Tried a DPF Regen and broken my car. Need help.
Tallrobbo
C?ID=558626
Good day to you all. I have a 2017 Q7 4M TDI. Ive been experiencing a lumpy engine on very light throttle and plugged in my VCDS to see if any codes. Nothing major so I deleted them all and went for a run. All clear.
No lumpy power so I thought whilst its plugged in I will perform a DPF Regen. Went in to basic settings and selected the DPF regen. It said to hold brake and accelerator. Revs climbed and then all of a suddent a yellow triangle and "Drive Train Fault". In limp mode.
Clearly I have done something wrong
Tried to reset the codes but it wont clear any of these
Wednesday,06,November,2024,21:27:27:62756
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUZZZ4M6HD054791   License Plate:
Mileage: 92794km-57659mi   Repair Order:
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 3C 42 44 46
          47 50 52 5F 65 69 6C 6D 74 81 82 84 8B A5 AC BB BC CA CB CF
          D6 D7
VIN: WAUZZZ4M6HD054791   Mileage: 92794km-57659miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H46 0009
   Revision: 91H46---    CVN: 5D7B420885D7D21E8947E11D
   Coding: 2A2A4032037E050334380000000000000000000000000000
   Shop #: WSC 51751 005 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401 001013
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 6695A7FAC8E89F7AC5F-8032
   VINID: 9D196AAAA11D1985001441C904BA73C404
5188 - Particle Filter
          P2463 00 [10100111] - Excessive Soot Accumulation
                    Mileage: 92794 km
                    Date: 2024.11.06
                    Time: 20:59:47
                    Engine RPM: 0.00 /min
                    Coolant temperature: 86  C
                    Intake air temperature: 18  C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 11.840 V
                    P Flt Ld fac Ash Cor: 0.9130
                    Particul.filter diff.pressure: 0 hPa
                    Exh t Adap T Oxi Cat Ds: 160.9  C
                    Exh t Adap TP Flt Ds: 170.4  C
                    Current operating mode_2-Bits 0-7: 128
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 16
5189 - Particulate Trap Bank 1
          P2002 00 [00100111] - Efficiency Below Threshold
                    Mileage: 92794 km
                    Date: 2024.11.06
                    Time: 20:59:47
                    Ambient temperature: 14.0  C
                    DPF: offset for differential pressure: 0 hPa
                    Particle filter: soot mass measured: 14.44 g
                    Particle filter: soot mass calculated: 45.96 g
                    Particle filter: kilometers since last regeneration: 167792 m
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 0
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H05 1013
   Revision: --H05---    CVN: 228458AD
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3B23268EE3EAF2924A1-806E
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0003 CVN: ACFBEF4F
   Coding: 249830B230A70A9AD1A5589A187E16A6E6A6DA240C0C508B1A18686567655B
   Shop #: WSC 02140 001 48576
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 45D74076952EB4622C5-8010
   Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
   Component: MEM-BFS       008 0031
   Serial number: 00000252901116 Dataset Number: 4M0909866C  0016
   Coding: 00383A000001B2410000010101010000110000313100000000000000000000
   Shop #: WSC 02140 111 12345
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0093
   Coding: 6618083D5549451102620280810000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 678BAAFECFE28672FE9-8032
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001433186
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 58D8C0A880PAG0MUFU02
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514R  0052
   Coding: 07501943E06940CD050D57195BBF8CF9130331019000000000000000620016810A4501AB32B70A
   VCID: 025D9B6AC480435A497-8056
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 170124  043 0893
   Serial number: 89565300401702400608
   Coding: 1BC7F7
   Serial number: 20195303X81A955547A0
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 AD    HW: 4M0 941 531 AD
   Component: E1 - LDS  H06 0008
   Serial number: 08 07 2016  00640346
   Serial number: GX1CE116011723610131
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00272345
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA133846000054054087
   Coding: 0A0100
   Subsystem 7 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000053691
196898 - Databus
          [Engine control module: received error value in signal TSK_status_PLA]
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.06
                    Time: 20:59:43
                    average_Voltage_terminals: 11.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 14.00  C
                    interior_temperature: 20.50  C
                    Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Dataset Number: 4M0909863L  0031
   Coding: 3477FFFB78FFEC0A949880A0
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323D0BAA34A033DA997-8066
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.06
                    Time: 20:59:43
                    Control Module temperature: 27  C
                    Voltage terminal 15: 11.7 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
   Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
   Component: Airbag10.44   H01 0106
   Serial number: 003UL000PH6G Dataset Number: 4M0909602AH 0003
   Coding: AACCF0D80C80000098F650F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 3D272896FDFEFCA2745-8068
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705J0096R01733
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706D0100R00310
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 063 103 17
   Serial number: 3577Y00BB21303C4232O
   Subsystem 4 - Part No SW: -----------    HW: 442 063 103 17
   Serial number: 3587Y00A921781A2E1F8
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 903 17
   Serial number: 3517700AB2220D23135Y
