Friday,01,November,2024,16:51:04:51622
VCDS Version: 24.7.1.0 (x64) HEX-NET CB: 0.4643.4
VIN: WVWZZZE1ZMP039807 License Plate: ID3 DOBITA
Mileage: 27291km-16957mi Repair Order: 011124 1650
Chassis Type: E1-VWE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 5F 75 8C
A5 C0 C6 D6 D7 8105 8107 8123 8124 8125 8128 C002 C003
VIN: WVWZZZE1ZMP039807 Mileage: 27291km-16957miles
51-Electric Drive -- Status: Malfunction 0010
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: Cannot be reached 0100
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623-EBJC) Labels: 0EA-907-425-V1.clb
Part No SW: 0EA 906 012 CD HW: 0EA 907 425 C
Component: E-Vehicle H01 1914
CVN: 6ACCBD4C
Coding: 010200060364140070080000001000402008060000000000
ASAM Dataset: EV_VCU00XXX0200EA906012CD 001001
ROD: EV_VCU00XXX0200EA906012AL.rod
VCID: 6FAE37A4B654AAEE22-803A SFD
VINID: 9E69EAAAA541A9D8000C92001CADD84EE8
Radiator shutter:
Subsystem 1 - Part No SW: 1EA 965 501 HW: 1EA 965 501
Component: V711 022 0006
Serial number: 20201110060404078720
31949 - Front Camera for Driver Assist Systems
U1229 00 [00100111] - Implausible Message
[Front camera for driver assistance systems implausible]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:11
Engine RPM: 16383.75 /min
Normed load value: 100.0 %
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Ambient air pressure: 2550 mbar
Voltage terminal 30: 12.285 V
LF_MVB_PDU_INTC_DIAG_1: 32792
LF_MVB_PDU_INTC_DIAG_2: 15360
LF_MVB_PDU_INTC_DIAG_3: 0
LF_MVB_PDU_INTC_DIAG_4: 32768
LF_MVB_PDU_INTC_DIAG_5: 7
LF_MVB_PDU_INTC_DIAG_6: 3976
LF_MVB_BUS_INTC_DIAG: 256
23039 - Implausible Data Received from ABS Control Module
U0415 00 [10100111] - -
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:15
20079 - Internal Control Module
P060C 00 [10100111] - Main Processor Performance
[Internal Control Module Main Processor Performance]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:15
Voltage terminal 30: 12.265 V
Driver intention torque: 0.0 Nm
PV: 0.00 %
LV_IGK: 00000001
TAA: 12.000 °C
Driving position: N
Brake light switch status-actuated__activated: Not operated
Brake light switch status-Ident_32: 0
Hybrid batt charge cond act val standardized: 73.50 %
15048 - Coolant Fan Control Circuit 1
P0480 00 [10100111] - Electrical Malfunction
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:15
PV: 0.00 %
LV_IGK: 00000001
TAA: 12.000 °C
Driving position: N
Address 03: ABS Brakes (J104) Labels: 1EA-614-517.clb
Part No SW: 1EA 614 517 AG HW: 1EA 614 517
Component: ESC-ZF_EBC470 H14 0178
Serial number: B001OMU Dataset Number: V03935378JG 0001
Coding: 09954A84153E903F5244A8DE11E011A648294916443111492888886512949268228C889214CECBBCFD0073D33DBF00
ASAM Dataset: EV_Brake1ZFESCEPBMEB 013149
ROD: EV_Brake1ZFESCEPBMEB.rod
VCID: 77BE0FC4CE04E22EFA-8022 SFD
2101834 - Steering angle sensor
C0528 00 [00100111] - Implausible signal
[MSG_LWI_LENKRADW_GESCHW_INVALID]
Mileage: 27291 km
Date: 2048.11.29
Time: 24:52:03
73857 - Steering angle sensor
[MSG_LWI_QBIT_LENKRADWINKEL_INVALID]
Mileage: 27291 km
Date: 2048.11.29
Time: 24:52:03
73856 - Steering angle sensor
[MSG_LWI_LENKRADWINKEL_INVALID]
Mileage: 27291 km
Date: 2048.11.29
Time: 24:52:03
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 R HW: 5WA 959 436 B
Component: Kessy IOBOX 070 0707
Serial number: --------------- Dataset Number: V03935344RT 0001
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003_VW38.rod
VCID: 63864B946A9C1E8EB6-8036
