Passat B8 2015 power seat fore/aft adjustment's sensor
vwuwu
Unverified
Poland
Hi All,
the problem is that during vacuum cleaning the seat was moved to both forward and backward maximum positions. After that it's moving only by 20mm and stops.
It's moving again after releasing and pressing the button again.
I assume that because of that seat's memory stopped working at all.
In the measurement blocks I can see that the position is not changing during the movement and DTC says:
9657641 - Sensor for Seat Fore/Aft Adjustment
B135D 29 [009] - Signal Implausible
Reset counter: 136
Mileage: 244801 km
Date: 2024.11.05
Time: 18:21:13
Somebody guide me please where should I look for aformentioned sensor?
I was checking all harneses' under the seat and everything looks fine.
I can't find and understand how the position is measured as I can't see any sensor on the rail ;)
vwuwu
Unverified
Poland
Thanks. I was thinking about this as the wiring diagram doesn't have any sensor on it.
Do You know how is this realized? Communication over power cables or something else?
I've just noticed that both seats have the same type of the motor.
I need to find some time and try to switch them places.
vwuwu
Unverified
Poland
I don't own VCDS unfortunately ;(
Those partial informations come from befriended workshop which is unable to resolve my issue.
Westbury, UK
Please ask the workshop to message or email you the text file of the full Auto-Scan - VCDS saves this in C:\Ross-Tech\VCDS\Scans so that you can share it here with us.
Dr Sheldon
Windsor UK
C?ID=334979
Might be a good time to buy one ?
vwuwu
Unverified
Poland
It seems that I definitely need to think about this as the workshop begins to get frustrated with its lack of skills.
Scan removed due to forum rules.
  • Disagree
vwuwu
Unverified
Poland
Really? Probably that's the reason they cannot handle the repair.
Anyhow I need to change the workshop.
Thanks for the support and sorry for the inconvenience.
