eGolf Error - Electrical system Stop
thecrave
California, USA
C?ID=602652
New user, verified (I received the account approved email), but I am not able to post. Posting here, perhaps mods can resolve and move post to correct forum.
Having a fatal issue with my eGolf after using VCDS 24.7.1 and going into module 8C, Basic Settings (04) and running ENG1311-Cell-Controller_Numbering. I assumed this to be an information pull, not anything that would impact operation. However, afterwards I received the red triangle with bang, and error, "Error: Electrical system. Stop!" and while the car powers on, it will not drive. Everything was fine with it prior to this action.
I also noticed my 50% GOM (should have been around 40ish miles) drop to 6 miles.
12V battery has a good charge.
I attempted removing the HV fuse and letting it sit for a few hours, then replacing - to no avail.
I've attempted to clear DTCs in modules 01, 51 8C with no resolution. My guess is the HV system has shut down and needs to be re-connected. Hoping this is doable with VCDS, else it's going to take a dealer trip.
Scan attached. Appreciate any assistance!
Friday,01,November,2024,16:10:25:49703
VCDS Version: 24.7.1.0 (x64)
VIN: WVWPP7AU3GW903514   License Plate:
Mileage: 38575km-23969mi   Repair Order:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75 8C
          BD C0 C5 C6
VIN: WVWPP7AU3GW903514   Mileage: 38575km-23969miles
51-Electric Drive -- Status: Malfunction 0010
8C-HV Battery -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: Malfunction 0010
Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 C    HW: 0EA 907 309 A
   Component: E-Vehicle     H23 8344
   Revision: WMH23---    CVN: 087F2E10
   Coding: 000D0016002400007000
   ASAM Dataset: EV_VCU00XXX0110EA906016C 002006
   ROD: EV_VCU00XXX0110EA906016C_002.rod
   VCID: 2F6608F476DF6BEE62-807A
   VINID: 9E69E08074650D79C900314110E648B86C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
   Component: ESC           H31 0809
   Revision: 00000000    Serial number: 62105000000367 CVN: 5FDA0203
   Coding: 01FA40A12C20316F017C020181C7298002348C80408194B202810058C242
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001.rod
   VCID: 050A8A5C84E301BEF8-8050
   Revision: 00021000    Serial number: 0376579074 Dataset Number: V03935209LA 0001
   Coding: 030C0C
   VCID: 3A7029A0BD9DBE46C5-806E
   Part No SW: 5GE 907 044 AD    HW: 5GE 907 044 AD
   Component: Climatronic   H02 1105
   Revision: 00001K07    Dataset Number: 0000
   Coding: 00022200200100000005004200111803
   ASAM Dataset: EV_ACClimaBHBVW37X 005132
   VCID: 7EF8E5B0E1355266B9-802A
   Air quality sensor:
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061521000088 Dataset Number: V03935221M0001
   Coding: 00011A66434182E169EC4000001407201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7F0618B4E63F5B6EB2-802A
   Component: WWS    150711  043 0551
   Serial number:         150811135710
   Component: RLHS  037 0059
   Serial number: S4Y15M08D25H19M55S23
   Coding: 90A8DD
   Revision: --------    Serial number: 39331523701307 Dataset Number: 5GE039v__A_ 0007
   Coding: 2031151011
   VCID: 438E5444CA57FF8E96-8016
   Serial number: 003GCR03139V Dataset Number: 5GE003V____ 0021
   Coding: 8CCCFC00002000005000001AC24800000065
   VCID: 47964054FE6FD3AE4A-8012
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000000000034ZADP
   Coding: 303139
   Subsystem 2 - Part No SW: -----------    HW: 480 001 408 15
   Serial number: 357000000006B114E51F
   Subsystem 3 - Part No SW: -----------    HW: 480 000 708 15
   Serial number: 358000000004A97DC51Y
   Subsystem 4 - Part No SW: -----------    HW: 480 401 108 15
   Serial number: 35100029D1C1EFA501DJ
   Subsystem 5 - Part No SW: -----------    HW: 480 400 808 15
   Serial number: 3520002991D1B621D181
   Subsystem 6 - Part No SW: -----------    HW: 480 401 108 15
   Serial number: 3550002AF1C1EFA2728Q
   Subsystem 7 - Part No SW: -----------    HW: 480 401 108 15
   Serial number: 3560002AF1C1EFA581AW
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 07081508490645
   Coding: 0410
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 07168054BEEF13AE8A-8052
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5GE 920 855 A    HW: 5GE 920 855 A
   Component: KOMBI         302 6420
   Coding: 0B35181A2B80CF05020868001700032000000000
   VCID: 3F8658B4A6BF9B6EF2-806A
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 D    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3225
   Revision: --------    Serial number: 31071510800530 Dataset Number: V03935223TM 0001
   Coding: 0201001706F81000FB001200081F00000001050100030000000300000000
