mileage: 259899 km
                    Date: 2024.11.08
                    Time: 14:29:22
                    Engine RPM: 1503.00 /min
                    Normed load value: 25.1 %
                    Vehicle speed: 26 km/h
                    Coolant temperature: 83 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 14.560 V
                    Unlearning counter according OBD: 31
                    Limitation: accelerator pedal: 60.0 Nm
                    selected gear-Bits 0-7: 2
Readiness: 0 0 0 0 X
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Revision: 00000000    Serial number:
   Coding: 20EE8A9220230A6D007F060701CC240451045000608024F200690020C0
   Shop #: WSC 00049 770 00102
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_008_SE37.rod
   VCID: 3A2641E5CCDA122A51F-806E
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 231
                    Mileage: 258557 km
                    Date: 2024.11.04
                    Time: 00:34:47
Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
   Part No SW: 5F0 907 044     HW: 5F0 907 044
   Component: Climatronic   H02 0503
   Revision: 00001K05
   Coding: 00100104202100011005004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_SE37.rod
   VCID: 6398DC811BD033E2229-8036
327940 - Motor for Left Temperature Flap
          B108C 71 [00001000] - Actuator Stuck
                    Fault Frequency: 18
                    Reset counter: 250
                    Mileage: 258323 km
                    Date: 2024.11.02
                    Time: 17:14:16
327941 - Motor for Left Temperature Flap
          B108C 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 208
                    Mileage: 258301 km
                    Date: 2024.11.02
                    Time: 13:40:36
327943 - Position Sensor for Left Temperature Flap Motor
          B1094 15 [00001000] - Open or Short to Plus
                    Fault Frequency: 198
                    Reset counter: 249
                    Mileage: 258301 km
                    Date: 2024.11.02
                    Time: 13:42:14
328196 - Motor for Right Temperature Flap
          B108D 71 [00001000] - Actuator Stuck
                    Reset counter: 249
                    Mileage: 258394 km
                    Date: 2024.11.03
                    Time: 00:09:49
263426 - Air Quality Sensor
          B10AF 31 [00001000] - No Signal
                    Fault Frequency: 59
                    Reset counter: 250
                    Mileage: 258341 km
                    Date: 2024.11.02
                    Time: 17:59:19
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011305902359 Dataset Number: Z16         0001
   Coding: 0B000842C2C100DB0BA44000B11C0728102A000000000000000000000000
   Shop #: WSC 00049 770 00194
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46DE2515882266CA257-8012
   Subsystem 1 - Part No SW: 5F2 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130207  041 0574
   Serial number:         130216002232
   Coding: 0BC5FD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY13030269S
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000056179454
   Humidity sensor: interior:
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20294741
          B1263 01 [00001000] - Electrical Failure
                    Reset counter: 250
                    Mileage: 258301 km
                    Date: 2024.11.02
                    Time: 13:47:42
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    Stoerschutzzaehler: 0
                    Voltage: 13.3 V
                    Outside temperature: 13.5 °C
197904 - Central Locking
          B140A 4B [00001000] - Over Temperature
                    Reset counter: 239
                    Mileage: 259850 km
                    Date: 2024.11.08
                    Time: 10:51:03
                    Terminal 15 status: OFF
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.5 V
                    Outside temperature: 8.5 °C
203016 - Unlock Switch in Rear Lid Handle
          B140B 29 [00001000] - Signal Implausible
                    Fault Frequency: 20
                    Reset counter: 250
                    Mileage: 258349 km
                    Date: 2024.11.02
                    Time: 18:55:35
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 14.2 V
                    Outside temperature: 12.0 °C
524556 - Internal Control Module Memory Check Sum Error
          B2000 96 [00001001] - Component Internal Failure
          [Notlaufpfad->elektrischer Fehler im Stromkreis]
                    Mileage: 25999 km
                    Date: 2014.11.24
                    Time: 14:45:36
                    OFF: operated
                    Low beam: Not operated
                    Voltage: 12.7 V
                    Outside temperature: 9.0 °C
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231305901267 Dataset Number: V03935140HK 0023
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_VW26.rod
   Part No SW: 3Q0 959 655 R    HW: 3Q0 959 655 R
   Component: Airbag VW20   011 0186
   Revision: --------    Serial number: 003NPP3D980N Dataset Number: V03935170KD 0005
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 4DCC1A396D549592E4D-8018
   Subsystem 1 - Part No SW: -----------    HW: 454 001 602 13
   Serial number: 3576U000000F70508C0C
   Subsystem 2 - Part No SW: -----------    HW: 454 002 502 13
   Serial number: 3586U0000003D91CBC0R
   Subsystem 3 - Part No SW: -----------    HW: 454 802 002 13
   Serial number: 3516R0C172101000000N
   Subsystem 4 - Part No SW: -----------    HW: 454 801 602 13
   Serial number: 3526REC0F21010000002
   Subsystem 5 - Part No SW: -----------    HW: 454 802 301 13
   Serial number: 3556V4CB1CB00000000F
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Revision: --------    Serial number: 05031304221606 Dataset Number: ----------
   Coding: 9400
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 77A098D1BF48CF426E1-8022
   Part No SW: 5F0 920 970 G    HW: 5F0 920 970 G
   Component: KOMBI         336 0556
   Coding: 27A402002980260001086A00000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   VCID: 2D0C7AB90D94B592C4D-8078
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000428503 Dataset Number: V03935132HG 0020
   Coding: 030100F40B087300FF0006C8080F00010001000000000000000000000000
   GVL: 01543C0000000000400C10000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 343A6FDDEEBEE45A8B3-8060
   Generator:
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0100
   Serial number: 000000000A0391040213
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004050276680
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000053695064  Dataset Number: V03935172UH 0001
   Coding: 00100220DC01020000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 0256F905E48A9AEA49F-8056
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000090495
   Coding: 2D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Dataset Number: V03935172CA 0002
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D2C4AF9DDF4251274D-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000054173893  Dataset Number: V03935172UG 0001
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 0154F609E18C81F2505-8054
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000118271
   Coding: 350000
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 249
                    Mileage: 258365 km
                    Date: 2024.11.02
                    Time: 20:34:07
   Component: LWR-ECU       005 0070
   Revision: --------    Serial number: -------------- Dataset Number: V03935177SD 0001
   Coding: 048C000001000000
   VCID: 75BC92D9A544BD527CD-8020
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD1.clb
   Part No SW: 5F0 035 858     HW: 5F0 035 858
   Component: MU-S-ND-ER    039 0151
   Serial number: E5F00503131688 Dataset Number: V03935171LU 0006
   Coding: 04730001D70A000021111101000800002F0101060100010046
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE.rod
   VCID: 6882CBADE2F650BAF7B-803C
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H45 0020
   Serial number: SEZ8Z9N5600C3J
   Subsystem 2 - Part No SW: 5F0 919 866 C    HW: -----------
   Component:  ECE 2013  --- 0021
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [00001001] - Open Circuit
                    Reset counter: 185
                    Mileage: 258301 km
                    Date: 2024.11.02
                    Time: 13:40:47
                    Voltage terminal 30: 12.3 V
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
End----------(Elapsed Time: 01:15, VBatt start/end: 13.2V/13.1V)-----------
Sorry here is the auto scan
Canard05
France
C?ID=600648
It's CD1, E1 and EF1 for right blinker.
I'm looking for the number of the rear fog light.
Could you please check your vehicle for lines with the word “Nebelschlusslicht” and let me know?
Charles
