Identifying wheel circumference setting specifications
boostin20v
NY, USA
C?ID=13456
In my 2021 B9.5 SQ5 I found this setting for defining wheel circumference. Is there documentation as to what each of the available drop down option circumferences are?
boostin20v
NY, USA
C?ID=13456
Unfortunate. Any thoughts on how one could test the configurable choices? I feel that my car reads a bit higher than it should compared to phone GPS even with stock sized tires.
Westbury, UK
That's totally normal and expected - the speedo has to never under read and not over read by more than 10%, so it's normally calibrated at the factory to read around 5-7% high.
Why not make another selection and observe its impact on your cluster reading?
Can be dangerous. In some clusters, changes to that are one-way only, i.e. irreversible.
Interesting.... I recall reading about speed limiters doing that, but this is the first I've heard of wheel specs.
I can't remember what vehicle it was. Might have been an Amarok or a current-gen Crafter van, but once you went to to a circumference/K-number that corresponded to a bigger tire size, it wasn't possible to go back.
Yeah, I believe Amarok or Transporter for sure. In addition, based on memory the 7P type of T'reg did non-desirable things if you changed the CCS versus ACC coding positions in address 17.
boostin20v
NY, USA
C?ID=13456
Yikes...well there goes any fiddling.
boostin20v
NY, USA
C?ID=13456
Ignoring Uwe's new info, I think you're missing the point. The fact that changes can be made is much of the reason anyone reads these forums...if I'm unsatisfied with a 5-7% high reading I have every right to explore what options exist to counter act that.
NEtech
Denmark
C?ID=56995
Please post an Autoscan.
16 out of 35 Autoscan I have, are coded 05 for Byte 3
19 out of 35 Autoscan I have, are coded 04 for Byte 3
For (FY) model.
But you have been warned:)
boostin20v
NY, USA
C?ID=13456
For (FY) model.
Thursday,07,November,2024,18:04:25:64390
VIN: WA1B4AFY2M210xxxx   License Plate:
Chassis Type: FY-AU49 (80C)
Scan: 01 02 03 08 09 13 15 16 17 19 32 36 3C 42 44 46 52 5F 69 6C
          6D 74 75 81 8B A5 A9 BB BC CA CF D6 D7 DE
VIN: WA1B4AFY2M210xxxx   Mileage: 51589km-32055miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD)       Labels:. 06M-907-309-V1.clb
   Part No SW: 80A 907 559 G    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0002
   Revision: B8H11000    CVN: D74EC72E
   Coding: 2A2A0032257E010E34280000000000000000000000000000
   ASAM Dataset: EV_ECM30TFS01180A907559G 001002
   ROD: EV_ECM30TFS01180A907559G.rod
   VCID: 33331DC33BBAD0F2929-8066
   VINID: 9D10521115A909D08100218004FA531E2F
28212 - Exhaust Pressure Control Valve 2
          P049F 00 [00101111] - Malfunction
                    Mileage: 50961 km
                    Date: 2024.11.01
                    Time: 12:31:27
                    Engine RPM: 0.00 /min
                    Coolant temperature: 42 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 11.800 V
                    Engine status: COENG_READY
   Part No SW: 80A 927 158 K    HW: 0D5 927 156 N
   Component: 0D5 30TFSINAR H06 0002
   Revision: --H06---    CVN: A99F9FD3
   Coding: 100000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011.rod
   VCID: 34311EDF3EB4D7CA8B3-8060
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 80A 907 379 AF    HW: 80A 907 379 H
   Component: ESP9 Premium  H17 0871
   Dataset Number: 80B909504AH 0005 CVN: D8C32A21
   Coding: 1CAA14BE30A20A9893A458915A7E52A2E5359A38280C50C91A5A4A45A7AC59
   Shop #: WSC 62320 003 1048576
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 73B3DDC37B3A90F2529-8026
   Part No SW: 80A 820 043 T    HW: 80A 820 043 T
   Component: Klima Zone 3  H60 0270
   Coding: 6608090D5544000D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2E050CB7D098FD1AFD7-807A
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000005918210
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H05 0010
   Serial number: A9C50E8400PAG0MUFU04
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W1 907 063 AG    HW: 8W1 907 063 G
