Tried a DPF Regen and broken my car. Need help.
   #21
So as you can see, there's no problem.
All you have left to do is pass all readiness monitors.... and that requires a bunch of driving.
As of right now, all is good.
   #22
He used adaptation to "fool" the ECU into thinking the DPF was replaced.....
In ODIS it warns against this with the poorly translated "warning. Vehicle may burn down"
   #23
Lots of documentation says to just replace once it's over 45g..... lots of us ignore all sorts of warning.... I've done it too ;)
   #24
Tallrobbo
C?ID=558626
Hi all again
Just done 100km of mainly motorway. I didnt regen. The "Soot Mass Measured" has increased as expected to 15.88g. It did go up and down depending on how hard I was driving. All motorway miles were above 2500 rpm.
Thursday,07,November,2024,17:55:17:62756
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUZZZ4M6HD054791   License Plate:
Mileage: 92899km-57724mi   Repair Order: scan afer trip
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 3C 42 44 46
          47 50 52 5F 65 69 6C 6D 74 81 82 84 8B A5 AC BB BC CA CB CF
          D6 D7
VIN: WAUZZZ4M6HD054791   Mileage: 92899km-57724miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H46 0009
   Revision: 91H46---    CVN: 5D7B420885D7D21E8947E11D
   Coding: 2A2A4032037E050334380000000000000000000000000000
   Shop #: WSC 51751 005 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401 001013
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 6695A7FAC8E89F7AC5F-8032
   VINID: 9D196AAAA11D1985001441C904BA73C404
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H05 1013
   Revision: --H05---    CVN: 228458AD
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3B23268EE3EAF2924A1-806E
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0003 CVN: ACFBEF4F
   Coding: 249830B230A70A9AD1A5589A187E16A6E6A6DA240C0C508B1A18686567655B
   Shop #: WSC 02140 001 48576
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 45D74076952EB4622C5-8010
   Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
   Component: MEM-BFS       008 0031
   Serial number: 00000252901116 Dataset Number: 4M0909866C  0016
   Coding: 00383A000001B2410000010101010000110000313100000000000000000000
   Shop #: WSC 02140 111 12345
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0093
   Coding: 6618083D5549451102620280810000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 678BAAFECFE28672FE9-8032
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001433186
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 58D8C0A880PAG0MUFU02
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514R  0052
   Coding: 07501943E06940CD050D57195BBF8CF9130331019000000000000000620016810A4501AB32B70A
   VCID: 025D9B6AC480435A497-8056
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 170124  043 0893
   Serial number: 89565300401702400608
   Coding: 1BC7F7
   Serial number: 20195303X81A955547A0
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 AD    HW: 4M0 941 531 AD
   Component: E1 - LDS  H06 0008
   Serial number: 08 07 2016  00640346
   Serial number: GX1CE116011723610131
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00272345
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA133846000054054087
   Coding: 0A0100
   Subsystem 7 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000053691
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Dataset Number: 4M0909863L  0031
   Coding: 3477FFFB78FFEC0A949880A0
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323D0BAA34A033DA997-8066
   Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
   Component: Airbag10.44   H01 0106
   Serial number: 003UL000PH6G Dataset Number: 4M0909602AH 0003
   Coding: AACCF0D80C80000098F650F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 3D272896FDFEFCA2745-8068
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705J0096R01733
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706D0100R00310
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 063 103 17
   Serial number: 3577Y00BB21303C4232O
   Subsystem 4 - Part No SW: -----------    HW: 442 063 103 17
   Serial number: 3587Y00A921781A2E1F8
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 903 17
   Serial number: 3517700AB2220D23135Y
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 903 17
   Serial number: 3527700C52220D23F04+
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 704 17
   Serial number: 35575000629E6207E4DG
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 704 17
   Serial number: 35675000A29E6207689D
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 203 17
   Serial number: 2307500B121FBF1081C9
   Subsystem 10 - Part No SW: -----------    HW: 442 421 711 16
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00C52093B73840D
   Subsystem 11 - Part No SW: -----------    HW: 442 421 711 16
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00AF2093B7340CQ
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 015F9466C186584250D-8054
   Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
   Component: FBenRDW       H17 0310
   Coding: 248D00F07C980E0001A3E9641000600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2E051FDA2098173AFDF-807A
   Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
   Component: Gateway       H30 0308
   Revision: 5C010004    Serial number: 0485C001417418 Dataset Number: 4M0909515M  0077
   Coding: 03010001008086407F07000000590032D41200070C0000000175078E10000000
   GVL: 01583C0C88040200C0FCC8000102C800110C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4CC17552B644452AF3B-8018
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20170401132115 00831
   Serial number: 7133033704
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0092
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 363537BAD8C82FFAB5F-8062
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: 77ABFABE9F4216F26E9-8022
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000056855013
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   Component: MEM-FS        008 0031
   Serial number: 00000252901049 Dataset Number: 4M0909856C  0018
   Coding: 00383B400001B6410000010101010000110000313100000000000000000000
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 4M0909535L  0015
   Coding: 5EE002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0057
   Serial number: 0000251473559  Dataset Number: 4M0909872F  0029
   Coding: 005D9A005E010082000930B2
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 40D951628A0C914A1F3-8014
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000740407 Dataset Number: 4M0909852P  0002
   Coding: B0110101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34310DB2CEB43DEA8BB-8060
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0344
   Dataset Number: 4M0909501G  0063
   Coding: 01351E006F9100406309A0006E00580203004004006F06502F0400000504803F001F0001000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 00599162CA8C514A5F3-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1704430TH
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000069118146
   Heated Windshield Control Module:
   Subsystem 3 - Part No SW: 4N0 907 133     HW: 4N0 907 133
   Component: J505-FSH  H08 0040
   Serial number: 17095001649011120081
   Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0815
   Serial number: 94001272
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000023780 Dataset Number: 4M1909510E  0011
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2313FEEE7B5AAA52621-8076
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000251844723 Dataset Number: 4M0909467C  0015
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0057
   Serial number: 0000251498334  Dataset Number: 4M0909873F  0029
   Coding: 005D9A005E010082000930B0
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 3FDB529EF7F2EEB2669-806A
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035 C    HW: 4M1 035 035
   Component: MU-P-LND-EU   033 1329
   Serial number: A641D0HB012062 Dataset Number: 4M0909545H  0037
   Coding: 013706010000000053111102000A00332F001BE7017001009E
   VCID: 2517E0F6756E54620C5-8070
   Subsystem 1 - Part No SW: V03 959 802 TT    HW: -----------
   Component: ECE 2024/2025  --- 0370
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M1 919 605     HW: 4M1 919 605
   Component: AU536_DU_HIGH  H44 0008
   Serial number: AUZ8Z9HJM00BBP
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 07041700000000000673
   Compact disc data bank:
   Component: Gracenote2  --- 1015
3084 - GSM antenna 2
          B1533 13 [00001001] - Open Circuit
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.07
                    Time: 11:07:52
                    Voltage terminal 30: 14.7 V
3086 - Antenna for Telephone Mount
          B1564 01 [00001001] - Electrical Failure
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.07
                    Time: 11:07:50
                    Voltage terminal 30: 14.8 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0010
   Serial number: 40000000005092 Dataset Number: 4M0909850B  0004
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 2F3B02DE27921E32F69-807A
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 A    HW: 8W1 907 383
   Component: Anhaenger     H10 0040
   Serial number: 000000000005802
   Coding: 0100000202001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG015672 Dataset Number: 4M1909460G  0022
   Coding: 02350601BF0FA10008404080
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31300638900000 Dataset Number: 4M0909541G  0025
   Coding: 00F0
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M0 907 777 J    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H35 1214
   Serial number: 1004170429  Dataset Number: 4M0909576M  0044
   Coding: B8505850F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130131890
   Coding: 303030
   Part No SW: 4M2 713 041 G    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170315002062
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU72.rod
   VCID: 2A0D13CA1C707B1A217-807E
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
   Component: HeadUpDisplay H29 1640
   Coding: 5F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU73.rod
   VCID: 353730B6C5CE24E2BC5-8060
Address 84: Night Vision (J853)       Labels:* Redir Fail!
