Hello everyone, I am a new member from Serbia. I need a little help.
Lakinikolaj
Serbia
C?ID=589725
Hello everyone, I am a new member and proud owner of vcds. I need help and advice, I have a VW Turan 2020 for the American market, I need to switch the rear signaling to the EU market. I am aware that new wires must be brought from the module. I looked at the coding, the coding helper does not offer coding like on older vehicles. Any advice and suggestions are welcome.
Tuesday,05,November,2024,04:27:33:38789
VCDS Version: 24.7.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: 3VV1B7AX5MM044647   License Plate: TIGUAN
Mileage: 39521km-24557mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 08 09 13 15 17 19 3C 42 44 52 5F 75 BB BC
VIN: 3VV1B7AX5MM044647   Mileage: 39521km-24557miles
Address 01: Engine (J623-DTEA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115 F    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0002
   Revision: 1DH31000    CVN: 481B24EC
   Coding: 012A00122424012F24000000000000000000000000000000
   Shop #: WSC 00066 790 00448
   ASAM Dataset: EV_ECM20TFS01183A907115F 001004
   ROD: EV_ECM20TFS01183A907115F.rod
   VCID: 29048EB1C9705A1228D-807C
   VINID: 0E698148746815D7401041841C0C137534
Readiness: 0100 0101
Address 02: Auto Trans (J217)       Labels: 09P-927-749-V1.clb
   Part No SW: 09G 927 158 FM    HW: 09G 927 158
   Component: AISIN AQ8     206 3757
   CVN: 5BEE8C68
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00443
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 0358FC190B9C6042421-8056
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 53150000000672
   Coding: 0BFA6BA450241B70C57D0204A2CA49D0D60AD8A34045927010415058D2824A0B00002E64121A03102F35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76BE95CD484E45EA75F-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-426.clb
   Part No SW: 5NN 907 426 D    HW: 5NN 907 426 D
   Component: AC Manuell el H36 4801
   Revision: 20K02000    Serial number: 00000D00648553
   Coding: 00020004200110001000000000000006
   ASAM Dataset: EV_ACManuePrehVW37X 002024
   ROD: EV_ACManuePrehVW37X_002_VW37.rod
   VCID: 51F40651816042D280D-8004
   Part No SW: 5Q0 937 085 CF    HW: 5Q0 937 085 CF
   Component: BCM MQBAB MNA H42 0411
   Serial number: 0332025101ÿÿÿÿ Dataset Number: V03935335T0001
   Shop #: WSC 00066 790 00247
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021_VW37.rod
   VCID: 7F5070E9677404A2269-802A
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 201103  034 0373
   Serial number: 20110121032660
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 FC    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0300211120200C201701
21511 - Bulb(s) for Rear Side Marker
          B145B 11 [00001000] - Short to Ground
                    Reset counter: 59
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:56:17
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: operated
                    Low beam: Not operated
                    Voltage: 11.8 V
                    Outside temperature: 14.0 °C
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0383
   Dataset Number: V03935333DX 0001
   Coding: 3200001110FF8728749C810500409700000000000000000014
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 45DC220145289E722C5-8010
196740 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_SENSOR_BLOCKAGE]
                    Reset counter: 59
                    Mileage: 39488 km
                    Date: 2024.11.05
                    Time: 12:26:34
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 34 °C
                    Vehicle speed: 12.93 m/s
                    Longitudinal acceleration: -0.28 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    008 0403
   Serial number: 003FGM0C2N07 Dataset Number: V03935282LS 0001
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 0C4AD72526C22F3A33B-8058
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000EZIRW0
   Coding: 303345
   Subsystem 2 - Part No SW: -----------    HW: 480 000 809 20
   Serial number: 357000000005E4116A4H
   Subsystem 3 - Part No SW: -----------    HW: 480 001 209 20
   Serial number: 3580000000075C8D3C4.