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 1EA 907 727 AF HW: 1EA 907 727 K
Component: Climatronic H01 0386
Coding: 002022017020320000100010110001102000102100021101000000000000
ASAM Dataset: EV_ACClimaBHBMEB31X 002007
ROD: EV_ACClimaBHBMEB31X.rod
VCID: 7EB01AE0E13ED366B9-802A
Subsystem 1 - Part No SW: 1EA 820 021 A HW: 1EA 820 021 A
Component: J126 J126 002 0004
Serial number: 00000000000000000011
A/C compressor sub:
Subsystem 2 - Part No SW: 1EA 816 551 L HW: 1EA 816 551 L
Component: J842 eKK H10 0005
Serial number: 1EA816551L060924319Y
Humidity sensor: exterior:
Subsystem 3 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H04 0010
Serial number: A5A9085800PAG0MUFU04
Auxiliary Heater Control Module/PTC 2:
Subsystem 4 - Part No SW: 1EA 963 581 C HW: 1EA 963 581 C
Component: 0123456789012 010 0160
Serial number: 5390220AA20318000348
Interior temperature sensor:
Subsystem 5 - Part No SW: 5WA 907 527 HW: 5WA 907 527
Component: E857 H01 0103
Serial number: 00002061120143714510
Expansion valve 1 for refrigerant:
Subsystem 6 - Part No SW: 1EA 816 681 A HW: 1EA 816 681 A
Component: N636 EV1_KaMi 003 0002
Serial number: E100000000000I9K4868
Expansion valve 2 for refrigerant:
Subsystem 7 - Part No SW: 1EA 816 682 A HW: 1EA 816 682 A
Component: N637 EV2_KaMi 003 0002
Serial number: E200000000000Q7K0036
Expansion valve 3 for refrigerant:
Subsystem 8 - Part No SW: 1EA 816 682 A HW: 1EA 816 682 A
Component: N638 EV3_KaMi 003 0002
Serial number: E300000000000Q7K0036
Carbon dioxide content sensor:
Subsystem 9 - Part No SW: 4N0 907 658 HW: 4N0 907 658
Component: G929 ICO2S H04 0231
A/C pressure/coolant temperature sensor 2:
Subsystem 10 - Part No SW: 4N0 959 126 G HW: 4N0 959 126 G
Component: G826 pT-Sens2 H04 0002
A/C pressure/coolant temperature sensor 3:
Subsystem 11 - Part No SW: 4N0 959 126 H HW: 4N0 959 126 H
Component: G827 pT-Sens3 H04 0002
Shut-off valve 1 for refrigerant:
Subsystem 12 - Part No SW: 1EA 816 681 A HW: 1EA 816 681 A
Component: V424 AV1_KaMi 003 0002
Serial number: A100000000000I9K4868
Shut-off valve 2 for refrigerant:
Subsystem 13 - Part No SW: 1EA 816 701 A HW: 1EA 816 701 A
Component: N640 AV2_KaMi 003 0002
Serial number: A20000000000038K0060
Shut-off valve 3 for refrigerant:
Subsystem 14 - Part No SW: 1EA 816 701 A HW: 1EA 816 701 A
Component: N641 AV3_KaMi 003 0002
Serial number: A30000000000038K0060
Shut-off valve 4 for refrigerant:
Subsystem 15 - Part No SW: 1EA 816 702 A HW: 1EA 816 702 A
Component: N642 AV4_KaMi 003 0002
Serial number: A4000000000000003R3K
Shut-off valve 5 for refrigerant:
Subsystem 16 - Part No SW: 1EA 816 702 A HW: 1EA 816 702 A
Component: N643 AV5_KaMi 003 0002
Serial number: A5000000000000003R3K
A/C pressure/coolant temperature sensor 4:
Subsystem 17 - Part No SW: 4N0 959 126 F HW: 4N0 959 126 F
Component: G395 pT-Sens1 H04 0002
A/C pressure/coolant temperature sensor 5:
Subsystem 18 - Part No SW: 4N0 959 126 G HW: 4N0 959 126 G
A/C pressure/coolant temperature sensor 6:
Subsystem 19 - Part No SW: 4N0 959 126 H HW: 4N0 959 126 H
7 Faults Found:
394240 - A/C Refrigerant Pressure/Temperature Sensor 1
P123D 00 [00100111] - Lower Pressure Limit not Reached
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
Voltage terminal 30: 12.10 V
Outside temperature: 12.00 °C
Inside temperature: 13.40 °C
394246 - A/C Refrigerant Pressure/Temperature Sensor 2
P123F 00 [00100111] - Lower Pressure Limit not Reached
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
394257 - A/C Refrigerant Pressure/Temperature Sensor 3
