Audi Q8 (2019) list of DTCs not clearing?
disuye
Hong Kong
C?ID=258260
Hi all,
Before and after scans pasted below.
My friend's 2018 Audi Q8 was parked up for 4~5 weeks, and he came back to a laundry list of warning lights. Usual suspect being low battery (Start/Stop warning; cleared after battery trickle charged), but the car is still stuck with about a dozen persistent DTCs which VCDS won't clear. Any thoughts?
I read about 'clearing DTCs with the hood open' (did not try) but if there's something else I'm missing, I'm all ears.
Thanks folks! Dan
Thursday,31,October,2024,14:46:41:30140
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WAUZZZF16KD010266   License Plate:
Mileage: 100219km-62273mi   Repair Order:
Chassis Type: F1-AU58 (4N4)
Scan: 01 02 03 06 09 13 15 16 17 19 36 3C 42 44 46 47 52 5F 61 69
          6C 6D 74 81 82 A5 AC BB BC C4 CA CC CD CF D6 D7 DB DC DE
VIN: WAUZZZF16KD010266   Mileage: 100219km-62273miles
74-Chassis Control -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DHXA)       Labels: None
   Part No SW: 4M8 907 401 P    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---    CVN: 68DE1EEDD8855ED2B866C2ADB866C2AD00000000D6C3ECFE
   Coding: 2A2A4032057E05033C286000000400000000000000000000
   Shop #: WSC 12309 005 1048576
   ASAM Dataset: EV_ECM30TDI0114M8907401P 001002
   ROD: EV_ECM30TDI0114M8907401M.rod
   VCID: 3E30F5ACA1020966F9-806B
   VINID: 9D196AAAA58119B50004008618C9AA28E4
5270 - Output for Starter Relay
          P0615 00 [00101110] - Open Circuit
                    Mileage: 99958 km
                    Date: 2024.10.23
                    Time: 11:56:53
                    Engine RPM: 0.00 /min
                    Coolant temperature: 20 ∞C
                    Intake air temperature: 21 ∞C
                    Voltage terminal 30: 10.300 V
                    Starter control: terminal 50 feedback-Bits 0-7: 4
                    Starter control: relay 1-Bits 0-7: 0
                    Starter control: shut-off conditions 1-Bits 0-7: 0
5457 - Starter Relay 2
          P26E4 00 [00100111] - Electrical Malfunction
                    Mileage: 100165 km
                    Date: 2024.10.31
                    Time: 11:01:48
                    Coolant temperature: 17 ∞C
                    Intake air temperature: 18 ∞C
                    Voltage terminal 30: 11.300 V
                    Starter control: shut-off conditions 1-Bits 0-7: 128
5273 - Output for Starter Relay
          P0616 00 [10100111] - Short to Ground
                    Fault Frequency: 8
                    Mileage: 100211 km
                    Date: 2024.10.31
                    Time: 14:27:00
                    Engine RPM: 1727.00 /min
                    Normed load value: 69.4 %
                    Vehicle speed: 120 km/h
                    Coolant temperature: 84 ∞C
                    Intake air temperature: 20 ∞C
                    Voltage terminal 30: 12.660 V
                    Starter control: shut-off conditions 1-Bits 0-7: 129
4814 - Voltage Supply 1 for Control Module
          U3501 00 [00100000] - Too Low
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [10101111] - Intermittent
                    Mileage: 99958 km
                    Date: 2024.10.23
                    Time: 11:56:54
                    Voltage terminal 30: 10.780 V
                    Mean injection quantity: 0.00 mg/stroke
                    Control Module temperature: 20.2 ∞C
                    EGR_governor_deviation: 246.9 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Standardized air flow ratio: 3.9999
                    Air mass at air mass meter 1: 62.5 kg/h
                    Actual charge pressure: 1012 hPa
33352 - Front Sensors for Driver-Assist Systems
          U12EF 00 [00101111] - Implausible Signal
          [Front sensor system for driver assistance systemsImplausible signal]
                    Fault Frequency: 30
                    Mileage: 100165 km
                    Date: 2024.10.27
                    Time: 10:16:54
                    Coolant temperature: 18 ∞C
                    Voltage terminal 30: 11.020 V
                    Com st X Set2 Val1-Bits 0-7: 0
                    Com st X Set2 Val2-Bits 0-7: 0
                    Com st X Set2 Val3-Bits 0-7: 0
                    Com st X Set2 Val4-Bits 0-7: 0
                    Com st X Set2 Val5-Bits 0-7: 0
                    Com st X Set2 Val6-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 1
Readiness: 1 1 0 0 0
   Part No SW: 4M8 927 158 AL    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 0002
   Revision: --H05---    CVN: 30B7FE2E00009238
   Coding: 100000
