AUDI A4 8E 2000 FSI Retrofit ABS CODING PROBLEM
mohamedaos
Egypt
C?ID=510606
hello guys
i have a problem here with ABS coding and Airbag module
i recieved a car with an engine and transmission swap to 2.0L with 01J transmission for abs coding
i tried as much as i can but no way tried 0004401 , 0004405 and the most successful one was 0004525 and i think it may work
the problem that no problem with engine but always have those errors
ESP-Sensor Unit (G419); Incorrect Component and check powertrain modules coding and no communication with air bag module
I NEED TO CODE ABS TO MATCH ENGINE & AIRBAG MODULE
VIN: WAUZZZ8E56A254045   License Plate: A4 2008
Mileage: 104050km-64653mi   Repair Order:
VIN: WAUZZZ8E56A254045   Mileage: 104050km-64653miles
   Part No SW: 8E0 910 115 Q    HW: 8E0 907 115 D
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H13---    Serial number:
   Coding: 010C000302070020
   Shop #: WSC 00010 773 74758
   VCID: 2F307F450B142FB2FE9-807A
   VINID: 9D196AAAA21514644214400414B03C2949
049489 - No Communications with Airbag Control Module
               U0151 - 008 -  - Intermittent
                    Mileage: 104056 km
                    Temperature: 97.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.446 V
Readiness: 0110 0001
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E1 910 155     HW: 01J 927 156 HT
   Component: V30 01J 2.0TFSI RdW 0030
   Revision: 00000008    Serial number: 00000000963616
   Coding: 0000001
   Shop #: WSC 06325 000 00000
   VCID: 6398C375175CDBD22A1-8036
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H06 0120
   Coding: 0004865
   Shop #: WSC 22441 000 00000
   VCID: 280294592EFA788A3F3-807C
00494 - ESP-Sensor Unit (G419); Incorrect Component
                    Hex Value: 0x0000
                    Hex Value: 0x4720
                    Hex Value: 0x0015
                    Hex Value: 0xDDAA
                    Hex Value: 0x0001
                    Hex Value: 0x0000
                    Hex Value: 0x4720
                    Hex Value: 0x0013
                    Hex Value: 0x169C
                    Hex Value: 0x0001
                    Hex Value: 0x0000
                    Hex Value: 0x4720
                    Hex Value: 0x0014
                    Hex Value: 0x21A6
                    Hex Value: 0x0001
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Hex Value: 0x0000
                    Hex Value: 0x4720
                    Hex Value: 0x0014
                    Hex Value: 0x10A7
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BJ
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   Shop #: WSC 06325
   VCID: 6A86AE51F5668A9AE97-513C
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 00003
   Shop #: WSC 06325
   VCID: 3D2C550DD468CD227C5-4B00
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H12 3730
   Revision: 91H12373    Serial number: 0036M0G3DH60
   Coding: 0031612
   VCID: 3B285B15CF6CC312421-806E
   Subsystem 1 - Serial number: 6332DRB403D28A91T
   Subsystem 2 - Serial number: 6342DRB403E2CE32Y
   Subsystem 3 - Serial number: 6352ARB4018C9605N
   Subsystem 4 - Serial number: 6362ARB4017F4480M
   Subsystem 5 - Serial number: 63729RB401147C40C
   Subsystem 6 - Serial number: 638  RB4        9
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 02041
   Shop #: WSC 06325
   VCID: 41D429FDA890A9C218D-4B00
02071 - Local Databus
            37-10 - Faulty - Intermittent
            35-00 - -
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8E0 920 901 E    HW: 8E0 920 901 E
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0006141
   Shop #: WSC 00999 444 64523
   VCID: 2700976523F477F2369-5184
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
   Coding: 0006141
   Part No: 8E0 959 433 CE
   Component: Komfortgerát T23    4135
   Coding: 06756
   Shop #: WSC 06325
   VCID: 76BE8A21B1DE5E7A7DF-4B00
   Subsystem 1 - Part No: 8E1959801H
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E1959802H
   Component: Tõrsteuer.BF BRM 0606
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
01366 - Opened Due to Crash Signal
            36-00 - Open Circuit
   Part No: 8E0 035 186 AA
   Component: concert II  GRO    0004
   Coding: 01005
   Shop #: WSC 06325
   VCID: 669EDA61E14EAEFACDF-4B1E
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
End----------(Elapsed Time: 05:20, VBatt start/end: 12.3V/12.1V)-----------
Dr Sheldon
Windsor UK
C?ID=334979
I'm only asking out of curiosity - so dont take me wrong !!
With the way the modern day car is set up why oh why do you folks think life is going to be a walk in the park fitting parts that are not for that car ?
I can understand messing about with components that are cheap and easy to bolt on and off. Yea - you lose an hour and a few $$ !
But I see on here the bravery ( madness n my eyes ) with Engine and Transmission transplants.
Just an ask because I read and sympathise with the torture you put yourself through !! I don't get it !
Perhaps your life is absolute bliss and you need a drama - Now I jealous !!
Perhaps the sense of achievement when the labour of love works out for you ?? - That I get, however, there must be easier and less painful ways to get the feeling of satisfaction and achievement ??
But then I do like to drive and own nice car with some power, convenience and safety features ...
Note - DRIVE and OWN !! Not build the 7uckin thing :facepalm::facepalm::facepalm::):)
What engine & trans were in this car originally?
mohamedaos
Egypt
C?ID=510606
mohamedaos
Egypt
C?ID=510606
I have the same ideas and no offence for sure
What is happening here is that I deal with many garages used to swap systems or make a full car swap to add the power and convenience but sometimes we see a a missing component so we are trying to do our best
All retrofit I make is 100% original with part numbers and wiring to make full function for it
This is the market brother you see various jobs and you need to do your best
Any help to code the abs ?
One problem here is that the cheap 1LZ brakes that this car almost certainly has were never installed in combination with a 2.0T and 01J.
You could try 0004356, but my confidence level is low.
mohamedaos
Egypt
C?ID=510606
i will test and report