P124F 00 [00100111] - Lower Pressure Limit Not Reached
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
458499 - Refrigerant Temperature/Pressure Sensor 4
P1C7E 00 [00100111] - Lower Pressure Limit Not Reached
[DTS4_R744 lower limit not reached]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
458503 - Refrigerant Temperature/Pressure Sensor 5
P1C80 00 [00100111] - Lower Pressure Limit Not Reached
[DTS5_R744 lower limit not reached]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
523582 - ROD - Unknown Error Code
- 00 [00100111]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
523548 - Engine Control Module
U12DB 00 [00100110] - Received Malfunction Message
[Engine Control Module (ECM) received malfunction 3]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
Address 09: Cent. Elect. (J519) Labels: 1EA-937-BCM-V1.clb
Part No SW: 1EA 937 089 L HW: 1EA 937 089 A
Component: SAM_H H22 0130
Serial number: 06102032300808- Dataset Number: V03935341HX 0001
ASAM Dataset: EV_SAMVW31x 003001
ROD: EV_SAMVW31x_003.rod
VCID: 47DEBF04FE6452AE4A-8012 SFD
Subsystem 1 - Part No SW: 10A 955 119 HW: 10A 955 119
Component: FWISCHER_MYJT 003 0050
Serial number: 909353F0402025900910
Wiper motor control unit 2:
Subsystem 2 - Part No SW: 10A 955 120 HW: 10A 955 120
Component: FWISCHER_SL02 003 0050
Serial number: 909453F0302027002726
Subsystem 3 - Part No SW: 5Q0 955 555 B HW: 5Q0 955 555 B
Component: RLHSS 054 0208
Serial number: S7Y20M10D08H00M14S42
Subsystem 4 - Part No SW: 10A 941 193 K HW: 10A 941 193 K
Component: LiSi H04 0513
Serial number: TW571413112000020227
Subsystem 5 - Part No SW: 10A 925 200 D HW: 10A 925 200 D
Component: DiEta H07 0513
Serial number: TW571419112000010412
Subsystem 6 - Part No SW: 5H0 959 561 K HW: 5H0 959 561 K
Component: DACHKONSOLE 006 0006
Serial number: 92413TFB00696-------
Address 10: Park/Steer Assist (-----) Labels:| 1EA-919-294.clb
Part No SW: 1EA 919 294 B HW: 1EA 919 294
Component: PDC08K------- H02 0208
Serial number: 000006092094630 Dataset Number: V03935338DY 0001
Coding: 0040010001
ASAM Dataset: EV_EPHBO18VW3100000 002016
ROD: EV_EPHBO18VW3100000_VWE3.rod
VCID: 3B36D3F4B2AC064EDE-806E
13637426 - Databus
U1123 00 [00100111] - Received Error Message
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
13639955 - Databus
[Steuergerät für Fahrzeugbewegung - EML_06.EML_LenkWnklVL - Datenbus empfangener Fehlerwert]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
13639956 - Databus
[Steuergerät für Fahrzeugbewegung - EML_06.EML_LenkWnklVR - Datenbus empfangener Fehlerwert]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
13639974 - Databus
[Steuergerät für Fahrzeugbewegung - EML_06.EML_Kurvenkruemmung - Datenbus empfangener Fehlerwert]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
13647889 - Databus
[Bremsensteuergerät - VMM_02.VZM_Systemstatus - Fehlerspeicher auslesen]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:14
Address 13: Auto Dist. Reg (J428) Labels:| 1EA-907-572.clb
Part No SW: 1EA 907 572 G HW: 1EA 907 572
Component: ARS510VW19 H02 0123
Dataset Number: V03935340ER 0001
Coding: 010310714071404512474008000040C5AF4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARCONTIVW310 003008
ROD: EV_FRONTRADARCONTIVW310_003.rod
VCID: 3C34D0E8B7A20176D7-8068
0723 - Databus
U1123 00 [00101111] - Received Error Message
[FAULT_BV_RELEVANT_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
209153 - Databus
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
