Incorrect Can Gateway - 2013 VW CC
KluelessInCali
California, USA
C?ID=573758
Please help. It appears that I purchased the incorrect CAN Gateway for my vehicle. Can someone please tell me what the correct one is? The current module I have installed is the: 7N0 907 530 M.
Here is the complete scan for the vehicle:
Tuesday,05,November,2024,12:40:22:33210
VIN: WVWBP7AN2DE511788   License Plate:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 1C 20 25 2E 32 3D 40 42 44 46
          47 4F 52 53 56 5D 61 62 63 65 6D 72 77 A5 A6
VIN: WVWBP7AN2DE511788   Mileage: 260690km-161985miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Not registered 0001
20-High Beam Assist. -- Status: Cannot be reached 1100
32-Differential Locks -- Status: Cannot be reached 1100
3D-Special Function -- Status: Cannot be reached 1100
40-AC Compressor -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
5D-Operations -- Status: Cannot be reached 1100
63-Entry Assist,D -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Cannot be reached 1100
A6-Microphone -- Status: Cannot be reached 1100
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 06J 906 027 FD    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 06 3951
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 040401081C070160
   Shop #: WSC 05314 000 00000
   VCID: 72BDCDDB48A73A3A59F-8026
   VINID: 9E69D280745E0945450411C8202A1F02E2
11 Faults Found:
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -
                    RPM: 718 /min
                    Load: 19.6 %
                    Temperature: 54.0 C
                    Temperature: 33.0 C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 44
                    RPM: 752 /min
                    Load: 18.0 %
                    Temperature: 55.0 C
                    Temperature: 33.0 C
                    Voltage: 13.843 V
001287 - Idle Control System RPM
               P0507 - 000 - Higher than Expected. - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 149
                    RPM: 1035 /min
                    Load: 11.8 %
                    Temperature: 96.0 C
                    Temperature: 24.0 C
                    Voltage: 13.970 V
004506 - Fuel Pressure Sensor (G247)
               P119A - 000 - Malfunction - MIL ON
                    RPM: 773 /min
                    Load: 11.0 %
                    Temperature: 96.0 C
                    Temperature: 34.0 C
                    Voltage: 13.843 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 000 -  - MIL ON
                    Mileage: 197379 km
                    Date: 2000.12.01
                    Time: 16:12:06
                    RPM: 893 /min
                    Load: 11.4 %
                    Speed: 3.0 km/h
                    Temperature: 97.0 C
                    Temperature: 38.0 C
                    Voltage: 13.716 V
               P0300 - 000 -
                    Fault Frequency: 56
                    RPM: 814 /min
                    Load: 11.4 %
                    Temperature: 107.0 C
                    Temperature: 60.0 C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.335 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected
                    Fault Frequency: 56
                    RPM: 814 /min
                    Load: 11.4 %
                    Temperature: 60.0 C
                    Voltage: 13.335 V
               P0299 - 000 - Control Range Not Reached - MIL ON
                    Date: 2028.05.24
                    Time: 23:07:34
                    RPM: 2270 /min
                    Load: 73.3 %
                    Speed: 113.0 km/h
                    Temperature: 94.0 C
                    Temperature: 47.0 C
                    Voltage: 13.589 V
               P2015 - 000 - Implausible Signal - Intermittent
                    Fault Frequency: 19
                    Mileage: 1118481 km
                    Date: 2004.04.08
                    Time: 17:04:34
                    RPM: 2414 /min
                    Load: 49.0 %
                    Speed: 121.0 km/h
                    Temperature: 94.0 C
                    Temperature: 27.0 C
                    Voltage: 13.843 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    RPM: 916 /min
                    Load: 28.2 %
                    Temperature: 74.0 C
                    Temperature: 45.0 C
                    Voltage: 13.589 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    RPM: 895 /min
                    Load: 15.3 %
                    Temperature: 69.0 C
                    Temperature: 38.0 C
                    Voltage: 13.970 V
Readiness: 0000 0001
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3505
   Revision: 05551213    Serial number: 00001205080131
   Shop #: WSC 05311 000 00000
   VCID: 2517E687C9E91D820CD-8070
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V43F 0024
   Revision: --H07---    Serial number: 00000005746787
   Coding: 0004495
   VCID: 71BFC2D74DA10122A05-8024
03366 - Vacuum Sensor
                    Fault Status: 00101001
                    Reset counter: 102
                    Mileage: 258872 km
                    Date: 2019.03.29.
