Hi. Half year ago I had break my exhaust system and I had leave my car for half year waiting for the repair. Finally it is done, but once returned from mechanic I found on screen big overheat info, however the temperature is fine. I have connected VCDS and it told me that I have ECU errors. Indeed there are 12 errors which come back instantly once engine is running. Mechanic had theory that battery can be damaged so I have ordered new one. In the meantime I have replaced the battery with the fine one from my other car and unfortunatelly the result is them same. How should I start inspecting that issue and find the problem? This list is overhelming me a bit...
13 Faults Found:
17980 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground
17984 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground
16441 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground
16421 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low
16415 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0031 - 002 - Short to Ground
16435 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0051 - 002 - Short to Ground
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 002 - Internal Resistance too High
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 002 - Internal Resistance too High
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
any recommendations where to start?
13 Faults Found:
