Audi Q5 Going into limp mode
Adrian Fuller
C?ID=156708
Hi all looking for a bit of help, I have recently travelled through spain and while driving some of the mountain/hilly roads my car tripped into limp mode, this was when I was on some of the more mountainous duel carriageways. As the car had previously gone into limp mode on my outbound journey I was trying to keep speed and demand for power at a minimum and discovered that at 100 kph I had no issues however when above 103 kph the car went into limp mode and I believe it was as traveling up hill although it only happened on a couple of occasions. I have had the car mapped about two years ago and have not had this issue in the uk....yet. The message on the dash when going into limp mode was Drive system fault. Any help on how to test the suspect sensors See code below) would be very much appreciated.
Many thanks in advance
Tuesday,05,November,2024,18:14:22:55696
VIN: WAUZZZFYXH2023118   License Plate: SA17
Mileage: 68116km-42325mi   Repair Order: scan at home after spain trip
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 22 29 2B 39 42 44 46 52 5F 69 6C
          6D 81 82 A5 AC BB BC D6 D7
VIN: WAUZZZFYXH2023118   Mileage: 68116km-42325miles
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 CE    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H34 6648
   Revision: B1H34---    CVN: 14B6028C2CBF6FC9B866C2AD
   Coding: 2A654032253605083408
   Shop #: WSC 40374 005 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026CE 005007
   ROD: EV_ECM20TDI01104L906026CE_005.rod
   VCID: 6FBBC09217109572B61-803A
   VINID: 9D196AAAA5A9A180800830412076897E14
19225 - Boost Pressure Regulation
          P0299 00 [01100000] - Control Range Not Reached
                    Mileage: 67139 km
                    Date: 2024.10.30
                    Time: 13:21:38
                    Engine RPM: 2048.00 /min
                    Normed load value: 37.6 %
                    Vehicle speed: 103 km/h
                    Coolant temperature: 90  C
                    Intake air temperature: 126  C
                    Ambient air pressure: 910 mbar
                    Voltage terminal 30: 12.880 V
                    Charge air pressure: specified value: 2909 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2235.0 hPa
                    Mass airflow sensor 1 bank 1 airflow: raw value: 993.3 mg/stroke
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.02 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.18 %
                    Turbine actuator 1 bank 1: posit.feedback - Actual value: 90.52 %
                    Mean injection quantity: 22.17 mg/stroke
25710 - Boost Pressure Regulation
                    Mileage: 67139 km
                    Date: 2024.10.30
                    Time: 13:21:38
                    Engine RPM: 2048.50 /min
                    Normed load value: 74.1 %
                    Charge air pressure: specified value: 2910 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2234.2 hPa
                    Mass airflow sensor 1 bank 1 airflow: raw value: 994.5 mg/stroke
                    Mean injection quantity: 45.18 mg/stroke
23753 - No Communication with Towing System Control Module (J345)
          U1003 00 [00100000] - -
          [Towing recognition control moduleNo Communication]
                    Mileage: 66966 km
                    Date: 2024.10.27
                    Time: 13:12:07
                    Engine RPM: 843.00 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 59  C
                    Intake air temperature: 43  C
                    Voltage terminal 30: 11.240 V
                    Unlearning counter according OBD: 36
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    selected gear-Bits 0-7: 0
   Part No SW: 80A 927 155 B    HW: 0CJ 927 156
   Component: 0CJ 20TDI RdW H03 0003
   Revision: --H03---    Serial number: 0000000329 CVN: 301AFEB1
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 2809EB8EF27E824A37B-807C
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071170009000386
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 80A 907 379 E    HW: 80A 907 379
   Component: ESP9 Plus     H07 0657
   Dataset Number: 80B909504L  0002 CVN: C561A5BE
   Coding: 14AA48BE28A40A99919F589220855292E6A5D228121450891A044A4967A54B
   ASAM Dataset: EV_ESP9BOSCHAU426K 011013
   ROD: EV_ESP9BOSCHAU426K.rod
   VCID: 313F06EAC1A4C382E05-8064
475904 - Databus
          U1121 00 [00101000] - Missing Message
          [ComScl:_PDU_Licht_hinten_01-_Timeout_error]
                    Mileage: 67905 km
                    Date: 2024.10.31
                    Time: 17:01:03
                    8F 40 80 01 88 24 00 00 00 00
494080 - Comfort Control Module
          C1254 F0 [00101000] - Brake Light Signal Implausible
                    Mileage: 67905 km
                    Date: 2024.10.31
                    Time: 17:01:03
                    90 40 80 01 88 24 00 00 00 00
   Part No SW: 80A 820 043 G    HW: 80A 820 043 G
   Component: Klima Zone 3  H32 0090
