Fuel Delivery check
senna1
C?ID=231631
Hi All
On vcds for Fuel delivery to run the Fuel pump to do a fuel delivery check or to bleed the system after a fuel filter change
I can only see on vcds output tests for fuel pump lists tests relay, the pump will run but in only short burst , a few seconds where if i want to do a delivery i need approx 30 seconds. i also looked in Basic settings
Monday,04,November,2024,14:08:57:51242
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZ1KZAM089734   License Plate: FULL SCAN FLEMIN
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
   Part No SW: 03L 997 557 M    HW: 03L 906 023 A
   Component: R4 1.6l TDI   H23 9983
   Revision: --H23---    Serial number: 00000000000000 CVN: C9BED9C6
   Coding: 00114014030500080000
   Shop #: WSC 00066 000 00084
   ASAM Dataset: EV_ECM16TDI02103L997557M 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 46DE39F2D82B6F9A257-8012
   VINID: 9E69EAAAA05BA917402091C3100DE55D70
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 133B200D092A0003C81204E7901D0081300000
   Shop #: WSC 00066 000 00000
   VCID: 78A2870AE2DFC96A67B-802C
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   Shop #: WSC 00066 000 00186
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D8CA65E9D1D7CC284D-8038
   Part No SW: 5K0 937 084 B    HW: 5K0 937 084 B
   Component: BCM PQ35 B    011 0028
   Revision: BA011001
   Coding: 08000A3A902DE1E0440000800400002403700088512081605C8000000000
   VCID: 31347A2E4125D822E05-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 18011  21  0512
   Coding: 009795
   Component: RLS 120110 05  54  0402
   Coding: 0330AD
   Component: 2K AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2HNZYV
   Coding: 0012875
   VCID: 3D2C561E817D2C4274D-8068
   Subsystem 1 - Serial number: 6332MSME4E322E5ET
   Subsystem 2 - Serial number: 6342MSME4D257548K
   Subsystem 3 - Serial number: 6351HSME1E2564289
   Subsystem 4 - Serial number: 6361HSME1E436B27G
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0000003
   VCID: 0256E5E2B80393BA49F-8056
Address 17: Instruments
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 081209F2001404
   Coding: E9807F06000202001003
   VCID: 6984D24EA57560E2E85-803C
   Component: IMMO          H05 0308
   VCID: 6A86AD42ACF36BFAE1F-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0308
   Revision: 13101005    Serial number: 0000241745
   Coding: 0002B4
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide_VW32.rod
   VCID: 270094767F6196923E1-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389__TSG-HR  006 1401
   Serial number: 00000004502966
   Coding: 000290
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 31347A2E4D25D822E05-8064
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.8 V
                        PD
                    Temperature: 13.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0308
   Revision: 15101005    Serial number: 0000195946
   Coding: 0002B4
   ROD: EV_DCU52BrosePasseSide_VW32.rod
   VCID: 2802974A727F99EA37B-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004512059
   Coding: 000290
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2I7255606
   Coding: 0500040004
   VCID: 659CDE7E456D4482CCD-8030
End----------(Elapsed Time: 02:06, VBatt start/end: 12.4V/12.4V)-----------
Jef
HQ
Please try Basic Settings IDE00459-Test of transfer fuel pump.
Derek
UK (ilexa)
C?ID=56983
Do you have "Initial fuel filling" in basic settings?
Best regards
Derek
(posted this at the same time as Jef and I'd try his idea first)
senna1
C?ID=231631
I'll Take another look tomorrow , ive used it Before on Vw T5 & Vw caddy van etc but could'nt see it yesterday all i could find was fuel pump relay
test which obviously would trigger the pump but not for long,
senna1
C?ID=231631
Best regards
Derek
Going to re check tomorrow thanks