   GVL: 01543C0000000608540C1000B000481800000000000000000000000000000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150001078680045214
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 7768177503
131707 - No Communication with HV Battery Energy Control Module
          U0112 00 [00001000] - -
                    Reset counter: 143
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:49:18
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: OFF
Address 23: Brake Booster (J539)       Labels:| 5QE-909-059.clb
   Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
   Component: EBKV          H14 0182
   Serial number:   085430010537
   Coding: 01720100321A02030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
   ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
   VCID: 4FA66874161F0BEE02-801A
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861270715141229
   Revision: 00000000    Serial number: 15000180517007
   Coding: 7900000000000000
   VCID: 346C07989FF948361F-8060
   Serial number: 180715BGI00051 Dataset Number: 5GE222v____ 0005
   Coding: 003E13208000040000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Serial number: 00000000000006926362
   Coding: 111000
          B1487 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 103
                    Mileage: 37430 km
                    Date: 2024.08.28
                    Time: 10:27:08
   Component: EPS_MQB_ZFLS  125 1061
   Dataset Number: 5G0074v____ 0887
   Coding: C102
Address 51: Electric Drive (J841)       Labels:. 5QE-907-080.clb
   Part No SW: 5QE 907 080 D    HW: 5QE 907 080 D
   Component: VW370E2615020 H07 2470
   Revision: 00H07000    CVN: D75E7ECA
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080D 001021
   ROD: EV_DMCM09550115QE907080C.rod
19063 - No Communication with Battery Energy Control Module
          U0111 00 [00100110] - -
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:58:40
                    Vehicle speed: 255 km/h
                    Voltage terminal 30: 11.794 V
                    Drive control condition: Prec
                    Drive control condition-Test_Program_Enum ACI st Drv Ctrl UBYTE: 21
19067 - No Communication with Battery Energy Control Module
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:58:40
19071 - No Communication with Battery Energy Control Module
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:58:40
19075 - No Communication with Battery Energy Control Module
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:58:40
                    Voltage terminal 30: 11.802 V
   Serial number: 150715BGF00803 Dataset Number: 5GE157v____ 0005
   Coding: 003E13208C00040000000000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 42805140D54DF6869D-8016
   Serial number: 00000000000007132438
   Coding: 091000
65591 - Motor for Window Regulator
          B1487 4B [00001000] - Over Temperature
                    Reset counter: 117
                    Mileage: 37692 km
                    Date: 2024.09.07
                    Time: 18:06:49
   Revision: --------    Serial number: -------------- Dataset Number: V03935194PG 0001
   Coding: 051A000101010000
   VCID: 75EAFA9CD403113EE8-8020
   Part No SW: 3G0 035 047 D    HW: 3G0 035 047
   Component: MU-H-NS-US    H42 0344
   Serial number: A296G0F7500789 Dataset Number: V03935223SB 0001
   Coding: 02737002FF00000051220001041C08001F0105D401200105DE
   VCID: 2142FECC300BCD9EE4-8074
   Subsystem 1 - Part No SW: 5G0 919 606 B    HW: 5G0 919 606 B
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU90016J
   Subsystem 2 - Part No SW: V03 959 801 BS    HW: -----------
   Component: NAR 2015/2016  --- 0044
   Compact disc data bank:
   Component: Gracenote2  --- 3007
                    Reset counter: 89
                    Mileage: 23021 km
                    Date: 2019.12.20
                    Time: 11:09:03
                    Voltage terminal 30: 13.4 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
0009 - Antenna for Satellite Radio
          B10F4 13 [00001001] - Open Circuit
                    Reset counter: 175
                    Mileage: 23021 km
                    Date: 2019.12.20
                    Time: 09:47:46
                    Satellite radio tuner status-Antenna current: 3 mA
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
   Component: OCULowMQBUS   007 0566
   Dataset Number: V03935221QP 0001
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB.rod
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
   Component: K8C           H13 0722
   Serial number: VWADFHR003     CVN: E708CF50
   ASAM Dataset: EV_BECM08820215QE915227M 003016
