- Sep 28, 2024
- 73
- 6
- Eureka, CA, USA
- C?ID=598147
Im not sure why but I have a crank no start issue and cant seem to figure out what the problem is. I do see that when comparing my old VCDS scans to the latest one that the CVN has changed which I believe means the ecu software has been changed (mine hasnt) so I am assuming it is corrupted? Is there anyway to code the correct CVN with VCDS?
old and new scans:
OLD SCAN:
New scan:
The only thing that stands out to me other than that is that my terminal 30 is way too high, shouldn't it match the voltage at the end of the scan where it shows the Vbatt start/end? I looked at the relay under the drivers seat and tested it and it passed all tests other than step number 4, which I used a meter and not a test light but it should have still showed battery voltage correct? When I tried to start the car without the relay, it would not turn over, when I put the relay back in, it does the same as before, cranks, starts for a few seconds running roughly, and then dies. Aldo, I never had the nox errors before, they suddenly showed up the same time the terminal 30 voltage started showing 15volts in the glow plug controller terminal 30 voltage field
Heres how I tested the relay:
1) ohm meter check between pin 86 & 85
should be between 50-120 ohms
2) apply 12v to pin 86 (+) and pin 85 (-)
Should hear click, if not its bad.
3) With relay still powered (Step 2)
use ohm meter and check between pins 30 & 87
Should be at 0 ohms
4) Attach 12v (+) to pin 30
Attach test light/buzzer (+) to pin 87
Attach test light/buzzer (-) to ground
Light should come on (or buzzer)
old and new scans:
OLD SCAN:
Thursday,03,October,2024,13:47:53:32476
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: WA1VMAFE7CD003066 License Plate: OCT 3 145PM
Mileage: 296760km-184398mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
56 5F 62 69 6D 6F 72 76
VIN: WA1VMAFE7CD003066 Mileage: 296760km-184398miles
4C-Tire Pressure II -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI FSA H18 0009
Revision: 54H18--- Serial number: CVN: 5B6F114CD45710C1755A2113
Coding: 2A2A4012253600050000
Shop #: WSC 27985 004 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401 002008
ROD: EV_ECM30TDI0114L2910401_002.rod
VCID: 61987DF911CE47C2305-8034
VINID: 9D10667515951D35000030061896D2B1F1
14625 - Glow Plug Control Module (J179)
P0683 00 [00100111] - Electrical Malfunction
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:21
Engine RPM: 0.00 /min
Coolant temperature: 19 °C
Intake air temperature: 25 °C
Voltage terminal 30: 12.500 V
Glow-control unit: activation voltage: 0 mV
Glow_period_control_unit_ground_offset_voltage: 0 mV
Glow-control unit: calculated glow voltage: 0 mV
Glow_period_control_unit_energy_integrator_calculated_value: 0.0 V²s
Glow cycles upon reaching temperature threshold-Bits 0-7: 0
Glow cycles upon reaching temperature threshold-Bits 0-7: 18
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 80
Co EOM st Op Mode Short-Bits 0-7: 0
9127 - Actuator Module for Turbocharger 1
P00AF 00 [10100111] - Stuck
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:21
Charge Pressure Actuator: activation: 5.00 %
Charge air pressure actuator: acknowledgment: -4.82 %
Turbocharger boost control: offset closed: 0.00 %
Turbocharger boost control: offset open: 0.00 %
High press turbocharger actuator: actual uncond volt value: 258.8 mV
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 3408
Serial number: CVN: 44BD1086
Coding: 001378
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3C26EC8DD6EC4A2A433-8068
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0099473
Shop #: WSC 31414 790 00001
VCID: 280E20DD3EF4F68A37B-807C
Fault Status: 01100101
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:17
Count: 128
Count: 4353
Count: 295
Count: 45824
01486 - System Function Test Activated
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:17
Count: 128
Count: 4353
Count: 320
Count: 45824
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:19
Count: 128
Count: 4353
Count: 197
Count: 45568
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401893047
Coding: 0000135
Shop #: WSC 44055 001 1048576
VCID: 251029E949E6EBE20CD-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
Component: FBSAUDIC6 IDG H01 0053
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AJ
Revision: 00---026 Serial number: 00000030208767
Coding: 0004A036
VCID: 251029E945E6EBE20CD-8070
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0012461892
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Serial number: 0012461828
Coding: 070000
014 - Defective
Fault Status: 01101110
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:21
Temperature: 21.0°C
02874 - Control Module 2 for Central Convenience (J773)
Fault Status: 01101000
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:21
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0139123
VCID: 6E8216C5DC90E8BABD7-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09VDZ9
Coding: 0014131
VCID: 2B04DFD12F02DD92DA9-807E
Subsystem 1 - Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Subsystem 2 - Serial number: 6332QSME180D265AK
Subsystem 3 - Serial number: 6342QSME180D2C78R
Subsystem 4 - Serial number: 6352QSME195E225AP
Subsystem 5 - Serial number: 6362QSME685C2972T
Subsystem 6 - Serial number: 63734SME315C3C7CD
Subsystem 7 - Serial number: 63834SME045B217E3
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H07000 Serial number: 90025111660484
Coding: 0012242
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 984 R HW: 4L0 920 984 R
Component: KOMBIINSTR. H22 0411
Revision: 00000000 Serial number: LMZ04009C
Coding: 8BD664040900CF05020205
VCID: 42DA9275B4883CDA09F-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0047
Revision: MB300033 Serial number: 3300M11819012B
Coding: 00C303
