Resolved Long Coding Helper
Resolved
dct-performance
hn2-032675
HELLO THERE I GOT PROBLEM WITH LONG CODING HELPER IS NOT SHOWING JUST BOUGHT TOOL ANY HELP SELLER NOT SUPORTING ME WITH THAT
AINils
Germany (AIB)
C?ID=56975
We need a full autoscan of car to help you in ths case.
Also a detailed description of your problem
Westbury, UK
Long Coding of which module? What vehicle? What model year (NOT UK registration plate)?
As AINils says you need to post an Auto-Scan, oh and please turn off your CAPS LOCK (posting all caps is seen as shouting).
dct-performance
hn2-032675
is with all cars is not just one
dct-performance
hn2-032675
any modules
dct-performance
hn2-032675
is looks like this option is not working at all
dct-performance
hn2-032675
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZ9W463476   Mileage: 266810km-165788miles
Address 01: Engine (BSE)       Labels: 06A-906-033-BGU.lbl
   Part No SW: 06A 906 033 JF    HW: 06A 906 033 J
   Component:  BSE S71 1.6 2V     4494
   Revision: --H01---    Serial number: 00000000000000
   Coding: 0044071
   Shop #: WSC 36634 001 1048576
   VCID: 6C8AB7F12A82BCFA933-8038
   VINID: 9E69EAAAA05BA899C41831071893FF96CA
Readiness: 0110 1001
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 133B200D092800FDC80F04EB901F00803000
   Shop #: WSC 52547 001 1048576
   VCID: 7EAE8DB940FE3E6A2D7-802A
   Part No SW: 3C8 907 336     HW: 3C8 907 336
   Component: Climatic      120 0102
   Revision: 00004001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6A86B1E92CF6A2CAE1F-803E
   Part No SW: 1K0 937 085     HW: 1K0 937 085
   Component: BCM PQ35  B+  020 0358
   Revision: 00020000
   Coding: 40180A3A9025189044000080100000E441010088524D8960648000000000
   VCID: 6C8AB7F12682BCFA933-8038
   Component: Wischer 21110  21  0501
   Coding: 009795
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    022 0507
   Serial number: 003C2D06H5CR   Dataset Number: v00300565K0 0001
   Coding: 00003136
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77A0989D6F440F226E1-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 097A1244ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 3C670240ZZZZZZZZZZZZ
   Serial number: 222B1901ZZZZZZZZZZZZ
   Serial number: 0807013BZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           853 0111
   Coding: 0000004
   VCID: 0358FC4D271C5382429-8056
   Part No SW: 5K0 920 960 F    HW: 5K0 920 960 F
   Component: KOMBI         H21 0029
   Coding: 470B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 30326381CAAA181AEFB-8064
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 251108F2000150
   Coding: E9801F06000202000003
   VCID: 3720589D2344CF22AE1-8062
   Component: IMMO          H21 0029
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
   Component: Tuer-SG         008 2016
   Coding: 0000564
   VCID: 79A49EA555D01952185-802C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 68     2301
   Revision: 00H15000
   Shop #: WSC 01324 785 00200
   VCID: 2A0671E9E0F662CA21F-807E
   Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
   Coding: 0000564
   VCID: 7AA681A950D6124A11F-802E
   Part No SW: 1K0 035 156 A    HW: 1K0 035 156 A
   Component: Radio         507 0517
   Revision: R0507020    Serial number: VWZ5Z1H0033197
   Coding: 0000020002
   VCID: 211496C591C0A192705-8074
End----------(Elapsed Time: 00:43, VBatt start/end: 13.9V/13.7V)-----------
dct-performance
hn2-032675
is a golf mk5 got oil level light on dash oil level is spot on... no faults so want to decode
Westbury, UK
any modules
Not all modules on all cars actually have Long Coding - so don't expect the Long Coding Helper to be available on every module on every car.
Look at the Auto-Scan if the coding looks similar to this (or even longer!)
Coding: 0C2500322464010B1000
then the Long Coding Helper will be available.
But if it looks similar to this
then as this module doesn't use Long Coding then the Long Coding Helper will not be available.
Actually that's not quite correct. Four digits, 2 bytes; that's going to be hexadecimal and will be "long" coding. Traditional decimal short coding is always an odd number of digits. So for example the coding for the engine in his scan:
Coding: 0044071
That has 7 digits. It's decimal, and is not a "long" coding.
However, coding for that ECU us well documented in the label file and will be shown in an info balloon if he pauses on the coding screen.
Now the dash in this car has:
Coding: 470B00
That's an even number of digits, clearly hexadecimal, and Long Coding Helper should work, and there's data for it in the label file.
dct-performance
hn2-032675
Thank you everyone one was problem with software done update of software plusy update of interface now is showing long Codding helper thank you
