- Jul 12, 2024
- 19
- 5
- South Africa
- C?ID=564687
Hi guys
I have a Polo 6R that we're working on that sometimes starts and other times doesn't. We're getting an immobilizer fault that states the instrument cluster has lost signal with the key. We also attempted immo off unsuccessfully.
Upon scanning the car we picked up an issue with the BCM ASM data not present message.
Can someone guide us as to what ROD file to select?
Regards
W
Regards
W
Friday,08,November,2024,15:37:20:14100
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
Dealer/Shop Name: NEERANG AUTOMOTIVE REPAIR CENTRE
VIN: AAVZZZ6RZHU106108 License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: AAVZZZ6RZHU106108 Mileage: 206790km-128493miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 LH HW: 04E 907 309 AF
Component: R4 1.2l TFS H24 3997
Revision: R4H24--- CVN: 40819633
Coding: 01110012232410010000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS01104E906027LH 001002
ROD: EV_ECM12TFS01104E906027BB_VW26.rod
VCID: 75B32D9ED54247E27CD-8020
VINID: 4519AAAAA1A2A9894100604020AE45D79F
7158 - Implausible Data Received from Diagnostic Gateway Module
U0447 00 [00100111] - -
[Invalid Data Received From Serial Data Gateway Module "A"]
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:44
Engine RPM: 0.00 /min
Coolant temperature: 23 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.368 V
Generator: load signal: 99.89 %
Generator performance: 0 W
Torque request: sum of auxiliary aggregate: 32.9 Nm
Starter activation: status-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
P1570 00 [10100111] - -
[Engine Control Module (ECM) locked]
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:40
Voltage terminal 30: 12.392 V
Mass flow through throttle valve: 0.0 kg/h
Mean injection time: 0.000 ms
Engine operating condition: Idle
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [00100111] - Malfunction
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:40
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 R HW: 6R0 907 379 BA
Component: ESP9.0i H04 0006
Serial number: 08507401170623 Dataset Number: V03935226BE 0124
Coding: 23DD2885492333C6091500690059C41492CC90000005C9098000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26_VW26.rod
VCID: 3E21F2B2A0F4C4BA6D7-806A
0716 - Databus
[Scl_KBI_Aussen_Temp_gef_Error]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:43
0717 - Databus
[Scl_KBI_Aussen_Temp_gef_Invalid]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:43
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 G HW: 6C0 820 045 G
Component: AC Manuell H03 0204
Serial number: 1707101B-0891 Dataset Number: V03935233RN 0012
Coding: 200100010000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 231723C62B568952629-8076
262916 - High Pressure Sensor
B10AE 14 [00001101] - Open or Short to Ground
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:38
262917 - High Pressure Sensor
B10AE 29 [00001101] - Signal Implausible
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:38
Address 09: Cent. Elect. (J519) Labels:. 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 E HW: 6C0 937 089
Component: BCM PQ26 Hi4R 0101
Serial number: 006728178888 Dataset Number: V03935258SR
Coding: 031008404053005B4F844080A107038000005B0053010000000000000000
VCID: 3239D68264AC10DA99F-8066
Subsystem 1 - Part No SW: 6R0 959 802 DK HW: 6R0 959 802 DK Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 004 0610
Serial number: KU0KU019071772003884
Coding: 1000A0
Subsystem 2 - Part No SW: 6R0 959 801 DH HW: 6R0 959 801 DH Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 004 0610
Serial number: KU0KU021071772021276
Coding: 0000A0
Subsystem 3 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY170022RW3
Subsystem 4 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.405 H03 0004
Serial number: 0000FST001O9LL400000
Coding: 181001
Subsystem 5 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 004 0610
Serial number: KU0KU025071772060688
Coding: 1000A0
Subsystem 6 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 004 0610
Serial number: KU0KU024071772051835
Coding: 0000A0
No ASAM data for: "" (VW26)
11018 - ROD - Unknown Error Code
- 00 [00001001]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:46
11530 - ROD - Unknown Error Code
- 00 [00001001]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:46
133387 - ROD - Unknown Error Code
- 00 [00001001]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:37
137217 - ROD - Unknown Error Code
- 00 [00001001]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:39
263442 - ROD - Unknown Error Code
- 00 [00001001]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:37
791044 - ROD - Unknown Error Code
- 00 [00001001]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:37
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00Q 002 0380
Revision: -------- Serial number: 003TH00MNM5Z Dataset Number: V03935228FG 0619
Coding: 88C0C000000000005C0000CA008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A29FEA2BCDCE89A51F-806E
Subsystem 1 - Part No SW: ----------- HW: 410 820 306 17
Component: SideSensor_Df 151 0800
Serial number: 3575H00022A70082414Y
Subsystem 2 - Part No SW: ----------- HW: 410 820 306 17
Component: SideSensor_Pf 151 0800
Serial number: 3585H00162A6BDA201FT
Subsystem 3 - Part No SW: ----------- HW: 442 150 507 17
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A009F266574082CG
Subsystem 4 - Part No SW: ----------- HW: 442 150 507 17
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A009F26657423224
B1006 1B [10001001] - Resistance Too High
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:40
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [10001001] - Resistance Too High
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:40
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [10001001] - Resistance Too High
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:40
Address 17: Instruments (J285) Labels:| 6C0-920-KOM-V1.clb-SRI3
Part No SW: 6C0 920 740 E HW: 6C0 920 740 E
Component: KOMBI 202 2310
Coding: 272409002080000801082A001000000000000000
VCID: 241520DA2E588E6A1B3-8070
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:37
9456681 - Key
B104C 29 [00001001] - Implausible Signal
Mileage: 206790 km
Date: 2024.11.05
Time: 00:11:18
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 0101
Revision: -------- Serial number: 006728178888 Dataset Number: 6C0067V____ 0046
Coding: 01010008200A560071000000000000000001010000000000000000000000
GVL: 01403C0000000000400000000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 26113AD258647C7A057-8072
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Serial number: 2011710231301213AD2B
Coding: 280000
0769 - Analog Measuring Input
C1155 31 [00001001] - No Signal
Reset counter: 121
Mileage: 206790 km
Date: 2024.11.05
Time: 00:34:38
Terminal 30 power supply: 12.4 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AK HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3250
Serial number: CH7A0335 Dataset Number: V03935251GH 0001
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 72B91682A42C50DA59F-8026
Part No SW: 3Q0 035 819 B HW: 3Q0 035 819 B
Component: MU-S--ER H31 0363
Serial number: VWZAZ2T1439912 Dataset Number: V03935250ZU 0001
Coding: 02620000BE00000051110001000918001F0100C60120010001
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 303DDC8A6AA022CAEFB-8064
Subsystem 1 - Part No SW: 6C0 919 603 HW: 6C0 919 603
Component: ABTm_Std2 H53 1031
Serial number: VWZ8Z9TKU02DQE
End----------(Elapsed Time: 00:47, VBatt start/end: 12.5V/12.5V)-----------