VCID: 3D20E189CD76432274D-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790354551
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000000293140
Coding: 0000006
VCID: 688E60DDFE74368AF7B-803C
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:21
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:27
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000013015459
Coding: 00581B00000011110000
VCID: 323AC2B504288C5A99F-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E02D6C51C10A8BAFD7-807A
Subsystem 3 - Serial number: 5F19.08.1100H010003C912704ÿ
Subsystem 4 - Serial number: 912704ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000012886533
Coding: 011F57205E40440004
VCID: 48CE805D92B4168AD7B-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H11 0120
Revision: 0120 --- Serial number: 01556943850000
Coding: 3569693
VCID: 382EF09DEE54660AA7B-806C
Part No SW: 4L0 035 223 H HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0130
Revision: CH003000 Serial number: 00000000009532
Coding: 030000
VCID: 270C23E13FEAF9F23E1-8072
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190106726
Coding: 0758477
VCID: 231437F147D215D2629-8076
Fault Status: 11101101
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:18
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.70 V
Temperature: 23.0°C
(no units): 0.0
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:18
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.70 V
Temperature: 23.0°C
(no units): 0.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000095857
Coding: 0012001
VCID: 5EE246052C30783A0D7-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000013387741
VCID: 47CC83619FAA19F2DE1-8012
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:17
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H52 0076
Revision: AB001007 Serial number: 156I50B7547359
Coding: 020007010000000000
VCID: 1F1C3B0167BA3132461-804A
Part No SW: 4L2 035 746 B HW: 4L2 035 746
Component: H-BNT-NA H42 0422
Revision: -------- Serial number: 097I.0B7503442
Coding: 180200060004E3EF51002345EF632003140000000100000000
VCID: 2D00D1C91D16D3A2C4D-8078
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H42 0094
Serial number: 9466GT0A0034437
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000001906487
Component: CD-Database 3371
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:21
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000013005192
Coding: 010E57204040230004
VCID: 46D28E6598A000FA257-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000156551204
Coding: 0200000000000000
VCID: 3138CDB9012EB742E05-8064
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C861CCDEA8C1AAA933-8038
Subsystem 3 - Serial number: RD08.09.11--H57001001A0268ÿ
Subsystem 4 - Serial number: 1A0268ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H07 0080
Revision: AAH07080 Serial number: 118895293-----
Coding: 0003595
VCID: 26122EE534E0E0FA057-8072
Component: J_245_EE16_SKB10H11 0220
Component: J_394_EE16_SKB10H11 0220
Component: J_392_EE16_SKB10H11 0220
02906 - Control Module for Sliding Roof; Rear (J392)
Reset counter: 206
Mileage: 296768 km
Date: 2024.10.03
Time: 13:40:16
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000013005343
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H03 0500
Revision: 00H03000 Serial number: 37361123701717
Coding: 0231266
VCID: 2A0ADAD520F8C49A21F-807E
End----------(Elapsed Time: 02:16, VBatt start/end: 12.7V/12.7V)-----------
New scan:
Sunday,03,November,2024,16:09:43:32476
Mileage: 297090km-184603mi Repair Order:
VIN: WA1VMAFE7CD003066 Mileage: 297090km-184603miles
Revision: 54H18--- Serial number: CVN: 5B6F114CD45710C100000000
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:06
Intake air temperature: 21 °C
Voltage terminal 30: 15.660 V
Glow cycles upon reaching temperature threshold-Bits 0-7: 19
28988 - No Communications with NOX Sensor 1
U029D 00 [00100110] - -
Fault Frequency: 79
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:06
Voltage terminal 30: 15.840 V
Cruise Control System (CCS): status-Bits 0-7: 44
CAN status - brake control module 1-Bits 0-7: 8
selected gear-Bits 0-7: 0
28990 - No Communications with NOX Sensor 2
U029E 00 [00100111] - -
Fault Frequency: 111
Mileage: 297094 km
Date: 2024.11.03
Time: 15:59:26
Voltage terminal 30: 15.900 V
Coding: 001378
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099473
VCID: 3436C4ADF23C826A8B3-8060
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:03
Count: 321
Count: 8215
Count: 44800
Coding: 0000135
Coding: 0004A036
Coding: 070000
Coding: 070000
014 - Defective
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:08
Temperature: 21.0°C
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:08
Coding: 0139123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 0014131
Coding: 0012242
Coding: 00C303
Coding: 0000006
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:08
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:13
Coding: 0010001
Coding: 3569693
Coding: 030000
Coding: 0758477
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:03
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.50 V
Temperature: 20.0°C
(no units): 0.0
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:03
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.50 V
Temperature: 20.0°C
(no units): 0.0
Coding: 0012001
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:03
Coding: 0000031
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:07
Coding: 0003595
01512 - Control Module for Sliding Roof
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:03
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:03
02907 - Control Module for Roof Shade (J394)
Reset counter: 216
Mileage: 297094 km
Date: 2024.11.03
Time: 15:58:03
Coding: 0231266
End----------(Elapsed Time: 02:12, VBatt start/end: 12.4V/12.3V)-----------
Should be at 0 ohms
