Afternoon,
Can someone please assist with the below, the car has a few issuse with might be linked with each other.
Symtoms are rear doors will not lock, tailgate won't open also when they are open they don't display that they are open on the dashboard also bonnet doesn't display open symbol either. The key has to be in the emergency location and will only work when it is there.
I've checked the Boot switch and bonnet catch wiring going to the BCM and it is fine. So not sure if it's BCM or "limp home" which is causing the fault. Has anyone has anything like this before?
I have tried doing a Basic Settings on Central Locking but I am unable to as the car doesn't recognise when the bonnet is open.
Monday,04,November,2024,16:31:36:34234
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Dealer/Shop Name:
VIN: VSSZZZK1ZNP011145 License Plate:
Mileage: 55024km-34190mi Repair Order:
Chassis Type: K1-SEE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 5F 6C 75
82 8C A5 C0 C6 D6 D7 8105 8107 811E 811F 8120 8121 8123 8124 8125 C002 C003
VIN: VSSZZZK1ZNP011145 Mileage: 55024km-34190miles
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
6C-Back-up Cam. -- Status: Cannot be reached 0100
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
C0-Act. for Ext. Noise -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: OK 0000
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
Address 01: Engine (J623-ECWB) Labels: None
Part No SW: 0EA 906 012 CR HW: 0EA 907 425 C
Component: E-Vehicle H01 2224
Coding: 0102000003641400700800000010008020000A0000000000
ASAM Dataset: EV_VCU00XXX0200EA906012CR 001002
ROD: EV_VCU00XXX0200EA906012CL.rod
VCID: 7DA7F5934D79354234D-8028 SFD
VINID: 9A38EAAAA6C1A9E80004104414744E9B89
Radiator shutter:
Subsystem 1 - Part No SW: 1EA 965 501 A HW: 1EA 965 501 A
Component: V711 022 0007
Serial number: 20220213060604073125
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 1EA-614-517.clb
Part No SW: 1EA 614 517 AR HW: 1EA 614 517
Component: ESC-ZF_EBC470 H15 0524
Serial number: B00ARII Dataset Number: V03935358LU 0002
Coding: 099B4984353C9037923DACE211DE11A648294916443141492888886512949268228C829214D6CBBCFD406BD33DBF02
ASAM Dataset: EV_Brake1ZFESCEPBMEB 013164
ROD: EV_Brake1ZFESCEPBMEB.rod
VCID: 025D866F34874ABA49F-8056 SFD
69744 - Databus
U1121 00 [00101111] - Missing Message
[MSG_DIETA_01_TIMEOUT]
Mileage: 55024 km
Date: 2050.04.00
Time: 29:56:03
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 J HW: 5WA 959 436 J
Component: Kessy IOBOX 100 0725
Serial number: --------------- Dataset Number: V03935346TV 0002
ASAM Dataset: EV_Kessy37w 004024
ROD: EV_Kessy37w_004_VW38.rod
VCID: 5BE39B0BF3ADDB726A9-800E
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 1EA 907 727 AG HW: 1EA 907 727 Q
Component: Climatronic H01 0460
Coding: 000122017010120000100010110001102000102100101101000000000000
ASAM Dataset: EV_ACClimaBHBMEB31X 002015
ROD: EV_ACClimaBHBMEB31X.rod
VCID: 7F5B0F9B47752752261-802A
Air quality sensor:
A/C compressor sub:
Auxiliary Heater Control Module/PTC 2:
Interior temperature sensor:
Expansion valve 1 for refrigerant:
524050 - Body Control Module (Central Electric)
U0140 00 [00100111] - No Communications
[Lost Communication With Body Control Module 5]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
Address 09: Cent. Elect. (J519) Labels: 1EA-937-BCM-V1.clb
Part No SW: 1EA 937 089 Q HW: 1EA 937 089 H
Component: SAM_H H30 0307
Serial number: 01102205201214- Dataset Number: V03935345WV 0016
ASAM Dataset: EV_SAMVW31x 004001
ROD: EV_SAMVW31x_004_AUE3.rod
VCID: 4CC1685746434CCAF33-8018 SFD
Subsystem 1 - Part No SW: 10A 955 119 A HW: 10A 955 119 A
Component: FWISCHER_MYJT 003 0050
Serial number: 909353F0302200400614
Wiper motor control unit 2:
Subsystem 2 - Part No SW: 10A 955 120 A HW: 10A 955 120 A
Component: FWISCHER_SL02 003 0050
Serial number: 909453F0302204900399