   ROD: EV_BECM08820215QE915227H.rod
   VCID: 52A06100052D66062D-8006
23264 - Internal Control Module
          P060C 00 [01100101] - Main Processor Performance
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:54
                    Current of H-V / hybrid battery: 0.000 A
18413 - Internal Temperature Measurement
          U1409 00 [00100100] - Implausible Signal
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:58:40
                    Battery temperature: 14.234 °C
18376 - Battery Control Module 3
          U01A2 00 [00100111] - No Communications
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:54
18386 - Battery Control Module 5
          U01A4 00 [00100111] - No Communications
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:54
18394 - Battery Control Module 7
          U01A6 00 [00100111] - No Communications
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:54
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V1.clb
   Part No SW: 5QE 915 022 G    HW: 12E 915 022 C
   Component: LMSG          H08 1075
   Serial number: 00920053170553 Dataset Number: 5GEHY1V____ 0018
   Coding: 4A4904
   ASAM Dataset: EV_HVChargManagVWMQB 001001
   ROD: EV_HVChargManagVWMQB_001.rod
   VCID: 458A4A5CC463C1BEB8-8010
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 H    HW: 5QE 035 335 H
   Component: E_SOUND_SG    H07 0198
   Serial number: EN153103100000 Dataset Number: 5QE035335H  0110
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 005012
   ROD: EV_ENoiseS1NNVW3707_005.rod
   VCID: 46884D50F965CAA6B1-8012
Address C5: Therm. mgt. (J1024)       Labels: 5GE-907-458.clb
   Part No SW: 5GE 907 458 A    HW: 5GE 907 458
   Component: TME-Min       H04 0109
   Serial number: 0010520
   ASAM Dataset: EV_ThermContrVISAU49X 001009
   ROD: EV_ThermContrVISAU49X_VW37.rod
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number: LM152203003807000031
   A/C compressor sub:
   Subsystem 3 - Part No SW: 5QE 820 803 A    HW: 5QE 820 803 A
   Component: J842 eKK  H03 0007
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G826 pT-Sens2  H61 0006
   A/C pressure/coolant temperature sensor 3:
   Subsystem 5 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G827 pT-Sens3  H61 0006
   A/C pressure/coolant temperature sensor 4:
   Subsystem 6 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G828 pT-Sens4  H61 0006
   A/C pressure/coolant temperature sensor 5:
   Subsystem 7 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G829 pT-Sens5  H61 0006
   Expansion valve 1 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 682 C    HW: 4M0 816 682 C
   Component: N636 EV1_KaMi  H09 0102
   Serial number: 00000000000020064141
   Expansion valve 2 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 682 C    HW: 4M0 816 682 C
   Component: N637 EV2_KaMi  H09 0102
   Serial number: 00000000000020064146
   Expansion valve 3 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 682 C    HW: 4M0 816 682 C
   Component: N638 EV3_KaMi  H09 0102
   Serial number: 00000000000020063966
   Shut-off valve 1 for refrigerant:
   Subsystem 11 - Part No SW: 4M0 816 703 A    HW: 4M0 816 703 A
   Component: V424 AV1_KaMi  H09 0102
   Serial number: 00000000000040063718
   Shut-off valve 4 for refrigerant:
   Subsystem 12 - Part No SW: 4M0 816 703 A    HW: 4M0 816 703 A
   Component: N642 AV4_KaMi  H09 0102
   Serial number: 00000000000040063714
   Shut-off valve 5 for refrigerant:
   Subsystem 13 - Part No SW: 4M0 816 703     HW: 4M0 816 703
   Component: N643 AV5_KaMi  H09 0102
   Serial number: 00000000000040060633
37000 - Implausible Data Received from Electric A/C Compressor
          U046C 00 [00101111] - -
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:57
37033 - Implausible Data Received from Electric A/C Compressor
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:57
59009 - A/C Compressor
          B1453 F2 [00101111] - Internal Shut-Down Required
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:57
59042 - Refrigerant Pressure/Temperature Sensor 5
          P1C65 00 [00101111] - Faulty
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:57
59043 - Refrigerant Pressure/Temperature Sensor 5
                    Mileage: 38575 km
                    Date: 2024.11.01
                    Time: 15:54:57
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H52 1550
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707_VW37.rod
   VCID: 4B9E7C64E20737CE6E-801E
End-------------------------(Elapsed Time: 05:29)--------------------------
Viking
C?ID=151455
Your account on the forum is approved, but you're not yet a verified / registered VCDS owner.
