2014 Amarok second speedometer mph to kmh
HuginnCorax
Köping, Sweden
C?ID=596822
Hi everyone, this is my first post, I hope I get something right.
I have an option in the cluster menu to add (rough translation) "Speedometer 2" to the info board. See attached picture of the result once this option is activated. Unfortunately it reads in mph, but I want it to read in kmh. There is an option to change the cluster info to kmh or mph, but this option does not affect this specific info. Is there a possibility to tweak also this info to kmh?
I hope it's OK to edit out the three last digits of the VIN.
Tuesday,15,October,2024,10:07:53:13394
VCDS Version: 24.7.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WV1ZZZ2HZEH008XYZ   License Plate:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 37 56 69 6C 0B
VIN: WV1ZZZ2HZEH008XYZ   Mileage: 209060km-129903miles
Address 01: Engine (J623-CSHA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 012 AF    HW: 03L 907 309 AC
   Component: R4 2.0l BTD   H24 9978
   Revision: 74H24---    Serial number: 00000000000000 CVN: C9BD90980000000000000000
   Coding: 012A401A233600080000
   Shop #: WSC 55175 005 1048576
   ASAM Dataset: EV_ECM20BTD01103L906012AF 004011
   ROD: EV_ECM20BTD01103L906012AF_004.rod
   VCID: E8824BFB22F01E6A773-80BC
   VINID: 9E606AAAA098A9560000804114CF021EA9
Readiness: 0010 0000
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 2H0 927 158 D    HW: 0CM 325 025
   Component: 2H0 20RTDIRdW H16 3001
   Revision: --H16---    CVN: ABDE511D
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211_002_VN81.rod
   VCID: AE0EFDE3C094805A7DF-80FA
Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 M    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0111
   Revision: 00H44001
   Coding: C07324B69A94039D24A359A46F55F0
   Shop #: WSC 02310 790 49167
   VCID: BA26C1B30C5C5CFAD17-80EE
   Serial number: 23101304651807
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: FEAE0DA35074B0DAADF-80AA
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H0 907 040 E    HW: 2H0 907 040 E
   Component: ClimatronicT5 H19 0406
   Revision: 00001003
   Coding: 0000000002
   Shop #: WSC 02310 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis_VN81.rod
   VCID: A3181CD79B563D32E21-80F6
9473137 - Motor for Left Temperature Flap
          B108C 71 [00001001] - Actuator Stuck
                    Reset counter: 58
                    Mileage: 209069 km
                    Date: 2024.10.14.
                    Time: 17:07:15
9473393 - Motor for Right Temperature Flap
          B108D 71 [00001000] - Actuator Stuck
                    Reset counter: 97
                    Mileage: 208851 km
                    Date: 2024.10.13.
                    Time: 16:37:34
9474161 - Motor for Defroster Flap
          B1090 71 [00001000] - Actuator Stuck
                    Fault Frequency: 8
                    Reset counter: 97
                    Mileage: 208738 km
                    Date: 2024.10.09.
                    Time: 09:41:56
9581681 - Positioning Motor for Front Footwell Air Distribution Flap
          B1234 71 [00001000] - Actuator Stuck
                    Fault Frequency: 19
                    Reset counter: 98
                    Mileage: 208704 km
                    Date: 2024.10.08.
                    Time: 10:08:18
9478145 - Control Circuit for Front Air Blower
          B10A0 01 [00001001] - Electrical Failure
                    Reset counter: 58
                    Mileage: 208686 km
                    Date: 2024.10.08.
                    Time: 09:29:02
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 306130635
   Coding: 640002380C21000001380E306CCB86D50F80610F60842041300000020003
   Shop #: WSC 02310 790 00111
   VCID: AD0CFAEFCD12FB42445-80F8
   Component: RLS 041113 05  54  0403
   Coding: 02302D
   Subsystem 2 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3322
   Coding: 040000
   Subsystem 3 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3322
   Coding: 040000
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Serial number: 0257455
   Coding: 820000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3322
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3322
03302 - Response Closing Status of Passenger's Door
                    Reset counter: 98
                    Mileage: 208839 km
                    Date: 2019.03.04.