                    Time: 14:18:45
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.50 V
                    Bin. Bits: 10011111
                    Count: 137
                    Hex Value: 0x0000
                    Reset counter: 62
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 62
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0202
   Revision: 00001K01
   Coding: 0010001008
   Shop #: WSC 00015 115 00000
   VCID: 7CA1E3E316637C4A033-8028
Address 09: Cent. Elect.
Address 10: Park/Steer Assist
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__713 VW10 HI   2118
   Revision: 24017000    Serial number: 003LDP97GNK8
   Coding: 0012595
   VCID: 4EC5792BFCDF3EDA9D7-801A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 00000000008JRQ
   Subsystem 3 - Serial number: 0005.04.120000300000660088  63
   Subsystem 4 - Serial number: 660088  6332MTS636651162   63
   Subsystem 5 - Serial number: 51162   6342MTS649981172   63
   Subsystem 6 - Serial number: 81172   6351HTS6H6832BKJ   63
   Subsystem 7 - Serial number: 32BKJ   6361HTS6E1K52BKR   63
   Subsystem 8 - Serial number: 52BKR   63727TS6N4GE2BKJ   63
   Subsystem 9 - Serial number: E2BKJ   63827TS6U6GE2BKR
   Subsystem 10 - Serial number: E2BKR
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Mileage: 247108 km
                    Date: 2019.03.29.
                    Time: 09:25:47
   Part No SW: 5K0 953 569 AR    HW: 5K0 953 569 AR
   Revision: --X01---    Serial number: 20150825301288
   Coding: 7982410000
   Shop #: WSC 01286 386 08256
   VCID: 08498F3352BB20EA17B-805C
   Component: E221__MFL-TK6  H07 0022
   Serial number: 10000000000000177545
   Coding: E20000
226839 - Turn Signal Switch
          B1144 11 [00001001] - Short to Ground
                    Reset counter: 62
                    Mileage: 242838 km
                    Date: 2024.11.05.
                    Time: 19:50:28
          B1149 13 [00001001] - Open Circuit
                    Reset counter: 62
                    Mileage: 242838 km
                    Date: 2024.11.05.
                    Time: 19:50:28
715535 - Cruise Control Switch
          B1154 96 [00001001] - Component Internal Failure
                    Reset counter: 62
                    Mileage: 242838 km
                    Date: 2024.11.05.
                    Time: 19:50:28
   Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
   Component: KOMBI         H05 0705
   Coding: 240F00
   Shop #: WSC 05314 115 00000
   VCID: 2C0113A3A6832CCAD33-8078
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Steuerger t f r Reifendruck berwachung: keine Kommunikation]
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2024.11.05.
                    Time: 10:56:46
13649664 - Function Restricted due to Missing Message(s)
          [Steuerger t f r Heckdeckelelektronik: keine Kommunikation]
                    Reset counter: 62
                    Mileage: 247165 km
                    Date: 2024.11.05.
                    Time: 10:56:46
12671232 - Function Restricted due to Missing Message(s)
          [Steuerger t f r Einparkhilfe: keine Kommunikation]
                    Reset counter: 164
                    Mileage: 247108 km
                    Date: 2024.11.05.
                    Time: 09:25:30
13635328 - Function Restricted due to Missing Message(s)
          [Steuerger t f r Sonderfahrzeuge: keine Kommunikation]
                    Reset counter: 62
                    Mileage: 247165 km
                    Date: 2024.11.05.
                    Time: 10:56:46
13648640 - Function Restricted due to Missing Message(s)
          [Steuerger t f r LaneDepartureWarning: keine Kommunikation]
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2024.11.05.
                    Time: 10:56:46
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 141111F2001393
   Coding: 004003
   VCID: 3A2D25FB5C57827A51F-806E
19 Faults Found:
                    Fault Status: 01110100
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:48
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:48
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:52
00483 - Control Module for Auxiliary Air Heater
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:49
00380 - Special Vehicle Control Module (J608)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:48
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:52
01302 - Control Module for Telematic (J499)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:52
02649 - Digital Radio Tuner
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:52
                    Mileage: 247108 km
                    Date: 2019.03.29.
                    Time: 09:25:29
02749 - Control Module / Control Head for Telephone (J738)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:49
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:52
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 164
                    Mileage: 247108 km
                    Date: 2019.03.29.
