2012 Audi Q7 TDI Keeps throwing NOx sensor bank 1 code NEED HELP!
Captain Casey
Seattle, WA, USA
C?ID=595273
Alrighty, So I got stuck with this Q7 in a divorce after the ex ran it into limp home mode. Bought the VCDS, scanned and saved it, but it had sat for a year. Cleared codes, and right away it had a NOx sensor bank 1 and an EGR stuck open code, amongst other code to due with ABS and stuff that needed to be driven to calibrate..... I pulled the EGR valve and cleaned it, but it was pretty sticky, so I replaced it. Cleared the codes and it drove great, but got another Bank 1 NOx sensor code. I cleared it with a little bluetooth module on the road, but the permanent code was still there, so the CEL came back on about 40 miles later. I replaced the NOx sensor for bank 1, and cleared the codes with VCDS again, and 40 miles later, got it again. Seems to be pretty consistant on coming back again and again since. Maybe cleared it 20 times in 700 miles since NOx sensor replaced. No drivability issues noticed, just the CEL light, but I keep clearing codes so it doesn't go into limp. Yes, I replaced the one by the turbo, the old one didn't look horribly caked. Anyone have any thoughts? I usually work on 1000hp plus marine diesels, so I'm not used to DEF system and I don't know the logic.... Thank you for your help!
what2be
Eureka, CA, USA
C?ID=598147
No advice, other than id be looking at the ECM possibly. Im pretty sure mine has shit the bed but still trying to determine for sure or not. I know that I suddenly have 2 nox sensor errors (no communication) when I had zero when I parked it previously. Now it wont even start. So maybe start with the exact code for the nox sensor and go from there? id be looking at the ecu if you have exhausted other options. Just my .02 cents and thats about what my advice is worth, lol.
Captain Casey
Seattle, WA, USA
C?ID=595273
Please see fresh code from today below, thank you again for your insights!
Tuesday,05,November,2024,17:49:41:06944
VIN: WA1LMAFE5CD001078   License Plate:
Mileage: 235070km-146065mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 42 46 47 4C 4F 52 55 56
          5F 62 69 6C 6D 6F 72 76
VIN: WA1LMAFE5CD001078   Mileage: 235070km-146065miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI FSA    H18 0009
   Revision: 54H18---    Serial number:                CVN: 5B6F114C38D3FF82755A2113
   Coding: 2A2A4012253600050000
   Shop #: WSC 05456 003 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 002008
   ROD: EV_ECM30TDI0114L2910401_002.rod
   VCID: 61987D9D81C81802305-8034
   VINID: 9D105C75159515350000100720CD503F7D
26253 - NOx Sensor 1 Bank 1
          P2201 00 [10101111] - Implausible Signal
                    Mileage: 235038 km
                    Date: 2024.11.04
                    Time: 13:02:20
                    Engine RPM: 2051.50 /min
                    Normed load value: 9.0 %
                    Vehicle speed: 45 km/h
                    Coolant temperature: 85 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.360 V
                    Accelerator pedal travel: 2.67 %
                    Accelerator pedal: sensor voltage 1: 977.4 mV
                    Accelerator pedal: sensor voltage 2: 488.6 mV
                    Accelerator pedal: switch positions-Bits 0-7: 1
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Limitation: torque: 195.0 Nm
                    Control Module temperature: 26.9 °C
Readiness: 1 1 0 1 1
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 3408
   Serial number:                CVN: 44BD1086
   Coding: 001378
   Shop #: WSC 19819 006 1048576
   ROD: EV_TCMAL991031_002_AU56.rod
   VCID: 3C26ECE946EA15EA433-8068
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099473
   Shop #: WSC 31414 790 00001
   VCID: 3436C4C9623ADDAA8B3-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401853389
   Coding: 0000131
   VCID: 2510298DD9E0B4220CD-8070
   Subsystem 1 - Part No: 4F0 910 132 J
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0054
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AH
   Revision: 00---026    Serial number: 00000030199700
   Coding: 0002A036
   VCID: 2510298DD5E0B4220CD-8070
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H31 0400
   Coding: 0039123
   VCID: 6FBC0BA54B9CBE72B61-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00022806
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09TLT9
   Coding: 0014131
   VCID: 2B04DFB5BF048252DA9-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME260451687
   Subsystem 3 - Serial number: 6342QSME681E3E58Z
   Subsystem 4 - Serial number: 6352QSME430C284AK
   Subsystem 5 - Serial number: 6362QSME621E0370B
   Subsystem 6 - Serial number: 63734SME1C040E50.
