2014 Volkswagen 2.0 tdi Jetta Wagon ABS (MK60EC1) Module coding.
jorgecastillo53
GA, USA
C?ID=549457
Good morning, I am in need of some assistance with the abs coding for a 2014 2.0 tdi Jetta wagon. A while ago I swapped in a new motor because the original jumped a tooth on the timing belt. Once I swapped the motor I decided to swap over the ecu, key, and instrument cluster. Prior to me swapping these out I had no issues with the abs. Once the parts were swapped over the abs light and traction light started flashing and would not stop. This is what the latest scan says. Thanks in advance.
Tuesday,05,November,2024,14:01:32:40169
VIN: 3VWPL7AJ0EM614425   License Plate:
Mileage: 478340km-297226mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ0EM614425   Mileage: 478340km-297226miles
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H16---    Serial number:
   Coding: 0050078
   Shop #: WSC 41946 004 1048576
   VCID: 30390289362A9D1AEFB-8064
   VINID: 0E69E070745A01574604410214E3620FDA
011174 - NOx Emissions Exceeded
               P2BA6 - 000 - SCR Catalyst Malfunction
                    Pressure: 980.1 mbar
                    Temperature: 19.8°C
                    Mass Air / Rev.: 1100.0 mg/str
                    Temperature: 33.3°C
006744 - NOx Catalyst
               P1A58 - 000 - Regeneration Required
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 00:00:13
                    Temperature: 19.8°C
                    Temperature: 33.3°C
Readiness: 0 0 0 1 1
   Component: GSG DSG AG6     521 9430
   Revision: 05652104    Serial number: 00001403131603
   Shop #: WSC 52038 001 1048576
   VCID: 1471AE19A272413AEB3-8040
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 0000000000000000000000000000000000000000
   Shop #: WSC 00066 790 00016
   VCID: 7EA5ECB1B0FEBB6A2D7-802A
01486 - System Function Test Activated
                    Reset counter: 192
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:29
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 320
                    Count: 43520
                    Count: 255
                    Count: 256
                    Reset counter: 192
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:29
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 195
                    Count: 43520
                    Count: 255
                    Count: 256
                    Fault Status: 01100101
                    Reset counter: 192
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:29
                    Count: 2
                    Count: 14
                    Count: 16384
                    Count: 212
                    Count: 43520
                    Count: 256
                    Reset counter: 192
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:29
                    Count: 2
                    Count: 14
                    Count: 16384
                    Count: 279
                    Count: 43520
                    Count: 256
                    Reset counter: 192
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:29
                    Count: 2
                    Count: 14
                    Count: 16384
                    Count: 270
                    Count: 43520
                    Count: 256
                    Reset counter: 192
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:29
                    Count: 2
                    Count: 14
                    Count: 16384
                    Count: 291
                    Count: 43520
                    Count: 256
   Part No SW: 7N0 907 426 CA    HW: 7N0 907 426 CA
   Component: AC Manuell    H20 0606
   Revision: 00001002
   Coding: 0010002002
   Shop #: WSC 00066 000 00121
   VCID: 75B7F39D8548F8327CD-8020
   Part No SW: 5K0 937 084 N    HW: 5K0 937 084 L
   Component: BCM PQ35 B    122 1184
   Revision: BG122001
   Coding: AF380E1A802F3EC4008800C17000004449000086535D0520648020200040
   Shop #: WSC 28982 003 1048576
   VCID: 3D272BBDFD78607274D-8068
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 27021  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R02VCU1   Dataset Number: 1KM003v__B_ 0047
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C2126B9E6E2697A433-8068
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00009VFL00
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME42124C41ZZZN
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME3A144C41ZZZX
   Serial number: 3511HSME3B5E1F30ZZZX
   Serial number: 3521HSME54091F30ZZZJ
   Serial number: 35527SME08480F30ZZZE
   Serial number: 35627SME01470F30ZZZ7
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440NE6000SJ Dataset Number: 5K0953507AH D005
   Coding: 188A140000
   Shop #: WSC 00066 790 00014
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5F491984EF32A757-8022
   Serial number: 0407317 FLE 20140104
   Coding: 820000
   Part No SW: 5K0 920 973 G    HW: 5K0 920 973 G
   Coding: 270F01
   Shop #: WSC 00066 000 00119
   VCID: 3537339DC5C8B832BCD-8060
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 22021403000155
   Coding: 352002
   VCID: 79AFFFADA9D09C52185-802C
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RPN4C07
   Coding: 0000002
   VCID: 7EA5ECB1BCFEBB6A2D7-802A
   VCID: 6A8DD0E1DCF627CAE1F-803E
Address 2E: Media Player 3
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0007984333
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE3852503AC4E426A9-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1509
   Serial number: 00000008491763
   Coding: 000490
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F3FADE5505C52585-806C
                    Fault Status: 11100101
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:28
                    Battery Volts: 12.2 V
                        DD
                    Temperature: 34.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0007930911
   Coding: 0004B4
   VCID: 5CE1863906A2497A633-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1509
   Serial number: 00000008103432
   Coding: 000490
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H07 0009
   Revision: -----12S    Serial number: VWZ4Z7P3571544
   Coding: 01000440040007
   Shop #: WSC 00066 000 00000
   VCID: 2B0315E5130CFEC2DA9-807E
                    Reset counter: 192
                    Mileage: 478349 km
                    Date: 2019.03.29.
                    Time: 01:03:47
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007665727718 Dataset Number: 5N0035729A  0001
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E051CF1209E8BEAFD7-807A
End----------(Elapsed Time: 01:15, VBatt start/end: 13.8V/13.9V)-----------
EuroX
Northern NJ USA
C?ID=208579
I can assist with coding for a small fee if you don't have the old coding.
jorgecastillo53
GA, USA
C?ID=549457
Hey thanks for the quick reply. How much would you charge? I lost the original code from the module.
Spacewalker
Poland
C?ID=159607
no comments ......
people spend months to make LC helper LBL file , they did looooooot of work in XLS to analize VIN, engine type , ABS sensors and many many more
and they share that for free a years ago
EuroX
Northern NJ USA
C?ID=208579
no comments ......
No comments?? You commented.What is your point? If they want it for free then they can learn to calculate it themselves and learn all the vin specific bytes and so on. OP can gladly wait for someone to calculate correct coding for them free of charge if not in a rush. If they need it now there is a price to pay which is still a tiny fractiong of a tow or a trip to the dealer.
You can go right ahead and calculate the correct coding for the OP then? Please do I'll tell you if your close or not.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I can only try: B14B400C492300FE8D0F02E6921E0042A1180012
It may be accepted, but I do not guarantee accuracy.
I am sure of the string length and VIN bytes. The rest are not available to me for NAR models.
EuroX
Northern NJ USA
C?ID=208579
Nope not correct sorry.
Spacewalker
Poland
C?ID=159607
did you ever seen EOL offociall VW coding helper ....
let go back to 2014 ....2015 ... show me you post from 2015 how you offer MK60EC1 coding , show me your engagement into that
EuroX
Northern NJ USA
C?ID=208579
No I have never seen that nor would I bother with that when coding can be calculated if you know what options the vehicle has and the vin but nice try.
Is this the actual VIN to the car:
3VWPL7AJ0EM614425
.. or the VIN from the Immo system donor car?
EuroX
Northern NJ USA
C?ID=208579
Above Coding is correct for original vin. I provided correct coding for original and donor via pm to OP.