   Shop #: WSC 31414 042 00001
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011.rod
   VCID: 06405D4CB95291A6F1-8053
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H01 0705
   Serial number: 1809010162
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M6 907 379 N    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0850
   Dataset Number: 4M8909504E  0001 CVN: 3DF04A26
   Coding: 24AA309631A30B96D3A05C971883D2E2F5BAC9240C8CD0CB3A184B47AF5D93
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 48DC9374F3C647D643-801D
10 Faults Found:
420352 - TPMS Warning; Front Left Tire
          C1054 00 [00101000] - Pressure too Low
                    Mileage: 99984 km
                    Date: 2024.10.23
                    Time: 12:33:34
                    90 00 80 34 89 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 26
416768 - TPMS Warning; Front Right Tire
          C1056 00 [00101000] - Pressure too Low
                    Mileage: 99984 km
                    Date: 2024.10.23
                    Time: 12:33:34
420096 - TPMS Warning; Rear Left Tire
          C1058 00 [00101000] - Pressure too Low
                    Mileage: 99984 km
                    Date: 2024.10.23
                    Time: 12:33:34
417024 - TPMS Warning; Rear Right Tire
          C105A 00 [00101000] - Pressure too Low
                    Mileage: 99984 km
                    Date: 2024.10.23
                    Time: 12:33:34
415488 - TPMS Warning; Front Left Tire
          C1055 00 [00101000] - Flat
                    Mileage: 100012 km
                    Date: 2024.10.23
                    Time: 13:08:29
                    80 00 00 2E 88 24 00 00 F0 70
                    Unlearning counter according OBD-OBD unlearning counter: 27
419328 - TPMS Warning; Front Right Tire
          C1057 00 [00101000] - Flat
                    Mileage: 100012 km
                    Date: 2024.10.23
                    Time: 13:08:29
419584 - TPMS Warning; Rear Left Tire
          C1059 00 [00101000] - Flat
                    Mileage: 96896 km
                    Date: 2024.01.19
                    Time: 11:26:09
                    78 00 80 3F 89 24 00 00 00 00
419840 - TPMS Warning; Rear Right Tire
          C105B 00 [00101000] - Flat
                    Mileage: 100012 km
                    Date: 2024.10.23
                    Time: 13:08:29
466432 - Databus
          U1123 00 [00101111] - Received Error Message
          [Signal_FA_Hoehenwert_VR_00_error_(255)]
                    Mileage: 100165 km
                    Date: 2024.10.27
                    Time: 10:16:55
                    6E C0 8F 00 C2 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
452352 - Databus
          U1123 00 [00100000] - Received Error Message
          [Signal_RCTA_Status_error_(3)]
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0042
   Serial number: 00000345975558 Dataset Number: 4M8909866A  0010
   Coding: 001010000000B0810040010101010000810000070700878700000000000000
   Shop #: WSC 31414 044 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D32F2A0AC04127EE0-8069
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
   Component: N477 VB1 BFSv  H06 0030
   Serial number: SJ800122091840258228
   Coding: BF2F00
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0652
   Dataset Number: 4M8909514D  0021
   Coding: 07000143C13900DD070E57889CBF8E78131B33110006009781010A00393216810A45093A42570508000001000041081B1802000044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 76A02D8CC9B28126E1-8023
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0401822601162
   Coding: 7DC727
   Serial number: 21853788X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S24.09.1800690140
   Serial number: GX1CE119061823810310
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 L    HW: 4K0 947 135 L
   Component: Dachmodul  H42 0413
   Serial number: Q00624030
   Coding: 0D0104
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA134401000055556055
   Coding: 0A0100
   Subsystem 7 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V512 LLR1SLvL  H01 0012
   Serial number: L84AI20502589
   Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V514 LLR1SKvL  H01 0012
   Serial number: L84AI20400506
   Subsystem 9 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V516 LLR1SLvR  H01 0012
   Serial number: L84AI20502562
   Subsystem 10 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V518 LLR1SKvR  H01 0012
   Serial number: L84AI20702940
   Front windshield washer pump:
   Subsystem 11 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001825000584
   Coding: 020000
8 Faults Found:
67735 - Databus