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 903 17
   Serial number: 3527700C52220D23F04+
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 704 17
   Serial number: 35575000629E6207E4DG
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 704 17
   Serial number: 35675000A29E6207689D
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 203 17
   Serial number: 2307500B121FBF1081C9
   Subsystem 10 - Part No SW: -----------    HW: 442 421 711 16
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00C52093B73840D
   Subsystem 11 - Part No SW: -----------    HW: 442 421 711 16
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00AF2093B7340CQ
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 015F9466C186584250D-8054
   Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
   Component: FBenRDW       H17 0310
   Coding: 248D00F07C980E0001A3E9641000600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2E051FDA2098173AFDF-807A
   Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
   Component: Gateway       H30 0308
   Revision: 5C010004    Serial number: 0485C001417418 Dataset Number: 4M0909515M  0077
   Coding: 03010001008086407F07000000590032D41200070C0000000175078E10000000
   GVL: 01583C0C88040200C0FCC8000102C800110C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4CC17552B644452AF3B-8018
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20170401132115 00831
   Serial number: 7133033704
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0092
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 363537BAD8C82FFAB5F-8062
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: 77ABFABE9F4216F26E9-8022
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000056855013
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   Component: MEM-FS        008 0031
   Serial number: 00000252901049 Dataset Number: 4M0909856C  0018
   Coding: 00383B400001B6410000010101010000110000313100000000000000000000
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 4M0909535L  0015
   Coding: 5EE002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0057
   Serial number: 0000251473559  Dataset Number: 4M0909872F  0029
   Coding: 005D9A005E010082000930B2
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 40D951628A0C914A1F3-8014
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000740407 Dataset Number: 4M0909852P  0002
   Coding: B0110101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34310DB2CEB43DEA8BB-8060
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0344
   Dataset Number: 4M0909501G  0063
   Coding: 01351E006F9100406309A0006E00580203004004006F06502F0400000504803F001F0001000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 00599162CA8C514A5F3-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1704430TH
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000069118146
   Heated Windshield Control Module:
   Subsystem 3 - Part No SW: 4N0 907 133     HW: 4N0 907 133
   Component: J505-FSH  H08 0040
   Serial number: 17095001649011120081
   Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0815
   Serial number: 94001272
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000023780 Dataset Number: 4M1909510E  0011
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2313FEEE7B5AAA52621-8076
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000251844723 Dataset Number: 4M0909467C  0015
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0057
   Serial number: 0000251498334  Dataset Number: 4M0909873F  0029
   Coding: 005D9A005E010082000930B0
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 3FDB529EF7F2EEB2669-806A
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035 C    HW: 4M1 035 035
   Component: MU-P-LND-EU   033 1329
   Serial number: A641D0HB012062 Dataset Number: 4M0909545H  0037
   Coding: 013706010000000053111102000A00332F001BE7017001009E
   VCID: 2517E0F6756E54620C5-8070
   Subsystem 1 - Part No SW: V03 959 802 TT    HW: -----------
   Component: ECE 2024/2025  --- 0370
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M1 919 605     HW: 4M1 919 605
   Component: AU536_DU_HIGH  H44 0008
   Serial number: AUZ8Z9HJM00BBP
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 07041700000000000673
   Compact disc data bank:
   Component: Gracenote2  --- 1015
3084 - GSM antenna 2
          B1533 13 [00001001] - Open Circuit
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.06
                    Time: 20:59:46
                    Voltage terminal 30: 11.9 V
3086 - Antenna for Telephone Mount
          B1564 01 [00001001] - Electrical Failure
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.06
                    Time: 20:59:44
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0010
   Serial number: 40000000005092 Dataset Number: 4M0909850B  0004
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 2F3B02DE27921E32F69-807A
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 A    HW: 8W1 907 383
   Component: Anhaenger     H10 0040
   Serial number: 000000000005802
   Coding: 0100000202001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG015672 Dataset Number: 4M1909460G  0022
   Coding: 02350601BF0FA10008404080
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31300638900000 Dataset Number: 4M0909541G  0025
   Coding: 00F0
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M0 907 777 J    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H35 1214
   Serial number: 1004170429  Dataset Number: 4M0909576M  0044
   Coding: B8505850F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130131890
   Coding: 303030
   Part No SW: 4M2 713 041 G    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170315002062
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU72.rod
   VCID: 2A0D13CA1C707B1A217-807E
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
   Component: HeadUpDisplay H29 1640
   Coding: 5F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU73.rod
   VCID: 353730B6C5CE24E2BC5-8060
Address 84: Night Vision (J853)       Labels:* Redir Fail!
