I am trying to fix a dead electric rack and pinon on a 2013 Audi A4, everything turns freely when the car is on the lift but no steering assist. I can clear the ABS fault (03) but not the J500 (44).
I checked the connections and removed the J500 to make sure it was dry, no burnt smell or any visual sign of corrosion.
I saw in I could do a factory reset but did not try yet, would the factory reset using vagcom be my next step ?
I am not familiar with these electric racks but I see they have turn something that worked very well (hydraulics) into infinite failing possibilities
thanks for the pointers guys
Alex
Alex
Monday,28,October,2024,14:50:06:19459
VCDS Version: 24.5.0.0 (x64)
VIN: WAUHFCFLXDN038426 License Plate: FREDA413
Mileage: 204710km-127200mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 72
VIN: WAUHFCFLXDN038426 Mileage: 204710km-127200miles
Address 01: Engine (0-----CAEB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 C HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0007
Revision: ECH09--- CVN: F70685C3
Coding: 4A190013242600062000
Shop #: WSC 24797 002 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115C 001008
ROD: EV_ECM20TFS0118K5907115C.rod
VCID: 3260E8C76563620685-8066
VINID: 9D195859359CA147800C81021826F3056F
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CJ HW: 8K0 907 379 CJ
Component: ESP8 quattro H09 0100
Coding: 071500
Shop #: WSC 02391 785 00200
VCID: 030E7D0382591B8E5E-8056
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 57
Mileage: 204717 km
Date: 2024.10.28
Time: 14:42:28
Hex Value: 0x0000
Hex Value: 0x0702
Hex Value: 0x000A
Hex Value: 0xC08C
Hex Value: 0x0000
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H12 0633
Coding: 0F814000000000000000
VCID: 0102770B9845099E4C-8054
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Serial number: 0813000008824005
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000002333001
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 55
Mileage: 204651 km
Date: 2024.09.17
Time: 16:38:36
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01280120132486
Coding: 6400208000
VCID: 3972DFEBB015915E44-806C
Reset counter: 55
Mileage: 204651 km
Date: 2024.09.17
Time: 16:31:32
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000545932102
Coding: 26000096863CAFC00000480300003D0D0F1C130822090201000008000400030100000020000000
VCID: 78F41AEFCB9F48567B-802C
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250113 H07 0080
Serial number: SWF13010255964
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20910812
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002301131357
Serial number: C4694D86000000000001
01229 - A/C Humidity Sensor (G260)
014 - Defective
Fault Status: 01101110
Reset counter: 55
Mileage: 204651 km
Date: 2024.09.17
Time: 16:31:36
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 55
Mileage: 204651 km
Date: 2024.09.18
Time: 11:56:48
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD91BF27 Dataset Number: 8K0909602VA 0001
Coding: 30454435473030303030554A304C384B3053
Shop #: WSC 04003 002 1048576
VCID: 4A909027EDF30AC6DD-801E
Serial number: 6334MSME77322B4CL
Serial number: 6344MSME76746055E
Serial number: 6352QSME332C2872G
Serial number: 6362QSME4229226CH
Serial number: 63732SME15252F4E4
Serial number: 63832SME3C2B45543
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MAN001EZ
Coding: 000016
VCID: 438EBD03C2D9DB8E1E-8016
Part No SW: 8K0 920 931 P HW: 8K0 920 931 P
Component: KOMBIINSTR. H35 0556
Revision: 00300000 Serial number: UVL56EN1E
Coding: 8BA4090002010008020000
VCID: 3B7EC5E3BA29A34E56-806E
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y131210139
Coding: 80C303FF00
Shop #: WSC 02391 823 56573
VCID: 4A909027E5F30AC6DD-801E
Serial number: 9505999001
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000049960754
Coding: 00581B00000000000000
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13204E00410001
VCID: 56A87457214B5E2649-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0013185767 Dataset Number: 8K0909852H 0022
Coding: 100000000001
ROD: EV_RCEPSAU48X_008.rod
VCID: 346CEEDF9F776C3697-8060
6628353 - Internal Control Module Memory Check Sum Error
B2000 49 [10001001] - Internal Electronic Failure
Mileage: 204636 km
Date: 2024.08.18
Time: 02:42:04
Write only channel
5258753 - Steering End Stops Not Learned
C10AC F0 [10001001] - Unknown Error Elaboration
Reset counter: 57
Mileage: 204717 km
Date: 2024.10.28
Time: 14:42:46
Write only channel
Revision: 00002001 Serial number: 0300328273
Coding: 0106023A00FA004580B0013200000000
Subsystem 2 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55AA735B3C4D553E40-8000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000160023
ROD: EV_ParkiBrake_AU48.rod
VCID: 3874DAEF831F8856BB-806C
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156A-0D7685530
Coding: 020007020100000001
VCID: 224018873D83F28675-8076
02246 - Loudspeaker; Center
Fault Status: 00101100
Reset counter: 97
Mileage: 204717 km
Date: 2024.10.14
Time: 16:52:00
Voltage: 11.60 V
Part No SW: 8R1 035 664 C HW: 8R1 035 664 B
Component: H-BN-NA H44 0624
Revision: -------- Serial number: 203AV0D7515792
Coding: 0F020000000681ED41008B4E00000403F40000020000000000
VCID: 3668D4D7810B7E26A9-8062
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Component: DU7 High H42 0104
Serial number: A130AC0D2631123
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001387871
Component: CD-Database 4949
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010C13204000210001
VCID: 59B27F6B5055715E64-800C
Component: TSG HR H07 0304
End-------------------------(Elapsed Time: 03:28)--------------------------
