2013 GTI Gauge Cluster Illumination
Waifu Factory
Minnesota, USA
C?ID=596447
I am trying to find a way to have my gauge cluster always fully illuminated without having to have my headlights on. Currently the gauge cluster will illuminate more the brighter the environment is. This feels backwards to me as I will often be in a parking garage during the day which has enough light to easily see other vehicles but the gauge cluster is completely dark and not visable. I would like to have the lights just always be on. I looked through the adaptations and coding through VCDS and did not see anything that looks to do what I want but wanted to check if there is some way to do this. Thanks in advance for the help!
Waifu Factory
Minnesota, USA
C?ID=596447
Here is the code. I hope this is what you were looking for as the video that waslinked said I should be able to just start the autoscan through the Can Gateway but that said it was not supported so I tried using the 7th and 8th digits of my vin and that produced this. Thanks again for the help!
Sunday,10,November,2024,16:50:52:03435
VIN: WVWEV7AJ6DW115969   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
VIN: WVWEV7AJ6DW115969   Mileage: 217300km-135023miles
2E-Media Player 3 -- Status: Sporadic communication error 1000
Address 01: Engine
Address 03: ABS Brakes
Address 08: Auto HVAC        Labels:
   VCID: 55F05968CC0180125CD-FFFE
   Note: Excessive Comm Errors
Address 09: Cent. Elect.
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R00W078   Dataset Number: 5K0003v__B_ 0080
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C26ECCC46EB715A433-8068
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00005L6N00
   Serial number: 3572MSME20371171ZZZF
   Serial number: 3582MSME2E216473ZZZX
   Serial number: 3512QSME4849215EZZZ
   Serial number: 3522QSME7A371A2EZZZ3
   Serial number: 35527SME7E124C2EZZZW
   Serial number: 35627SME5F344C2EZZZ-
   Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number: WHRPI…ruHHH‚r  Dataset Number: 5K0953507AJ D005
   Coding: 1882100000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 78AE30DC32539D7A67B-802C
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0002818
   Coding: 820000
0516 - Databus
                    Fault Frequency: 63
                    Reset counter: 244
                    Mileage: 216479 km
                    Date: 2024.10.31.
                    Time: 19:23:51
49675 - Control Circuit for Ignition Key Lock Solenoid
          B114A 13 [00001001] - Open Circuit
                    Reset counter: 209
                    Mileage: 216331 km
                    Date: 2024.10.01.
                    Time: 17:51:25
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 372CF3E07FCD5202AE1-8062
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 301012F2003361
   Coding: 350000
   VCID: 74B604EC2EBBF91A4B3-8020
03272 - Control Module for Audio Interface
                    Fault Frequency: 85
                    Reset counter: 28
                    Mileage: 216331 km
                    Date: 2019.02.22.
                    Time: 18:02:42
Address 1C: Position Sensing        Labels:
   Component: IMMO          H05 0705
   VCID: 6A8A1A947CFF3FEAE1F-803E
Address 2E: Media Player 3
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 372CF3E0734D5202AE1-8062
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 56: Radio        Labels: None
   Part No SW: 3TD 035 156     HW: 3TD 035 156
   Component: RadioSK46MID  006 0010
   Coding: 010004240410D00003DA0401
   Shop #: WSC 00078 790 00000
   VCID: 7F5CDBC017FDAA42261-802A
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663692828 Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2AEAD44CDF4F6A51F-806E
          B104F 13 [00001001] - Short to GND
                    Reset counter: 209
                    Mileage: 216331 km
                    Date: 2024.10.01.
                    Time: 17:51:30
          B104E 13 [00001001] - Short to GND
                    Reset counter: 209
                    Mileage: 216331 km
                    Date: 2024.10.01.
                    Time: 17:51:30
End----------(Elapsed Time: 01:29, VBatt start/end: 14.5V/14.6V)-----------
2kaa52
Ceska Republica, Praha
C?ID=319193
Its possible by Cluster eeprom modification.
  • Informative