          [MxB not available]
                    Reset counter: 64
                    Mileage: 99908 km
                    Date: 2024.08.24
                    Time: 10:31:20
                    average_Voltage_terminals: 14.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 26.50 ∞C
                    interior_temperature: 26.00 ∞C
                    Vehicle speed: 1.63 km/h
393529 - Motor for Right Temperature Flap
          B108D 07 [00001000] - Mechanical Failure
                    Reset counter: 66
                    Mileage: 96857 km
                    Date: 2023.09.02
                    Time: 17:01:55
                    average_Voltage_terminals: 14.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 24.50 ∞C
                    interior_temperature: 32.50 ∞C
                    Vehicle speed: 0.00 km/h
393621 - Motor for Defroster Flap
          B1090 07 [00001000] - Mechanical Failure
                    Reset counter: 66
                    Mileage: 96879 km
                    Date: 2024.01.19
                    Time: 11:02:51
                    average_Voltage_terminals: 15.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 7.50 ∞C
                    interior_temperature: 9.00 ∞C
393781 - Motor for Right Side Vent Flap
          B10CA 07 [00001000] - Mechanical Failure
                    Reset counter: 70
                    Mileage: 99958 km
                    Date: 2024.10.23
                    Time: 11:56:58
                    average_Voltage_terminals: 10.90 V
                    Outside air temperature sensor-Outside air temperature on CAN: 21.50 ∞C
                    interior_temperature: 21.00 ∞C
393817 - Motor for Right Center Vent Flap
          B10CC 07 [00001000] - Mechanical Failure
                    Reset counter: 66
                    Mileage: 99923 km
                    Date: 2024.09.02
                    Time: 14:27:21
                    average_Voltage_terminals: 14.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 27.00 ∞C
                    interior_temperature: 26.50 ∞C
393831 - Motor for Left Footwell Flap
          B10B9 07 [00001000] - Mechanical Failure
                    Fault Frequency: 13
                    Reset counter: 70
                    Mileage: 96876 km
                    Date: 2023.10.16
                    Time: 16:02:53
                    average_Voltage_terminals: 14.10 V
                    Outside air temperature sensor-Outside air temperature on CAN: 22.00 ∞C
                    interior_temperature: 24.50 ∞C
393859 - Motor for Rear Left Temperature Flap
          B10D5 07 [00001000] - Mechanical Failure
                    Reset counter: 66
                    Mileage: 96186 km
                    Date: 2023.04.20
                    Time: 11:55:45
                    average_Voltage_terminals: 12.50 V
                    Outside air temperature sensor-Outside air temperature on CAN: 20.00 ∞C
                    interior_temperature: 24.00 ∞C
                    Vehicle speed: 55.74 km/h
405507 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Function limitation due to energy management system]
                    Fault Frequency: 57
                    Reset counter: 66
                    Mileage: 96856 km
                    Date: 2023.08.23
                    Time: 12:51:55
                    average_Voltage_terminals: 11.50 V
                    Outside air temperature sensor-Outside air temperature on CAN: 39.50 ∞C
                    interior_temperature: 47.50 ∞C
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 L    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Dataset Number: 4M8909863J  0001
   Coding: 5665FF5A58082C00010360E0000000BE4A1246484481009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 393AE6B0B82C2E5ECC-806D
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Fault Frequency: 22
                    Reset counter: 31
                    Mileage: 99908 km
                    Date: 2024.08.24
                    Time: 10:31:17
                    Control Module temperature: 31 ∞C
                    Voltage terminal 15: 14.0 V
                    Vehicle speed: -0.39 m/s
                    Longitudinal acceleration: 0.04 m/s≤
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 234.400 ∞
                    Yaw_rate-Data: -0.566 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: -0.056 ∞
                    Misalignment angle: horiz: fast algorithm: -0.033 ∞
                    Congestion pilot: status: OFF
                    Outside temperature: 26.50 ∞C
                    Sensor blindness: radar: no blindness detected
2345 - Databus
