Active blind spot detection not working after installing new mirror on passenger side.
aswinikumarkj
Cayman Islands
C?ID=599397
Good day everyone
I recently purchased a 2018 RHD MK7.5 VW Golf R and this is my first post after the purchase of VCDS which I got delivered last week. I am still in the process of learning the immense amount of things that VCDS is capable of doing, only if I had a little more time :cry:.
But, I would like some help with something. I would really appreciate it if someone can provide me with a helping hand in sorting this out.
I had to replace the left side passenger mirror assembly and my mirror on my car. I purchased the new part using the VIN number and the part was shipped to me by LLLParts from Lithuania. I went ahead and installed both the parts and everything (auto fold/unfold on lock/unlock, indicators, mirror positioning motor etc.) works fine. But, I am not able to get my active blind spot detection to work. Before the new mirror was installed, I had to drive around with just my right side mirror because I was waiting for the parts to arrive. The blind spot was working on the right side mirror then. But, after the install, it does not work on both the mirrors.
Then, I discovered on the ICE system that, the checkbox for Blind Spot Detection was unticked. I selected that option but, it would not come one and the instrument cluster gave me a warning ("Error: Rear Traffic Alert/Blind Spot Monitor"). When I installed the mirror, I did connect the two pin connector with two wires for active blind spot (a red/green wire and a brown/green wire) but I am not sure if I connected it the other way round because, I am cannot recall how it was originally connected on the OEM mirror. Can anyone shine some light into this issue that I am having?
Really appreciate your assistance
What does the scan tell you?
aswinikumarkj
Cayman Islands
C?ID=599397
Thank you for your reply
Thank you for the quick reply. I only got the mirror assembly and the mirror installed yesterday and only yesterday evening did I realise that it was not working. The scan is clean when there are no errors on the cluster but, I have not done a VCDS scan yet with the error/alert on the instrument cluster. I will do a scan in the next hour or so and will update this post. Hopefully something can be figured out.
When asking for help around here, a scan is necessary as no one has a crystal ball for the details you're not sharing. ;)
aswinikumarkj
Cayman Islands
C?ID=599397
Sorry about that. This is my first post on this forum and this is my first VAG car. So, I did not how to do a post here. Will do like that in the future.
aswinikumarkj
Cayman Islands
C?ID=599397
I just did a VCDS scan when there was the error on the instrument cluster. The full auto scan report is as follows.
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 24.7.1(x64) Data version: 20240919 DS356.3
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,06,November,2024,13:59:01:59514
VIN: WVWZZZAUZJW020139 License Plate:
Mileage: 89413km-55558mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C 42
 44 4B 52 57 5F A5 A9 D6 D7
VIN: WVWZZZAUZJW020139 Mileage: 89413km-55558miles
Address 01: Engine (J623-DJHA) Labels:. 06K-907-425-V1.clb
 Part No SW: 8V0 906 259 J HW: 06K 907 425 B
 Component: 2.0l R4 TFSI H13 0003
 Revision: --H13--- CVN: D47DA4BA
 Coding: 092500122466050B3004
 ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
 ROD: EV_ECM20TFS0208V0906259J.rod
 VCID: 47CC83852F237392DE1-8012
 VINID: 9E69EAAAA465A9A9C008004324B1A104C6
 Part No SW: 0GC 300 012 A HW: 0GC 927 711 G
 Component: GSG DQ381 H06 1401
 Revision: 00H06V07 CVN: 616C0F77
 ROD: EV_TCMDQ381061.rod
 VCID: 21183D1DE1476DA2705-8074
 No subsystems:
 Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
 Component: ESC H25 0513
 Revision: 00000000 Serial number: 61587000002258
