DQ200 basic settings
Rektafrent
Pirate
Walking the Plank
Wigan, UK
Hi am doing basic settings on my DQ200 and I am receiving 96 under status of basic setting-Basic Setting Status.
I’m unsure what this figure is relating too as I cannot find anyone with the same issue.
comes up with aborted due to malfunction
Rektafrent
Pirate
Walking the Plank
Wigan, UK
Removed.  Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
  • Disagree
TTT
C?ID=547002
Re-post and do not remove any text from auto scan.
Rektafrent
Pirate
Walking the Plank
Wigan, UK
TIME    Loc. IDE02824-ENG99279    TIME    Loc. IDE02825-ENG100313    TIME    Loc. IDE02826-ENG120866
STAMP    Main status of abort code basic setting-Basic Settings Main Status    STAMP    Substatus of abort code basic setting-Basic Settings Sub Status    STAMP    Basic setting sequence index-Basic_Settings_Flow_Index
Rest Removed.  Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
  • Disagree
TTT
C?ID=547002
What’s the backstory? Gearbox shows no faults.
Rektafrent
Pirate
Walking the Plank
Wigan, UK
Gearbox casing took a hit so had to get a full new box.
Worked in all gears yesterday but was slipping / shifting weird
siLc
Tallinn, Estonia
C?ID=330192
   Part No SW: 0CW 300 040 P    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1002
Doesn't look like a correct 0CW DQ200 mechatronic software for 1.8 TSI DAJB.
Look at the TCU measuring blocks. There is a channel, which contains the software identification string. For your vehicle it should be something like "FL_0CW300040B_0902_LDQV_sw". If not, please write it here.
Rektafrent
Pirate
Walking the Plank
Wigan, UK
Hi I cannot get into measure blocks -08 I can only get into advance meas values or advanced ID
TTT
C?ID=547002
Same thing.
Rektafrent
Pirate
Walking the Plank
Wigan, UK
All the software ones only returned a value no strings
Sorry I am fairly new to VCDS but the mechatronics is the original out of my car and was working yesterday through all gears but as I say they was choppy + sloppy and was recommended to run basic settings and re adapt the learning, if the software is wrong how would I rectify this ?
TTT
C?ID=547002
If the mechantronics is the same, software is the same. But indeed, that would not match another gearbox plug&play. Are you sure the replacement has the same part number?
Rektafrent
Pirate
Walking the Plank
Wigan, UK
The gearbox was the same code as the one taken out, I did install it originally with the mechatronics that came on the box but I got immobilizer active
siLc
Tallinn, Estonia
C?ID=330192
Of course. You can't swap 0CW DQ200 mechatronics willy-nilly as they are part of the immo.
Rektafrent
Pirate
Walking the Plank
Wigan, UK
Yeah I had done the same swap previously 6 months ago and just seating my mechatronics worked fine, the basic settings runs through but fails after turning car on for 4 minutes
Rektafrent
Pirate
Walking the Plank
Wigan, UK
What would be my best course of action from here
