Dear all, I am at a loss.
I am Hans from the Netherlands and I am quite new to VCDS but I am an enthusiastic mechanic. The project I am working on is to convert my BMW K100 motorcycle into a diesel engine, using the engine from a Lupo 3L.
I already built one (and it got approved
) but when I got the ecu flashed to get rid of the immo, it ran perfectly in the beginning, but the engine did not start anymore after some time. And I found at that point, that there was no communication possible. I used a cheap China-dongle, which initially worked fine. Please notice, that I reduced the wiring harness quite intensely, to get rid of any unwanted systems, like airbag, radio and so on.
Since it did not communicate anymore, I ran into a problem. I already deleted the (unnecessary) wiring from the immo, dash, transmission, airbags and some other stuff, and checked if the engine started at each removal step. But apparently, I am missing something……
So I decided to buy another VW Lupo 3L, from 2002, with the AYZ-engine to get a solid starting point, including the HEX-V2-dongle from Ross-Tech. This new Lupo 3L, which ran when I bought it, won’t communicate either. What I tried to solve it until now:
I am at a loss. Hopefully you can help with tips what to do next.
A screen from the Test result:
) but when I got the ecu flashed to get rid of the immo, it ran perfectly in the beginning, but the engine did not start anymore after some time. And I found at that point, that there was no communication possible. I used a cheap China-dongle, which initially worked fine. Please notice, that I reduced the wiring harness quite intensely, to get rid of any unwanted systems, like airbag, radio and so on.Since it did not communicate anymore, I ran into a problem. I already deleted the (unnecessary) wiring from the immo, dash, transmission, airbags and some other stuff, and checked if the engine started at each removal step. But apparently, I am missing something……
- I removed the complete (!) wiring harness from the car, including all the sensors, ecu’s and so on, which was a logical step in the process to convert it to the motorcycle. And I have easy access to any ecu.
- Made sure both the dongle and the VCDS-software is up to date.
- The dongle passes the test, though it gives no CAN-communication.
- Disconnected and reconnected the different ECU’s. No difference.
- I rewired the K-line to make sure I have a direct connection between the dashboard (which includes the gateway), the immo and the OBD-port. So it’s hard wired with only these three components. Though, when I add the other ecu’s to the K-line, it does not make a difference.
- Checked the fuses. All okay.
- Checked the wiring. No strange stuff, though some wires where already cut by the previous owner. But the car ran when I bought it.
- Pulled the fuses one by one, to see whether the K-line signal changed. No influence.
- Did the shortage to 12V-test, with the resistor, though I used a 10K. When I add the resistor, the voltage drops to 1.1 V.
- I checked for shortage to ground and 12V. No problems there. I swapped the dashboard with another unit (which I still had from my previous car), but it made no difference.
- I noticed the OBD port is only having pin 5 for ground, and not pin 4. Nor is Vign available.
- I noticed there is no K-line between the engine ecu and the dashboard, only CAN-wiring.
- I noticed that there is no CAN data visible (with a seperate scope).
- The VCDS always answers with ‘no response from controller’ and ‘K-line init failed’. The dongle flashed blue when not connected to the OBD-port, turns green and starts flashing green when connected to the port and flashes green/red when I try to reach the Engine ECU. Also, in the AutoScan, it gives ‘No response from gateway’, when I select the Gateway Installation List.
- I am unsure whether the Lupo requires a can wake up signal, nor do I know whether there is communication possible with a disconnented tranmission ecu.