   Subsystem 7 - Serial number: 63834SME451E05682
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025111380160
   Coding: 0002042
   VCID: 280E20B9AEF2A94A37B-807C
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 984 R    HW: 4L0 920 984 R
   Component: KOMBIINSTR.   H22 0410
   Revision: 00000000    Serial number: JXB209V6C
   Coding: 8BD664040100CF05020205
   VCID: 42DA9211248E631A09F-8016
   Part No SW: 4F0 907 468 P    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0047
   Revision: LB200032    Serial number: 3200L116030025
   Coding: 00C303
   Shop #: WSC 22155 444 108754
   VCID: 3C26ECE9466A15EA433-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790761280
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000000283659
   Coding: 0000006
   VCID: 688E60B96E72694AF7B-803C
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000006252010
   Coding: 00581300000011110000
   VCID: 323AC2D1942ED39A99F-8066
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000006348823
   Coding: 011F07205E40440004
   VCID: 48CE803902B2494AD7B-801C
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01520447490000
   Coding: 3569693
   VCID: 3530F9CD6940C4A2BCD-8060
   Part No SW: 4L0 035 223 H    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0130
   Revision: CH003000    Serial number: 00000000002561
   Coding: 030000
   VCID: 270C2385AFECA6323E1-8072
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191123715
   Coding: 0758477
   VCID: 23143795D7D44A12629-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000091693
   Coding: 0012001
   VCID: 5EE24661BC3627FA0D7-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000006353014
   VCID: 47CC83050FAC4632DE1-8012
   Part No: 8P0 907 357 H
   Coding: 0000007
   VCID: 3FDC9BE55B7C0EF2661-806A
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H51 0076
   Revision: AB001007    Serial number: 156FW0B7515522
   Coding: 020007010000000000
   VCID: 1F1C3B65F7BC6EF2461-804A
   Part No SW: 4L2 035 746     HW: 4L2 035 746
   Component: H-BNT-NA      H42 0385
   Revision: --------    Serial number: 097FU0B7500900
   Coding: 180200060004E3EF41002345EF632003140000000100000000
   VCID: 6B841FB5738442529A9-803E
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466FU0B0605317
   Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
   Component: E0380 Bedient  H01 0060
   Serial number: 00000001857453
   Component: CD-Database  3371
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000006364092
   Coding: 010E07204040230004
   VCID: 46D28E0108A65F3A257-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000151547096
   Coding: 0200000000000000
   VCID: 3138CDDD9128E882E05-8064
   Revision: --H05---    Serial number: 525PA8-J18467Y
   Coding: 1030301
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H56 0500
   Revision: --H56001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C861CA97A8A456A933-8038
   Subsystem 3 - Serial number: RD21.06.11--H56001001B0169ÿ
   Subsystem 4 - Serial number: 1B0169ÿ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 117201445-----
   Coding: 0003595
   VCID: 26122E81A4E6BF3A057-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000006364403
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37331116603576
   Coding: 0231246
   VCID: 2A0ADAB1B0FE9B5A21F-807E
01543 - Parking Aid Warning Chime (H15)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 253
                    Mileage: 234985 km
                    Date: 2024.11.04
                    Time: 09:23:25
End----------(Elapsed Time: 02:08, VBatt start/end: 14.5V/14.6V)-----------
Log its output to see if it's playing nice or not.
Did you check wiring\connections?
Like this... see how quickly you can spot that my sensor 2 is dead?
Captain Casey
Seattle, WA, USA
C?ID=595273
I did check connections and wiring, looks intact. However, the connection plastic head sure are cheesy…
Instruments are typically used for checking power/ground/comms..... not just naked eyeballs...
Captain Casey
Seattle, WA, USA
C?ID=595273
I only got to check for bite marks. When I get more time I’ll ohm em out.