 Coding: 01FA93A15422216C4778070340CC6980C92A84E2E0029677384250F8C2A8430000000012121212B835351919323200
 VCID: 77AC33451F43C3126E1-8022
 Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
 Component: VWKESSYMQB 021 0803
 Revision: 00021000 Serial number: 0444254913 Dataset Number: V03935252RD 0001
 Coding: 032C0C
 VCID: 3C26EC6966E5204A433-8068
 Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
 Component: Climatronic H04 1801
 Revision: 00001K08
 Coding: 0012000410010001110500001010102A
 VCID: 6D80112D6D1F79C284D-8038
 Air quality sensor:
 Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
 Component: BCM MQBAB MNA H36 0253
 Serial number: 01001715400162 Dataset Number: V03935262DA 0001
 ROD: EV_BCMBOSCH_018.rod
 VCID: 06524E8168A9AA9A657-8052
 Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
 Component: WWS 170514 042 0551
 Serial number: 170526162733
 Component: RLHS 042 0105
 Serial number: S5Y17M06D13H03M41S35
 Coding: 31E8DD
 Serial number: 000000000ZY171381YVK
 Serial number: 00000000000069775342
 Part No SW: 5QA 919 294 B HW: 5QA 919 294
 Serial number: 000308418617159 Dataset Number: V03935278KF 0001
 Coding: 0471155811
 Shop #: WSC 32032 002 1048576
 VCID: 4BC4BFB5334B97F2FA9-801E
13637426 - Databus
 Reset counter: 78
 Mileage: 89248 km
 Date: 2024.10.31
 Time: 00:17:32
13688835 - Databus
 [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
 Reset counter: 55
 Mileage: 89408 km
 Date: 2024.11.07
 Time: 10:39:07
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
 Part No SW: 5Q0 907 572 J HW: 3QF 907 572
 Component: ACC BOSCH MQB H10 0654
 Dataset Number: V03935259QS 0001
 Coding: 330007C159FFC728949C810580400600000000000000000000
 ASAM Dataset: EV_ACCBOSCHVW416 002006
 VCID: 3E22E66170F9325A6D7-806A
2068 - Databus
 [FAULT_TSK_IRREV_FAIL]
 Reset counter: 78
 Mileage: 89248 km
 Date: 2024.10.31
 Time: 00:22:45
 Control Module temperature: 53 °C
 Voltage terminal 15: 12.7 V
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
 Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
 Serial number: 11051741350375 Dataset Number: V03935231PP 0001
 ROD: EV_DRCONTITEMIC_VW37.rod
 VCID: 382EF07952DD0C6AA7B-806C
 Part No SW: 5Q0 959 655 BK HW: 5Q0 959 655 BK
 Component: AirbagVW21 005 0336
 Serial number: 003VXR31GPX0 Dataset Number: V03935259SL 0001
 Coding: 98FCC0C0000000005C5400CF008800000065
 VCID: 0A4A7AB17CB1CEFA01F-805E
 Left seat belt tensioner:
 Component: BeltPretRevFL H37 0350
 Serial number: 34169677E05061750854
 Coding: 333135
 Right seat belt tensioner:
 Component: BeltPretRevFR H37 0350
 Serial number: 34169676E08061750965
 Coding: 333135
 Subsystem 3 - Part No SW: ----------- HW: 480 001 006 17
 Serial number: 357000000006123D752B
 Subsystem 4 - Part No SW: ----------- HW: 480 001 006 17
 Serial number: 3580000000013D4D752L
 Subsystem 5 - Part No SW: ----------- HW: 480 400 706 17
 Serial number: 3510001B725DA8B5568F
 Subsystem 6 - Part No SW: ----------- HW: 480 400 706 17
 Serial number: 3520001BD25DA8B4E62O
 Subsystem 7 - Part No SW: ----------- HW: 480 401 206 17
 Serial number: 3550001AD2625E15879A
 Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
 Revision: -------- Serial number: 07061708491257
 Coding: 0C10
 ROD: EV_SMLSKLOMQB_018_VW37.rod
 VCID: 094845BD79B7C5E2085-805C
 Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
 Component: KOMBI 407 3193
 Coding: 27AD30187F88000E02886B0B5401000080000000
 VCID: 2A0ADA319C71AEFA21F-807E
 Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
 Component: GW MQB High 433 4303
 Revision: -------- Serial number: 0006427279 Dataset Number: V03935261SP 0001
 Coding: 030100047F085900FB00827E9C0F00010001070000000000000000000000
 GVL: 01D63C100000060040DC80000000CC0000000000000200000000000000000000
 ROD: EV_GatewNF_VW37.rod
 VCID: 3334C7554BBBEF32929-8066
 Generator:
 Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
 Component: E221__MFL-DC1 H11 0040
