Question regarding few tweaks for California T6.1
Uporabnik
Maribor, Slovenia
C?ID=529258
I am looking for information on how to achieve a few tweaks on VW California T6.1
Particularly for three mods that would have been done via VCDS:
- what needs to be changed on the T6.1 to achieve a start-stop disable function or to retain the last selection on the button (if possible),
- how to activate Scandinavian lights in the rear (where both the front DRL and rear position lights are on simultaneously),
- how to enable external mirrors to fold when locking the vehicle.
Apologies for multiple questions. I did some research and found some instructions, but they were mostly contradictory so if someone has any experience with this, much appreciated.
Westbury, UK
Since not all T6.1 are equipped the same you need to post an Auto-Scan of yours made with the English version of VCDS to know what is possible and how.
Uporabnik
Maribor, Slovenia
C?ID=529258
Sure!
Here it is:
Friday,25,October,2024,12:41:49:22985
VCDS Version: 24.7.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WV2ZZZ7HZNH048010
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 15 17 18 19 3D 44 5F 75 800B
VIN: WV2ZZZ7HZNH048010   Mileage: 20241km-12577miles
3D-Special Function -- Status: OK 0000
800B-Aux air heater 2 -- Status: OK 0000
Address 01: Engine (J623-DNAA)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 023 JG    HW: 05L 907 309 F
   Component: R4 2.0l TDI   H80 2670
   Revision: N1H80---    CVN: F19C03D9F3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
   Coding: 0019003C0324050800000000000000000000000000000000
   Shop #: WSC 02354 005 1048576
   ASAM Dataset: EV_ECM20TDI01105L906023JG 006002
   ROD: EV_ECM20TDI01105L906023JG.rod
   VCID: 76BE88C1C842A12A75F-8022
   VINID: 9E60AAAAA1D8A9E600108001003D2EF93D
Readiness: 0 0 0 1 1
Address 03: ABS Brakes (J104)       Labels: 7LX-614-517-V1.clb
   Part No SW: 7LB 614 517 B    HW: 7LB 614 517
   Component: ESC_base      H01 0800
   Serial number: 08513952211021
   Coding: 10552752C84BEE8D0854E4A513667726383024B8
   Shop #: WSC 00012 790 00047
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
   ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
   VCID: 3FD02DE5A7F82062669-806A
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 7LA 907 040 E    HW: 7LA 907 040 E
   Component: Climatronic   H01 0602
   Coding: 9030100008102300010009005040010500000000000B1501A04000000000
   ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
   ROD: EV_AirCondiBHTCVN54XT6PA_VN46.rod
   VCID: 3D2C57EDADF43272745-8068
   Rear A/C Control Head 1:
   Subsystem 1 - Part No SW: 7LA 906 453 A    HW: 7LA 906 453 A
   Component: E857  H01 0206
   Serial number: 00002191121002532103
   Subsystem 2 - Part No SW: 7LA 907 049 F    HW: 7LA 907 049 F
   Component: E857  H02 0301
   Serial number: 00003065170201270702
   Part No SW: 2Q5 937 090 B    HW: 2Q5 937 090 A
   Component: BCM T6PA Std+ H12 0954
   Serial number: 01102131600653 Dataset Number: V03935359SV 0001
   ASAM Dataset: EV_BCMA0 207001
   ROD: EV_BCMA0_207_VN46.rod
   VCID: 363E48C188C2E12AB5F-8062
   Driver door control module:
   Subsystem 1 - Part No SW: 7L2 959 405 B    HW: 7L2 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000055503133
   Coding: 130007
   Front passenger door control module:
   Subsystem 2 - Part No SW: 7L2 959 406 B    HW: 7L2 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000054702003
   Coding: 090007
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058321331 Dataset Number: V03935313KK 0001
   Coding: 8451151001
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_010_AU37.rod
   VCID: 53F811553B70D402B21-8006
   Part No SW: 2Q0 959 655 AQ    HW: 2Q0 959 655 AQ
   Component: VW22Airbag    020 0511
   Revision: --------    Dataset Number: V03935351ZF 0001
   Coding: 88CCC000000000007C0000CF000C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X_VN46.rod
   VCID: 0C4ACA29A6CECBFA33B-8058
   Subsystem 1 - Part No SW: -----------    HW: 442 060 309 21
   Serial number: 3577Y52B9056AC0212E6
   Subsystem 2 - Part No SW: -----------    HW: 442 060 309 21
   Serial number: 3587Y52B9056AC024554
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7LA 920 741 A    HW: 7LA 920 741 A
   Component: KOMBI         202 8500
   Coding: 07A409022180000801082A000401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_VN46.rod
   VCID: 3C2A5AE9B6EE3B7A43B-8068
Address 18: Aux. Heat (J364)       Labels:* Redir Fail!