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 80C909514A  0012
   Coding: 87000363E0691CCD050D87099CBE9CB9110B35490000009401010A00200016010861013B0257090000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 015F870B3186B262505-8054
   Subsystem 1 - Part No SW: 80B 955 119 B    HW: 80B 955 119
   Component: 426 LL 210414  041 0590
   Serial number: 00000002104132105501
   Coding: FFC7F7
   Component: G397_RLFSS  H06 0004
   Serial number: 40971891X81A955555B0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AN    HW: 4M0 941 531 AN
   Component: E1 - LDS  H07 0008
   Serial number: 27 04 2021  11170916
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z008402
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR112042123311394
   Interior Light Module:
   Subsystem 6 - Part No SW: 80A 947 135 BJ    HW: 80A 947 135
   Component: Dachmodul  H42 0415
   Serial number: Q00051935
   Coding: 0D0101
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H08 0210
   Serial number: WA146109000095842262
   Coding: 0A0700
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 80A 907 561 C    HW: 8W0 907 561
   Component: LRR4          H12 0451
   Dataset Number: 80B909863J  0004
   Coding: B57687FA58FFEC06747861A1
   ASAM Dataset: EV_ACCBOSCHAU49X 003024
   ROD: EV_ACCBOSCHAU49X_003_AU49.rod
   VCID: 2809FAAFF27CA32A37B-807C
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 239
                    Mileage: 51243 km
                    Date: 2024.11.03
                    Time: 09:42:18
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 13.1 V
                    Vehicle speed: 2.66 m/s
                    Longitudinal acceleration: 0.42 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
   Part No SW: 80A 959 655 T    HW: 80A 959 655 T
   Component: AirbagVW30    004 0703
   Serial number: 0032SM00SHKY Dataset Number: 80A909602AA 0016
   Coding: AECCFCC000800000A000003FF20C400000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   VCID: 44D14E1F6E14674A3B3-8010
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 80A857705P0015V00835
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 80A857706P0016V01059
   Coding: 80000D
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH0000D21000FSQM10P
   Coding: 303039
   Subsystem 4 - Part No SW: -----------    HW: 480 002 302 21
   Serial number: 35700000000C3574A15J
   Subsystem 5 - Part No SW: -----------    HW: 480 002 402 21
   Serial number: 35800000000DAB4DA15/
   Subsystem 6 - Part No SW: -----------    HW: 480 031 203 21
   Serial number: 351002C180B42DB00C98
   Subsystem 7 - Part No SW: -----------    HW: 480 031 303 21
   Serial number: 352002C180B4A8E13E8K
   Subsystem 8 - Part No SW: -----------    HW: 480 031 803 21
   Serial number: 355002C1863D96D0B89S
   Subsystem 9 - Part No SW: -----------    HW: 480 031 803 21
   Serial number: 356002C180B268D0E88L
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 102 21
   Component: CentrSensorXY  005 0108
   Serial number: I0O0001BCC1BE762E77I
   Part No SW: 80A 907 129 DH    HW: 80A 907 129 DH
   Component: Lenks.Modul   H03 0009
   VCID: 71BFD7CB0126A2E2A05-8024
   Part No SW: 80A 920 790 J    HW: 80A 920 790 J
   Component: FBenRDW------ H10 0161
   Coding: 83CF3EC57EA8CF050280636018002B0208003000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU49.rod
   Part No SW: 80C 907 468 F    HW: 80B 907 468 B
   Component: Gateway       H07 0613
   Serial number: 1RF02236080201 Dataset Number: 8W0909515Q  0034
   Coding: 030300010000064054070000005900327C9A0001980000000100008E00000000
   GVL: 01503C5008000000C0DCC8008002C800110C0000000000000000000000006500
   ASAM Dataset: EV_Gatew31xAU65x 003250
   ROD: EV_Gatew31xAU65x_AU49.rod
   Subsystem 1 - Part No SW: 80A 951 523 M    HW: 80A 951 523 M
   Component: J453 MFL  H08 0004
   Serial number: 20210224181154 01087
   Serial number: 3220448100
   Subsystem 3 - Part No SW: 80A 419 508 B    HW: 80A 419 508 B
   Component: J1158 KLR  H03 0007
   Serial number: 21048017603S0007H032
131830 - Ethernet Module for Emergency Call