Subsystem 3 - Part No SW: 5Q0 955 555 B HW: 5Q0 955 555 B
Component: RLHSS 054 0208
Serial number: S6Y22M04D13H15M31S31
Subsystem 4 - Part No SW: 5H0 941 193 AD HW: 5H0 941 193 AD
Component: LiSi H04 0513
Serial number: TW571411042200020010
Subsystem 6 - Part No SW: 5H0 959 561 AA HW: 5H0 959 561 AA
Component: -VW----LINDA- 503 0822
Serial number: MW3LND23022200011352
203016 - Unlock Switch in Rear Lid Handle
B140B 29 [00100111] - Signal Implausible
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
Terminal 15 status: On
Terminal 50 status: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 13.9 V
Outside temperature: 14.0 °C
0: not active
Position lamps: not active
automatic: not active
Low beam: not active
Malfunction: not active
197128 - Locking Module for Central Locking; Driver Side Rear
B1953 29 [00100111] - Signal Implausible
Mileage: 55024 km
Date: 2024.11.04
Time: 16:25:57
Status of brake lamp switch: discrete: On
Voltage: 13.9 V
0: not active
197384 - Locking Module for Central Locking; Passenger Side Rear
B1954 29 [00100111] - Signal Implausible
Mileage: 55024 km
Date: 2024.11.04
Time: 16:25:57
Voltage: 13.9 V
0: not active
951556 - Control Head for Driving and Comfort Functions
U115E 00 [00100111] - No Communcations
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:30
Voltage: 13.9 V
Outside temperature: 13.5 °C
0: not active
8667166 - Limp Mode
C10CA 00 [00100111] - -
[Limp home mode active]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
Voltage: 13.9 V
0: not active
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
Address 15: Airbags (J234) Labels: 1EA-959-655.clb
Part No SW: 1EA 959 655 DR HW: 1EA 959 655 DR
Component: VW40Airbag 010 0375
Serial number: W091NzE1FE4
Coding: 88CC008000F0C000000000200000000051540000A1540000C000F68000AB0065
ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
ROD: EV_AirbaVW40ALVVW38X_VW41.rod
VCID: 1471B0375EF3D40AEB3-8040 SFD
Address 16: Steering wheel (J527) Labels:* 1EA-953-507.clb
Part No SW: 1EA 953 507 N HW: 1EA 953 507 N
Component: GSMMEB 007 0072
Serial number: 000000210222260
Coding: 0000
ASAM Dataset: EV_SMLSKLOMEB 010001
ROD: EV_SMLSKLOMEB_010_VW49.rod
VCID: 42DD466F74078ABA09F-8016
Address 17: Instruments (J1254) Labels:| 10A-920-320.clb
Part No SW: 10A 920 320 C HW: 10A 920 320 A
Component: FAHRERDISPLAY 021 0531
Serial number: 1K1X1662-423557
Coding: E670
ASAM Dataset: EV_DashBoardLGMEB 001027
ROD: EV_DashBoardLGMEB_001_VWE4.rod
VCID: 1577CD335509CD029CD-8040 SFD
Address 19: CAN Gateway (J533) Labels: 1EA-937-012.clb
Part No SW: 1EA 937 012 P HW: 1EA 937 012 A
Component: ICAS1 Host-SG 072 0297
Serial number: SMERBG010322005 Dataset Number: V03935369C 0001
GVL: 2D0800002608508C8060904248180040C400400000060000000000000000DE57
ASAM Dataset: EV_GatewICAS1MEB 005001
ROD: EV_GatewICAS1MEB.rod
VCID: 3D2735930DF9F54274D-8068 SFD
Subsystem 1 - Part No SW: 1EA 915 181 B HW: 1EA 915 181 B
Component: J367-BDMConti H04 1074
Serial number: 7738610300220211013D
Subsystem 4 - Part No SW: 10E 959 442 A HW: 10E 959 442 A
Component: MFL H09 0312
Serial number: 17042684070202200662
7467521 - Data Set Implausible
B2012 00 [00100111] - -
[Data_set_implausible_CMS]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
7467522 - Data Set Implausible
[Data_set_implausible_HLC]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
951817 - Control head for driving and comfort functions
U115F 00 [00100111] - Implausible signal
[DiETa -> Datenbus unplausible Botschaft (Botschaftszähler)]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:30
7467526 - Data Set Implausible
[Data_set_implausible_ECM]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
65763 - Protection of Central Locking
B1691 54 [00100111] - Missing Calibration / Basic Setting
[Central_locking_protection_no_basic_setting]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
Address 23: Brake Booster (J539) Labels: Redir Fail!