   Coding: 641800295544450D02000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 211FF6AA91447302705-8074
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0003
   Serial number: 00000000000001205433
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 66F8046880PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
327971 - Motor for Fresh Air / Recirculated Air Flap
          B11AF 07 [00001000] - Mechanical Failure
                    Reset counter: 119
                    Mileage: 66985 km
                    Date: 2024.10.30
                    Time: 11:43:10
                    Fresh-air door motor / specified value: 9699
                    Fresh air flap motor: actual value: 11196
                    System run time-Engine running time: 145 s
                    System run time-Terminal 15 on: 147 s
                    Fresh air flap motor: diagnostic-Last operating state: No routine started
                    Fresh air flap motor: diagnostic-Operating condition: Blocking handling
                    Voltage terminal 30: 14.48 V
                    Outside temperature: 23.00  C
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 80B909514C  0024
   Coding: 07501143C13900CD0545511897BF80F9110B3108000000000000000020001C810A450222025605
   VCID: 025D99263482881A49F-8056
   Subsystem 1 - Part No SW: 80C 955 119     HW: 80C 955 119
   Component: 426 RL 170202  040 0570
   Serial number: 00000001701312105324
   Coding: 5FC7F7
   Serial number: 20185065X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 27 02 2017  70580034
   Serial number: GX1CE109021723610230
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 G    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00005667
   Coding: 0D0104
   Subsystem 6 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000030346005
66332 - Reading Lamp; 3rd Row Left
          B14F7 01 [00001000] - Electrical Failure
                    Reset counter: 122
                    Mileage: 66984 km
                    Date: 2024.10.29
                    Time: 19:40:13
                    average_Voltage_terminals: 12.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 22.50  C
                    interior_temperature: 25.00  C
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM00NUJB Dataset Number: 80A909602G  0012
   Coding: AACCF0C00C800000585400FFF08C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   VCID: 3E252DD600FA2CFA6D7-806A
   Subsystem 1 - Part No SW: -----------    HW: 480 001 401 17
   Serial number: 357000000001C411F028
   Subsystem 2 - Part No SW: -----------    HW: 480 001 301 17
   Serial number: 3580000000090794C02G
   Subsystem 3 - Part No SW: -----------    HW: 480 031 512 16
   Serial number: 351000C1C314D900CE48
   Subsystem 4 - Part No SW: -----------    HW: 480 031 512 16
   Serial number: 352000C1C500AD714D8A
   Subsystem 5 - Part No SW: -----------    HW: 480 030 401 17
   Serial number: 355000C1CD2C9130596C
   Subsystem 6 - Part No SW: -----------    HW: 480 030 401 17
   Serial number: 356000C1C505EDA06FEZ
   Subsystem 7 - Part No SW: -----------    HW: 480 030 602 17
   Component: PedP_Sensor_C  002 0149
   Serial number: 230000C1CBC971D0DBEZ
   Subsystem 8 - Part No SW: -----------    HW: 480 002 712 16
   Serial number: I0M00000000847597E9H
   Subsystem 9 - Part No SW: -----------    HW: 480 002 712 16
   Serial number: I0N000000007A730CE9H
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 101 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C1230E743C62N
   Part No SW: 80A 907 129 AC    HW: 80A 907 129 AC
   Component: Lenks.Modul   H02 0003
   VCID: 698FAE8A29F47B42E85-803C
   Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
   Component: FBenRDW       H15 0307
   Coding: 24A48DD4A88006000123E9601000600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 42DD59267402481A09F-8016
   Part No SW: 8W5 907 468 D    HW: 8W5 907 468 C
   Component: Gateway       H30 0308
   Revision: 5A010004    Serial number: 0485A038816C28 Dataset Number: 80B909515C  0037
   Coding: 03010001000086404107000000590032C8320007100000000175078E10000000
   GVL: 01D03C0808040200C08C08000002C80000080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4ACD71064C32905AC1F-801E
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20161221094224 00489
   Serial number: 1863344900
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 80A 927 755     HW: 0CJ 927 749
   Component: Q5_DL3_N_SD4  H01 0004
   Serial number: 1620316778
   Coding: 01070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 6C81D79E26066E6A933-8038
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H06 0016
   Dataset Number: 80B909519B  0008
   ASAM Dataset: EV_LCMLeftCONTIAU426 001008
   VCID: 303903EECAAECA8AEFB-8064
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000258025018
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 323D09E6C4A2F89A99F-8066
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 80B909520B  0008
   ASAM Dataset: EV_LCMRightCONTIAU426 001008
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1QBK00729 Dataset Number: 80B909872A  0023