          [FAULT_CAMERA_ERROR]
                    Reset counter: 64
                    Mileage: 99908 km
                    Date: 2024.08.24
                    Time: 10:31:17
                    Vehicle speed: -0.43 m/s
                    Longitudinal acceleration: 0.08 m/s≤
                    Adaptive distance regulation: status: ACC_StandBy
                    Steering_angle-Data: 164.800 ∞
                    Yaw_rate-Data: -0.383 rad/s
2341 - Databus
          [FAULT_LIDAR_ERROR]
                    Reset counter: 30
                    Mileage: 100165 km
                    Date: 2024.10.27
                    Time: 10:16:57
                    Control Module temperature: 20 ∞C
                    Voltage terminal 15: 11.3 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s≤
                    Steering_angle-Data: 2.900 ∞
                    Yaw_rate-Data: 0.000 rad/s
                    Misalignment angle: horiz: -0.102 ∞
                    Misalignment angle: horiz: fast algorithm: -0.147 ∞
                    Outside temperature: 18.00 ∞C
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 31
                    Mileage: 100211 km
                    Date: 2024.10.31
                    Time: 14:27:00
                    Control Module temperature: 32 ∞C
                    Voltage terminal 15: 12.3 V
                    Vehicle speed: 34.00 m/s
                    Longitudinal acceleration: 0.36 m/s≤
                    Steering_angle-Data: 1.100 ∞
                    Yaw_rate-Data: 0.020 rad/s
                    Misalignment angle: horiz: -0.119 ∞
                    Misalignment angle: horiz: fast algorithm: -0.351 ∞
                    Outside temperature: 17.50 ∞C
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H09 2710
   Serial number: 003YZM00LARN Dataset Number: 4M8909602AD 0001
   Coding: AACCF0C000C00000985400FFF00D41A800C5
   Shop #: WSC 31414 029 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 4AD8A97CEDCAB5C655-801F
   Left seat belt tensioner:
   Serial number: 00AI2018220632300000
   Coding: 03F001
   Right seat belt tensioner:
   Serial number: 00AI2018242310000000
   Coding: 03F001
   Subsystem 3 - Part No SW: -----------    HW: 480 001 409 18
   Serial number: 357000000009F97CC33%
   Subsystem 4 - Part No SW: -----------    HW: 480 001 409 18
   Serial number: 3580000000080059C33D
   Subsystem 5 - Part No SW: -----------    HW: 480 031 809 18
   Serial number: 351001C143DE6D500D19
   Subsystem 6 - Part No SW: -----------    HW: 480 031 809 18
   Serial number: 352001C14FCD1090AF4L
   Subsystem 7 - Part No SW: -----------    HW: 480 030 109 18
   Serial number: 355001C1472515B07B3/
   Subsystem 8 - Part No SW: -----------    HW: 480 030 109 18
   Serial number: 356001C14726592059B2
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 9 - Part No SW: -----------    HW: 480 031 809 18
   Component: SideSens_B_Df  002 0149
   Serial number: 352001C143DE2EB088BQ
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 10 - Part No SW: -----------    HW: 480 031 809 18
   Component: SideSens_B_Pf  002 0149
   Serial number: 355001C14FC510311F64
9634932 - Control Module for Front Left Belt Tensioner
          B1304 74 [00001000] - Actuator Slipping
                    Mileage: 96047 km
                    Date: 2023.04.20
                    Time: 09:33:36
   Part No SW: 4N0 907 129 BC    HW: 4N0 907 129 BC
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 73A61498DAC0940EC6-8027
   Part No SW: 4K0 920 790 C    HW: 4K0 920 790 C
   Component: FBenRDWACC--- H11 0153
   Dataset Number: 4M8909525C  0013
   Coding: 858410C67C88000803A3E1609080680008003000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 2D12C2E07C6482FE50-8079
   Part No SW: 4N4 907 468 AB    HW: 4N4 907 468 AB
   Component: Gateway       H14 0036
   Revision: 8W020004    Serial number: 0488W514518903 Dataset Number: 4K0909515B  0028
   Coding: 02010005000406408C960000005B0132DC9A004718000000097F078E10000000
   GVL: F1513C080804000082FC88000002C800110E0070000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 7BB63CB8F290DC4E9E-802F
   Subsystem 1 - Part No SW: 4M8 951 523 A    HW: 4M8 951 523 A
   Component: J453 MFL  H03 0004
   Serial number: 20180725145529 30384
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 75885202001809190B72
8519683 - Energy Management Active
          U140B 00 [00001000] - -
                    Fault Frequency: 58
                    Reset counter: 66
                    Mileage: 96856 km
                    Date: 2023.08.23
                    Time: 12:51:44
                    EM_vehicle_state: 04 00
