As the title says, car starts and drives but all lights on the dash stay on, the clocks do not work so you cannot see speed and RPM and all the other things like fuel and temp or mileage, the MAXIDOT does not work either.
I ran VCDS through it and after saving the logs a few times and deleting all codes that came up I went from a ton of codes at the start to not as many but some persist.
After a bit of scanning and deleting I had a loud beep followed by the dash message that the ignition was on, all mileage date and time and then it went from every warning light you don't to see when driving to the normal battery, hand brake, seatbelt, TCS and CEL warnings and the fuel needles indicated 1/4 of a tank so at this point the clocks must have functioned.
The car then automatically switched to ESP fault then to telling me that the door was open and then after all this and turning the car off and starting the MAXIDOT flickered when starting and went out. Upon lockig the car, all the bad lights we all hate stayed on for 30 seconds before going out. Remote locking functioned as it should.
The car did this once in the winter some years ago and it has never come around since.
SOS HELP -
FIRST SCAN LOG
LAST SCAN LOG
SOS HELP -
FIRST SCAN LOG
Sunday,03,November,2024,18:31:06:34356
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUZZZ8P3AA038009 License Plate:
Mileage: 196230km-121931mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P3AA038009 Mileage: 196230km-121931miles
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 S HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 2917
Revision: --H11--- Serial number: AUX7Z0I6FNL0PH
Coding: 0000071
Shop #: WSC 06314 000 00000
VCID: 372A29D16345E7F2AE9-8062
VINID: 9D196AAAA2200D14400C80002402E2643E
Subsystem 1 - Part No: 03G 906 056 S
No Faults Found
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 1342201209250002C80B04E4902200813800
VCID: 7EA4FCF500FF16BA2DF-802A
Reset counter: 109
Count: 12800
Count: 8208
Count: 40448
Count: 256
Reset counter: 109
Count: 12288
Count: 8211
Count: 41216
Count: 256
Address 08: Auto HVAC Labels: 8P0-820-047.clb
Part No SW: 8P0 820 047 D HW: 8P0 820 047 D
Component: J255 Klima Man H08 0050
Revision: 00H08004 Serial number: 00000000000000
VCID: 313E17C98D2139C2E0D-8064
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 HW: 8P0 907 063
Component: BCM PQ35 B 104 0575
Revision: 00104 AH
Coding: 06000A2CB013F0C0203041E00000005C471229AA100DC121E40008800040
Shop #: WSC 12345 123 61029
VCID: 71BED7C941A179C2A0D-8024
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Component: LIN BACKUP HO H03 1301
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Fault Status: 00101110
Reset counter: 120
Mileage: 180096 km
Date: 2023.12.28
Time: 09:57:32
Voltage: 14.20 V
Term 50 Off
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 81
Reset counter: 80
Mileage: 193331 km
Date: 2024.09.05
Time: 19:07:29
Voltage: 12.20 V
Term 50 Off
Fault Frequency: 72
Reset counter: 80
Mileage: 193331 km
Date: 2024.09.05
Time: 19:25:00
Voltage: 12.05 V
Term 50 Off
Reset counter: 109
Mileage: 195814 km
Voltage: 11.70 V
Term 50 On
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0140
Revision: -------- Serial number: 003FB002DG5M Dataset Number: 8P0909602M 0003
Coding: 30314238303830303037554A305238503053
ROD: EV_Airba10AURB4_AU35.rod
VCID: 4FFA7131F7554F32969-801A
Serial number: 3572DRB4000094D4D10U
Serial number: 3582DRB4000094DD12A$
Serial number: 35128RB400004F354E6Q
Serial number: 35228RB400004F353ADT
Serial number: 35547RB400004F25687R
Serial number: 35647RB400004F25631H
12670208 - No Communication with Instrument Cluster
U0155 00 [00001000] - -
Reset counter: 109
Part No SW: 1K0 953 549 DB HW: 1K0 953 549 DB
Component: J0527 037 0070
Coding: 0000002
VCID: 75B6E3D939C955E27C5-8020
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H02 0980
Revision: D0H02002 Serial number: 2246I002005474
Coding: 0006128
Shop #: WSC 12345 111 45799
VCID: 40D8420D368BA04A1F3-8014
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 156042 km
Date: 2019.11.28
Time: 10:36:56
001 - Upper Limit Exceeded
Fault Status: 01100001
Reset counter: 80
Mileage: 196236 km
Date: 2024.11.03
Time: 16:00:27
Reset counter: 80
Mileage: 196236 km
Date: 2024.11.03
Time: 16:01:42
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 5223
Revision: H16 Serial number: 4120K097200861
Coding: E9807F06000202002103
VCID: 6694B495746FAE7AC5F-8032
Reset counter: 109
Mileage: 195814 km
Reset counter: 109
Mileage: 195814 km
Revision: D0H02002 Serial number: AUX7Z0I6FNL0PH
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0000692
VCID: 46D4541514AF8E7A25F-8012
01706 - Switch for Mirror-Adjust (E43)
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 232 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 2F3A11B19B152F32F69-807A
Reset counter: 109
Voltage: 11.75 V
DD
Temperature: 11.0 C
00750 - Warning Lamp
Fault Status: 11101101
Voltage: 10.88 V
DD
Temperature: 11.0 C
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.5 V
PD
Temperature: 11.0 C
Count: 2
Steering Angle: 0.00
SteerAng n.Init
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0000692
VCID: 47CA591113A59772DE9-8012
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 E HW: 8P0 035 152 E
Component: R Chorus2+ H02 0280
Revision: 00H02000 Serial number: AUZ1Z2I5217674
Coding: 0020021
VCID: 2D060BB991195D22C45-8078
Reset counter: 109
00871 - Bass Speaker Front Right (R23)
Reset counter: 60
Mileage: 184566 km
Date: 2024.03.18
Time: 09:27:00
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 42DC48053887B25A097-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000144
VCID: 43D24D01279DBB52021-8016
End----------(Elapsed Time: 02:26, VBatt start/end: 12.2V/12.2V)-----------
LAST SCAN LOG
Sunday,03,November,2024,18:58:41:34356
Coding: 0000071
Revision: 00H45001
Revision: 00104 AH
Coding: 00DD13
Reset counter: 80
Mileage: 196238 km
Date: 2024.11.03
Time: 00:32:06
Voltage: 10.85 V
Term 50 Off
Reset counter: 80
Mileage: 196238 km
Date: 2024.11.03
Time: 00:32:07
Voltage: 11.55 V
Term 50 Off
Coding: 0000002
Coding: 0006128
014 - Defective
Mileage: 156042 km
Date: 2019.11.28
Time: 10:36:56
Reset counter: 80
Mileage: 196238 km
Date: 2024.11.03
Time: 00:13:02
Reset counter: 80
Mileage: 196238 km
Date: 2024.11.03
Time: 00:13:02
Coding: 0000692
Revision: 00H17000
000 - - - MIL ON
Mileage: 196238 km
Date: 2024.11.03
Time: 00:13:02
Battery Volts: 12.1 V
DD
Temperature: 15.0 C
Count: 2
SteerAng n.Init
Voltage: 11.00 V
DD
Temperature: 15.0 C
Coding: 0000692
Coding: 0020021
Reset counter: 80
Mileage: 196238 km
Date: 2024.11.03
Time: 00:13:14
Coding: 0000144
Coding: 0000144
End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.1V)-----------
