Resolved Seat Leon 5F MIB2 STD2 amplifier
Resolved
adwar
Poland
C?ID=381462
Hi, I've got problem with MIB2 Unit MST2_EU_SE_ZR_P0369T, 5QA035824A. Car came to me with problem: no sound when it's phone calling. Person with who is calling, hear me but I don't hear anything. I noticed there isn't buttons sound too (turned on in menu). Car has added amplifier "Match" and probably there is the problem. I changed coding and add "Speakers with external Booster" but still the same. I tried with another unit and it didn't work too.
siLc
Tallinn, Estonia
C?ID=330192
On MIB radios, the BT phone call volume is seperately adjustable from the normal radio/media volume when the phone call is active. If the normal radio plays OK, then it's probably only a matter of turning up the volume from zero :)
downtime
Finland
C?ID=280813
And Match system has no impact whatsoever on the microphone or bluetooth part of the system. So I would follow @siLc 's advice.
adwar
Poland
C?ID=381462
When I call I tried turning up volume of course. I made maximum but didn't hear anything. :/
Dr Sheldon
Windsor UK
C?ID=334979
Post an Autoscan
siLc
Tallinn, Estonia
C?ID=330192
Don't have much faith that an aftermarket amp installer knows anything about datasets. There are amps which take the high level signal and work with that and no changes are necessary on the radio side.
2kaa52
Ceska Republica, Praha
C?ID=319193
Maybe we know more when Autoscan is uploaded
adwar
Poland
C?ID=381462
Car came to with errors of low tone speakers, after coding "external BOOSTER" errors disappeared. There isn't sound of system too. When I touch screen should be sound but there isn't. I didn't load dataset because I don't know which parameter I should choose.
Here is full scan:
Sunday,03,November,2024,14:10:17:21580
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
Dealer/Shop Name: WARCAR Jaworzno
VIN: VSSZZZ5FZGR246510   License Plate: LEON5F
Mileage: 81893km-50885mi   Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69
VIN: VSSZZZ5FZGR246510   Mileage: 81893km-50885miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2833
   Revision: R7H25---    CVN: C7FD2D74
   Coding: 01190032243419080000
   Shop #: WSC 13717 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B96DC7F82D1BCCE0E-803E
   VINID: 9A38EAAAA156A978821061410024F709CC
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 63096000001434
   Coding: 23EE6A9224241172447C060140C324C456248822600224720021F070C002420000000012121212B835351919323200
   Shop #: WSC 00049 770 00103
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036_SE37.rod
   VCID: 004C9BD39B574F96CB-8054
   Part No SW: 5F0 907 044 AE    HW: 5F0 907 044 AE
   Component: Climatronic   H05 1601
   Revision: 00001K09
   Coding: 02000004200110011005000000101020
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 699AA677882DAEDE7C-803C
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061630300010 Dataset Number: V03935245CK 0001
   Coding: 08020A46424102FB43E04000401407081000000000000000000000000000
   Shop #: WSC 00049 770 00125
   ROD: EV_BCMBOSCH_015.rod
   VCID: 044497C38F4F53B6EF-8050
   Subsystem 1 - Part No SW: 5F1 955 119 A    HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 161012  041 0574
   Serial number:         161028094638
   Coding: 0BC5FD
   Component: RLHS  042 0105
   Serial number: S7Y16M11D03H01M34S23
   Coding: 00095D
   Revision: --------    Serial number: 39331631406442 Dataset Number: V03935210FD 0006
   Coding: 0031151101
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 43C654DFCAC1948E96-8016
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPMWJ1A. Dataset Number: V03935204MW 0001
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F6EA8EFD60920EE42-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 211 16
   Serial number: 3576U000000CF84C2C1V
   Subsystem 2 - Part No SW: -----------    HW: 454 002 810 16
   Serial number: 3586U000000984206F1B
   Subsystem 3 - Part No SW: -----------    HW: 454 802 910 16
   Serial number: 3516RC813540D0000002
   Subsystem 4 - Part No SW: -----------    HW: 454 802 910 16
   Serial number: 3526R6205540D000000Z
   Subsystem 5 - Part No SW: -----------    HW: 454 802 310 16
   Serial number: 3556V4CBC4C0D000000W
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 30101604220376
   Coding: 1400
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 7EB0E52BE1A33966B9-802A
   Part No SW: 5F0 920 710 D    HW: 5F0 920 710 D
   Component: KOMBI         206 8311
   Coding: 07AD1A012980000800082A001000000000000000
   VCID: 2208F15B359BBD86FD-8076
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 30101610801651 Dataset Number: V03935223RC 0004
   Coding: 030100F42F085700EA0002C0000F00010001050000000000000000000000
   GVL: 01543C0000000000C00C10000000480000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CB4EF23F7BF2B7697-8028
   Generator:
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000B0593310816
   Coding: 002000
   Serial number: 75410803001611034644
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        010 0032
   Serial number: 0000226560099  Dataset Number: V03935240ES 0002
   Coding: 00100320C000040000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 45C24AC7C4F5AABEB8-8010
   Serial number: 00000000000012242372
   Coding: 310000
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: V03935226QL 0003
   Coding: 0103
   ROD: EV_SteerAssisMQB_013.rod
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       010 0032
   Serial number: 0000225581749  Dataset Number: V03935240ET 0002
   Coding: 00100320CC00040000001000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 44C457C3CFCF93B6AF-8010
   Serial number: 00000000000012254129
   Coding: 290000
   Revision: --------    Serial number: -------------- Dataset Number: V03935210HG 0003
   Coding: 038A000009000000
   VCID: 75A2FA07D4957A3EE8-8020
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 824 A    HW: 5QA 035 824 A
   Component: MU-S--ER      H30 0369
   Serial number: SEZAZ2S0198230 Dataset Number: V03935238AB 0002
   Coding: 04730200D70A00001111000500080A002F0205D40120010002
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE37.rod
   VCID: 3E30252BA123F966F9-806A
   Subsystem 1 - Part No SW: 5F0 919 604     HW: 5F0 919 604
   Component: ABTm_Std2  H44 1031
   Serial number: SEZ8Z9SLL01Y1Z
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0421381363 Dataset Number: V03935222LJ 0001
   Coding: 0101000202000000
End----(Elapsed Time: 01:22, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
siLc
Tallinn, Estonia
C?ID=330192
This seems to be an issue with the non-factory amp. Why not check it's voltage and ground connections?
adwar
Poland
C?ID=381462
Because there is sounds from radio, bluetooth streaming etc. but there isn't sounds of buttons, screen touching and phone calling.
siLc
Tallinn, Estonia
C?ID=330192
Just look at the audio settings in radio menu :)
downtime
Finland
C?ID=280813
There’s nothing wrong with the amp. That is not the cause of problems. I’ve had multiple different Match DSPs and Audiotec Fischer who make these really know their shit. They are premium stuff.
What type of passthrough adapter you have? Between match and MIB?
adwar
Poland
C?ID=381462
Sorry, that's so late. I solved problem. Solution was parameterization file from Fischer site (producer) which I downloaded, put on SD card and plug into amplifier. Now everything is ok. Thanks for your help!