   Part No SW: 4M0 907 547 A    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H11 0029
   Serial number: 640551900201720
   Coding: 200111
   ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
   ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H07 0006
   Serial number: 639589400B2003100343
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0023
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 303901A23AAC01CAEF3-8064
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H14 0042
   Dataset Number: 4M0909466L  0042
   Coding: 0407030600000402034023B7CD0000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0005
   Dataset Number: 4M0909571H  0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
   Component: TSG HFS       009 0057
   Serial number: 0000252578818  Dataset Number: 4M0909897F  0030
   Coding: 004D980000010082000830A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 42DD5B6A8400835A097-8016
   Component: TSG HBFS      009 0057
   Serial number: 0000252578754  Dataset Number: 4M0909896F  0030
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 4M0909469F  0014
   Coding: 7A8000053602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3A2D238AECD0CB9A517-806E
Address CB: Rear Axle Steering (J1019)       Labels:* 4M0-909-145.clb
   Part No SW: 4M0 909 145 G    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0607
   Revision: --------    Serial number: CCC_007_D_07_03 Dataset Number: 4M0909904H  0017
   Coding: 008528
   ASAM Dataset: EV_RearAxleSteerZFAU736 005010
   ROD: EV_RearAxleSteerZFAU736_005.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 5EE002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 33330EAECBBA3AD2921-8066
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1675D73AB808CFFA95F-8042
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
End----(Elapsed Time: 02:54, VBatt start/end: 11.8V/11.6V. VIgn 11.6V)-----
Any ideas or help will be greatly appreciated
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Were there any DTCs before you engaged the regeneration operation?
Something related to the differential pressure sensor or exhaust system temperature sensors, maybe?
Tallrobbo
C?ID=558626
Thanks. No DTCs at all. The error came up within a few minutes, I tried to do another run but it was "Aborted due to safety reasons"
Gutted. Should have left it alone!
Boki Ar
C?ID=57300
It is better that it was interrupted for security reasons.
Someone correct me if I'm wrong, but it seems like too much soot build-up, it would be dangerous if the regeneration continued.
The exhaust temperature would be too high.
Tallrobbo
C?ID=558626
Thats what is saying but I had no DTCs before. The action of trying to regen seems to have created some. The figures quoted dont seem super high do they?
Boki Ar
C?ID=57300
When everything is in order, the regeneration would not hurt and would be done to the end.
Tallrobbo
C?ID=558626
would it be worth trying it again in the morning when cool?
Tallrobbo
C?ID=558626
I would have thought it would let you clear the codes when not running and then as soon as it starts up it would then measure the difference and brig on the MIL. It comes back even when not running. Is this normal?
Tallrobbo
C?ID=558626
Hi all, so, it would seem the only way to remove the MIL is to go in to 10 Adaption > Carbon Mass , and change the "New value" to 0. Then will then clear the codes by making the car think it has a new DPF.
This will then let me perfom a regen?
If my level is actually 41g will a regen be dangerous? Is it safer to perform a regen whilst on the road? If so how do I check it regening? I have done around 6K miles recently and all on motorway at over 2k revs so I would have thought it would have done it already. Please let me know your thoughts
regards
Dr Sheldon
Windsor UK
C?ID=334979
Weird ??
I would use a DPF Cleaner on that.
https://www.ebay.co.uk/itm/276545317683
Follow the instructions to the letter - That will chemically clean the filter for you.
DPF Pressure differential sensors fail for fun on these cars - Either test yours properly if you have the tools or go get a new one - New one from the Dealer and no where else !! Ignore all that OEM mumbo Jumbo - Dealer only !!!!!! I cannot stress that enough !!
And Clean the pipes from the DPF to the sensor !!
Tallrobbo
C?ID=558626
Thanks Doctor. After flush etc should I drive in limp mode to see if I can get a regen or should I use VCDS and change the Carbon Mass value, hopefully remove the MIL and perform the test stationary? The sensor is in a fantastic position, so I could do a clean regularly. You mention above, performing a test on the sensor "if I have the tools", what am I looking for?
