1995 VW Eurovan transmission issues
mfran
Canada
C?ID=595230
main issues on transmission ...
on reverse, does not turn,
on neutral, turns slowly, speeds up when pressing accelerator
on drive, from 02-20 miles , when it reaches 20mph, it drops then goes up to 20 mph again, cyclical
on D3, same as on drive mode
on D2, runs
on M1 initially turns then it will stop even when pressing accelerator
replaced solenoid harness
vehicle is in garage and jacked up while the above tests were performed
Thank you all, in advance to any input and directions on what to do....
Sunday,03,November,2024,14:00:00:28934
Chassis Type: 70 - VW Transporter/Multivan (1991 > 1996)
Scan: 01 02 03 08 15 22 25
Address 01: Engine        Labels: 023-906-024.lbl
   Part No: 023 906 024 A
   Component: DIGIFANT 1.73       1713PMC
   VCID: 0B447F39DA5240323A9-0962
00523 - Intake Air Temp Sensor (G42)
            03-00 - No Signal
00522 - Engine Coolant Temperature Sensor (G62)
            30-00 - Open or Short to Plus
00540 - Knock Sensor 2 (G66)
            03-00 - No Signal
00758 - Secondary Air Injection System (AIR)
            37-00 - Faulty
00560 - Exhaust Gas Recirculation System
            01-00 - Signal Shorted to Plus
00515 - Camshaft Position (Hall) Sensor (G40)
            37-00 - Faulty
Readiness: N/A
Address 02: Auto Trans        Labels: 098-927-731.lbl
   Part No: 098 927 731 AB
   Component: AG4 Getriebe 098    1687
   Coding: 00000
   VCID: 61987D91085EBA62305-0964
10 Faults Found:
00258 - Solenoid Valve 1 (N88)
            36-10 - Open Circuit - Intermittent
00260 - Solenoid Valve 2 (N89)
00262 - Solenoid Valve 3 (N90)
00264 - Solenoid Valve 4 (N91)
00266 - Solenoid Valve 5 (N92)
00270 - Solenoid Valve 7 (N94)
00293 - Multi-function Switch (F125)
            25-10 - Unknown Switch Condition - Intermittent
00281 - Vehicle Speed Sensor (G68)
            03-10 - No Signal - Intermittent
            35-10 - - - Intermittent
00300 - Transmission Fluid Temp. Sensor (G93)
            34-10 - No Elaboration Available - Intermittent
End----(Elapsed Time: 01:49, VBatt start/end: 14.4V/14.2V. VIgn 0.0V)------
Dr Sheldon
Windsor UK
C?ID=334979
Post a Full Autoscan please in the correct fashion. The fault codes in the edited scan is missing a massive amount of useful data !!
Would not hurt you to get a Wiring Diagram for it either !!
Does this have ABS ?
Dr Sheldon
Windsor UK
C?ID=334979
Wrong way to get any useful diagnostic direction from that method of testing - Very Wrong !!
That will give you mental health issues !! False Positives and Negatives.
That could be construed as the van is not in Neutral ?? When in fact it probably is !!
On a brighter note, it seems, that you have an Electrical / Control / Wiring Issue rather than a Mechanical failure in the gearbox.
However it is too early in the diagnostic process to KNOW anything !!
Same goes for the DTC's in Engine !!
mfran
Canada
C?ID=595230
hi, thanks for responding ... I am a 1st time user of the vcds scanner and still navigating thru on how to use it. I used the autoscan feature , the readings above are what it gave me ,copied and posted it on the board.
also, where would one be able to access a wiring diagram, as you suggested/
thanks