   Coding: 001D9A014001040000001082
   VCID: 08498B0E12BEA24A17B-805C
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000504395 Dataset Number: 80B909852F  0019
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34310FFE3EB6F6AA8B3-8060
   Part No SW: 8W0 907 064 CP    HW: 8W0 907 064 P
   Component: BCM2 MLBevo   018 0344
   Dataset Number: 80B909501B  0020
   Coding: 013500002F9100406301A0000E00D80233034010004306502F0000000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 0C41B71E06C6CE6A333-8058
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY16308354V
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000067356187
   Subsystem 3 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58016265
65642 - Response Closing Status of Drivers Door
          B1468 F0 [00001000] - Implausible
                    Reset counter: 110
                    Mileage: 66508 km
                    Date: 2024.10.06
                    Time: 18:03:55
                    Supply voltages-Terminal 30 power supply: 12.392 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.337 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.365 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0  C
                    general_additional_freeze_frame-interior_temperature: -50.0  C
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 4A 12 04 98
                    zv_engine_lwr_rear_wiper_freeze_frame: 11110000 00100111 00000000 00000000
65644 - Rear Driver Side Door Closing Status
          B1800 F0 [00001000] - Implausible
                    Reset counter: 110
                    Mileage: 66884 km
                    Date: 2024.10.20
                    Time: 09:31:40
                    Supply voltages-Terminal 30 power supply: 12.555 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.500 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.528 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 06 80
131120 - Remote key 1
          B1479 18 [00001000] - Current Too Low
                    Reset counter: 97
                    Mileage: 66532 km
                    Date: 2024.10.09
                    Time: 12:18:05
                    Supply voltages-Terminal 30 power supply: 12.500 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.446 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.486 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 98
                    key_error_freeze_frame: 01001111 11111111 11111111 11111111
65907 - Alarm Horn / Siren for Anti-Theft System
          B131D 29 [00001000] - Signal Implausible
                    Reset counter: 120
                    Mileage: 66025 km
                    Date: 2024.09.19
                    Time: 14:10:25
                    Supply voltages-Terminal 30 power supply: 12.609 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.555 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.582 V
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1QC3006V3 Dataset Number: 80B909873C  0032
   Coding: 001D8A014001040000001000
   Shop #: WSC 11335 004 1048576
   VCID: 074B88321FA0AD321E1-8052
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035     HW: 8W5 035 035
   Component: MU-P-LND-EU   033 0917
   Serial number: A829C0H9183951 Dataset Number: 80B909545D  0019
   Coding: 01240601FF0A000053111101000A00332F0015E7017001009E
   VCID: 74B1CFFE7E36B6AA4B3-8020
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Multimedia System 1:
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL00LQJ
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 13011700000000000042
   Compact disc data bank:
   Component: Gracenote2  --- 1015
3084 - GSM antenna 2
          B1533 13 [00001000] - Open Circuit
                    Fault Frequency: 20
                    Reset counter: 120
                    Mileage: 65604 km
                    Date: 2024.09.03
                    Time: 14:41:41
                    Voltage terminal 30: 13.2 V
3086 - Antenna for Telephone Mount
          B1564 01 [00001000] - Electrical Failure
                    Fault Frequency: 36
                    Reset counter: 122
                    Mileage: 66426 km
                    Date: 2024.10.02
                    Time: 11:31:07
                    Voltage terminal 30: 13.1 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: ConWysTrailer H20 0211
   Serial number: 0384670490
   Coding: 0100000202000000
   VCID: 33330CE23BB8F192929-8066
   Component: RVC Compact   H12 0240
   Dataset Number: 80B909460F  0007
   Coding: 0224060102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number:                Dataset Number: 80B909541C  0009
   Coding: 07B0
   Shop #: WSC 00047 210 12345
   ROD: EV_DeckLidCONTIAU736_VW48.rod
   VCID: 48C94B0E523E624AD7B-801C
   Part No SW: 80C 713 041 E    HW: 80C 713 041 E
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20170224000607
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 2019F3AE9A4E7A0A7FB-8074
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 80A 919 617 A    HW: 80A 919 617 A