2055 - Databus
U1122 00 [10101111] - Implausible Message
[FAULT_ALP_STEERING_WHEEL_INIT]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
2101 - Databus
U1123 00 [10101111] - Received Error Message
[FAULT_ESP_STATUS_SYSTEM_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
0577 - Databus
[FAULT_VZM_SYSTEM_STATUS_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:13
2068 - Databus
[FAULT_TSK_IRREV_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
Address 15: Airbags (J234) Labels: 1EA-959-655.clb
Part No SW: 1EA 959 655 CD HW: 1EA 959 655 CD
Component: VW40Airbag 009 0366
Serial number: U320VzE1A58 Dataset Number: V03935341DN 0001
Coding: 88CC008000F0C000000000200000000051540000A1540000C000F680002B0065
Shop #: WSC 20746 004 1048576
ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
ROD: EV_AirbaVW40ALVVW38X_VW41.rod
VCID: 0542750C84E880BEF8-8050 SFD
Subsystem 1 - Part No SW: ----------- HW: 440 001 510 20
Component: SideSensor_Df 00A 0887
Serial number: 357CJ0000007F124FB4J
Subsystem 2 - Part No SW: ----------- HW: 440 000 909 20
Component: SideSensor_Pf 00A 0887
Serial number: 358CJ000000D59A4394I
Subsystem 3 - Part No SW: ----------- HW: 440 001 310 20
Component: SideSensor_Dr 00A 0189
Serial number: 351CJ0462EA4F642D00Y
Subsystem 4 - Part No SW: ----------- HW: 440 001 310 20
Component: SideSensor_Pr 00A 0189
Serial number: 352CJ2C62EA4F2B3E007
Subsystem 5 - Part No SW: ----------- HW: 440 002 909 20
Component: FrontSensor_P 00A 014A
Serial number: 355CJB2F43913215F00T
1075464 - Databus
[NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:13
1075461 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:13
1075462 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:13
1075463 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:13
1075465 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:13
Address 16: Steering wheel (J527) Labels:* 1EA-953-507.clb
Part No SW: 1EA 953 507 G HW: 1EA 953 507 G
Component: GSMMEB 006 0071
Serial number: 000000161120260
Coding: 0000
ASAM Dataset: EV_SMLSKLOMEB 010001
ROD: EV_SMLSKLOMEB_010_VW49.rod
Address 17: Instruments (J1254) Labels:| 10A-920-320.clb
Part No SW: 10A 920 320 A HW: 10A 920 320
Component: FAHRERDISPLAY 009 0520
Serial number: 0K1X2884-D85511
Coding: E670
ASAM Dataset: EV_DashBoardLGMEB 001027
ROD: EV_DashBoardLGMEB_001_VWE3.rod
VCID: 13665B54FABC2E0E66-8046 SFD
Address 19: CAN Gateway (J533) Labels: 1EA-937-012.clb
Part No SW: 1EA 937 012 M HW: 1EA 937 012 A
Component: ICAS1 Host-SG 065 0136
Serial number: SJ8ICS201120117 Dataset Number: V03935364VL 0001
GVL: 2D0000002608508C8062904048180040C000400000060000000000000000C057
ASAM Dataset: EV_GatewICAS1MEB 005001
ROD: EV_GatewICAS1MEB.rod
VCID: 3A38D6F0BD963F46C5-806E SFD
Subsystem 1 - Part No SW: 1EA 915 181 HW: 1EA 915 181
Component: J367-BDMConti H04 1074
Serial number: 7646660400201108057A
Subsystem 2 - Part No SW: 1EA 959 442 HW: 1EA 959 442
Component: MFL H08 0028
Serial number: 17029815051272000902
2502842 - Ethernet Antenna Module
U1646 00 [00100111] - No Communication
[Antenna_control_module_1_no_communication_vlan]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:29
8397571 - LV Energy Management
B1802 F1 [00100111] - Warning Triggered
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
100
8540417 - EgoMaster
U15FA 00 [00100111] - Input Data Error
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
Address 23: Brake Booster (J539) Labels: Redir Fail!
