2014 MK7 Golf Lost Code for ABS (MK100IPB)
teemoh1991
C?ID=425121
Any help with this mess would be greatly appreciated.
Monday,04,November,2024,08:00:30:63033
VIN: WVWZZZAUZEP010747   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP010747   Mileage: 236731km-147097miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   X22 5514
   Revision: 83X22---    CVN: 8E8F2B5D
   Coding: 01190012034505082000
   Shop #: WSC 00028 028 00072
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79AFE6B0F9563152185-802C
   VINID: 9E69EAAAA465A958000401C41C58A5AB1F
          U0428 00 [00101111] - -
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:50
                    Engine RPM: 0.00 /min
                    Coolant temperature: 43 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.380 V
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00101111] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:49
                    Limitation: accelerator pedal: 126.7 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
4716 - No Communications with Parking Brake Control Module
          U0128 00 [00101111] - -
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:49
14690 - Loading Mode active
          P169A 00 [10101111] - -
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:27:24
                    Coolant temperature: 27 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 12.940 V
                    Unlearning counter according OBD: 0
Readiness: 1 1 0 0 1
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 6156300000051A
   VCID: 074B9048BFA257A21E1-8052
11 Faults Found:
0195 - Control module not coded
          U1013 00 [10001001] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:40
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:39
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:39
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:39
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:39
0394 - Function Shut-Off Active
          C10C8 00 [00001000] - -
          [The function AYC+TCS or EDS were deactivated by adaption]
                    Reset counter: 240
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:40
8278 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
          [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:39
8290 - Coding Not Possible
          U10BC 00 [10001001] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:34:46
8306 - Databus
          U1122 00 [10001001] - Implausible Message
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:34:46
8308 - Control Module Incorrectly Coded
          U1014 00 [00001000] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 240
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:41
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [10001001] - Switches/Motors Detected
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:10:40
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00120104202100011005000000101000
   Shop #: WSC 00028 028 00023
   VCID: 382923B482DCE85AA7B-806C
   Air quality sensor:
          B10CD 00 [00001001] - -
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 13:19:39
                    Voltage terminal 30: 12.0 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011315801280 Dataset Number: V03935237MG 0001
   Coding: 03000842C24102FB0BA44080B1040328100A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 48C95374F23C98DAD7B-801C
   Component: WWS    130521  042 0551
   Serial number:         130529220655
   Component: RLFS  024 0042
   Serial number: Y13M06D12H01M49S10S1
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131203FFS
   Serial number: 00000000000056862690
          B1263 01 [00001000] - Electrical Failure
                    Reset counter: 240
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:37:23
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.3 V
                    Outside temperature: 11.0 °C
204546 - Remote key 2
          B147A 18 [00001001] - Current Too Low
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:37:23
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.4 V
545300 - Databus
          [Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
                    Terminal 15 status: On
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.3 V
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231316300332 Dataset Number: 5G0039v__A_ 0008
   Coding: 0071051001
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   VCID: 3B233CB8B3EAC3424A9-806E
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
13637426 - Databus
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R03HPR$ Dataset Number: 5G0003v____ 0079
   Shop #: WSC 00028 028 00065
   VCID: 4ACD697CEC306ACAC1F-801E
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B10061340815
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B12061340174
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 406 13
   Serial number: 357670000009F7210D0W
   Subsystem 4 - Part No SW: -----------    HW: 480 002 905 13
   Serial number: 35867000000CE8802D00
   Subsystem 5 - Part No SW: -----------    HW: 480 400 706 13
   Serial number: 3516502BD10CBDF4F19+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 706 13
   Serial number: 3526502BD10CBDF611AV
   Subsystem 7 - Part No SW: -----------    HW: 480 400 806 13
   Serial number: 3556502A910CBDF2F19
