Resolved Audi Q5 8R MY10 and automatic transmission adaptation problem
Resolved
V3lmu
Oulu, Finland
C?ID=229426
Hey!:)
Car info:
Audi Q5 8R MY2010
2.0 TDI Quattro (CAHA)
S-Tronic (0B5)
The owner of the car has changed to a transmission parts: dual mass flywheel and dual wet clutch.
These parts have been replaced because the car jerked and a vibration was felt when the car started moving or when the car stopped.
Now that the parts have been replaced, I assume that the transmission needs to be taught the values again so that the transmission works smoothly.
I checked the auto-scan log for information about the gearbox and found the information: 0B5. I tried using the instructions in this link to adapt the gearbox, but it crashes with an error message.
I tried to adjust the gearbox when the car was cold or warm (driven +50km) but it didn't work. I tested VCDS 24.9.1 beta and 24.7.1, but same result..
Can the adaptation fail because the software version of the gearbox is too old?
Auto-Scan log:
Tuesday,05,November,2024,19:24:11:00464
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4656.4
Dealer/Shop Name: J.P - V3lmu
VIN: WAUZZZ8R3BA013811   License Plate: AUDI Q5 -10
Mileage: 241500km-150061mi   Repair Order: 1. kierros - 5.11.24
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 42 46 52 53 55 56 62 6D
          72
VIN: WAUZZZ8R3BA013811   Mileage: 241500km-150061miles
Address 01: Engine (J623-CAHA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 019 AS    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H05 9977
   Revision: 11H05---    CVN: C0AF04B1
   Coding: 01210023241F2120
   Shop #: WSC 36754 001 1048576
   ASAM Dataset: EV_ECM20TDI03L906019AS A01011
   ROD: EV_ECM20TDI03L906019AR.rod
   VCID: 7CA1F4E7C66B7AEA033-8028
   VINID: 9D196AAAA2220D244004320104A722779B
7859 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [10101111] - Implausible Signal
                    Fault Frequency: 9
                    Mileage: 241387 km
                    Date: 2024.10.31
                    Time: 08:04:35
                    Engine RPM: 0.00 /min
                    Coolant temperature: 59  C
                    Intake air temperature: 5  C
                    Voltage terminal 30: 13.240 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Accelerator position: 0.00 %
                    V Sw Vlv r Drft Opn mp: 11.79 %
                    V Sw Vlv r Drft Clsd mp: 7.56 %
                    V Sw Vlv u Raw: 391.8 mV
                    V Sw Vlv st Mon-Bits 0-7: 0
Readiness: 1 1 0 0 0
   Part No SW: 8R0 927 156 R    HW: 0B5 927 156 F
   Component: 0B5 20 TDIRdW H05 0004
   Revision: --H05---    Serial number: 0000001608 CVN: 00009E06
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 4ACD623FDC3F145AC1F-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
   Component: ESP8 quattro  H06 0100
   Coding: 0D5548
   VCID: 45D75103F5A1FB222CD-8010
   Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
   Component: BCM2 2.0      H04 0430
   Coding: 010500
   VCID: 015F8513A1091702505-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H50 0071
   Serial number: 0510000041781021
   Serial number: 0210000117041009
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 192
                    Mileage: 241339 km
                    Date: 2024.10.28
                    Time: 18:58:10
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A1000000    Serial number: 01190620101137
   Coding: 34090000
   VCID: 7DA7F9E3DDF173E234D-8028
   Component: BCM1 1.0      H29 0392
   Revision: 10029001    Serial number: 00000000577038
   Coding: 2600D0914034AF010001000300001D0D001C470802010101000000
   VCID: 3C2134E7866BBAEA433-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 100617  H10 0041
   Serial number: 90243014100614150616
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10967488
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002306102282
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941018100548
   Coding: 100105
   VCID: 48C95837C2B3E64AD7B-801C
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 E    HW: 8R0 959 655 E
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GND0GEHX6   Dataset Number: 8R0909602D  0001
   Coding: 30423331313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 46D5560FC827F03A257-8012
   Serial number: 6334MSME5601295DE
   Serial number: 6344MSME55044D4DM
   Serial number: 6352QSME27693F26R