   Subsystem 4 - Part No SW: -----------    HW: 480 400 110 20
   Component: SideSensor_Dr  004 6149
   Serial number: 35100010A6378AD26470
   Subsystem 5 - Part No SW: -----------    HW: 480 400 110 20
   Component: SideSensor_Pr  004 6149
   Serial number: 35200011C63817B134E$
   Subsystem 6 - Part No SW: -----------    HW: 480 402 610 20
   Serial number: 355000120638D772D51
   Subsystem 7 - Part No SW: -----------    HW: 480 402 610 20
   Component: FrontSensor_P  004 6149
   Serial number: 356000120638D775163X
   Part No SW: 5NA 920 850 E    HW: 5NA 920 850 E
   Component: KOMBI         344 8400
   Coding: 0BB4090A2388CF0502882A091400000020200000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   VCID: 41D436115100B25210D-8014
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 28112000840620 Dataset Number: V03935325RE 0001
   Coding: 030100347F085900FA000048180F00010001070000000000000000000000
   GVL: 01403C0000000000404C80008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 74BAAFC55E3257FA4BB-8020
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 A    HW: 5NA 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2542003100900196FE2B
   Coding: 280000
   Serial number: 2975157700
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 11230028389310  Dataset Number: V03935321CR 0001
   Coding: 5294C640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 39245EF139D0EA9258D-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 11230028431789
   Part No SW: 5Q4 959 393 N    HW: 5Q4 959 393 N
   Component: TSG FS        008 0820
   Serial number: 99028033101277 Dataset Number: V03935321ZQ 0001
   Coding: 003003200000048000000000
   Shop #: WSC 01383 790 50316
   VCID: 4ECE1D2D905E5D2A9DF-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000007197332
   Coding: 011000
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Dataset Number: V03935302RN 0001
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 5Q4 959 392 N    HW: 5Q4 959 392 N
   Component: TSG BFS       008 0820
   Serial number: 00028032501578 Dataset Number: V03935322BB 0001
   VCID: 4DCC1A219D586632E45-8018
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000007191519
   Coding: 091000
   Part No SW: 3CN 035 869     HW: 3CN 035 869
   Component: MU-E--ER      720 0890
   Serial number: 06102000024390 Dataset Number: V03935340BP 0001
   Coding: 02231600BE00000041110001001000009F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
1597 - Data Set Implausible
          B2012 00 [00001001] - -
          [Control module (data record download) - implausible data record for language]
                    Reset counter: 18
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:55:53
                    Voltage terminal 30: 11.8 V
   Part No SW: 5WA 035 283     HW: 5WA 035 283
   Component: OCUGen3Low    H10 0295
   Serial number: 0000000011NVPA1 Dataset Number: V03935337VW 0001
   Coding: 02326020196828008005461160100607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW37.rod
   VCID: 0256F91D1486694A497-8056
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:55:57
12866049 - Databus
          [Airbag: Error value received]
                    Reset counter: 39
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:55:54
End----------(Elapsed Time: 01:13, VBatt start/end: 12.2V/12.4V)-----------
   CVN: 5BEE8C68
                    Reset counter: 59
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:56:17
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.8 V
                    Reset counter: 59
                    Mileage: 39488 km
                    Date: 2024.11.05
                    Time: 12:26:34
   Coding: 303345
   Generator:
   Coding: 280000
   Coding: 5294C640
   Coding: 011000
   Coding: 011F0000
   Coding: 091000
                    Reset counter: 18
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:55:53
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:55:57
12866049 - Databus
                    Reset counter: 39
                    Mileage: 39487 km
                    Date: 2024.11.04
                    Time: 22:55:54
End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.2V)-----------
Address 17,5NA 920 850 E,recoded (Long Coding),from,0BB4090A2388CF0502882A091400000020200000,to,0BB5090A2388CF0502882A091400000020200000,(00066/790/00443),
If you are sure you need to actually do the above (wiring) , I would get a wiring diagram for your vehicle and post the link where you learned about this additional wiring for EU spec. ; that way the members can view all the necessary information. Perhaps even other methods?? The members will most likely also want to see the channel map for any module in question.