          B13BC F2 [10001001] - No function
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
1049093 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Fault Frequency: 14
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:51
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:47
1049094 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Fault Frequency: 14
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:51
1049095 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                    Fault Frequency: 14
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:51
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 18061304401141 Dataset Number: ----------
   Coding: 0D00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 7BA3FCB8F36A03420A9-802E
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         252 2210
   Coding: 27A419002780260001886A01040000
   VCID: 2809F3F4527C78DA37B-807C
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:50
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 10061310801658 Dataset Number: 5G0067v____ 1407
   Coding: 030100040B087300EF00065C080F00010001000000000000000000000000
   GVL: 01543C0000000000400C80000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   Generator:
   Component: E221__MFL-DC1  H14 0035
   Serial number: 27130000692580053213
   Coding: 2C0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 2989930603
66054 - Extended CAN Bus (SAE Bus C)
          U0047 00 [00001001] - Performance
          [Globaler Timeout CAN-Extended]
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:47
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000062565706  Dataset Number: 5G0222v____ 0042
   Coding: 003B0220D001028000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 025D815C9480728A49F-8056
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001654716
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Dataset Number: 5G0074v____ 0128
   Coding: 80
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D2732A0ADFECD7274D-8068
15117 - Internal Fault
          B200F F0 [00001000] - Unknown Error Elaboration
          [Rotorlage Sensor: Radius Überwachung  Radius verkleinert sich um mehr als 40 digits im Uncontrolled-Zustand bei stehendem Rotorwinkel (delta<10°).Ursache kann ein Kurzschluss in Signalen des Sensorelements sein.]
                    Fault Frequency: 8
                    Reset counter: 240
                    Mileage: 236689 km
                    Date: 2024.11.03
                    Time: 14:18:04
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.00 V
                    Temperature: 47.0 °C
                    KFC: 3B
                    KFA: 00 0D
                    Freeze frame conditions: 71
                    Rotorlagesensorspannung AMR Sinus: 2.215 V
                    Rotorlagesensorspannung AMR Kosinus: 9.757 V
                    Rotorlagesensorspannung AMR Sinus 2: 2.318 V
                    Rotorlagesensorspannung AMR Cosinus 2: 9.708 V
                    Rotorlagesensorspannung Hall 1: 0.0 V
                    Rotorlagesensorspannung Hall 2: 0.0 V
                    Aktueller Sinus-Offset für ASIC: 0.0 mV
                    Aktueller Cosinus-Offset für ASIC: -0.1 mV
                    aktuelle Sinusverstärkung für ASIC: 0.169
229504 - Internal Control Module Memory Check Sum Error
          B2000 00 [10011001] - -
          [Steuergeräte defekt - Interne Störung]
          MIL ON - Confirmed - Not Tested Since Memory Clear
                    Fault Frequency: 8
                    Reset counter: 240
                    Mileage: 236689 km
                    Date: 2024.11.03
                    Time: 14:18:04
                    Motor status: 01
                    KFC: 3B
                    KFA: 00 0D
15873 - Steering angle sensor
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 200
                    Mileage: 236731 km
                    Date: 2024.11.04
                    Time: 01:31:46
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 23.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Freeze frame conditions: 4B
                    uAdSensI_U5VFiltered_xdu16: 5.08797 V
                    uioUdNotFilt_xdu16: 12.27 V
                    uAdSensI_SwitchedKl30_xdu16: 12.26 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 01
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000062993194  Dataset Number: 5G0157v____ 0045
   Coding: 003B0020DE01028000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 015F8E5091866992505-8054
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001646502
   Coding: 050000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    040 0421
   Serial number: V7F01006131481 Dataset Number: 5G0CV1v____ 0001
   Coding: 02730001FF00000021111201002800001F0100060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 678BB0C89FE2B7A2FE1-8032
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H44 0020
   Serial number: VWZ8Z9N34021ME
End----------(Elapsed Time: 01:20, VBatt start/end: 12.6V/12.6V)-----------
How was the coding lost? What parts have been replaced?
teemoh1991
C?ID=425121
everything is same, nothing was replaced. The person who i got the car off said someone has reset the module to factory setting but from his knowledge nothing was changed.
WHY does this keep happening? It must be the most common question on here.