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
10489862 - Locating Assistant
          B17DF F4 [00001001] - Self-Test Failed
                    Reset counter: 226
                    Mileage: 96042 km
                    Date: 2023.04.03
                    Time: 17:12:02
9457921 - Backup Battery
          B1916 04 [00001001] - Internal System Fault
                    Mileage: 96857 km
                    Date: 2023.09.15
                    Time: 16:56:23
                    Voltage terminal 30: 14.50 V
   Component: MEM-FS        009 0042
   Serial number: 00000345959436 Dataset Number: 4M8909856A  0010
   Coding: 00181A400000B4810003010101010000810000070700878700000000004000
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H06 0030
   Serial number: SJ800122091840258234
   Coding: BF2F00
   Part No SW: 4N0 907 566 E    HW: 4N0 907 566 A
   Component: MRR_HR H12 0265
   Dataset Number: 4M8909535C  0012
   Coding: 1FDB00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 383CE3B48326375633-806D
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS001 0188
   Serial number: YE007RHF03921 Dataset Number: 4M8909872A  0019
   Coding: 001DDB4352000480A001B430
   VCID: 40CC8B54DBF67F968B-8015
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Dataset Number: 4M8909852E  0003
   Coding: B8000101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 312ADE90605CE61E74-8065
   Part No SW: 8W0 907 064 FP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   025 0406
   Dataset Number: 4M8909501D  0021
   Coding: 01340000002000E06309A0046C00CC0203004000804F02502F0400200504823F001F0100010F01
   ASAM Dataset: EV_BCM2HellaAU736 015015
   ROD: EV_BCM2HellaAU736_015_AU58.rod
   VCID: 0F6E7868D628D0EE42-805B
   left tail lamp 1:
   Subsystem 1 - Part No SW: 4M8 945 069 B    HW: 4M8 945 069 B
   Component: SHL_li1  H04 0004
   Serial number: 069B1809050000012724
   Subsystem 2 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11191406
   left tail lamp 2:
   Subsystem 3 - Part No SW: 4M8 945 217 F    HW: 4M8 945 217 F
   Component: SHL_li2  H04 0004
   Serial number: 217F1809100000014390
   Right rear tail lamp 1:
   Subsystem 4 - Part No SW: 4M8 945 070 B    HW: 4M8 945 070 B
   Component: SHL_re1  H04 0004
   Serial number: 070B1809040000012246
   Right rear tail lamp 2:
   Subsystem 5 - Part No SW: 4M8 945 218 F    HW: 4M8 945 218 F
   Component: SHL_re2  H04 0004
   Serial number: 218F1809100000014390
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJKC00JZBT Dataset Number: 4M8909510B  0005
   Coding: 0135360A00AAAAAFAA0000010000
   Shop #: WSC 05340 995 00000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 240427C42FAE43B68F-8071
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS001 0188
   Serial number: YE007RHF1580A Dataset Number: 4M8909873A  0019
   Coding: 001DDB035E000480A001B430
   VCID: 3FCE88A8A608006EF2-806B
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 064 D    HW: 4K0 035 064 A
   Component: MU-H-LN-EU    046 2711
   Dataset Number: 4M8909545B  0022
   Coding: 0135360100000000C3110002000800302F0001E401F008008E
   VCID: 25023AC02494BABE98-8071
   Subsystem 1 - Part No: V03 959 807 SF
   Component: MIB2P_EU_Q121  0520
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M8 919 605 B    HW: 4M8 919 605
   Component: DU AU536 High  H41 0147
   Serial number: INX00128071800100668
   Compact disc data bank:
   Component: Gracenote2  1008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Serial number: 00004418000178546034
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 C    HW: 4N0 919 603
   Component: DU AU651 Bot  H41 0147
   Serial number: INX00111081800050803
   Media Player 1 Sub:
   Subsystem 6 - Part No SW: 4N0 035 123     HW: 4N0 035 123
   Component: DISC PLAYER  H06 0006
   Serial number: AUZ8ZCJKJ00GM5G
   Media socket:
   Subsystem 7 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800587929008
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 291A36F0488C9EDEBC-807D
   Part No SW: 4M0 907 383 G    HW: 4M0 907 383 B
   Component: Anhaenger     H33 0272
   Revision: 9A001003    Serial number: 0492249983 Dataset Number: 4M8909527A  0005
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3620ED8C8932C12621-8063
   Component: RVC Compact   H15 0250
   Dataset Number: 4M8909460A  0006
   Coding: 0235360103002005C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_AU58.rod
   VCID: 3326D4989A40D40E06-8067
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C737-6252-2 Dataset Number: 4M8909541B  0006
   Coding: 28F0
   VCID: 3424D7849F4ED3361F-8061
Address 74: Chassis Control (J775)       Labels:* 4N0-907-777.clb