Part No SW: 1EA 909 059 AN HW: 1EA 909 059
Component: EBB-ZF-Gen1 H28 0626
Serial number: ÿÿÿÿÿÿÿ
Coding: 189B2184003C1837843D00E220DE2020202020202021212121400404040404040404848484840208001000
ASAM Dataset: EV_BrakeBoostZFMEB 012153
ROD: EV_BrakeBoostZFMEB_012_VWE3.rod
VCID: 06559A7F18AF769A657-8052 SFD
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 1EA 905 861 HW: 2Q0 905 861 B
Component: ELV-MEB H09 0040
Serial number: 22000056126010
Coding: 8800000000000000
Shop #: WSC 00028 000 00000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 74B1D0B77E33740A4B3-8020
Part No SW: 1EA 959 593 E HW: 1EA 959 593
Component: TSG FS 004 0551
Serial number: 0000463826889 Dataset Number: V03935352QS 0002
Coding: 00351220D001848005001000
ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
VCID: 44D140776E13848A3B3-8010
Door operating panel: driver side:
Subsystem 1 - Part No SW: 10A 959 862 AE HW: 10A 959 862 AE
Component: EX36 TBF_FS H22 0110
Serial number: 0529-24.02.22-------
Subsystem 2 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000057644866
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 1EA 907 144 AQ HW: 1EA 907 144 H
Component: BASGEN1MQB37 246 5033
Serial number: 00995882 Dataset Number: V03935358SE 0002
Coding: 00000000000002010000020101000100000001000101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 009050
ROD: EV_SteerAssisBASGEN1MQB37_009_VW27.rod
Address 51: Electric Drive (J841) Labels: 1EA-907-121.clb
Part No SW: 1EA 907 121 BD HW: 1EA 907 230
Component: MEB INV4.0 H09 3506
Serial number: VES_P2001097257
ASAM Dataset: EV_DMCM17000F11EA907121BD 001013
ROD: EV_DMCM15000F11ED907121AQ_VWE3.rod
VCID: 71BFD9A301214122A05-8024
No ASAM data for: "EV_DMCM17000F11EA907121BD" (SEE3)
Part No SW: 1EA 959 592 E HW: 1EA 959 592
Component: TSG BFS 004 0551
Serial number: 0000462763663 Dataset Number: V03935352QT 0002
Coding: 00351020DC01048001801000
ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
VCID: 43D3436B6B1D83B2029-8016
Subsystem 1 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000057693353
Part No SW: 10E 035 816 H HW: 10E 035 816 A
Component: IC3-SF-AR-EU H30 0561
Dataset Number: V03935346WQ 0006
Coding: 43101068000100000000000000000000000000000000000000
ASAM Dataset: EV_MUICASSAFEPart 001001
ROD: EV_MUICASSAFEPart_001.rod
VCID: 2517FDF385695D820CD-8070 SFD
Subsystem 1 - Part No SW: 5FA 919 606 A HW: 5FA 919 606 A
Component: ABT_W_12 H43 6085
Serial number: APUFF409042200040173
Address 6C: Back-up Cam.