See here for how to be verified.
thecrave
California, USA
C?ID=602652
Apologies, I submitted the form for verification and misunderstood the “account approved” email. I’ll wait for the verification to process. Thanks.
Eric
HC800000
Do you have an autoscan prior to the basic settings?
Warnings:
  • You should refer to the Factory Repair Manual for your particular car (or some other documented procedure) before "playing" with the Basic Settings function. Failure to follow the proper procedures can result in serious damage to the vehicle.
thecrave
California, USA
C?ID=602652
I do have an old auto scan. I'll post below. Seems no coding has changed, likely something deeper.
Thursday,17,May,2018,22:25:04:49703
VCDS Version: 18.2.0.3
Mileage: 14007km-8703mi   Repair Order:
          BD C0 C5 C6
VIN: WVWPP7AU3GW903514   Mileage: 14007km-8703miles
BD-Hi Volt. Batt. Charg. -- Status: Malfunction 0010
   Revision: WMH23---
   VCID: 2F6608F476DF6B3CB1-807A
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   ROD: EV_Brake1UDSContiMK100OMG_001_VW37.rod
   VCID: 050A8A5C84E3016C2B-8050
16401 - Tire Pressure Warning
          C102D 00 [032] -  -
   Coding: 030C0C
   VCID: 3A7029A0BD9DBE9416-806E
   Revision: 00001K07
   Coding: 00022200200100000005000200111803
   VCID: 7EF8E5B0E13552B46A-802A
   Air quality sensor:
   VCID: 7F0618B4E63F5BBC61-802A
   Coding: 90A8DD
   Coding: 2031151011
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 438E5444CA57FF5C45-8016
   VCID: 47964054FE6FD37C99-8012
   Occupant Detection:
   Coding: 303139
   Front Sensor Passenger:
   Coding: 0410
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 07168054BEEF137C59-8052
   VCID: 3F8658B4A6BF9BBC21-806A
   Coding: 30FFFF
Address 23: Brake Booster (J539)       Labels:* None
   VCID: 4FA66874161F0B3CD1-801A
   Brake Assistance Sub:
   ROD: EV_ELVMarquMQB.rod
   VCID: 346C07989FF948E4CC-8060
   Coding: 111000
   Coding: C102
   Revision: 00H07000
   VCID: 42805140D54DF6544E-8016
   Coding: 091000
   VCID: 75EAFA9CD40311EC3B-8020
   Part No SW: 3G0 035 047     HW: 3G0 035 047
   VCID: 5DBA823C4CF3A9AC53-8008
   Compact Disc Database:
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 12
                    Mileage: 9280 km
                    Date: 2017.03.02
                    Time: 17:45:37
                    Voltage terminal 30: 14.8 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Audio Signal: Available
                    Satellite radio tuner status-Reception quality: optimum_signal
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   VCID: 52A06100052D66D4FE-8006
   Coding: 4A4904
   VCID: 458A4A5CC463C16C6B-8010
2098720 - AirConditioning not possible because Battery SOC too Low
          P33EF 00 [008] - -
                    Fault Frequency: 96
                    Reset counter: 121
                    Mileage: 12629 km
                    Date: 2018.01.29
                    Time: 06:30:00
                    HV battery charge state: 0.0 %
   Coding: 04
   VCID: 46884D50F965CA7462-8012
Address C5: Therm. mgt. (J1024)       Labels: None
   Air Conditioning Compressor Sub:
   Refrigerant Pressure And Temperature Sender 2:
   Refrigerant Pressure And Temperature Sender 3:
   Refrigerant Pressure And Temperature Sender 4:
   Refrigerant Pressure And Temperature Sender 5:
   Refrigerant Expansion Valve 1:
   Refrigerant Expansion Valve 2:
   Refrigerant Expansion Valve 3:
   Refrigerant Shut Off Valve 1:
   Refrigerant Shut Off Valve 4:
   Refrigerant Shut Off Valve 5:
32837 - HV Electronics Coolant Pump Control
          P0CEB 00 [040] - Short to GND
                    Mileage: 5682 km
                    Date: 2016.04.16
                    Time: 15:51:43
36919 - Databus
                    Fault Frequency: 16
                    Mileage: 12177 km
                    Date: 2017.12.12
                    Time: 07:06:48
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
   VCID: 4B9E7C64E207371CBD-801E
End-------------------------(Elapsed Time: 05:42)--------------------------
I was hoping that the blockmaps that someone posted of my exact year and model (this is a 2016 SEL) would be helpful, in this post.
