Hello!
This is a cross-post from VWVortex as I'm still a bit lost in terms of sorting this problem.
I recently replaced the ignition lock in my 2006 Jetta after I had it fail on me in my driveway (thankfully). Since then, I have been trying to resolve the infamous steering angle defective code to no avail. I have tried on numerous occasions to get the car to go through the calibration process for it outlined on Ross Tech's wiki for code 00778, in addition to watching numerous videos and reading tons of threads on this, but I have not had any luck. I used VCDS to query the ABS sensors and all four of them appear to be reading the same speed, but I won't rule it out if it warrants another visit. Any time I am anywhere near G85 calibration within VCDS, I usually see something indicating that it is not possible. I've verified that the steering wheel lines up with the notch on the steering column, and I thought I was careful enough with the clock spring when I removed it to replace the lock, but perhaps something is wrong there.
I also had a code for the steering column control module when I initially put everything back together. I double-checked that the connectors are fully seated and cleared the code. It has not reappeared. For reference, here was the code that I received.
Reset counter: 38
Mileage: 410839 km
Time: 21:55:42
Here is the most recent scan I have:
I'm not sure where to go from here, but I'm happy to give any advice here a go. Thank you!
Reset counter: 38
Mileage: 410839 km
Time: 21:55:42
Monday,28,October,2024,18:58:52:43342
VCDS Version: 24.7.0.0 (x64)
VIN: 3VWDT71K56MXXXXXX License Plate:
Mileage: 410860km-255296mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 36 37 42 44 46 47 52 56 62
65 72 7D
VIN: 3VWDT71K56MXXXXXX Mileage: 410860km-255296miles
15-Airbags -- Status: OK 00000
37-Navigation -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F4485147
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64CD91B8A7F2F1B647-8030
VINID: 0E69D490705B1467400C118014C1B120E3
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000605180069
VCID: 51A3486CC840741E1C-8004
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73EFE2E4121C660ECE-8026
014 - Defective
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BN HW: 1K0 907 044 BN
Component: ClimatronicPQ35 110 1010
Revision: 00110021 Serial number: 00000000000000
VCID: 74EDE1F817126136D7-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000427586
Coding: 14018E234004150007140000001400000028770B5C0000
VCID: 377716F446E4CA2E32-8062
Component: Wischer 180806 020 0501
Coding: 00038805
Shop #: WSC 00066
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F2035511
VCID: 2A513F80855667C6BD-807E
Reset counter: 2
Mileage: 410868 km
Time: 05:04:17
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0558HP
Coding: 0013889
VCID: 6CDDF9984F22B9F60F-8038
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME11444701-
Subsystem 3 - Serial number: 6342MSME0F3308708
Subsystem 4 - Serial number: 6351HSME0A4248566
Subsystem 5 - Serial number: 6361HSME0A4017381
Subsystem 6 - Serial number: 63727SME0A065150U
Subsystem 7 - Serial number: 63827SME0A064E3B9
Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
Component: J0527 035 0070
Coding: 0012121
VCID: 030FB22442BC568EDE-8056
Component: E0221 002 0010
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4485147
Coding: 0023203
VCID: 2E593390B9BE0BE661-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066231247
Coding: 3FFF0B6A07001002
VCID: 2C5D39988FA279F64F-8078
Reset counter: 2
Mileage: 410868 km
Time: 05:04:21
Component: IMMO 3HL 1610
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
Address 37: Navigation
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1125
Revision: 11006001 Serial number: 00000010068722
Coding: 0001463
VCID: 3C7D09D87FC2E976DF-8068
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D21F85792213617-8060
02546 - Steering Limit Stop
Mileage: 410860 km
Temperature: 20.0∞C
Voltage: 13.90 V
Voltage: 13.70 V
014 - Defective
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0888F0488DC00
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000006499
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1125
Revision: 11006001 Serial number: 00000582468717
Coding: 0001462
VCID: 3D7B04DC64D8E07EE8-8068
Address 56: Radio
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000364184
Coding: 0001168
VCID: 3E7903D069DEFB66F1-806A
Component: RDK 0420
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12004001 Serial number: 00000000300079
Coding: 0001168
VCID: 3F877ED46ED4F26EFA-806A
Component: PTC-Element 0404
VCID: 2D5B349CB4B870FE58-8078
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:30)--------------------------
