hello i got no-start warning light comes on on the dashboard and there are no other fault codes.
i have report
please help
포함된 링크:
i have report
please help
포함된 링크:
Tuesday,05,November,2024,20:48:13:41326
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUZZZ4H3FN030510 License Plate: 123123
Mileage: 131397km-81646mi Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 13 15 16 17 19 20 34 36 3B 42 44 46
47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 82 85 88 89 8B 8E 8F
90 AC
VIN: WAUZZZ4H3FN030510 Mileage: 131397km-81646miles
Address 01: Engine (J623-CTBB) Labels:. 059-907-401-V2.clb
Part No SW: 4H0 997 401 E HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0004
Revision: 58H14--- CVN: 1EC455B515D91B8D8947E11D
Coding: 0A2A4032056601060000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM30TDI0114H0997401E 001004
ROD: EV_ECM30TDI0114H0997401E.rod
VCID: 2F3B15F937975A92F61-807A
VINID: 9D196AAAA1180D67800C014100CC28C8F1
4812 - Engine Control Module Incorrectly Coded
P1612 00 [00100111] - -
Engine RPM: 0.00 /min
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
selected gear-Bits 0-7: 0
Part No SW: 4H1 927 158 CL HW: 0BK 927 156 AD
Component: 0BK 30TDIRdW H19 1011
Revision: --H19--- CVN: 975A626A
VCID: 7CA1F2B5B661710A033-8028
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 AA HW: 4H0 907 379 AA
Component: ESP PREMIUM H10 0665
Coding: 60E5AB8006A7D501E300
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005024
ROD: EV_ESPPremi_005_AU64.rod
VCID: 71BFD381E1230C62A05-8024
Part No SW: 4H0 907 064 FF HW: 4H0 907 064 EF
Component: BCM2 2.0 H36 0560
Coding: 05A76F0E000000000000
VCID: 72BDDC8DE4A5377A59F-8026
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000132228926
Coding: C018320085047201000001010101112131313333283333
VCID: 35372791D54B6042BCD-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 P HW: 4H0 820 043 P
Component: Klima 2 Zonen H20 0210
Coding: 3601602E3C0000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2D070FF13D9B2882C4D-8078
0263 - Local Databus
U1030 00 [00001000] - Electrical Malfunction
Reset counter: 77
Mileage: 131397 km
Date: 2024.11.05
Time: 20:19:42
Part No SW: 4H0 907 063 DB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0311
Revision: 19020001 Serial number: 00000962974601
Coding: 0105001440349FE2C9014084A0001800009CC3082E08020180000894610117000040002C0B0000
VCID: 6B83C1E9C38FE6B29A9-803E
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 141120 H36 0090
Serial number: 141203140417
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23635257
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 F HW: 4H0 941 531 F
Component: E1 - LDS H01 0044
Serial number: 05 01 2015 00002070
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA110936000011147670
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 1798C567000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2313E9C96BDFEEF2629-8076
Part No SW: 4H0 907 561 C HW: 4H0 907 561
Component: ACC3 H21 0032
Serial number: 00000000000000 Dataset Number: 4H0909863E 0037
Coding: 7C04010201
ASAM Dataset: EV_AdaptCruisContrAU64X 002024
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2B0301E9038F26B2DA9-807E
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[FAULT_CIS_LRRS_FAIL]
Reset counter: 77
Mileage: 131397 km
Date: 2024.11.05
Time: 19:16:58
Control Module temperature: 46 °C
Voltage terminal 15: 11.889 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s?
Revision: -------- Serial number: 003P1002VE3- Dataset Number: 4H0909602J 0017
Coding: 30333045313430303033554A304C34483053
VCID: 3B2331A9F3EFB6324A9-806E
Serial number: 3575HRB405N2RDNK3G73
Serial number: 3585HRB40532R6CO50A2
Serial number: 3515JRB400S52RQMB8E3
Serial number: 3525JRB400Q52RQM9PIL
Serial number: 3554VRB405933RVO1HE9
Serial number: 3564VRB404T33RVOD0FP
Revision: -------- Serial number: 01335NLI000KY
Coding: 00003C
VCID: 372B2D99CF479252AE1-8062
Subsystem 1 - Part No SW: 4H0 951 528 J HW: 4H0 951 528 J
Component: E221 - MFL H09 0010
Serial number: 06 12 2014 30020677
Part No SW: 4H0 920 930 R HW: 4H0 920 930 R
Component: TDieRDWACC--- H53 0707
Revision: 37081202 Serial number: 658060115592026
Coding: 138608001F41000C120000
ASAM Dataset: EV_RBD4K 004050
ROD: EV_RBD4K_AU64.rod
VCID: 35372791D5CB6042BCD-8060
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 M HW: 4H0 919 204 M
Component: Analoguhr D4 H05 0225
Serial number: 2141204006832
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4H0 907 468 AF HW: 4H0 907 468 AC
Revision: -------- Serial number: 00000001698045 Dataset Number: 4H0909515L 0087
Coding: C0CD078100
GVL: FFCFE908FFE3E8CFC0000000
VCID: 75B7E791954B20427CD-8020
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 61349M47121911225936
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 15006001030021200410
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0020
Revision: AA001002
Coding: 04018B6B74745D545420363E00
VCID: 678BBDD9DF67C2D2FE1-8032
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Dataset Number: 4H0909553H 0038
Coding: 008002
ROD: EV_AirSuspe_003_AU64.rod
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000132168480
Coding: C0183B0085057201000001010101112131313333203333