Tallrobbo
C?ID=558626
Hi again. Started it up and managed to clear the codes. I hit go on IDE00467 Resetting of learned values of particle filter
At present the readings are
IDE00432 Particle filter: time since last regeneration 1027s
IDE00433 Particle filter: oil ash volume 0.001
IDE00434 Particle filter: soot mass calculated 0.45 g
IDE00435 Particle filter: soot mass measured 2.97 g
IDE00436 Particle filter: kilometers since last regeneration 0 m
No lights on, all DTCs have cleared
Was it just a glitch?
MVB "Particle filter: soot mass calculated: 45.96 g", over 40g so not going to happen, filter off and send to DPF Clean Team.
Tallrobbo
C?ID=558626
Understood. As above, its all fine today with a calculated mass of 0.45 g and a measured of 2.97 g. No lights, no DTC's. Ill take it for a run later on the motorway and see what it does.
How did you do that?
Tallrobbo
C?ID=558626
This morning I plugged in VCDS to see if I could find IDE00467 and have the option when needed to manually change the values to Zero. When I navigated to IDE 467 I was expecting to have to enter values as I have seen elsewhere. I guess the updated VCS just does it for you now, unless I should have opened IDE 467 elsewhere? The DPF pressure diff on idle is 12 hpa. Which doesnt sound much but I would welcome your thoughts. I will introduce some chemical cleaner anyway and see what happens.
If it is indeed blocked, would the measured grams not return very soon?
To re-iterate, I did not have any DTC's or lights before my attempt at re gen last night, sadly though I did not take the soot readings beforehand.
Car has 57k miles on it.
Post current DPF stats... they will reveal if you still have issues, etc.
Post full autoscan.... they all contain clues.
Example from my CNRB
                Address 01: Engine  (7P0 907 401 K)
18:32:26
  IDE00432   Particle filter: time since last regeneration 36033 s
  IDE00433   Particle filter: oil ash volume 0.30 l
  IDE00434   Particle filter: soot mass calculated 19.18 g
  IDE00435   Particle filter: soot mass measured 18.82 g
  IDE00436   Particle filter: kilometers since last regeneration 524658 m
  IDE00584   Distance driven since erasing DTC memory 8146 km
  IDE00603   Number of driving cycles since erasing DTC memory 194
  IDE01922   Vehicle distance driven 215148 km
  IDE03386   Long-term adaptation of reduction agent dosage 0.94
  IDE05857   DPF statistics: current measured charging rate 0.0320 g/km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 381 km
  IDE07197   Average reducing agent since lest filling 1.10 l/1000 km
Tallrobbo
C?ID=558626
Thank you for you help and time so far
Please see the scans below
Thursday,07,November,2024,15:30:07:62756
Mileage: 92794km-57659mi   Repair Order: lastest scan
          D6 D7
   Coding: 100000
   Coding: 1BC7F7
   Coding: 0200FF
   Coding: 230000
   Coding: 0A0100
   Coding: 88001B
   Coding: 88001B
   Coding: 5EE002
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.07
                    Time: 11:07:52
                    Voltage terminal 30: 14.7 V
                    Reset counter: 251
                    Mileage: 92794 km
                    Date: 2024.11.07
                    Time: 11:07:50
                    Voltage terminal 30: 14.8 V
   Coding: 00F0
   Coding: B8505850F8
   Coding: 303030
   Coding: 5F01C0
   Coding: 200111
   Coding: 008528
   Revision: --------
   Coding: 5EE002
End----------(Elapsed Time: 02:53, VBatt start/end: 14.5V/14.6V)-----------
With IGN on Engine NOT running
Thursday,07,November,2024,15:33:13:62756
Mileage: 92794km-57659mi   Repair Order: engine off ign on
                Address 01: Engine  (4M0 907 401 )
15:33:01
  IDE00432   Particle filter: time since last regeneration 3723 s
  IDE00433   Particle filter: oil ash volume 0.00 l
  IDE00434   Particle filter: soot mass calculated 1.09 g
  IDE00435   Particle filter: soot mass measured 8.07 g
  IDE00584   Distance driven since erasing DTC memory 0 km
  IDE00603   Number of driving cycles since erasing DTC memory 0
  IDE01922   Vehicle distance driven 92794 km
  IDE03386   Long-term adaptation of reduction agent dosage 1.00
  IDE05857   DPF statistics: current measured charging rate 3.9999 g/km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 412 km
With Engine running
Thursday,07,November,2024,15:25:56:62756
Mileage:    Repair Order: engine data
15:25:36
  IDE00432   Particle filter: time since last regeneration 3423 s
  IDE00434   Particle filter: soot mass calculated 1.02 g
  IDE07197   Average reducing agent since lest filling 2.23 l/1000 km