Guessing I should pull mine and compare
Eric
HC800000
So you haven't autoscanned in 6 1/2 years!? I was mostly curious if the 8C/P060C was there before, because that's a pretty serious one.
thecrave
California, USA
C?ID=602652
I mostly use VCDS on my other car, so only have a few saved scans here. Found one from 2019, looked basically the same.
There was definitely no issues with 8C before I started yesterday.
I’ve got the 12V on charge now since it’s run down due to all the scans I’m running. Fingers crossed that helps.
thecrave
California, USA
C?ID=602652
Updating here -
1) got my registration squared away on VCDS - thanks for the help!
2) vehicle status - Towed it to the dealer, they've had it for over two weeks and are recommending replacing "Cell Circuit 'C'" which includes two modules and a bunch of labor (dropping the battery) for a total of $8,575 + tax. 🤦‍♂️ Car is only worth about $12k. ha!
The main part numbers in the W.O. are 5QE-915-599-AH and two 5QE-915-599-AKs, listed as "Cell Modules." The rest is labor misc things.
Any insights into what running "ENG1311-Cell-Controller_Numbering" in VCDS did and perhaps how to un-do it? Some sort of adaptation on a BCM?
The independent shops w/ EV specialty that I've talked to said they can't help since they don't have ODIS.
I'd welcome additional insights or other resources to explore.
golfi_vend
Tartu, Estonia
C?ID=195131
I've seen it before.
Got a call that after "reading faults" car won't drive. We tried reflash of the named module, but nothing.
I don't know the the story after as car was towed to somewhere and I never got feedback. What I do know is that the module is buried deep inside the HV battery and whole battery needs to be taken apart. Module itself doesn't cost much, but labor does.
thecrave
California, USA
C?ID=602652
Sadly, that aligns with the information I'm getting back. Trying to figure out where to go from here. Real shame if I have to walk away from it. Here's a copy of the proposed effort:
dnoermann
C?ID=358118
Search for a used battery.
In Germany you get them between 2k and 5k €
DASGTI
Canada
C?ID=269988
Did you explain to the dealer what you did in VCDS before they gave you that quote?
thecrave
California, USA
C?ID=602652
I told them I tried to pull codes on it and then this happened. I didn't say I was using VCDS, specifically, and didn't say the specific action I took ("ENG1311-Cell-Controller_Numbering").
Would that even mean anything to them?
DASGTI
Canada
C?ID=269988
I mean at this point what choice do you have? I would talk to the technician directly and be honest with them.
thecrave
California, USA
C?ID=602652
I'm with you. I would love to know more about what that action (ENG1311-Cell-Controller_Numbering) specifically does as part of that conversation so that I could explain it in lower-level terms (not just VCDS terms). e.g., does it 0 out values and we would need to go back in there to put in proper values, etc.
Is there someone from Ross-Tech that can help with that understanding first so then I can go to the tech?
Else, I can just bring VCDS to the dealer with me and show them.
DASGTI
Canada
C?ID=269988
ENG1311-Cell-Controller_Numbering is not a VCDS function. All VCDS does is communicate with the module and it's the module that reported that this output test is there. VCDS then instructs the module to activate it's own test.
Bringing VCDS to the dealer won't do anything either. I think your best bet would be to find an independent shop who pays for ODIS access to try to work with you on an hourly flat rate. They would connect with ODIS and see if there is a guided function available for that module that would get you out of this error state. If that fails you might want to try to pay for one of those online services where someone connects remotely to help and they use ODIS-E (ODIS engineering).
thecrave
California, USA
C?ID=602652
This is helpful, thanks.
thecrave
California, USA
C?ID=602652
I just talked to the Service Advisor, told him the actions I took, what I wanted to pursue next and he said they had multiple calls with VWoA techs who remotely assisted their local tech with "guided fault" exploration in ODIS and this was their conclusion. Replace the modules.
Given that, do you think that an independent shop with ODIS-E would still be a valid path to pursue? Are there things one can do with ODIS-E that the VWoA techs won't/can't?
