2014 Passat MK60EC1 (USA) - Rebuild/Replace? ECU Maverick or Other?
robf
Winter Garden, FL, USA
C?ID=246080
My 2014 Passat with the MK60EC1 ABS controller (1K0907379BK) is throwing two fault codes that I can't resolve:
  • 00003 - Control Module / 005 - No or Incorrect Basic Setting / Adaptation
  • 01130 - ABS Operation / 008 - Implausible Signal
After lots of unsuccessful troubleshooting and attempts to calibrate basic settings, I think I'm at the point of having to rebuild or replace the module.
  • What is my best option?
  • Does anyone have any experience with ECU Maverick (MK60EC1 rebuild is $499) or another source that you would recommend or advise to stay away from?
  • Is it something I can do myself, or am I better off bringing it to a mechanic?
  • Do I need to replace any other components in addition to the controller?
  • Is it safe to drive with the ESP, ABS, and airbag lights on?
Thank you in advance for your suggestions.
Regards,
Rob
The long, gory details...
I completely rebuilt the front suspension this past summer. The bushings in the control arms had finally worn out, and every time I pulled something apart, I found something new to replace. This is the list of everything I installed:
  • Remanufactured hydraulic rack and pinion
  • New lower control arms
  • New struts
  • New springs
  • New stabilizer bar
  • New stabilizer bar linkages
  • New ball joints on control arms
  • New outer tie rods
  • New pendulum mount and bushing
  • New bolts all around
The car was on jack stands for about 3 months, and the battery was completely dead and had to be replaced. I did not replace any brake or electrical components besides the dead battery. Prior to the rebuild, I did not have any warning lights in the instrument cluster. Now it’s showing the ESP, ABS, and airbag lights. (I can't do anything about the airbag until I take care of the ABS.)
I contacted Ross-Tech support, and Dana was very helpful even though I haven't been able to resolve this. I followed the written instructions on the wiki page and in the video. I was running VCDS and pressing the pedal exactly as they were demonstrated. I was never able to successfully complete the 025 step. It was a challenge to keep the readings within the spec range. It kept faulting out (code 004), usually after about 4-6 pedal presses. I was able to go through about 12-15 presses (maybe more) one time before it faulted out. Dana suggested replacing the brake fluid since it had been a long time since it had been done. This helped with keeping the readings in range, but I still got the same result.
These are the ABS faults:
Monday,04,November,2024,20:39:29:00414
VCDS Version: Release 24.7.1 (x64) Running on Windows 11 x64
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.CLB
Control Module Part Number: 1K0 907 379 BK    HW: 1K0 907 379 BK
  Component and/or Version: ESP MK60EC1   H31 0152
           Software Coding: C54BC0F5492308FEA30F03E9921C1061A61000
            Work Shop Code: WSC 09003 957 00200
                      VCID: 7CF7B18AFFEAF97697-8028
                    Fault Status: 01100101
                    Mileage: 456551 km
                    Date: 2019.03.28.
                    Time: 21:07:53
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 143
                    Count: 49664
                    Count: 512
                    Fault Status: 01101000
                    Mileage: 456551 km
                    Date: 2019.03.28.
                    Time: 21:16:33
                    Count: 16387
                    Count: 12
                    Count: 12800
                    Count: 113
                    Count: 48384
                    Count: 256
                    Count: 256
                    Count: 3328
I did not do scan prior to rebuilding the front end. The most recent auto-scan I have before then is from February 2021 when the car had 30,000 fewer miles on it. I don't remember why it has any of the faults it lists. I'm pretty sure I was using VCDS to code a new clockspring at the time:
Sunday,21,February,2021,13:42:25:00414
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.12.0.1 (x64)
VIN: 1VWBH7A39xxxxxxxx   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 46 4F 52 56 62
          72 75 77
VIN: 1VWBH7A39xxxxxxxx   Mileage: 406650km-252680miles
Address 01: Engine
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           2251
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 09003 957 00200
   VCID: 020BCF725D0E8F9414-FFFF
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   VCID: 7CF7B18AFFEAF9645E-8029
                    Fault Status: 00101101
                    Reset counter: 12
                    Mileage: 406607 km
                    Date: 2015.07.13
                    Time: 18:03:15
                    Count: 32768
                    Count: 12800
                    Count: 8193
                    Count: 50688
                    Count: 1024
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0193464145
   Coding: 030C0C
   VCID: 346759AA9F3AF124D6-8061
Address 08: Auto HVAC
Address 09: Cent. Elect.
   Serial number: 003MWM02E0JS
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75E1A4AED4C0A82C21-8021
   Serial number: 6940000Y130000W6A20L
   Coding: 303044
   Serial number: 3572MSME6E466079ZZZ2
   Serial number: 3582MSME4E312078ZZZX
   Serial number: 3516KSME1D454E24ZZZ-
   Serial number: 3526KSME1A243623ZZZL
   Serial number: 3556LSME24366423ZZZO
   Serial number: 3566LSME45526A23ZZZW
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20190227200282
   Coding: 110A140000
   Shop #: WSC 01286 386 08256
   VCID: 020BCF72950E8F9414-8057
   Serial number: 00000000000000733057
   Coding: E20000
   Part No SW: 561 920 970 F    HW: 561 920 970 F
   Coding: 231E01
   VCID: 1D319C0E0CB0506C09-8049
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 19071303001569
   Coding: 461000
   VCID: 7BF5B296FAE4FE5C57-802F
   Coding: 000007
   VCID: 6ADB87D28D7E77D4BC-803F
Address 2B: Steer. Col. Lock        Labels:* 5K0-905-861.clb
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 306F55BA6B22CD04B2-FFFF
Address 2E: Media Player 3
Address 37: Navigation
Derek
UK (ilexa)
C?ID=56983
I had a customer struggling to complete the basic settings for the 00003 code a while back and they had two metal brake pipes swapped over after a refit. When the pipes were put in the correct positions, the procedure went through easily.
If none of the brake parts on your car have been disconnected, I wonder if this issue could also be caused by sticking brake pads or weak flexi hoses
(be aware the 01130 code can only be cleared after the car has been driven a short distance)
Best regards
Derek
robf
C?ID=246080
Best regards
Derek
I was wondering if something like that could cause the problem or at least prevent me from fixing the settings. I didn't see anything that had obvious damage, and Firestone (ugh) didn't report anything after the brake inspection I got with the fluid replacement. However, I'll poke around again this weekend. I really hope it's something that simple. Thanks!