   Part No SW: 4M8 907 777 N    HW: 4M8 907 777
   Component: Fahrwerk-SG   H51 2031
   Serial number: 1409180346  Dataset Number: 4M8909576F  0004
   Coding: 985C5848F840
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 4CD4AF64E7BEABF667-8019
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130407639
   Coding: 303030
4194324 - Valve for DamPing Adjustment Front Right
          C1041 13 [10001001] - Open Circuit
                    Fault Frequency: 45
                    Reset counter: 31
                    Internal DTC: 165
0016 - Front Right Ride-Height Sensor
          C1035 11 [10001001] - Short to Ground
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:37:18
                    Internal DTC: 465
0017 - Front Right Ride-Height Sensor
          C1035 15 [00001000] - Open or Short to Plus
                    Fault Frequency: 55
                    Reset counter: 71
                    Internal DTC: 466
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18080448662539
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   VCID: 271E30C85E98A8AEAA-8073
Address 82: Head Up Display (J898)       Labels:| 4Nx-919-617-V1.clb
   Part No SW: 4M8 919 617 B    HW: 4M8 919 617 B
   Component: HeadupDisplay H06 1815
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 3C34FFA4B71E1B76D7-8069
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0291
   Dataset Number: 4M8909466G  0034
   Coding: 040184000000000000FC060000D0462C199F5600000000000000000000000000001900000000000000000000000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F4EC8A8E688C06EB2-802B
2114638 - Databus
          [LS1_SensorHeader_LS1_Fehler]
                    Fault Frequency: 20
                    Reset counter: 31
                    Mileage: 100165 km
                    Date: 2024.10.27
                    Time: 10:16:56
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [00001000] - View Temporarily Restricted
          [temp view limitations]
                    Reset counter: 47
                    Mileage: 99068 km
                    Date: 2024.05.28
                    Time: 17:45:04
                    EyeQ temperatures-CPU: -40 ∞C
                    EyeQ temperatures-VPM: 37 ∞C
                    Vehicle speed: 58.52 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: No
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
221281 - Control Module for Driver Assist Systems
          C12D5 FA [00001000] - Image Processor does not Repsond.
                    Reset counter: 64
                    Mileage: 99908 km
                    Date: 2024.08.24
                    Time: 10:31:17
                    EyeQ error source: General malfunction
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 19
                    Reset counter: 71
                    Mileage: 99908 km
                    Date: 2024.08.24
                    Time: 10:31:17
4108 - Databus
          [irreversibler_Fehler_im_ACC_System]
                    Reset counter: 31
                    Mileage: 100211 km
                    Date: 2024.10.31
                    Time: 14:27:01
65537 - Intersection Assistant
          C12D8 F0 [00001000] - Status Feedback for HMI Implausible
                    Fault Frequency: 17
                    Reset counter: 60
                    Mileage: 96234 km
                    Date: 2023.04.20
                    Time: 13:27:13
                    Profile master status intersection assistant-Nominal status: On
                    Profile master status intersection assistant-Actual status:: Initialization
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   Dataset Number: 4M8909571C  0002
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736.rod
   VCID: 3228D19C655ADD060D-8067
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS003 0188
   Serial number: YE007RH318852 Dataset Number: 4M8909897A  0019
   Coding: 000DD90300000480A000B020
   VCID: 42C8815CD5FA6D869D-8017
   Component: TSG HBFS003 0188
   Serial number: YE007RH318856 Dataset Number: 4M8909896A  0019
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   Dataset Number: 4M8909475A  0002
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A38F9BCBD2A2546C5-806F
   Component: SAD_STG_1     005 0002
   Dataset Number: 4M8909469C  0011
   Coding: 628040053632
   VCID: 75A22A80D4B48A3EE8-8021
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 26091800020307
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   VCID: 302CDB946B56EF167B-8065
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0201
   Dataset Number: 4M8909639K  0002
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   VCID: 3522EA809434CA3E28-8061