Part No SW: 1EA 909 059 AJ HW: 1EA 909 059
Component: EBB-ZF-Gen1 H28 0276
Serial number: ˙˙˙˙˙˙˙ Dataset Number: V03935344AZ 0001
Coding: 08951384003E103FC84400DE20E02020202020202021212121000404040404040404848484840008001000
ASAM Dataset: EV_BrakeBoostZFMEB 012139
ROD: EV_BrakeBoostZFMEB_012_VWE3.rod
VCID: 02486E1095C6B786DD-8056 SFD
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 1EA 905 861 HW: 2Q0 905 861 B
Component: ELV-MEB H09 0040
Serial number: 20000272883001
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 74A438C8DF728936DF-8020
Part No SW: 1EA 959 593 D HW: 1EA 959 593
Component: TSG FS 003 0543
Serial number: 0000425622752 Dataset Number: V03935344WW 0001
Coding: 00310320D00084000D001000
ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
VCID: 43C6AB14CA5C7E8E96-8016
Door operating panel: driver side:
Subsystem 1 - Part No SW: 10A 959 862 N HW: 10A 959 862 N
Component: EX36 TBF_FS H21 0107
Serial number: 0088-11.11.20-------
Subsystem 2 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000117104142
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 1EA 907 144 AF HW: 1EA 907 144 G
Component: BASGEN1MQB37 215 5024
Serial number: 00463309 Dataset Number: V03935342PF 0001
Coding: 0000000000000201000002010100010000000100010102
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
5423 - Steering Angle Sensor
B1168 F2 [10100111] - Not Initialized
[DTC_RACKPOS_NOINIT]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:08
MonitorId: 00 00
HybridDriveReady: 00000000
IgnitionEnabled: 00000001
Communication control: 00000000
Diagnostic session: 00000001
ComM_ModeType: 00000000
NM_Signal_Fahrbereit: 00000000
NM Signal V gr 7: 00000000
System status: 3
ECU Status: 0
HWLib Status: 1
Support power reduction: 0.0 %
Voltage terminal 30: 12.281 V
Temperature circuit board: 25 °C
Output stage temperature: 16 °C
Rackposition: 0.00 mm
Rackspeed: 0.00 mm/s
pinion angle dependent amplitude factor: 0 °
Steering wheel angle: 0.25 °/s
SupplierFreezeFrameData: 01 00 00 00 02 02 00 00 DC B7 08 00 01 00 00 00 01 00 00 00
Address 51: Electric Drive (J841) Labels: 1EA-907-121.clb
Part No SW: 1EA 907 121 AC HW: 1EA 907 121 C
Component: MEB INV4.0 H08 6044
Serial number: NRR_M9000085346 CVN: 4E52525F4D39303030303835
ASAM Dataset: EV_DMCM15000F11EA907121AC 001011
ROD: EV_DMCM15000F11EA907121BC.rod
41735 - Databus
[Databus error value received]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:12
Inverter_operating_state: FREEWHEEL_MODE
Actual_mechanical_torque_calculated: 0.208 Nm
Actual_mechanical_torque_commanded_value: 0.000
Temperature_IGBT_phase_U: 14.706 °C
Temperature_IGBT_phase_V: 15.000 °C
Temperature_IGBT_phase_W: 15.000 °C
CAN_operation_mode_HV_battery_module_control: HV_inaktiv
Voltage_Terminal_15: 12.346 V
DC_link_voltage: 0.705 V
Freewheel_active: Fehler__EM_im_Freilauf
Actual_possible_maximum_torque: 0.208 Nm
Actual_possible_minimum_torque: 0.208 Nm
Absolut_value_RPM_e_machine: -0.034 /min
Inverter_damping_control_gear_ratio: 11.531
Inverter_damping_control_tooth_number: 43
Expected_model_type: 0