                    Time: 09:25:30
02010 - Left Entry Assistance Control Module (J572)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:48
02011 - Right Entry Assistance Control Module (J573)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:48
02874 - Control Module 2 for Central Convenience (J773)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:48
02054 - Control Module for Differential Locks (J647)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:48
00317 - Rear Lid Control Module (J605)
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:49
03395 - Control Module for High Beam Assistant
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 11:19:25
03753 - Control Module for Microphone
                    Reset counter: 166
                    Mileage: 247165 km
                    Date: 2019.03.29.
                    Time: 10:56:52
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128R33R103
   Coding: 0000002
   VCID: 75B7F6C739C92D027CD-8020
Address 20: High Beam Assist.
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0400
   VCID: 372B3CCF63459F12AE1-8062
   Revision: A1001003    Serial number: 7662448961
   VCID: 290FEAB7A9F139E2285-807C
Address 32: Differential Locks
Address 3D: Special Function
Address 40: AC Compressor
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0551
   Revision: 12110009    Serial number: 0004934272
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X_VW46.rod
   VCID: 6D87DEA75D19E5C284D-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002912860
   Coding: 010490
68105 - Function Restricted due to Missing Message(s)
          [Front CAN MFG]
                    Reset counter: 204
                    Mileage: 245494 km
                    Date: 2024.11.05.
                    Time: 14:05:48
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.302 1101
   Revision: 1AH03735    Serial number: 00121180325901
   Coding: 0000258
   VCID: 3D272EE74179B54274D-8068
   Component:    KSG PQ47 ELV 042 0634
   Coding: 1B910F8001862E521204141FF08A0F0E105801
   Shop #: WSC 05311 000 08193
                    Reset counter: 204
                    Mileage: 245494 km
                    Date: 2019.03.29.
                    Time: 14:52:53
Address 47: Sound System
Address 4F: Centr. Electr. II
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0551
   Revision: 14110009    Serial number: 0004945512
   Coding: 0004B6
   VCID: 6E85D9AB501F1EDABD7-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002901880
   Coding: 010490
          [Front CAN MFG]
                    Reset counter: 204
                    Mileage: 245494 km
                    Date: 2024.11.05.
                    Time: 14:05:48
   Revision:   H19       Serial number: 00000000203891
   Coding: 0022156
   VCID: 363531CB644F661AB57-8062
                    Fault Status: 00111101
                    Reset counter: 2
                    Mileage: 259438 km
                    Date: 2019.03.29.
                    Time: 14:49:21
                    Voltage: 13.50 V
                    Count: 103
                    Speed: 56.0 km/h
                    Hex Value: 0x1261
                    Hex Value: 0x0024
                    Hex Value: 0x0101
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H04 0007
   Revision: -----08S    Serial number: VWZ4Z7M1118430
   Coding: 0100040004000F
   VCID: 6491BB838E53A48ADB3-8030
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 164
                    Mileage: 247108 km
                    Date: 2019.03.29.
                    Time: 09:25:31
Address 5D: Operations
Address 61: Battery Regul.
Address 63: Entry Assist,D
Address 65: Tire Pressure
Address 6D: Trunk Elect.
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007662528894 Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2D25FB5CD7827A51F-806E
Address A5: Frt Sens. Drv. Assist
Address A6: Microphone
End----------(Elapsed Time: 01:47, VBatt start/end: 13.9V/13.9V)-----------
Jef
HQ
For WVWBP7AN2DE511788, from what I can tell the original J533 module was part number 7N0 907 530 AA and as per PL24, the new replacement part number is 7N0 907 530 AN.
Note that these part numbers also have an "index code", a hidden part number of sorts:
  • /Z00
  • /Z01
  • /Z02
  • /Z03
As per PL24, the complete replacement part number is 7N0 907 530 AN Z00. If going with a used original part number, 7N0 907 530 AA, I don't think I'd be too worried about the index code since it is basically for cars without driver alert system... none of those cars in NAR came with that feature.
Just FYI, the ABS module is fine, but confused... don't worry about it.
ST?ID=114372
siLc
Tallinn, Estonia
C?ID=330192
What makes you think the current CAN gateway is wrong?
Look at all the stuff "cannot be reached" - this CC obviously doesn't have these. You can remove them from the CAN gateway installation list. This goes for any second-hand CAN gateway you buy.
Only caveat is those vehicles with ACC - those need the CAN gateway to have the CAN Extended bus. Not all 7N0 CAN gateways have this. The aforementioned 7N0907530AN is an universal replacement and it has it.
