- Nov 2, 2024
- 8
- 0
- Pennsylvania, USA
- C?ID=601330
Hello everyone,
Thank you in advanced for reading this post and any insight is helpful! I'm running into some issues trying to replace ECM in my 2014 VW Jetta SE.
Quick background - I recently purchased the car and have been combing through recalls and typical vehicle maintenance to refresh it and get it running healthy again.
Question: I'm attempting to swap the ECM with a direct replacement (identical p/n and SIMOS 12.2). When i swap the ECM, the car attempts to start but stalls and displays "IMMOBiLIZER" on the column display as expected. I'm fairly new to VCDS and VAGcom, but I understand that there is probably multiple adaptations and processes involved with installing a replacement ECM. I attempted to follow a wiki article here: http://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_ECU_Swapping. However, when I select [01-Engine] the [Meas. Blocks - 08] is greyed out and i'm unable to continue the instructions. So, I stopped the swap and reinstalled the old ECM to get the car to start again. I'm attempting to replace the ECM as i'm unsure if there was any changes to it as it was a used vehicle. So, i'm hoping to swap a default replacement ECM into the car.
From what I understand, I have to install the ECM, adapt the CAN gateway, and then perform key adaptations for the ECM to recognize the key fobs and turn off the immobilizer. This car doesn't have a physical ignition key hole, but instead, sensors and a start/stop engine button. Any insight on the process would be greatly appreciated. The car current runs and starts with the old ECM, but i'm getting ERROR that the CAN BUS is coded incorrectly - please see scan details. If i switch to the new ECM, the car doesn't start.
Thanks!! So far VCDS and the Hex V2 have been awesome for diagnosing!
VCDS SCAN OF THE OLD RUNNING ECU - NOTE
01044 - Control Module Incorrectly Coded shows up with the OLD ECM connected as well as the new replacement ECM.
Sunday,03,November,2024,19:55:17:64521
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: 3VWB17AJ1EM421037 License Plate:
Mileage: 328190km-203927mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 05 08 09 15 17 19 25 2B 2E 44 56 75 77
VIN: 3VWB17AJ1EM421037 Mileage: 328190km-203927miles
25-Immobilizer -- Status: Not registered 0011
75-Telematics -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 070 F HW: 06K 907 425
Component: R4 1.8l TFS H09 9360
Revision: --H09--- Serial number: 00000000000000 CVN: E96FF6B6
Coding: 00110012242400171000
Shop #: WSC 00066 790 07025
ASAM Dataset: EV_ECM18TFS02006K906070F 001014
ROD: EV_ECM18TFS02006K906070F.rod
VCID: 2D00D1642D9EFEF2C4D-8078
VINID: 0E69D204745A0557440810031CD84C6C42
14963 - Fan 1 Control Circuit
P0691 00 [00101000] - Short to GND
Mileage: 328189 km
Date: 2024.11.01.
Time: 21:43:36
Engine RPM: 1920.25 /min
Normed load value: 14.5 %
Vehicle speed: 255 km/h
Coolant temperature: 85 ∞C
Intake air temperature: 31 ∞C
Voltage terminal 30: 14.199 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 694 s
MAP_MES_SAE: 29 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.865 V
FAC_TPS_1_SAE: 13.671875 %
FUP_H_SAE: 5620.0 kPa
16481 - Vehicle Speed Sensor
P0501 00 [01101101] - Implausible Signal
Fault Frequency: 8
Mileage: 328189 km
Date: 2024.11.01.
Time: 03:14:54
Engine RPM: 2148.50 /min
Intake air temperature: 34 ∞C
Voltage terminal 30: 14.023 V
Engine: operating status: PUC
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 740 s
MAP_MES_SAE: 25 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.642 V
FAC_TPS_1_SAE: 13.281250 %
FUP_H_SAE: 18010.0 kPa
16491 - Implausible Data Received from ABS Control Module
U0415 00 [00101100] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Fault Frequency: 12
Mileage: 328189 km
Date: 2024.11.01.
Time: 03:04:33
Engine RPM: 1990.50 /min
Normed load value: 32.2 %
Coolant temperature: 58 ∞C
Intake air temperature: 32 ∞C
Voltage terminal 30: 14.179 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 119 s
MAP_MES_SAE: 68 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.982 V
FAC_TPS_1_SAE: 19.531250 %
FUP_H_SAE: 19840.0 kPa
14971 - Fan Control Module 1
P2D89 00 [01101101] - Supply Voltage Malfunction
Mileage: 328189 km
Date: 2024.11.01.
Time: 21:44:58
Engine RPM: 2219.75 /min
Normed load value: 40.0 %
Voltage terminal 30: 14.121 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 776 s
MAP_MES_SAE: 81 kPa
FAC_TPS_1_SAE: 23.046875 %
FUP_H_SAE: 19870.0 kPa
Readiness: 0010 0101
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492400FB850B02E792200041A1100012
Shop #: WSC 48613 001 1048576
VCID: 045654C0DE14DFBA7B3-8050
Fault Status: 00101101
Fault Frequency: 11
Reset counter: 227
Mileage: 328189 km
Date: 2019.03.25.