          U1642 00 [00001000] - No Communication
          [Timeout_Node_0xF6_conBox_DiagAdress_0075]
                    Reset counter: 241
                    Mileage: 51151 km
                    Date: 2024.11.02
                    Time: 21:42:46
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163 A    HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0070
   Revision: 5WK12701    Serial number: 605106123200107
   Coding: 0001
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   VCID: 3A2D30E71CD021BA51F-806E
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 12A14110900541 Dataset Number: 80B909856C  0014
   Coding: 015C1A000000B0010003010101010000000000000000000000000000004000
   VCID: 7BA3F5E3536AD8B20A9-802E
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 80A 907 566 B    HW: 80A 907 566
   Component: MRR1Rear      H23 0441
   Revision: --------    Dataset Number: 80B909535C  0006
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 2C0106BFE6848F0AD33-8078
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0430
   Serial number: CLSM1UDO003JZ Dataset Number: 80B909872F  0046
   Coding: 005F8B005E00148000010032
   VCID: 46D554175828555A257-8012
196711 - Motor for Window Regulator
          B1487 29 [00001000] - Signal Implausible
                    Reset counter: 242
                    Mileage: 51464 km
                    Date: 2024.11.04
                    Time: 22:12:29
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 242
                    Mileage: 51464 km
                    Date: 2024.11.04
                    Time: 22:12:29
   Dataset Number: 80B909852M  0001
   Coding: B0002101000101
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D18C7C4A0D9FA99F-8066
   Part No SW: 4N0 907 064 EP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H16 0224
   Dataset Number: 80C909501B  0013
   Coding: 013400004FB100C0650BA0006C01D802030040008104A6502F0000000F04803F001E0680000A31
   ASAM Dataset: EV_BCM2CONTIAU651 011009
   ROD: EV_BCM2CONTIAU651_011.rod
   ID - sensor:
   Serial number: 000000000ZY210852HLY
   Serial number: 00000000000049527039
   Subsystem 4 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38477604
   Rear spoiler control module:
   left tail lamp 2:
   Subsystem 6 - Part No SW: 80A 945 429 E    HW: 80A 945 429 E
   Component: T2 LH SAE  H10 0503
   Serial number: 00G
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 80A 945 430 E    HW: 80A 945 430 E
   Component: T2 RH SAE  H10 0503
   Serial number: 2EI
65676 - Sensor for Rear Lid/Hatch Opening
          B1337 13 [00001001] - Open Circuit
                    Reset counter: 193
                    Mileage: 50961 km
                    Date: 2024.11.01
                    Time: 12:31:26
                    Supply voltages-Terminal 30 power supply: 12.012 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 11.984 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 11.949 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 60
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0430
   Serial number: CLSM1UDD000VM Dataset Number: 80B909873F  0046
   Coding: 005F8B005E00148000010030
   VCID: 45D7531B652E5E422CD-8010
   Part No SW: 80A 035 050 H    HW: 80A 035 050
   Component: MU-TH-NS-US   042 3696
   Serial number: 8VV-DDM28.04.21 Dataset Number: 8W1909545J  0045
   Coding: 14260000804220000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU49.rod
   VCID: 1E65DC77A0386D9A4D7-804A
   Multimedia System 1:
   Subsystem 1 - Part No SW: 80B 919 620     HW: 80B 919 620
   Component: CenterDisplay  H41 0160
   Serial number: AUZ8Z9M6H01UBB
   Subsystem 2 - Part No: V03 959 820 KQ
   Component: MIB3_NA_       0956
   Compact disc data bank:
   Component: Gracenote2     3004
   Volume Control 1:
   Subsystem 4 - Part No SW: 80B 919 616 A    HW: 80B 919 616 A
   Component: LSR-Q5PA       H20 0103
   Serial number: ALJAL223122000050733
   Media socket:
   Subsystem 5 - Part No: 8W0 035 708 A
009 0007
   Digital Sound System Control Module 2:
   Subsystem 6 - Part No SW: 8Y0 035 465     HW: 8Y0 035 465
