2005 VW Polo 9n steering assist problem
VoiceTech
Poland
C?ID=351360
A 2005 Polo 9n came to my service with a power steering problem. Sometimes the power steering stops working, an error pops up 00816 - Power Steering Sensor (G250) 30-00 - Open or Short to Plus but only when the wheels are turned to the left or right to the maximum. The previous service replaced the power steering pump and the sensor on the rack, but it did not improve the situation.
I do not know what the original pump numbers should be, I got a second one for this car also with the ending AB and there is the same problem.
Is the pump number wrong, is there a problem with some calibration or is the rack damaged?
Thank you for your help, best regards
edit:
I forgot to add. I have a new type of sensor (3pin) on the rack without a cable - with a socket
Thursday,07,November,2024,08:48:07:03174
VCDS Version: 24.7.0.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WVWZZZ9NZ6Y025478   License Plate:
Mileage: 121380km-75422mi   Repair Order: Polo 9N steering
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y025478   Mileage: 121380km-75422miles
Address 01: Engine        Labels: 03E-906-033-AZQ.lbl
   Part No: 03E 906 033 R
   Component: 1,2l/4V SIMOS3 G00HS7002
   Coding: 00071
   Shop #: WSC 00788
   VCID: 2F2EEFB1EF112AEE6A-5184
   WVWZZZ9NZ6Y025478     VWZ7Z0D0966252
17977 - Cruise Control Switch (E45)
            P1569 - 35-10 - Implausible Signal - Intermittent
Readiness: 0000 0100
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H03 0002
   Coding: 0002085
   Shop #: WSC 00788 785 00200
   VCID: 014A790959056C9ECC-50D0
Address 08: Auto HVAC        Labels: 6Q0-907-044.lbl
   Part No: 6Q0 907 044 C
   Component: CLIMAtronic PQ24    0301
   VCID: 3228E6C5AC23070605-50D0
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00AF BN-SG.         1S34
   Coding: 26270
   Shop #: WSC 00788
   VCID: 3C34C8FD2E67C176DF-50D0
   Part No: 1C0 909 605 K
   Component: 17 AIRBAG VW51 0N   0008
   Coding: 12599
   Shop #: WSC 00788
   VCID: 2C14F8BDDE0751F64F-50D0
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 823 F
   Coding: 01131
   VCID: 3522DDD90D4D103E20-50D0
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70AC2CCD32AF751633-50D0
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10160
   Shop #: WSC 00186
   VCID: 6FAE2FB12F916AEE2A-50D0
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 5F Komfortger t     0002
   Coding: 00017
   Shop #: WSC 00788
   VCID: 3D32C5F9357DC87EE8-4B3C
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 6Q0 035 152 E    HW: 6Q0 035 152 E
   Component: Radio DE2           0003
   Revision: 00001000    Serial number: VWZ4Z4GN160295
   Coding: 0040400
   Shop #: WSC 00020 000 00000
   VCID: 2C14F8BD8E0751F64F-50D0
00877 - Treble Speaker Rear Right (R16)
00856 - Radio Antenna
End----(Elapsed Time: 02:51, VBatt start/end: 11.8V/11.8V. VIgn 0.0V)------
Thursday,07,November,2024,08:59:02:03174
VCDS Version: Release 24.7.0 (x64) Running on Windows 11 x64
                Address 44: Steering Assist       Labels: 6Q0-423-156.CLB
Control Module Part Number: 6Q0 423 156 AB
  Component and/or Version: LenkhilfeTRW        V270
           Software Coding: 10160
            Work Shop Code: WSC 00000
                      VCID: 6FAE2FB12E916AEE2A-50D0
Theoretically it is the correct pump but used electrics are a fools game, we would use a TRW JER162 exchange unit.
VoiceTech
Poland
C?ID=351360
Thanks,
I also try not to install used things like this, but this is how it came from the previous workshop.