Part No SW: 1EA 959 592 D HW: 1EA 959 592
Component: TSG BFS 003 0543
Serial number: 0000422828975 Dataset Number: V03935344WX 0001
Coding: 00310120DC00040001801000
ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
VCID: 42C8AE10D54677869D-8016
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000117106417
Address 5F: Information Electr. (J794) Labels:| 10A-035-IC3-V1.clb
Part No SW: 10A 035 820 G HW: 10A 035 820 A
Component: IC3-SF--EU H20 0912
Dataset Number: V03935348NE 0001
Coding: 23106030000000000000000000000000000000000000000000
ASAM Dataset: EV_MUICASSAFEPart 001001
ROD: EV_MUICASSAFEPart_001.rod
VCID: 1B763374126C664E3E-804E SFD
Subsystem 1 - Part No SW: 10A 919 605 K HW: 10A 919 605 K
Component: ABT_E_10 H55 2092
Serial number: APUF6317112000030079
Part No SW: 10A 035 284 F HW: 10A 035 284
Component: OCUGen4 H17 0442
Serial number: 0000000011VIBB7 Dataset Number: V03935351PP 0001
Coding: 02310010106880008005460000000000
ASAM Dataset: EV_OCUGen4 001034
ROD: EV_OCUGen4_VWE3.rod
VCID: 1E703A60017E7366D9-804A SFD
1375744 - Secure Onboard Communication
U14FE 00 [00101111] - Signature Verification Failed
[SOK_signature_verification_failed]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:11
Address 8C: HV Battery (J840) Labels: 0Z1-915-184.clb
Part No SW: 0Z1 915 184 H HW: 0Z1 915 184 D
Component: J840 K8C BMC 007 0930
Serial number: 000000241120010 Dataset Number: V03935356KC 0001 CVN: EC5290A80000000037CBCE7B3DFBA09F3DFBA09F
ASAM Dataset: EV_BMCeVWBSMEB 001012
ROD: EV_BMCeVWBSMEB_001.rod
VCID: 3FCEA7E4A6B41A6EF2-806A
Cell module control module 1:
Subsystem 1 - Part No SW: 0Z1 915 140 BD HW: 0Z1 915 140 BC
Component: SX6 X74 CMC 005 0900
Serial number: 00000013112025061349
Cell module control module 5:
Subsystem 2 - Part No SW: 0Z1 915 140 E HW: 0Z1 915 140 D
Serial number: 00000025112027060647
Cell module control module 9:
Subsystem 3 - Part No SW: 0Z1 915 140 E HW: 0Z1 915 140 D
Serial number: 00000025112027050649
Coolant heating:
Subsystem 4 - Part No SW: 1EA 963 231 HW: 1EA 963 231
Component: J848 HV-PTC H03 0500
Serial number: CE201783014402000653
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 1EA 980 654 J HW: 1EA 980 654
Component: MEB MFK 4.1 H03 5230
Dataset Number: V03935361MN 0001
Coding: 0008302A150108E0062420000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK41ValeoMEB 001053
ROD: EV_MFK41ValeoMEB_VWE3.rod
VCID: 41CAA11CD0406C9E84-8014
7 Faults Found:
1124497 - Databus
[ACC_18_ACC_Status_ACC_irreversibel_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
1123077 - Databus
[LH_EPS_03_EPS_BLW_Qbit_EPS_Berechneter_LW_QBIT_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
1124684 - Databus
[ESP_21_ESP_Systemstatus_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
1124638 - Databus
[LWI_01_LWI_Qbit_Lenkradwinkel_LWI_Lenkradwinkel_QBIT_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
1126404 - Databus
[EML_06_EML_LenkWnklVL_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
1126405 - Databus
[EML_06_EML_LenkWnklVR_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