   Part No SW: 4M0 907 547 A    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H11 0029
   Serial number: 640551900201720
   Coding: 200111
   ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
   ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H07 0006
   Serial number: 639589400B2003100343
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0023
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 303901A23AAC01CAEF3-8064
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H14 0042
   Dataset Number: 4M0909466L  0042
   Coding: 0407030600000402034023B7CD0000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0005
   Dataset Number: 4M0909571H  0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
   Component: TSG HFS       009 0057
   Serial number: 0000252578818  Dataset Number: 4M0909897F  0030
   Coding: 004D980000010082000830A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 42DD5B6A8400835A097-8016
   Component: TSG HBFS      009 0057
   Serial number: 0000252578754  Dataset Number: 4M0909896F  0030
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 4M0909469F  0014
   Coding: 7A8000053602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3A2D238AECD0CB9A517-806E
Address CB: Rear Axle Steering (J1019)       Labels:* 4M0-909-145.clb
   Part No SW: 4M0 909 145 G    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0607
   Revision: --------    Serial number: CCC_007_D_07_03 Dataset Number: 4M0909904H  0017
   Coding: 008528
   ASAM Dataset: EV_RearAxleSteerZFAU736 005010
   ROD: EV_RearAxleSteerZFAU736_005.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 5EE002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 33330EAECBBA3AD2921-8066
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1675D73AB808CFFA95F-8042
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
End----------(Elapsed Time: 02:54, VBatt start/end: 13.2V/12.8V)-----------
DPF Figures after Trip
Thursday,07,November,2024,17:51:34:62756
Mileage:    Repair Order: with trip
                Address 01: Engine  (4M0 907 401 )
17:51:20
  IDE00427   Particle filter: difference pressure 20 hPa
  IDE00428   DPF: offset for differential pressure 0 hPa
  IDE00432   Particle filter: time since last regeneration 9138 s
  IDE00433   Particle filter: oil ash volume 0.00 l
  IDE00434   Particle filter: soot mass calculated 5.11 g
  IDE00435   Particle filter: soot mass measured 15.88 g
  IDE00436   Particle filter: kilometers since last regeneration 104831 m
  IDE00584   Distance driven since erasing DTC memory 104 km
I dont suppose a chem clean in situ will do any harm so I will have a go over the weekend UNLESS you tell me not to!!!
thanks again for your help
   #25
Tallrobbo
C?ID=558626
I ignore or miss most of them....usually to my peril !! The wife can probably write a book on them.
I think "fooling" the system with the direct intention of fixing the problem ASAP is fine, fooling it and just carrying on driving would be foolhardy and short lived
I did notice on my early scans before I "zeroed" my data that my last regen (on the motorway) was 166km ago, now 266km.
I will monitor the figures over the next few trips and try to see when it regens and the results.
thanks for you help, MUCH appreciated.
   #26
As I said earlier, I don't see any problems\issues.
You've set readiness, and still no codes.
Loads look fine.
You don't have sufficient odometer reading to be anywhere close to having filled up the DPF near capacity. (ash reading)
Scan it again after more driving cycles until you can see evidence of regens taking place to confirm all is well.
If it was me, I wouldn't piss around with any chems as there's no evidence of any cleaning being required.... but it's your vehicle and your money.
   #27
Tallrobbo
C?ID=558626
understood. ill monitor and go from there. if it keeps regening and maintains 15-20g then should be good....touch wood.
   #31
Boki Ar
Arandjelovac, Serbia
C?ID=57300
They say "no need for evil", I can't translate that, we can say just in case.
Anyone who has seen something like this knows what I'm talking about.
   #32
Tallrobbo
C?ID=558626
I dont think I want that!! I have two Wynns DPF cleaners. Do you think it best to put these in? Now, am I correct in thinking that the DPF condition is measured by the difference between the inlet and the outlet pressures seen by the DPF Sensor on my bulkhead? As I have 20hpa at tick over could it possibly be that the oirinal MIL was just a gremlin?
saVAGsoot said he wouldnt bother but its my car and my money, well if I cant do any harm then why not, especially as the two pipes for the pressure sensor are very easy to access.
thoughts?
   #33
"I ignore or miss most of them....usually to my peril !! The wife can probably write a book on them."
I know almost nothing about TDI's , but It sounds like you are not big on maintenance.. , I think I would find out what maintenance is due or required and well, do it!
   #34
Tallrobbo
C?ID=558626
Thanks Stefdds. Quite the opposite, "oil is cheaper than engines", the comment was more directed at not doing what she tells me rather than vehicle maintenance. Ive stuck in a wynnes "on car DPF cleaner" just to see if it makes ANY difference. You never know.