   Component: HeadUpDisplay H11 1603
   Coding: 2B01C0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 2B031482E388A952DA9-807E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217     HW: 80A 907 217
   Component: BVS           H14 0042
   Dataset Number: 80B909466C  0021
   Coding: 0404020600000401024023A1A50000FE10F0C020C280
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 6393BCA2CBD82112229-8036
1123600 - Predictive Route Data
          B1630 02 [00001000] - Signal Failure
                    Fault Frequency: 12
                    Reset counter: 114
                    Mileage: 65513 km
                    Date: 2024.08.30
                    Time: 18:21:35
                    Control Module temperature: 40  C
                    Voltage terminal 15: 14.30 V
1123601 - Predictive Route Data
                    Reset counter: 110
                    Mileage: 66743 km
                    Date: 2024.10.17
                    Time: 14:40:12
Address AC: Reductant Control (J880)       Labels: 80A-907-355.clb
   Part No SW: 80A 907 355 E    HW: 80A 907 355 D
   Component: SCR-Stg-G4H07 0003
   Dataset Number: 80B909571G  0002
   ASAM Dataset: EV_RDCMHelbaAU426 003010
   ROD: EV_RDCMHelbaAU426_003.rod
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1QBI004TZ Dataset Number: 80B909897A  0024
   Coding: 000D98000001040000001080
   VCID: 0A4DB1060CB2D05A01F-805E
   Component: TSG HBFS001 0737
   Serial number: CLSM1QBI004TB Dataset Number: 80B909896A  0024
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   Dataset Number: 80B909471A  0003
   VCID: 1A6DC146BC1220DAB1F-804E
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
   Dataset Number: 80B909472A  0003
End----(Elapsed Time: 02:01, VBatt start/end: 11.8V/11.9V. VIgn 12.0V)-----
Dr Sheldon
Windsor UK
C?ID=334979
She is definitely mapped !!
Your turbo is making 2235 hpa (atmosphere + 1235 hpa) just not getting to 2902 hpa.
That is a good indicator that the boost mechanics are working !! I reckon you got a Boost Leak. Pipe or split Intercooler.
Adrian Fuller
C?ID=156708
Hi thanks for the feedback, would a split boost pipe or intercooler give me lots of black smoke? As the emissions look fine?
TIA
Adrian Fuller
C?ID=156708
Hi what is the location id for charge air pressure actual value, all I can find is charge pressure before throttle valve calculated actual value. IDE07375 is this the same thing ?
They won't be for long as it appears the tuna is attempting to break the turbo... I'd love to see EGT logs from this thing!
Rich (BB code):
                    Mileage: 67139 km
                    Date: 2024.10.30
                    Time: 13:21:38
Also, why is your alternator struggling to keep up with electrical demand? Do you have a crappy battery or something? I wouldn't like that voltage at 2k rpm.
Dr Sheldon
Windsor UK
C?ID=334979
Smart Charge ??
Dr Sheldon
Windsor UK
C?ID=334979
12.88 Under load is still enough !! And no Voltage DTC !!
Dr Sheldon
Windsor UK
C?ID=334979
Yes - Hell yes
Until the DTC is set and then it will protect the environment, the neighbours. That can happen in 100mS
Smart Charge ??
It's feasible that the system is bright enough to reduce alternator output due to limp mode and an engine that is already under torque reduction throttling.... maybe the ECU is saving all the available beans for driving force. ;)
Dr Sheldon
Windsor UK
C?ID=334979
Or the battery and alternator are healthy ?? Not needing a breast feed right now >>
Adrian Fuller
C?ID=156708
Hi, I have logged some of the parameters recorded on the fault recorded in the ECU, please see attached drop box link to the XL format file. Note column R is the difference between specified boost and actual boost (some instances show over 1000 difference). I have looked at hoses and turbo actuator is holding vacuum. Any further thoughts and also how many incidents of low boost pressure need to be captured until the car goes into limp mode?
Dr Sheldon
Windsor UK
C?ID=334979
With respect - There is no need for a data log to show us what is already very transparent in the FFF Data of the DTC.
Yes ! you have a lack of boost !!
It is either not being generated or it is being leaked.
You have the car in front of you !! Only you can do the testing
Our friend @SaVAGeSoot is very clear there - Your tuner is trying to kill your turbo and possibly your engine !!!!
He has asked about EGT Exhaust Gas Temp logs ??
I would start by removing that tune / map from the car !! It is far too ambitious !!
So does that not confirm what we've all been telling you? Boost leak!
Visual inspection of charge system is not sufficient. You could have a crack in a pipe or intercooler or a split connection that only "opens up" once significant pressure exists in the system.
Pressure testing of the system is required.
Your IATs are through the roof, because your turbo is being asked to maintain 27psi of boost with a hole in the system.... so as a result, your compressor is being pushed way off its efficiency map and pretty much just creating heat while trying to self-destruct.