Time: 03:04:35
Count: 7
Count: 4608
Count: 8196
Count: 49664
Count: 1
Count: 4
Fault Status: 00100011
Reset counter: 227
Mileage: 328189 km
Date: 2019.03.25.
Time: 03:04:34
Count: 3
Count: 4608
Count: 53
Count: 49438
Count: 1
Count: 5
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 227
Mileage: 328189 km
Date: 2019.03.25.
Time: 03:04:28
Count: 16384
Count: 12800
Count: 37
Count: 49677
Count: 2
Count: 249
Count: 2304
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 223
Mileage: 328189 km
Date: 2019.03.24.
Time: 23:21:32
Count: 3
Count: 2
Count: 29184
Count: 16401
Count: 49408
Count: 510
Reset counter: 228
Mileage: 328189 km
Date: 2019.03.24.
Time: 23:21:41
Count: 2
Count: 29184
Count: 16390
Count: 49664
Count: 510
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0321602102 Dataset Number: 160116v____ 0002
Coding: 030C0C
Shop #: WSC 00066 790 00221
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 3436C400CEB4AF3A8B3-8060
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 13 [00001001] - Open Circuit
Fault Frequency: 23
Reset counter: 228
Mileage: 328189 km
Date: 2024.10.31.
Time: 23:36:46
1057291 - Antenna for Keyless Entry System; Passenger Side
B1170 13 [00001001] - Open Circuit
Reset counter: 224
Mileage: 328189 km
Date: 2024.10.31.
Time: 23:39:03
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BN HW: 5C0 820 047 BN
Component: J301 Klimaanlage 0204
Revision: 2001001S Serial number: 00000002027536
Shop #: WSC 33819 000 1048576
VCID: 6D801164E19E3EF284D-8038
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 J HW: 5C0 937 087 A
Component: BCM25 JLB H3 H34 0411
Revision: B2034001 Serial number: 08013046140826
Coding: 7B994B9A08AB0B0008382000240884C500C2502E6000400030A050002000
Shop #: WSC 00066 123 12345
VCID: 3436C400CE34AF3A8B3-8060
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585140204190509
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584140124215620
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH000AUO8%
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Serial number: 0406891 FLE 20140104
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587140130153239
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586140131112556
Coding: 800000
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD03B9FL Dataset Number: 160003v____ 0219
Coding: 00004138
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 74B604008E34EF3A4B3-8020
Serial number: 6940000Y1400011VUE06
Coding: 303036
Serial number: 3572MSME5326667FZZZ0
Serial number: 3582MSME08591A41ZZZW
Serial number: 3516KSME53156F2AZZZ-
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME213A6F2AZZZ$
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME5402582AZZZU
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME1E0E4F2AZZZC
B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
Fault Frequency: 27
Reset counter: 13
Mileage: 328189 km
Date: 2024.11.01.
Time: 03:04:44
Part No SW: 5C6 920 953 B HW: 5C6 920 953 B
Component: KOMBI H04 0809
Coding: 270A01
VCID: 2C06DC601684F7FAD33-8078
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H34 0411
Revision: B2034001
Coding: 102200
VCID: 70BE0810FAACD31AAFB-8024
Mileage: 328191 km
Date: 2019.03.26.
Time: 00:04:49
Component: IMMO H04 0809
Coding: 000007
Shop #: WSC 00066 000 00122
VCID: 6A8A1A78DCF029CAE1F-803E
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [00001000] - -
Mileage: 328191 km
Date: 2024.11.02.
Time: 00:00:32
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000002123002
Coding: 4100000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 303EC8103AAC931AEFB-8064
Address 2E: Media Player 3
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 69 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3928F534E5565252585-806C
Fault Frequency: 12
Reset counter: 13
Mileage: 328191 km
Date: 2019.03.27.
Time: 06:58:36
Voltage: 14.38 V
DU
Temperature: 15.0∞C
RPM: 1971 /min
Speed: 18.0 km/h
Speed: 18.0 km/h
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H07 0008
Revision: -----11S Serial number: VWZ4Z7P3535613
Coding: 01000400020006
Shop #: WSC 00066 000 00000
VCID: 649674403E547FBADB3-8030
02788 - Internal Communications Error
Fault Frequency: 20
Reset counter: 228
Mileage: 328189 km
Date: 2019.03.24.
Time: 23:22:50
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140514 Dataset Number: V03935196FH 0010
Coding: 02630102C2163A107F1606000000
Shop #: WSC 01383 790 50316
ROD: EV_OCULow_001.rod
VCID: 53F4A79C6B7A8802B29-8006
2103041 - Control Module
B1788 F0 [00001001] - Start Prohibition Deactivated
Fault Priority: 8
Reset counter: 228
Mileage: 328191 km
Date: 2024.11.03.
Time: 08:33:46
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665768701 Dataset Number: 5N0035729A 0001
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E02D668209885EAFD7-807A
End----------(Elapsed Time: 01:41, VBatt start/end: 14.3V/14.3V)-----------