10510404 - Databus
          [EML_HIGHT_AND_ANGLES_ERROR]
                    Reset counter: 30
                    Mileage: 100165 km
                    Control Module temperature-Host: external temperature: 18 ∞C
                    Control Module temperature-Zynq: internal temperature: Initialization
                    Control Module temperature-Host: internal temperature: 13 ∞C
                    Control Module temperature-Zynq: external temperature: Initialization
                    Voltage terminal 15: 11.039 V
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0265
   Dataset Number: 4M8909468C  0012
   Coding: 1FDB00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0030
   Dataset Number: 4M8909471C  0011
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 72A8119CA5DA9D06CD-8027
   Dataset Number: 4M8909472C  0011
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 E    HW: 4N0 907 669 A
   Component: MRR_VR H12 0265
   Dataset Number: 4M8909482C  0010
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0265
   Dataset Number: 4M8909483C  0011
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0061
   Coding: 800000
   VCID: 220821DC35BA4D86FD-8077
End----(Elapsed Time: 02:33, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
And after clearing the DTCs a few times (one by one, CAN, etc) ...
Thursday,31,October,2024,15:10:58:30140
VIN: WAUZZZF16KD010266   License Plate: 9999
          P0615 00 [00100111] - Open Circuit
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 15:03:37
                    Coolant temperature: 81 ∞C
                    Intake air temperature: 30 ∞C
                    Voltage terminal 30: 11.660 V
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 15:03:37
          P0104 00 [00100111] - Intermittent
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 15:03:38
                    Voltage terminal 30: 11.680 V
                    Control Module temperature: 38.9 ∞C
                    EGR_governor_deviation: 225.0 mg/stroke
                    Air mass at air mass meter 1: 60.5 kg/h
                    Actual charge pressure: 992 hPa
          U12EF 00 [00100111] - Implausible Signal
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 15:03:38
   Coding: 100000
   ATF pump:
466432 - Databus
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:56:47
                    75 00 80 00 C2 03 00 00 00 00
   Coding: BF2F00
   Coding: 7DC727
   Coding: 02005D
   Coding: 0D0104
   Coding: 0A0100
   Coding: 020000
2342 - Databus
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:57:13
                    Control Module temperature: 45 ∞C
                    Voltage terminal 15: 11.5 V
                    Steering_angle-Data: -312.600 ∞
                    Misalignment angle: horiz: -0.134 ∞
                    Misalignment angle: horiz: fast algorithm: -0.144 ∞
                    Outside temperature: 20.00 ∞C
2341 - Databus
          [FAULT_LIDAR_ERROR]
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:57:13
   Coding: 03F001
   Coding: 03F001
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 15:04:10
                    Voltage terminal 30: 11.70 V
   Coding: BF2F00
   Coding: 1FDB00
   left tail lamp 1:
   left tail lamp 2:
   Volume Control 1:
   Media Player 1 Sub:
   Media socket:
   Coding: 28F0
   Coding: 303030
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:58:25
                    Internal DTC: 165
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:58:25
                    Internal DTC: 465
   Coding: 4700E0
2114638 - Databus
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:58:35
4107 - Databus
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:58:35
10510404 - Databus
                    Reset counter: 31
                    Mileage: 100219 km
                    Date: 2024.10.31
                    Time: 14:58:59
                    Control Module temperature-Host: external temperature: 44 ∞C
                    Control Module temperature-Zynq: internal temperature: 59 ∞C
                    Control Module temperature-Host: internal temperature: 43 ∞C
                    Control Module temperature-Zynq: external temperature: 40 ∞C
                    Voltage terminal 15: 11.536 V
   Coding: 1FDB00
   Coding: 001000
   Coding: 001000
   Coding: 800000
End----(Elapsed Time: 02:24, VBatt start/end: 12.5V/11.8V. VIgn 11.7V)-----
Does it start and run?
Given that list of fault codes and the fact that it was parked for a month, I'd inspect the wiring for rodent damage.
disuye
Hong Kong
C?ID=258260
Yes, runs and drives as per expected, no actual / operational issues just the errors.
