Audi rs6 c7 steering wheel slightly off-centre after new steering rack
liverpoolphil
C?ID=573380
As the title says, I fitted my reconditioned power steering unit and with the wheels straight the steering angle sensor is hovering around 0 degrees but the steering wheel itself is slightly off-centre. I'm fully aware there's a mechanical (alignment) route to take and more than happy to take it, I've also read some stories about folk removing the wheel and moving it a notch or two but this seems ill-advised and often only seems to make the wheel off-centre in the opposite direction so less happy to try this. I'm wondering if VCDS can help me 'tweek' things but still a bit new to it all and not confident enough to be going through settings / I can only see it ending badly for me and with my other car off the road definitely could do without
Any help advice would be appreciated - auto-scan below
Sunday,03,November,2024,13:02:41:50316
VIN: WUAZZZ4G8HN904219   License Plate: PH51PPH
Mileage: 79869km-49628mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 22 28 30 34 36 3B 42 44 46 52
          53 55 5F 62 65 6D 72 85 BA 47
VIN: WUAZZZ4G8HN904219   Mileage: 79869km-49628miles
Address 01: Engine (------CWUC)       Labels: Redir Fail!
   Part No SW: 4G0 906 560 F    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0003
   Revision: NCH63---    CVN: 148E177A
   Coding: 122A00326526010B2800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906560F 001004
   ROD: EV_ECM40TFS0114G0906560F.rod
   VCID: 2B031750D3897892DA9-807E
   VINID: 9E546AAAA11721878900408124B5B88353
Readiness: 0110 1001
   Part No SW: 4G0 927 158 BH    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H22 1010
   Revision: --H22---    CVN: DCB4FFF1
   VCID: 75B7F128454D7E627CD-8020
   Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
   Component: ESP9 Premium  H01 0100
   Coding: 62B7DA4146ED5B829F00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 42DD5AF4440399DA09F-8016
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B9704E000000000000
   VCID: 7CA1E40C66E72F2A033-8028
   Serial number: 3216000301552010
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 13021700041040
   Coding: 68221078050000
   VCID: 6A8DD2541CF3A19AE1F-803E
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001598161101
   Coding: 0105001440349FE0690140C7A0001800CF9DC70A2F08020180000894E100170200400024030000
   VCID: 74B1CC2C4EB7676A4B3-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 161121  H38 0080
   Serial number:         170105133130
   Coding: 0045F7
   Serial number: 20121801X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 17 02 2017  00000020
   Component: EVLS-SG  H08 0300
   Serial number: WA125963000027504236
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 36E8439800PAG0MUFU03
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100CUUT1 Dataset Number: 4G0909602M  0003
   Coding: 30333130313730323737554A305234473053
   VCID: 3B23271023E9E8124A9-806E
   Serial number: 3575HRB40654D4Q8B0B
   Serial number: 3585HRB400I57HGC5GUY
   Serial number: 3515JRB400Q599U08PBQ
   Serial number: 3525JRB401259BLKBOIQ
   Serial number: 3554VRB405P4958U6GUD
   Serial number: 3564VRB405D4958UF8DT
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QBD000FE
   Coding: 000035
   VCID: 372B3B201F41CC72AE1-8062
   Subsystem 1 - Part No SW: 4G0 951 528 J    HW: 4G0 951 528 J
   Serial number: 26 01 2017  E0036663
   Part No SW: 4G0 920 982 T    HW: 4G0 920 982 T
   Component: TBenGb    Nv  H15 0225
   Revision: 15001308    Serial number: 658220217596030
   Coding: 33AF910B9B412600010400
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 3D2729083DFDE62274D-8068
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002538042 Dataset Number: 4G0909515N  0025
   Coding: C0ED07481C
   GVL: FD83C8D8DCA9600101040000
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 7274513004
   Voltage stabilizer:
   Serial number: 161217000000000004B1
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 001602170001015 Dataset Number: 4G0909104B  0023
   VCID: 2809E85CC27F538A37B-807C
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 20021700041115
   Coding: 22
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000001657
   Coding: 01010101000000000001000102
   VCID: 6491BC6CFE57F7EADB3-8030
   Dataset Number: 4G0909553G  0036
   Coding: 008000
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2F3B0340E79104B2F61-807A
   Revision: AA000000    Serial number: 00000241487673
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77ABFB205FC10C726E1-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02N030 Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B3B201FC1CC72AE1-8062
   Component: TSG FA        H03 0511
   Coding: 011F16015E21620002080002
   VCID: 47CB4BE06FA1BCF2DE1-8012
   Part No SW: 4G0 909 144 AA    HW: 4G0 909 144 G
   Component: RCEPS         H35 0013
   Revision: 00001000    Serial number: 0002156156
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 6889A85C02FF938AF7B-803C