   Part No SW: 5WA 963 271 C    HW: 5WA 963 271 C
   Component: STH-VW37x     006 0012
   Serial number: 000000000000141
   Coding: 7143221854121512DCE519
   ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
   ROD: EV_AuxilHeateWOSVW38X_002_VN3S.rod
   VCID: 4CCA0A29E64E8BFAF3B-8018
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 27112110801760 Dataset Number: V03935338SA 0001
   Coding: 030000344F056A0400000248000F00010001070000000000000000000000
   Shop #: WSC 00012 790 00181
   GVL: 01443C0000100000400000008004480000000000100000000000000000000000
   ROD: EV_GatewNF_VN46.rod
   VCID: 79A483FDF95CCE5218D-802C
   Generator:
   Component: 5-00-11-00-04
   Subsystem 2 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
   Serial number: 771972000021110505D9
Address 3D: Special Function (J608)       Labels:* Redir Fail!
   Part No SW: 2N0 907 427 R    HW: 2N0 907 427 H
   Component: KFG       H24 0408
   Serial number: GB24215034073 Dataset Number: V03935349WS 0001
   Coding: 04000000000000200200000860B80300B8000000
   ASAM Dataset: EV_SpeciFunctFlextVN54X 008036
   ROD: EV_SpeciFunctFlextVN54X_008_VN3S.rod
   Subsystem 5 - Part No SW: 7C0 907 155     HW: 7C0 907 155
   Component: U13DCAC  H05 0870
   Serial number: A025099
   Subsystem 6 - Part No SW: 7E0 915 181 M    HW: 7E0 915 181 M
   Serial number: 77194501002111040037
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 G    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7160
   Dataset Number: V03935340DA 0001
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002015
   ROD: EV_SteerAssisMNB_VN46.rod
   VCID: 46DE3801F82271AA25F-8012
   Part No SW: 3CN 035 869 A    HW: 3CN 035 869 A
   Component: MU-E-D-ER     720 0920
   Serial number: 29092100021415 Dataset Number: V03935343RV 0001
   Coding: 06640500BE00000041110101008000001F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 44DA2209CE1E43BA3BB-8010
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0092
   Serial number: 0000000110NVAX0 Dataset Number: V03935344U  0001
   Coding: 06462000196818008005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VN46.rod
   VCID: 0154EB1D918C969250D-8054
Address 800B: Aux air heater 2 (J604)       Labels:* None
   Part No SW: 7C0 963 273 C    HW: 7C0 963 273 C
   Component: LSH_DIESEL    008 0026
   Dataset Number: 0026        0026
   Coding: 2200
   ASAM Dataset: EV_LSHECCSMNB 002018
   ROD: EV_LSHECCSMNB.rod
   VCID: 2B0869B54380ACC2DA1-807E
End----------(Elapsed Time: 01:07, VBatt start/end: 13.1V/13.1V)-----------
Dr Sheldon
Windsor UK
C?ID=334979
Cannot give you all the answers but I'm quite sure that VCDS will not disable the Start Stop for you !
Uporabnik
Maribor, Slovenia
C?ID=529258
Bummer:(
Not even with that voltage meddling that I've read about somewhere?
Unsure if something like this exists in your market but I think you need to modify that on the hardware/switch level. Random NAR VW product examples:
If you can find a solution like that I believe it retains the last selection of the button.
Next, in regards to the BCM (09: Cent. Elect.) SA code 31347 = Adaptation Enabling may be needed first. I think this will change DRLs from front only to front and rears on:
Adaption channel: [*ENG141647-ENG149105*] Außenlicht_Front - Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht
From Not Active to Active​
When searching for DRL stuff in general also use the terms Tagfahrlicht and TFL since most is in German.
Lastly, I don't have any folding mirror suggestions but if you post an Adaptation function map from address 09 it may add clarity.
When posted in-between code tags they look like the Golf 7 ones in post #3 here:
That will show us what's what in your BCM since it isn't the same as the Golf 7 based units that I'm more familiar with. Maps are explained here:
Yep. At roughly MY 2019, VW removed those kinds of tweaks, likely at the behest of regulatory agencies.