   Component: B_A_3_P_0_AU   H10 0140
   Serial number: C5B-26028.04.2166610
          B201A 00 [00001001] - -
                    Reset counter: 193
                    Mileage: 50961 km
                    Date: 2024.11.01
                    Time: 12:31:24
                    Voltage terminal 30: Write only channel V
                    module_name: Write only channel
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0563644232 Dataset Number: 80B909527A  0008
   Coding: 0210000200000000
   VCID: 353723DB35CECEC2BCD-8060
   Part No SW: 8W0 907 428 B    HW: 4M0 907 428
   Component: Areaview 2    H16 0107
   Serial number: C854609JJ005088 Dataset Number: 80B909460M  0019
   Coding: 02240602BB0FA10038004000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 002001
   ROD: EV_CamSysRVAV2CE2MLBPA_002.rod
   VCID: 3FDB41F307F20492661-806A
   Part No SW: 4KE 959 107     HW: 4KE 959 107
   Component: HDSG-Modul    H04 0330
   Revision: --------    Serial number: A2-C772-8040-3 Dataset Number: 80B909541E  0014
   Coding: 07A0
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_AU49.rod
   VCID: 03538D032B9AA072429-8056
0054 - Databus
                    Fault Frequency: 180
                    Reset counter: 1
                    Mileage: 50961 km
                    Date: 2024.11.01
                    Time: 17:05:34
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 80A 907 777 AK    HW: 80A 907 777 C
   Component: Fahrwerk-SG   H38 1253
   Serial number: 0902211749  Dataset Number: 80B909576AA 0001
   Coding: 94603832F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 7AADF0E75C50E1BA11F-802E
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132230794
   Coding: 303030
   Part No SW: 4KE 035 283 F    HW: 4KE 035 283 B
   Component: CB_H_NAR      041 0372
   Serial number: A971C0MS170780 Dataset Number: 8W0909612H  0025
   Coding: 01E0E0F8C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_AU49.rod
   Part No SW: 80B 713 041 AC    HW: 80B 713 041 AC
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20210425000449
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 5EE59C77E0B82D9A0D7-800A
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541 C    HW: 8W0 907 541
   Dataset Number: 80B909885F  0002
   ASAM Dataset: EV_ACC2BOSCHAU49X 003024
   ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
   VCID: 2615F497F868B55A057-8072
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 F    HW: 80A 907 217 D
   Component: BVS           H28 0070
   Dataset Number: 80B909466F  0037
   Coding: 0404020600000204022023AFAD0000FEA0F0C020C020
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 290FFFABE9769A22285-807C
1123220 - Databus
          [KLR_01_KLR_Touchauswertung]
                    Reset counter: 239
                    Mileage: 51243 km
                    Date: 2024.11.03
                    Time: 09:42:18
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 13.00 V
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Serial number: 210119202209
   VCID: 6889BAAF32FC632AF7B-803C
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0430
   Serial number: CLSM1UD5000RY Dataset Number: 80B909897G  0048
   Coding: 000F89000000148040000020
   VCID: 48C95A2F523C432AD7B-801C
   Component: TSG HBFS004 0430
   Serial number: CLSM1UD50009X Dataset Number: 80B909896G  0048
   Dataset Number: 80B909469G  0012
   Coding: 22804004260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7E3DB754E8EC27CD-8020
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 80A 907 590 B    HW: 80A 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   Part No SW: 4K0 941 572 DD    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H06 0040
   Dataset Number: 80B909471F  0011
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   Dataset Number: 80B909472F  0011
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 80A 035 502 B    HW: 80A 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 1A6DD067BC1001BAB1F-804E
End----(Elapsed Time: 02:26, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