 Serial number: 39170001329270077203
 Coding: 2DFFFF
 Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
 Serial number: 2314794204
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
 Serial number: HA1-00024.04.17 Dataset Number: v1260x015G0 0000
 Coding: 0001
 VCID: 4ACABAB13C318EFAC1F-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
 Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
 Component: LCM_MLBevoH08 0014
 Component: ELV-MQBA H01 0120
 Revision: 00000000 Serial number: 17000146916001
 Coding: 5D00000000000000
 VCID: 3436C4494EB5E80A8B3-8060
Address 36: Seat Mem. Drvr (J810) Labels:* None
 Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
 Component: Sitzmemory H08 0022
 Serial number: Y0006QET10034
 Coding: 0014000000000500018280808080000000008181000000F400
 ASAM Dataset: EV_SeatMemorDriveSide 002021
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
 Dataset Number: V03935262JC 0001
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
 Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
 Component: HRE_Master H12 0080
 Serial number: 0441517715 Dataset Number: V03935258DF 0001
 Coding: 02011203
 ROD: EV_HREntryHella_VW37.rod
 VCID: 3D20E16D7DFF294274D-8068
 Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
 Component: HRE_Slave H12 0080
 Serial number: 0442400206
 Coding: 020112
730378 - Warning Lamp for Blind Spot Detection in Left Exterior Mirror
 C122C 15 [00001001] - Open or Short to Plus
 Reset counter: 55
 Mileage: 89408 km
 Date: 2024.11.07
 Time: 10:39:06
 Component: TSG FS 020 0041
 Serial number: 310517EEU36942 Dataset Number: V03935257JP 0001
 Coding: 003F1220D201048000001000
 ROD: EV_DCUDriveSideEWMAXKLO.rod
 VCID: 43D497951B1B5FB2029-8016
 Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
 Component: FOND_FHSG_DRV 005 0007
 Serial number: 00000000000015163274
 Coding: 0D0000
65593 - Switch for Central Locking
 B122D 29 [00001000] - Signal Implausible
 Reset counter: 90
 Mileage: 89390 km
 Date: 2024.11.06
 Time: 11:44:49
 Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
 Component: EPS_MQB_ZFLS 506 5072
 Dataset Number: V03935259RW 0001
 Coding: 9107
 ROD: EV_SteerAssisMQB_013.rod
 VCID: 3A2AEA716CD11E7A51F-806E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
 Part No SW: 3Q0 907 338 HW: 3Q0 907 338
 Component: FCM MQB Low 002 0286
 Serial number: 01061710520675 Dataset Number: V03935259VB 0001
 Coding: 000000050100165607204F01020000000000000000000000000000000000
 VCID: 72BA02517421A63A59F-8026
 Component: TSG BFS 020 0041
 Serial number: 260517EEQ02055 Dataset Number: V03935257JW 0001
 Coding: 003F1020DE01048000801000
 ROD: EV_DCUPasseSideEWMAXKLO.rod
 VCID: 42DA9291040156BA09F-8016
 Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
 Component: FOND_FHSG_PSG 005 0007
 Serial number: 00000000000015042626
 Coding: 150000
Address 57: TV Tuner (R78) Labels:| 8V0-919-DTV-V1.clb
 Part No SW: 8V0 919 129 F HW: 8V0 919 129 D
 Component: JP-DTV H12 2110
 Coding: 02041C0000000100000002
 ASAM Dataset: EV_TVMELC 001039
 ROD: EV_TVMELC_VW37.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
 Part No SW: 5NA 035 050 A HW: 5NA 035 050
 Component: MU-H-N-JP 053 0829
 Serial number: K5F AW7U80M0O4 Dataset Number: V03935262VW 0001
 Coding: 02731006FF00000051380001001038001F0107F601200400FE
 ASAM Dataset: EV_MUHig4CGen2AW7 001081
 ROD: EV_MUHig4CGen2AW7_VW37.rod
 VCID: 323AC251B4A1E63A99F-8066
 Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
 Component: ABT_High-2 H50 9120
 Serial number: VWZ6ZHT1632323
 Subsystem 2 - Part No SW: V03 959 802 NK HW: -----------
 Component: JPN 2018 --- 7910
 Control module for chip card reader:
 Subsystem 3 - Part No SW: 8V0 919 813 B HW: 8V0 919 813 B
 Component: DSRC UNIT H10 0003
 Serial number: 502129458521
 Traffic data antenna:
 Subsystem 4 - Part No SW: 8V0 035 504 B HW: 8V0 035 504 B
 Component: VICS Antenna H07 0001
