P00AF & P2563 Issues
blimes69
Canada
C?ID=565846
VW Jetta Wagon 2009 - stock
Monday,04,November,2024,22:21:28:60169
VIN: 3VWML81K19M357945   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 56 62 72
VIN: 3VWML81K19M357945   Mileage: 148340km-92174miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 H    HW: 03L 906 022 J
   Component: R4 2.0l TDI G001AG  9983
   Revision: 12H01---    Serial number: VWX7Z0I424L0JC
   Coding: 0350078
   Shop #: WSC 11361 004 1048576
   VCID: 33330FE0F73BD802929-8066
   VINID: 0E69DD70805B04974314724414FB388CC3
7 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 184
                    Mileage: 137261 km
                    Time: 02:22:06
                    Voltage: 12.54 V
                    Lambda: -11.0 %
                    Lambda: 4.7 %
                    Bin. Bits: 00011110
                    Voltage: 3.876 V
000175 - Actuator Module for Turbocharger 1
               P00AF - 001 - Stuck - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 56
                    Mileage: 147825 km
                    Time: 17:56:15
                    RPM: 1150 /min
                    Speed: 5.0 km/h
                    Load: 26.3 %
                    Load: 100.0 %
                    Lambda: 14.2 %
                    Pressure: 992.2 mbar
                    Temperature: 33.3°C
               P00AF - 002 - Stuck - Intermittent
                    Mileage: 147886 km
                    Time: 18:32:55
                    RPM: 828 /min
                    Load: 32.2 %
                    Mass Air / Rev.: 0.0 mg/str
                    Mass Air / Rev.: 270.0 mg/str
                    Mass Air / Rev.: 275.0 mg/str
009571 - Turbocharger Boost Control Position Sensor Circuit
               P2563 - 000 - Implausible Signal - Intermittent
                    Mileage: 148341 km
                    Time: 05:33:40
                    RPM: 920 /min
                    Voltage: 14.52 V
                    Temperature: 138.0°C
                    Lambda: 0.0 %
                    Bin. Bits: 00001110
                    Voltage: 3.496 V
009572 - Turbocharger Boost Control Position Sensor Circuit
               P2564 - 000 - Signal too Low - Intermittent
                    Mileage: 148341 km
                    Voltage: 12.16 V
                    Temperature: 36.0°C
                    Lambda: 7.1 %
                    Bin. Bits: 00000000
                    Voltage: 0.000 V
009573 - Turbocharger Boost Control Position Sensor Circuit
               P2565 - 000 - Signal too High - Intermittent
                    Mileage: 148341 km
                    Time: 05:29:27
                    Voltage: 12.08 V
                    Temperature: 36.0°C
                    Lambda: 7.1 %
                    Bin. Bits: 00000000
                    Voltage: 5.396 V
               P00AF - 000 - Stuck - Intermittent
                    Mileage: 148341 km
                    Time: 05:33:36
                    RPM: 828 /min
                    Load: 100.0 %
                    Lambda: 21.3 %
                    Temperature: 13.5°C
Readiness: 1 3 0 0 0
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 8938
   Revision: 04844002    Serial number: 00000904091419
   Shop #: WSC 00066 000 00000
   VCID: 51FF65686DE78A12805-8004
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 113B600D49270001881406E8921E0042B100
   Shop #: WSC 25113 002 1048576
   VCID: 77ABFBF0AFC3F4226E1-8022
   Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 70B9C0ECC6ADA31AAFB-8024
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009498982
   Coding: 14898F2340041500070000001C000000000873075C000120000000000000
   VCID: 323D0AE40821D10A99F-8066
   Component: Wischer 020609 021  0501
   Coding: 00038805
                    Fault Status: 00101100
                    Reset counter: 199
                    Mileage: 148341 km
                    Voltage: 12.60 V
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 199
                    Mileage: 148341 km
                    Voltage: 12.75 V
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 07 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM00A1PK
   Coding: 0012343
   VCID: 6E85DE94DC99B5EABD7-803A
   Subsystem 1 - Serial number: 6332MSME47130D032
   Subsystem 2 - Serial number: 6342MSME74426D0FN
   Subsystem 3 - Serial number: 6351HSME00250727X
   Subsystem 4 - Serial number: 6361HSME00252708Z
   Subsystem 5 - Serial number: 63727SME1C204874+
   Subsystem 6 - Serial number: 63827SME1C1E487AI
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001032
   VCID: 025D9A24F801A18A49F-8056
   Part No SW: 1K0 920 854 D    HW: 1K0 920 854 D
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0002000    Serial number: VWX7Z0I424L0JC