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA7702D9WL
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372B2D99CFC79252AE1-8062
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H07 0280
Revision: -------- Serial number: 0000129746700
Coding: 011F1E005E0062C202083007
VCID: 48C95E65B2B9EDAAD7B-801C
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0020344550 Dataset Number: 4H0909852J 0023
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 33331989DBBF7E72929-8066
Revision: 00002001 Serial number: 0356687535
Coding: 011A0E2080B93185F320C7C40E0316470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H08 0006
Serial number: WOO33758224
Coding: 901F00
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: Dachelektroni H13 0080
Serial number: A2015000000000831960
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS014 H06 0005
Serial number: WOO100091N8
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93407971
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000156628
Coding: 030000
VCID: 1D67DF314DBBD80254D-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H07 0280
Revision: -------- Serial number: 0000130244322
Coding: 011F1E005E0062C202083006
VCID: 3C2132B5F661B10A433-8068
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001323583 Dataset Number: 4H0909522D 0017
ROD: EV_ParkiBrake_VW51.rod
Part No SW: 4H4 907 357 B HW: 7P6 907 357 B
Component: MxB-ECU 001 0049
Revision: -------- Serial number: -------------- Dataset Number: 4H0909865C 0018
Coding: 02F2021022600200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
VCID: 313F138121A34C62E05-8064
Subsystem 1 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7540
Coding: E00200
Subsystem 2 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7540
Coding: E00200
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227AY0F8524192
Coding: 080003010000000001
VCID: 2615F0DD18ED1BDA057-8072
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4H0 919 129 E HW: 4H0 919 129
Component: DMB-DTV H05 0550
Revision: R0050000 Serial number: 05300206107701
Coding: 1A0100
VCID: 303916852A29456AEFB-8064
Part No SW: 4H0 035 748 J HW: 4H0 035 748
Component: H-BN-KO H19 0808
Revision: -------- Serial number: K5FAN1B4AYA12
Coding: 02050000000BFDEF65908B0E00000003FD0001020000000000
VCID: 313F138121234C62E05-8064
Subsystem 1 - Part No: 8R0 060 884 CM
Component: KOR-15.05.14. 7810
Subsystem 2 - Part No SW: 4H1 919 600 N HW: 4H1 919 600 A
Component: E380 BDT D4 H11 0110
Serial number: 00000000182024
Subsystem 3 - Part No: 8R0 060 961 G
Component: CD-Database 5950
00658 - Control Head
Reset counter: 77
Mileage: 131397 km
Date: 2024.11.05
Time: 19:18:56
Voltage: 12.20 V
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 37
Mileage: 131397 km
Date: 2024.11.05
Time: 19:15:59
Voltage: 11.80 V
03787 - Rotation Mechanism for Display Module Front
Reset counter: 37
Mileage: 131397 km
Date: 2024.11.05
Time: 19:15:55
Voltage: 11.90 V
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H07 0280
Revision: -------- Serial number: 0000131905070
Coding: 010F1E00400062C202083006
Part No SW: 4H0 907 428 D HW: 7P6 907 441 F
Component: TopView H07 0330
Revision: 11001001 Serial number: 82330JF0196674
Coding: 020E000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
VCID: 2E0508FD309D539AFD7-807A
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 350400989 Dataset Number: 4H0909541F 0008
Coding: 021004C020
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FBBD5F9F7171A92B61-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000172543 Dataset Number: 4F0000000__ U001
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393A9C92BDFAEF2229-8036
Component: TSG HR H07 0280
Revision: -------- Serial number: 0000131905072
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H09 0083
Revision: 0L0D5015 Serial number: SN141122 0258
ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4H0 919 617 HW: 4H0 919 617
Component: HeadUpDisplay H17 0021
Coding: C20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7_AU57.rod
VCID: 6D87CFF1FD1BE88284D-8038
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000 Dataset Number: 4H0909547F 0046
Coding: E8040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C0102F50681218AD33-8078
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00019307117202 Dataset Number: 4H0909880D 0019
Coding: 662FF2
ROD: EV_IVBDriveSideFrnt_AU57.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00019307117902 Dataset Number: 4H0909881D 0019
Coding: 262FF2
Part No SW: 4H0 907 541 C HW: 4H0 907 541
Coding: 7C04010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 290FFBE1097334A2285-807C
Component: BV-SG H33 0090
Serial number: 005000621212147
Coding: 01A08A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Dataset Number: 4H0909614C 0003
Coding: 00660600031F0376000308014248D2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H13 0080
Dataset Number: 4H0909615C 0003
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D1C8D24A5777A99F-8066
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 143280504 Dataset Number: 4H0909571G 0019
ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 02:58, VBatt start/end: 13.1V/14.2V)-----------