Part No SW: 10A 035 284 G HW: 10A 035 284
Component: OCUGen4 H19 0538
Serial number: 0000000112VIHJ5 Dataset Number: V03935344HC 0005
Coding: 04310610106880008005460060000000
ASAM Dataset: EV_OCUGen4 001031
ROD: EV_OCUGen4_VWE3.rod
VCID: 1F1BEF1BA7358752461-804A SFD
Address 82: Head Up Display (J898) Labels: None
Part No SW: 10C 919 608 D HW: 10C 919 608 C
Component: HeadupDisplay H10 0146
Serial number: ARHUD
ASAM Dataset: EV_ARHeadUpDisplMEB 001036
ROD: EV_ARHeadUpDisplMEB_001.rod
VCID: 290FF1C3E97179E2285-807C
Address 8C: HV Battery (J840) Labels: 0Z1-915-184.clb
Part No SW: 0Z1 915 184 J HW: 0Z1 915 184 D
Component: J840 K8C BMC 010 1041
Serial number: 000000030322160 Dataset Number: V03935364KM 0001 CVN: 9534C8BD00000000000000000000000000000000
ASAM Dataset: EV_BMCeVWBSMEB 002015
ROD: EV_BMCeVWBSMEB_002_VWE3.rod
VCID: 41DF4963710191A2105-8014
Cell module control module 1:
Subsystem 1 - Part No SW: 0Z1 915 140 BE HW: 0Z1 915 140 BC
Component: SX6 X74 CMC 005 1000
Serial number: 00000022022204070121
Cell module control module 5:
Subsystem 2 - Part No SW: 0Z1 915 140 F HW: 0Z1 915 140 D
Serial number: 00000015022204070039
Cell module control module 9:
Subsystem 3 - Part No SW: 0Z1 915 140 F HW: 0Z1 915 140 D
Serial number: 00000015022204060043
Coolant heating:
Subsystem 4 - Part No SW: 1EE 963 231 HW: 1EE 963 231
Component: J848 HV-PTC H04 0020
Serial number: 1EE96323122007000631
Address A5: Frt Sens. Drv. Assist
Address C0: Act. for Ext. Noise
Address C6: Batt. Chrg. (J1050) Labels:| 1EA-915-684.clb
Part No SW: 1EA 915 684 EA HW: 1EA 915 684 BK
Component: HV_CHARGER H60 1019
Serial number: 93286UFL000A2
Coding: 1080
ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002017
ROD: EV_OCCXPhase1KLOMEB01B.rod
VCID: 7EA5F29F407F2E5A2D7-802A
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
Address 8105: DC/DC Converter 12V (A19) Labels: 1EA-907-190.clb
Part No SW: 1EA 907 190 G HW: 1EA 907 190 G
Component: DCDC Gen4H13 1142
Revision: 00H13000
ASAM Dataset: EV_DCDC10030111EA907190G 001022
ROD: EV_DCDC10030111EA907190G.rod
VCID: 3829248722DBD06AA7B-806C
Address 8107: Antenna (J666) Labels:* None
Part No SW: 1EA 035 741 G HW: 1EA 035 741 D
Component: TrxModulHigh H07 0221
Serial number: 0000000112VIKE7
Coding: 043106110402C0
ASAM Dataset: EV_TrxMLGEMEB 006014
ROD: EV_TrxMLGEMEB.rod
VCID: 323D16AFC4A73A3A99F-8066 SFD
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 D HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002_VW38.rod
VCID: 49CF5143493159E2C85-801C
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4) Labels: V04-007-XXX-SWC4.clb
Part No: V04 007 005 AB
Component: ICAS1 Sys_Ada 0297
Dataset Number: V03935353RU 0002
ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
ROD: EV_AppServe1Syste1ICAS1.rod
VCID: 698FB1C329F1B9E2E85-803C SFD
Address 8124: App server 1 system 2 Java (SWC5) Labels: V04-007-XXX-SWC5.clb
Part No: V04 007 005 AC
Component: ICAS1 Sys_Jav 0297
ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
ROD: EV_AppServe1Syste2ICAS1.rod
VCID: 6A8DCECF2CF7B2FAE1F-803E SFD
Address 8125: App server 3 system 1 infotaint. (SWC6) Labels:| V04-007-XXX-SWC6.clb
Part No: V04 007 003 HQ
Component: IC3-IVI-D-EU 0561
Dataset Number: V03935346SH 0012
ASAM Dataset: EV_MUICASIVIPart 002007
ROD: EV_MUICASIVIPart_002.rod
1637 - Interface for External Media
U11B8 00 [00001001] - No Communications
[USB - communication error]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:39
Voltage terminal 30: 13.8 V
Interface for external media: status: Open circuit
Address C002: SW Cluster Embedded (SWC2) Labels: V04-007-XXX-SWC2.clb
Part No: V04 007 005 AD
Component: ICAS1 SWCL_Em 0297
Dataset Number: V03935350HK 0006
ASAM Dataset: EV_SWCLEmbed1ICAS1 005001
ROD: EV_SWCLEmbed1ICAS1.rod
VCID: 6B83CBCB230DABF29A9-803E SFD
7467527 - Data Set Implausible
[Data_set_implausible_ECP]
Mileage: 55024 km
Date: 2024.11.04
Time: 16:07:25
Address C003: SW Cluster Housekeeping (SWC3) Labels: V04-007-XXX-SWC3.clb
Part No: V04 007 005 AE
Component: ICAS1 SWCL_HK 0297
ASAM Dataset: EV_SWCLHouse1ICAS1 005001
ROD: EV_SWCLHouse1ICAS1.rod
VCID: 6C81C8D72603ACCA933-8038 SFD
End----------(Elapsed Time: 02:12, VBatt start/end: 13.3V/13.8V)-----------