Ill give it a try after and see if the Hpa reading reduces any. Regen is set at 28g and I am at 17g this morning. I will continue to monitor and let you know. The last regen was now 260km ago so I doubt my filter is so clogged it going to set on fire, but lets see. Hpa pressure on tick over is .3psi and rises to a maximum so far of 3psi with foot flat to floor in manual. If I was still getting more faults, or high pressures then I would agree, it needs either a chem clean to see if it helps or remove it and send it away for proper cleaning.
   #35
Tallrobbo
C?ID=558626
Hi All
So, I put the DPF treatment in and left it an hour. Started on tick over with MAF discnnected as advised. 5min later ran it at 2500 rpm for 5 mins. Hardly any foam, not like on other videos, what there was, was pure white, a few bubbles in the air.
Now, I suspect that when the cleaner is all over the face of the DPF the pressure change should be MUCH worse until it can push the cleaner through and make some holes.
Before the treatment 20HPA
After treatment 30 hPA
After 5 mins of 2500 RPM 12 HPA
MAF back on and went for a drive.
omg WHAT A LOT OF DARK GREY SMOKE. Soon cleared and I watched as the Measured Grams went lower.
I took a log
  BEFORE DPF on car Wynns
TIMELoc. IDE00433TIMELoc. IDE00434TIMELoc. IDE00435TIMELoc. IDE04263
STAMPParticle filter: oil ash volumeSTAMPParticle filter: soot mass calculatedSTAMPParticle filter: soot mass measuredSTAMPSensor for particle filter differential press: raw value
lgghPa
0.56​
0​
0.01​
6.46​
0.13​
17.32​
0.28​
29​
1.27​
0​
0.71​
6.46​
0.85​
17.32​
0.99​
29​
1.97​
0​
1.41​
6.46​
1.56​
17.32​
1.7​
29​
2.68​
0​
2.12​
6.46​
2.26​
17.32​
2.4​
29​
3.38​
0​
2.83​
6.46​
2.96​
17.32​
3.1​
29​
4.1​
0​
4.25​
6.46​
3.66​
17.32​
3.81​
29​
4.8​
0​
4.94​
6.46​
4.38​
17.32​
4.52​
29​
5.5​
0​
5.64​
6.46​
5.08​
17.32​
5.22​
29​
6.2​
0​
6.32​
6.46​
5.79​
17.32​
5.92​
29​
After (this snapshot is at the end of the trip and the full log is 1700 lines long, no need for that)
Saturday09November14:36:27:62756-VCID:6695A7FAC8E89F7AC5F-8032Data version: 20240715 DS356.3
4M0 907 401ADVMB3.0TDI EDC17 H46 0009
G104G105G106G107G438
MarkerTIMELoc. IDE00433Loc. IDE00434Loc. IDE00435Loc. IDE00436Loc. IDE04263
STAMPParticle filter: oil ash volumeParticle filter: soot mass calculatedParticle filter: soot mass measuredParticle filter: kilometers since last regenerationSensor for particle filter differential press: raw value
lggmhPa
2054.43​
0​
8.2​
7.09​
156878​
18​
2055.68​
0​
8.2​
7.09​
156878​
18​
2056.94​
0​
8.2​
7.09​
156878​
18​
2058.15​
0​
8.2​
7.09​
156878​
18​
2059.42​
0​
8.2​
7.09​
156878​
18​
2060.63​
0​
8.2​
7.09​
156878​
18​
2061.87​
0​
8.2​
7.09​
156878​
18​
2063.14​
0​
8.2​
7.09​
156878​
17​
1​
2064.4​
0​
8.2​
7.09​
156878​
18​
2065.66​
0​
8.2​
7.09​
156878​
17​
So, my thoughts are,
the hectopascals have reduced from 29 - 19,
the calculated and measured "grams values" are now much more in line 6 / 17 and now 8 / 7, which more than likely is because I accidentally told it I had a new DPF fitted and this was clearly not as clear as it calculated,
no difference in performance etc.
I have another Wynns which I will add soon and just ordered a JML DPF cleaner and the DPF fuel additive.
Fire Extinguisher now in the car...Just in case!
Thank you all for your very helpful posts and I will keep you posted.
TL;DR
So what "problem" did your Wynns solve? :confused:
   #37
Tallrobbo
C?ID=558626
There was no "Problem", I agreed with you at the start, for some reason my Manual Regen freaked it out. I already bought some Wynns so, as everybody was telling me that my car would burn down and I was poor at maintenance I saw no harm in putting it in.
I will keep it monitored and make sure it self regens when the clogging gets to 28G.
