Resolved Function not supported by gateway
Resolved
Newwave
Wales, UK
C?ID=190383
Hi, this is the first time in 12 years of using VCDS that ive had this message. can not get passed this message whatever i try. Any ideas please? the vehicle is a 2018 transporter. Thanks in advance.
Derek
UK (ilexa)
C?ID=56983
Hello
Have you scanned this vehicle before?
Make sure the ignition is on, and also try running the scan by choosing the chassis type from the drop down list (chars 7 and 8 from the VIN)
Post the scan if it works and that will show more
Best regards
Derek
Can you directly enter any address such as the engine or CAN BUS?
Newwave
Wales, UK
C?ID=190383
Hello
Best regards
Derek
Hi no not scanned before, and cant choose chassis, it says the same thing whatever i try.
Derek
UK (ilexa)
C?ID=56983
Try individual modules as Crasher suggested.
Also, is this a running van?
Does it show ignition and battery voltage as above 12v on the failed scan?
Best regards
Derek
Newwave
Wales, UK
C?ID=190383
Best regards
Derek
Hi yeah its running van and battery life is good
Derek
UK (ilexa)
C?ID=56983
If you choose VCDS / Select / engine. Does it connect to the engine?
Battery life is good, but does it show ignition and battery voltage as above 12v on the failed scan?
Best regards
Derek
Newwave
Wales, UK
C?ID=190383
Best regards
Derek
Hi yeah does show battery at 12.2v and when i go into engine it say no response from controller.
Derek
UK (ilexa)
C?ID=56983
Does it show ignition voltage on the scan and if yes, is it above 12v
What type of interface do you have?
Open VCDS, choose options / test and post the screenshot of the result
In Options, click restore defaults, click save, close VCDS, reopen VCDS and retry engine
Best regards
Derek
Newwave
Wales, UK
C?ID=190383
Best regards
Derek
Derek
UK (ilexa)
C?ID=56983
I don't think so. Would you post a picture please
(You bought your VCDS from me so you're welcome to give me a call and we can go through some tests quickly on the phone)
Best regards
Derek @ ilexa
Newwave
Wales, UK
C?ID=190383
Best regards
Derek @ ilexa
Hi Derek, found out what was going on, theres something plugged into original port, maybe something to do with an anti theft device? Unplugged it and all good now. Thanks very much for your help. Martin
Eric
HC800000
Pictures please! :popcorn:
Derek
UK (ilexa)
C?ID=56983
Great! glad it's sorted
Best regards
Derek