 Serial number: 503510126501
 Compact disc data bank:
 Subsystem 5 - Part No SW: V03 959 800 EG HW: -----------
 Component: Gracenote2 --- 2014
 Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
 Component: MQB_B_MFK H07 0272
 Serial number: 30051711K24267 Dataset Number: V03935260KJ 0001
 Coding: 0003070000000501000223548150A90084000E300040
 Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
 Component: SAS-GEN 2 H07 0001
 Serial number: 170426202076
 VCID: 2F3CCB25A793CBD2F61-807A
 Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
 Component: LED1L H06 0002
 ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
 ROD: EV_LEDMinMaxL_KEBODAVW481.rod
 VCID: 3928F57D69D71562585-806C
 Component: LED1R H06 0002
 Dataset Number: V03935284BG 0001
 ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:11, VBatt start/end: 12.5V/12.5V)-----------
Kushdaiin
CT, USA
C?ID=192983
Looks like you might have the connector in upside down.
 Coding: 02011203
 Coding: 020112
 Reset counter: 55
 Mileage: 89408 km
 Date: 2024.11.07
 Time: 10:39:06
aswinikumarkj
Cayman Islands
C?ID=599397
Looks like you have an open circuit. Maybe you didn't plug the connector in all the way?
 Coding: 02011203
 Coding: 020112
 Reset counter: 55
 Mileage: 89408 km
 Date: 2024.11.07
 Time: 10:39:06
I will need to check again if the connector is all the way in into the blind spot connector. I had it installed with the help of a mechanic and he was the one who connected it up. So, if it is not connected properly, then, should I check both the connectors (the one on the actual mirror and the other one behind the door panel?
downtime
Finland
C?ID=280813
There’s no connection for the bsd behind door panel. The mirror connector goes to the door connector directly and from there to BSD module behind the rear bumper.
aswinikumarkj
Cayman Islands
C?ID=599397
Thank you for the clarification
Sorry, I am a rookie here. So please bear with me. So, where do you think I should check the connections? At the door connector (pic attached) and at the back of the mirror?
downtime
Finland
C?ID=280813
That's door module connector. That does not have anything to with blind spot monitoring. The connection is in the mirror and from there it goes directly to the door wiring harness that goes from door to frame of the car. That black rubber grommet between door and frame you see when you open the door. From the car frame side connector the wire goes directly to the BSD module. From driver mirror to driver side module behind the rear bumper and from passenger side to passenger side master module behind the rear bumper
Sorry for not being clear in my first posting. I wrote it from a mobile so not so convinient :D
aswinikumarkj
Cayman Islands
C?ID=599397
Thank you for the reply brother. I see clearly what you mean now. So, where do you think I should start with troubleshooting this issue? I am thinking of first verifying the connection at the back of the mirror, then the connection on the frame side connector. From the online pics that I have seen, these pins cannot be connected in reverse and only go one way but I might be wrong.
I am going to try and remove the mirror over the weekend and verify of those two connections and I will give you an update. I appreciate your assistance.
If the issue only started after whatever fix was performed, re-trace anything that was touched and validate that nothing was fuqd
  • Agree
downtime
Finland
C?ID=280813
I would follow what @Kushdaiin already wrote. Check the that the pins on the mirror connector are correct way around. Then check inside the rubber grommet going from door to frame. VW cars a infamous in destroying and shorting the wiring inside the grommet.
If you have any skills in electronics, you can easily measure the pins from the connector you connect to the mirror that which one is ground and which one is live.
