2004 golf tdi bew long crank no start sometimes help
peopleschoice
C?ID=328777
can i post a log here .. my injector quantity is off and i cant seem to change it. i have one injector that is suspect you will see it in the log
peopleschoice
C?ID=328777
Tuesday,12,November,2024,11:36:02:00549
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: 9BWGR61J044021479   License Plate:
Mileage: 329190km-204549mi   Repair Order:
          76
VIN: 9BWGR61J044021479   Mileage: 329190km-204549miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 906 016 H    HW: 028 101 114 6
   Component: R4 1,9L EDC G050AG  6327
   Revision: 12345678    Serial number: VWZ7Z0C7085743
   Coding: 0150034
   Shop #: WSC 08316 552 00000
   VCID: 1964BE59F5899092B85-5184
   VINID: 2529D788605A004100081107242E54907E
Readiness: 0 0 1 0 0
Address 02: Auto Trans        Labels: 09A-927-750.lbl
   Part No: 09A 927 750 AM
   Component: AG5 Getriebe 09A   0242
   VCID: 76BE95E521D71FEA757-50AE
01236 - Shift Selector Locking Solenoid (N110)
            31-10 - Open or Short to Ground - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019458
   Shop #: WSC 00001 785 00200
   VCID: 343A6FED722B4DFA8B3-5184
   Part No: 1C0 909 605 F
   Component: 08 AIRBAG VW61 0202 0003
   Coding: 12344
   Shop #: WSC 00001
   VCID: 270088A1B6FD36623E1-513C
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
            30-00 - Open or Short to Plus
   Part No: 1J0 920 907 F
   Coding: 15234
   Shop #: WSC 00001
   VCID: 2C0A778DAF1B153AD33-513C
   9BWGR61J044021479     VWZ7Z0C7085743
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00001
   VCID: 70B2A3FD43B331DAAFB-513C
   Part No: 1C0 959 799 C
   Component: 8C Komfortger t HLO 0003
   Coding: 00258
   Shop #: WSC 00001
   VCID: 372058E1665DA6E2AE1-4B1E
   Component: 8C T rsteuer.FS KLO 0202
   Component: 8C T rsteuer.BF KLO 0202
   Component: 8C T rsteuer.HL KLO 0202
   Component: 17 T rsteuer.HR KLO 0202
            35-00 - -
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 G
   Component:    Radio ZSW        0016
   Coding: 00031
   Shop #: WSC 00001
   VCID: 241A9FADC7CBDD7A1B3-513C
End----------(Elapsed Time: 04:51, VBatt start/end: 13.6V/13.9V)-----------
peopleschoice
C?ID=328777
Tuesday,12,November,2024,11:40:28:00549
Mileage: 329190km-204549mi   Repair Order: 2004golfbew111224
                Address 01: Engine  (038 906 016 H)
11:39:48
  19.5 mg/str   Injection Quantity
  10.7°KW   Injection Duration (specified)
  22.5 mg/str   Start Injection Quantity
  1.29 mg/str   Injection Quantity Deviation Cyl. 1
  -1.41 mg/str   Injection Quantity Deviation Cyl. 2
  -0.12 mg/str   Injection Quantity Deviation Cyl. 3
  0.21 mg/str   Injection Quantity Deviation Cyl. 4
  0.0   Injector Status Cylinder 1
  0.0   Injector Status Cylinder 2
  0.0   Injector Status Cylinder 3
  0.0   Injector Status Cylinder 4
Dr Sheldon
Windsor UK
C?ID=334979
Not too bad for that mileage - Unlikely to be the cause of a No Start
peopleschoice
C?ID=328777
the TSB has already been done. the ecu has been updated and coding is correct. fuel pressure, volume, etc. all meet specs. i dont know where to go next. i did find a ambient sensor in the cowl that has been chewed on and has a open. i am fixing it right now but i dont think it would effect starting.
NZDubNurd
New Zealand
C?ID=230482
You quite possibly need a new starter. NEW. Or at least make sure all the connection on the power and earth circuits are immaculate.
A local guy went through 3 used ones, before getting a new one that fixed it. They are very sensitive to cranking RPM.