   Coding: 0005303
   Shop #: WSC 00066 067 57207
   VCID: 2C01149C2A0587FAD33-8078
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 180409F2000342
   Coding: ED807F06000203002002
   VCID: 382938CCEE5D3B5AA7B-806C
   Component: IMMO            3HL 1222
   Shop #: WSC 57104 004 1048576
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000764998518
   Coding: 0001205
   VCID: 6FBBC390DB93BCE2B61-803A
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Fault Status: 01101000
                    Reset counter: 159
                    Mileage: 148321 km
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 70     2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 139007885283281B0904058FB0880F0488FCA0
   VCID: 71BFC5E8CDA7AA12A05-8024
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 6695A6B4F8697DAAC57-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
01512 - Control Module for Sliding Roof
                    Fault Status: 01100101
                    Reset counter: 157
                    Mileage: 148320 km
                    Time: 19:49:00
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08122702515203
   Coding: 0001204
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7J3168239
   Coding: 0040401
   VCID: 2A0D128420F199CA21F-807E
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003957376
   Coding: 0001168
   VCID: 76B5F6F4A4C98D2A757-8022
Address 72: Door, Rear Right        Labels: None
   Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D
   Component: J389   TUER-SG HR   1509
   Revision: 12008001    Serial number: 00000007145014
   Coding: 0001168
   Shop #: WSC 08224 016 263172
   VCID: 2B0317802F0B80C2DA9-807E
End----------(Elapsed Time: 01:26, VBatt start/end: 12.5V/12.4V)-----------
P2015 code is always on and off. Have bought aftermarket attachment and cleaned intake manifold and still comes back but is irrelevant to this post..
Issues originally started with only a P00AF code and flashing glow plug light. A vacuum test on the wastegate actuator (G581) proved to not hold vacuum and likely contained a worn diaphragm. All other vacuum lines hold vacuum. Wastegate actuator was replaced with OEM VAG part and rod was set identical to previous actuator. Vacuum was tested with a mightyvac on the new part and it moves throughout its full range of motion freely with no binding or signs of sticky turbo...
After installing new part I now have P00AF and P2563 codes with no flashing glow plug light. I then noticed that running the N75 output test that the actuator rob would not move the full ~1cm up and down when running the test. I then replaced the N75.
Now the glow plug light will only turn on when hitting "Go" on measuring block 120 with the engine running. Actual voltage in 120.4 reads 0.46V at idle and when running test will jump to 3.35V then back to 0.46V. If I then stop the test the flashing glow plug light will go away. I understand 0.46V is not within the specified range of 0.65-0.85V but would this alone cause me to have the now added code and still the P00AF even though the actuator was replaced? Another interesting point is when running the 120 measuring block the voltage basically jumps from 0.45 to 3.35V and does now steadily move between. After running the measuring block 120 test I now have the P2564 and 2565 codes aswell...
I have double checked vacuum to all parts of the system and everything holds. I manually checked voltage to the actuator with the engine running with a voltmeter and mightvac on the wastegate actuator and observed 3.35v at pin 2 (violet black) with no vacuum which steadily increased to 0.5V when applying vacuum from ~3" to ~15"Hg. Pin 1 (brown green) reads 0V for the ground and Pin 3 (yellow) blue reads 5V.
I have also double checked the correct connection is actually plugged in the N75 and not to the identical connection going into the valve attached to the turbo intake. Could a leak along my intake hose to the turbo cause something like this? Everything appears tight but I do not have a smoke machine to test...
Attached screenshot of specified vs actual boost which reacted similarly before any of the repairs...
It seems to me like a possible communication issue here but I really am not the most experienced with VCDS and electrical (especially in a VW...). Any ideas would be much appreciated as I have searched high a low to find an identical issue and have had no luck. This diagnosis was inspiring but sadly is not my issue but did help me try to dig further into the issue. (
) - part 2 of 2.
Respectfully I have not posted often on these forums but have been a long time reviewer,
Thank you VAG-COM team and users