   Serial number: 6362QSME2468270AH
   Serial number: 63732SME53653C20Z
   Serial number: 63832SME5165540E/
   Part No SW: 8K0 953 568 E    HW: 8K0 953 568 E
   Revision: --------    Serial number: 90304JFB000MO
   Coding: 000007
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 B    HW: 8R0 920 931 B
   Component: KOMBIINSTR.   H12 0258
   Revision: 00000000    Serial number: EK1224P6A
   Coding: 0F06220002000008010000
   VCID: 34311CC7AE3B72AA8B3-8060
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 192
                    Mileage: 241321 km
                    Date: 2024.10.28
                    Time: 18:13:50
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 A    HW: 4H0 265 105 A
   Component: Standheizung  H20 0230
   Revision: 34003004    Serial number: 20100621235608
   Coding: 5D4000
   VCID: 2019E0970AC3FE0A7FB-8074
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G106148380
   Coding: 00C303
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650211224
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000106066049
   Coding: 011002205000440004
   VCID: 4ACD623FDCBF145AC1F-801E
   Revision: 00002001    Serial number: 0132042712
   Coding: 0100062020B930808420053280000000
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000105986305
   VCID: 49CF5D33D9B91F42C85-801C
   Revision: 00000003    Serial number: 00000000678481
   Part No: 8K0 907 357 D
   Coding: 0000006
   VCID: 363526CFB44760BAB57-8062
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H07 0350
   Revision: 00000011    Serial number: AUZ5Z6J1425827
   Coding: 0500048004050100055B070000
   VCID: 44D14C07FE9BC22A3B3-8010
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000106019189
   Coding: 010002204000240004
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H50 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B2337FB8365BDD24A9-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H50 0330
   Serial number: 8R0827852B
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000106019186
End----------(Elapsed Time: 01:22, VBatt start/end: 14.1V/14.5V)-----------
Not all TCMs support the Erase counter for start and stop processes step so it isn't uncommon to receive the error but the engine running steps:
Clutch valve calibration
and
Distance sensor calibration
... are always supported and they need to finish correctly. Did those report errors as well?
Edit. This car has PR-Code 7L7 Regenerative braking with 12.5 V but it doesn't have start/stop. That explains why the first basic settings resulted in error. I'll edit that Wiki page to make it less confusing. :thumbs:
V3lmu
Oulu, Finland
C?ID=229426
Not all TCMs support the Erase counter for start and stop processes step so it isn't uncommon to receive the error but the engine running steps Erase counter for start and stop processes and Distance sensor calibration are always supported and they need to finish correctly. Did those report errors as well?
I tried once that I skipped the first part of this. It started to do the 2nd function, but ended with the message: Aborted|Safety reason.
I firstly want to mention that I spotted a copy and paste failure in my earlier reply and edited post #2.
If it failed on the Clutch valve calibration step you may be able to obtain additional information by firstly having these Advanced Measuring Values pulled up before starting the Basic Settings:
[*ENG103018-ENG188701*] Current Test Routine
[*ENG107524-ENG104213*] M045_Grd_AbbruchCode - Abbruch Grunde
Additionally, if there were any fault codes in older Auto-Scans they may provide clues about any other issues with this transmission.
In regards to the software level it does look like several flash updates applied over the years:
If you can get it flash updated from SWL 0004 to the latest version 0015 that would be ideal. In that case I would use the test plans in ODIS as well to see if it can calibrate the transmission (or not).
V3lmu
Oulu, Finland
C?ID=229426
Okay. The point is clear. I'm going to test this and report back when I figure things out.
V3lmu
Oulu, Finland
C?ID=229426
We finished this today. And it works. :)
1. We updated the controller software. (0004->0015)
2. Use these instructions to adjust the gearbox. The car does not have a start/stop function. The first part of the instructions was skipped.
3. Test drive. No fault codes appeared after the test drive, so the task was completed successfully.
Thanks DANA :thanks:
