2009 Audi Quattro Cabriolet
prfox
South Carolina, USA
C?ID=543379
I have been getting a lot of MIL faults related to battery or voltage issues. These occur if I do not drive the vehicle for a couple of weeks. I also have an issue where I need to put the key in the on position for a few seconds to let the fuel pump pressurize before starting the vehicle. I don't think this is related to the other electrical issues but they could be related. Below is the last scan I performed today on the vehicle. Any support would be welcome.
Thursday,31,October,2024,07:30:30:31465
VIN: WAUDF48H29K006642   License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUDF48H29K006642   Mileage: 120520km-74887miles
   Part No SW: 8E1 910 115 H    HW: 8E0 907 115 D
   Revision: 5EH15---    Serial number:
   Coding: 011C010A190F0120
   Shop #: WSC 00672 785 00200
   VCID: 270BE80333EABAA23E1-8072
   VINID: 9D19545842180896C0006184080AB0F0C2
001672 - ECM Power Relay Load Circuit
               P0688 - 002 - Open Circuit - Intermittent
                    Mileage: 120299 km
                    Temperature: 33.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 0.000 V
012423 - Voltage Supply Relay for Engine Components
               P3087 - 002 - Electrical Malfunction
                    Fault Status: 01100010
                    Mileage: 120421 km
                    RPM: 193 /min
                    Load: 78.8 %
                    Temperature: 20.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 10.160 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -
                    Fault Status: 01101000
                    Mileage: 120421 km
                    RPM: 1248 /min
                    Load: 55.3 %
                    Temperature: 33.0°C
                    Temperature: 33.0°C
                    Voltage: 13.589 V
   Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
   Component: AG6 09L 2,0TFSI USA 0080
   Revision: --H01---    Serial number:        4485709
   Coding: 0000002
   VCID: 2F3B00231B1AE2E2F61-807A
006273 - Powertrain Data Bus: Missing Message
               P1881 - 000 - Acceleration Request - Intermittent
                    Fault Frequency: 14
                    RPM: 96 /min
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 54.0°C
                    T.B. Angle: 60.0°
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
               U0100 - 000 -  - Intermittent
                    Fault Frequency: 14
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004528
   VCID: 2E051D271C10EBEAFD7-807A
                    Hex Value: 0x00C0
                    Hex Value: 0x0722
                    Hex Value: 0x0014
                    Hex Value: 0x4197
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6D87DA2BD48650F284D-5118
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 21023
   VCID: 3D272A6BC466007274D-4AA4
   Part No SW: 8E0 035 593 N    HW: 8E0 035 593 N
   Component: SDAR SIRIUS         0150
   Serial number: AUZ4Z7H0426634
   VCID: 34310F4FF21CC13A8B3-5160
Address 15: Airbags        Labels: 8H0-959-655-94.lbl
   Part No SW: 8H0 959 655 H    HW: 8H0 959 655 H
   Component:    Airbag 9.42  H01 1830
   Revision: 92H01183    Serial number: 003D000076UG
   Coding: 0132105
   VCID: 3FDB5063CB7A1262661-806A
   Subsystem 1 - Part No: 8H0 910 339 B
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 02FFU
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332BRB4044989CD/ÿ†63
   Subsystem 5 - Serial number: 989CD/ÿ†6342BRB4044989A1Rÿ†63
   Subsystem 6 - Serial number: 989A1Rÿ†63729RB403F7953E$ÿ†63
   Subsystem 7 - Serial number: 7953E$ÿ†63829RB403F78843Wÿ
   Subsystem 8 - Serial number: 78843Wÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 03041
   Shop #: WSC 00672
   VCID: 41DF569BB89E6492105-4AA4
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8H0 920 951 F    HW: 8H0 920 951 F
   Component: KOMBI+WFS 4     H14 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0007261
   Shop #: WSC 09223 444 59203
   VCID: 3039035F0634FD1AEFB-50F4
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
   Coding: 0007261
Address 26: Auto Roof        Labels: 8H0-959-255.clb
   Part No: 8H0 959 255 B
   Component:  VSG  B6 CABRIO     7195
   Shop #: WSC 09218 444 83803
   VCID: 3537324BF956D832BCD-50F4
   Part No: 8H0 959 433 L
   Component: Komfortgerát T7B    5442
   Coding: 11820
   Shop #: WSC 00672
   Subsystem 1 - Part No: 8H1959801D
   Component: Tõrsteuer.FS BRM 0205
   Component: Tõrsteuer.BF BRM 0205
            49-00 - No Communications
00962 - Alarm via. Tilt Sensor
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
   Part No: 8P0 907 357 H
   Coding: 0000005
                    Reset counter: 39
   Part No SW: 8E0 035 195 AF    HW: 8E0 035 195 AF
   Component: R Symphony2+    H06 0270
   Revision: 00H06000    Serial number: AUZ1Z4H2987531
   Coding: 0650102
   VCID: 6B83D433EFA25EC29A9-5160
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F   H13   0010
   Coding: 00005
   Shop #: WSC 00065
   VCID: 3537324BFC66D832BCD-4B3C
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062121
   VCID: 2A0D113720D887CA21F-5160
                    Fault Status: 11100100
                    (no units): 96.0
                    Voltage: 13.90 V
                    (no units): 61.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Time: 0.0 s
02214 - Tire Pressure Warning
                    (no units): 18.0
                    Temperature: 18.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Raw, Index/Key Err.: 186 000 000
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H13   0010
   Coding: 00005
   Shop #: WSC 00065
   Part No SW: 8P0 862 335 T    HW: 8P0 862 335 T
   Component: FSE_256x BT     H34 0550
   Revision: 00000000    Serial number: 00000005009833
   Coding: 0001607
   VCID: 47CB488393BA5AA2DE1-50D0
End----------(Elapsed Time: 04:46, VBatt start/end: 13.4V/13.4V)-----------
EuroX
Northern NJ USA
C?ID=208579
Replace both power supply relay in Ebox under the good.
prfox
South Carolina, USA
C?ID=543379
Okay - will look at replacing these power supply relays. Thanks!