1126410 - Databus
[EML_06_EML_Kurvenkruemmung_ERROR]
Mileage: 27291 km
Date: 2024.11.01
Time: 15:46:09
Address C0: Act. for Ext. Noise (J943) Labels: 1EA-035-335.clb
Part No SW: 10A 035 335 C HW: 1EA 035 335
Component: E_SOUND_SG H05 0006
Serial number: JTK072041120812
ASAM Dataset: EV_ESoundMEBHarma 004011
ROD: EV_ESoundMEBHarma.rod
VCID: 187C2C78E35A0D5613-804C
Address C6: Batt. Chrg. (J1050) Labels:| 1EA-915-684.clb
Part No SW: 1EA 915 684 BG HW: 1EA 915 684 BF
Component: HV_CHARGER H52 0013
Serial number: 92832THU00047
Coding: 1080
ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002010
ROD: EV_OCCXPhase1KLOMEB01B.rod
VCID: 014A611C90C0AC9EC4-8054
Part No SW: 992 941 591 DE HW: 992 941 591 D
Component: LED1L H08 9202
Dataset Number: V03935336SE 0001
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 6A9826B08DB64FC675-803E
Component: LED1R H08 9202
Dataset Number: V03935336SL 0001
Address 8105: DC/DC Converter 12V (A19) Labels: 1EA-907-190.clb
Part No SW: 1EA 907 190 G HW: 1EA 907 190 D
Component: DCDC Gen4H11 1142
Revision: 00H11000
ASAM Dataset: EV_DCDC10030111EA907190G 001022
ROD: EV_DCDC10030111EA907190G.rod
VCID: 383CCCF8839A2D5633-806C
Address 8107: Antenna (J666) Labels:* None
Part No SW: 1EA 035 741 H HW: 1EA 035 741 D
Component: TrxModulHigh H07 0202
Serial number: 0000000009VIPA3 Dataset Number: V03935340QH 0001
Coding: 02310611040280
ASAM Dataset: EV_TrxMLGEMEB 006014
ROD: EV_TrxMLGEMEB.rod
VCID: 3326FBD49AFCCE0E06-8066 SFD
Address 8123: App server 1 system 1 adaptive (SWC4) Labels: V04-007-XXX-SWC4.clb
Part No: V04 007 003 EP
Component: ICAS1 Sys_Ada 0136
Dataset Number: V03935361TL 0001
ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
ROD: EV_AppServe1Syste1ICAS1.rod
VCID: 79BA09FCF810F45E8C-802C SFD
Address 8124: App server 1 system 2 Java (SWC5) Labels: V04-007-XXX-SWC5.clb
Part No: V04 007 003 EQ
Component: ICAS1 Sys_Jav 0136
ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
ROD: EV_AppServe1Syste2ICAS1.rod
VCID: 7AB816F0FD16FF4685-802E SFD
Address 8125: App server 3 system 1 infotaint. (SWC6) Labels:| V04-007-XXX-SWC6.clb
Part No: V04 007 003 FH
Component: IC3-IVI-D-EU 0912
Dataset Number: V03935346WP 0001
ASAM Dataset: EV_MUICASIVIPart 002007
ROD: EV_MUICASIVIPart_002.rod
VCID: 72A83ED0A5668706CD-8026 SFD
Address 8128: Light line display (J145) Labels: 10B-919-451.clb
Part No SW: 10B 919 451 B HW: 10B 919 451 B
Component: Lichtlinie1 004 0106
ASAM Dataset: EV_SmartLight1MEB 002001
ROD: EV_SmartLight1MEB.rod
VCID: 22080E9035065786FD-8076
Address C002: SW Cluster Embedded (SWC2) Labels: V04-007-XXX-SWC2.clb
Part No: V04 007 003 ER
Component: ICAS1 SWCL_Em 0136
Dataset Number: V03935362KU 0001
ASAM Dataset: EV_SWCLEmbed1ICAS1 005001
ROD: EV_SWCLEmbed1ICAS1.rod
VCID: 7BB613F4F22CC64E9E-802E SFD
Address C003: SW Cluster Housekeeping (SWC3) Labels: V04-007-XXX-SWC3.clb
Part No: V04 007 003 ES
Component: ICAS1 SWCL_HK 0136
ASAM Dataset: EV_SWCLHouse1ICAS1 005001
ROD: EV_SWCLHouse1ICAS1.rod
VCID: 7CB410E8F722C17697-8028 SFD
End----------(Elapsed Time: 02:18, VBatt start/end: 12.2V/12.2V)-----------