                    Time: 16:52:60
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231326201743
   Coding: 318103
   ASAM Dataset: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN81.rod
   VCID: BB28C4B703E665F2CA1-80EE
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00B H07 0013
   Revision: --------    Serial number: 003HN00F18J0 Dataset Number: 2H0003v____ 0156
   Coding: 000000000000000000000000000000003042
   Shop #: WSC 02739 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: B338EC972BB6ADB2121-80E6
   Serial number: 3495RRB401E50NQIK9KB
   Serial number: 3505RRB401250M2CM9I3
   Serial number: 3555YRB400450LAKFGQ$
   Serial number: 3565YRB400250LAKK1VX
   Part No SW: 2H0 920 871     HW: 2H0 920 871
   Component: KOMBI         H04 0709
   Coding: 151A00
   ROD: EV_Kombi_UDS_VDD_RM09_004_VN81.rod
   VCID: E59C42CFD5E203024C5-80B0
Address 18: Aux. Heat        Labels: 7E0-815-071.clb
   Part No: 7E0 815 071 C
   Component: J737__Standheizung  0605
   Revision: 00087000    Serial number: 09024900A00000
   Coding: 0010031
   VCID: A51C02CF99E2C3028C5-80F0
01413 - Dosing/Metering Pump (V54)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 8
                    Mileage: 161958 km
                    Date: 2016.03.06.
                    Time: 06:04:56
                        Start
                    Temperature: 13.0°C
                    Voltage: 13.80 V
                    Temperature: 0.0°C
02251 - Heater Unit Locked
                    Mileage: 165937 km
                    Date: 2016.04.19.
                    Time: 16:03:22
                        Malfunction
                    Temperature: 21.0°C
                    Voltage: 14.08 V
                    Temperature: 0.0°C
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 742200
   VCID: F0B2239B1AA0D6AA2F3-80A4
   Component: IMMO          H04 0709
   VCID: EA8631F33CFC2C7A617-80BE
   Part No SW: 3C8 035 279 F    HW: 3C8 035 279 F
   Component: RNS315-EU   H76 0410
   Serial number: VWZAZ2N0600938
   Coding: 000004110200160000031002
   ROD: EV_RNS315EUV2UDS_SK25.rod
   Component: EUR_W_V5  0055
   Revision: 3A001001    Serial number: 00008030518805
   Coding: 010D000100000000
   VCID: B032E39BDA2096AA6F3-80E4
   Part No SW: 2H0 907 441     HW: 2H0 907 441
   Component: J772__Rearview      0020
   Revision: 00H12000    Serial number: 525 PA8J370207
   Coding: 0030017
   Shop #: WSC 02757 790 00000
   VCID: E3985CD7D7567D32A21-80B6
End----------(Elapsed Time: 01:56, VBatt start/end: 14.2V/14.4V)-----------
HuginnCorax
Köping, Sweden
C?ID=596822
Some more info.
Here you can see the option available from menu. "Hastmätare 2" is "Speedometer 2", although a bit compressed due to space limitation.
If the option is not checked, I can cycle through the information display and get it to read correctly in kmh. However I prefer the smaller info, so I can read other information as well, simultaneously.
Any help is appreciated.
Kind regards,
I don't have high hopes, but check what this Adaptation Channel is set to:
IDE03346-MAS01456 -- Units adjusted - Speed
HuginnCorax
Köping, Sweden
C?ID=596822
Hello, thank you for your reply. It took me a while to get this reading done. It is already set to km/h, see picture. I entered km/h as new value, clicked "Do it!". I turned off the car, disconnected the HEXNET from the ODB port and restarted the car and it's still set as mp/h as previously. Are there any other suggestions or hints I can try to change this?
Thanks in advance and kind regards,