   Revision: 00002001    Serial number: 0430756224
   Coding: 013B0622A0B93880C3300984000113470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00029951509
   Component: TSG BF        H03 0511
   VCID: 46D546E468ABA5FA257-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002116635 Dataset Number: 4G0909522G  0001
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 323D0A34F4A3295A99F-8066
   Revision: --------    Serial number: -------------- Dataset Number: 4G0909865D  0019
   Coding: 04FE02202A130200
   VCID: 34310C2C0EB7276A8B3-8060
   Coding: E01F00
   Coding: E01F00
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 020 G    HW: 4G1 035 020 D
   Component: MU-H-ND-EU    053 0910
   Serial number: A735B0H7521428 Dataset Number: 4G1909545G  0040
   Coding: 017562010000000013111102000A00002F0008E7F1700100DF
   VCID: 1D67C9889D3D862254D-8048
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY8075T1
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349QBF000ME
   Compact disc data bank:
   Component: Gracenote2  --- 1015
   Component: TSG HL        H03 0511
   Coding: 010F14004021620002080002
   VCID: 49CF4DD879B54A82C85-801C
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000037896 Dataset Number: 4G0909850C  0004
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A0D1254DC73619A21F-807E
12652551 - Tire Pressure Monitoring
          C10DC 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 48
                    Mileage: 79865 km
                    Date: 2024.11.03
                    Time: 11:51:35
8397058 - Front Left TPMS Sensor
          C1050 31 [00001001] - No Signal
                    Reset counter: 48
                    Mileage: 79866 km
                    Date: 2024.11.03
                    Time: 11:54:33
8397314 - Front Right TPMS Sensor
          C1051 31 [00001001] - No Signal
                    Reset counter: 48
                    Mileage: 79866 km
                    Date: 2024.11.03
                    Time: 11:54:33
8397570 - Rear Left TPMS Sensor
          C1052 31 [00001001] - No Signal
                    Reset counter: 48
                    Mileage: 79866 km
                    Date: 2024.11.03
                    Time: 11:54:33
8397826 - Rear Right TPMS Sensor
          C1053 31 [00001001] - No Signal
                    Reset counter: 48
                    Mileage: 79866 km
                    Date: 2024.11.03
                    Time: 11:54:33
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0152
   Revision: 14005001    Serial number: 024701697 Dataset Number: 4G0909541E  0005
   Coding: 093205C010
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 3635362418CB357AB57-8062
   Component: TSG HR        H03 0511
   Component: DPC-SG        H28 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G0909547D  0008
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01144CD6877FAAD33-8078
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813008005601 Dataset Number: 4G0909578B  0013
   ROD: EV_AEMLearAU64X_AU57.rod
   Part No SW: 4G5 035 223 E    HW: 4G5 035 223
   Component: MIB2_amp_P    H03 0440
   Serial number: 00000000018234 Dataset Number: 4G1909510Q  0013
   Coding: 01756208018AF02A5A0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 2411FC6CBE57B7EA1B3-8070
End----(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
Derek
UK (ilexa)
C?ID=56983
Hello
What's the steering wheel like when you drive straight?
I think you'll need go the mechanical alignment route, but the autoscan is missing lots of modules and details, and in case there's any coding or adaptations that need doing, would you run another and see if it has all the modules showing, and if it has then post the full scan.
Best regards
Derek
I don't think you're going to fix "Steering - Mechanical Failure" and "Position Sensor for Motor - Signal Implausible" with a scan tool.
liverpoolphil
C?ID=573380
I'm sorry I copied the incorrect auto-scan so have edited the original post with the correct one
liverpoolphil
C?ID=573380
Hello
Best regards
Derek
Sorry Derek, I posted the incorrect auto-scan which has now been corrected in the OP
Morski
Cheshire, UK
C?ID=90186
You need a decent 4 wheel alignment. Protyre have branches around and they use the hunter system. Had my RS6 done from them and worked great, however you need a decent technician to carry out the work. They will affix the steering in the dead centre position and then adjust the track rod ends to the correct postion.
Derek
UK (ilexa)
C?ID=56983
The new scan looks better and it's clear of related faults. When you have the alignment done, as long as the adjustment isn't too much, the steering angle will probably be recalibrated as you drive. But if the adjustment is a lot, you might need to run the calibrations yourself afterwards
Best regards
Derek
Morski
Cheshire, UK
C?ID=90186
Just be aware that after a 4 wheel alignment you might see lots of warning lights suddenly appear (mine did twice), 4wd, esp etc. shold clear with a quick drive and or with vcds.
