2019 Passat (NMS) ABS problem. coding (MK60EC1)
Brd
Fayetteville, GA, USA
C?ID=193546
problem want accept long coding
0000000000000000000000000000000000000000
with new abs controller, programming. I have old long coding, but for some reason it won't take. Can someone help me please.
Wednesday,23,October,2024,13:51:45:36288
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: 1VWMA7A31KC009188   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 3C 42 44 46 47 4F
          52 5F 61 62 72 75 A5
VIN: 1VWMA7A31KC009188   Mileage: 92440km-57439miles
Address 01: Engine (J623-DDSA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 016 D    HW: 06K 907 309
   Component: R4 2.0l TSI   H31 9887
   Revision: 1EH31000    CVN: 0689CCD7
   Coding: 411A00922444000F9000
   Shop #: WSC 07207 444 00000
   ASAM Dataset: EV_ECM20TFS01106K906016D 003006
   ROD: EV_ECM20TFS011_VW32.rod
   VCID: 2B086FAB038DEC52DA9-807E
   VINID: 0669DD44744305B4C0009048204EBE8023
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [00101000] - -
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
                    Engine RPM: 1034.00 /min
                    Normed load value: 50.6 %
                    Coolant temperature: 15  C
                    Intake air temperature: 17  C
                    Voltage terminal 30: 14.200 V
                    Acceleration: 0.000 m/s
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 8
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
30935 - Internal Control Module
          P060C 00 [00100000] - Main Processor Performance
                    Mileage: 92410 km
                    Date: 2024.10.21.
                    Time: 12:27:19
                    Engine RPM: 3397.00 /min
                    Normed load value: 26.7 %
                    Vehicle speed: 82 km/h
                    Coolant temperature: 52  C
                    Intake air temperature: 19  C
                    Voltage terminal 30: 14.060 V
                    Outside temperature: 21  C
                    Absolute intake pressure: 73 kPa abs
                    Engine torque: 85.5 Nm
                    Fuel: tank fill level: 58.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Engine operating condition: Part throttle
                    Engine operating condition-Test_Program_Channel 87: 6
11955 - EVAP Emission Control Sys
          P0442 00 [01100000] - Small Leak
                    Mileage: 91179 km
                    Date: 2024.09.22.
                    Time: 14:04:07
                    Engine RPM: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 86  C
                    Intake air temperature: 58  C
                    Voltage terminal 30: 12.540 V
                    Unlearning counter according OBD: 29
                    Outside temperature: 215  C
                    Absolute intake pressure: 98 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 67.0 l
                    Engine operating condition: Idle
   Part No SW: 09G 927 158 DQ    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3517
   CVN: 20F315F0
   Coding: 010200000C000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 055CF913C5A9FA226CD-8050
22969 - Implausible Data Received from ABS Control Module
          U0415 00 [00101000] - -
                    Reset counter: 97
                    Mileage: 91981 km
                    Engine RPM: 1033.0 /min
                    Transmission input speed: 25 /min
                    Engine torque: 792 Nm
                    ATF temperature: 17  C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: closed
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F549220003A30C03EC9221004100F0F01A
   VCID: 75BC89D395C9EAA27CD-8020
                    Reset counter: 138
                    Mileage: 92125 km
                    Date: 2019.03.13.
                    Time: 12:44:10
                    Count: 32768
                    Count: 4608
                    Count: 57
                    Count: 50547
                    Count: 768
03840 - RPM Sensor Front Right: Incorrect Signal
                    Reset counter: 139
                    Mileage: 91993 km
                    Date: 2019.03.11.
                    Time: 13:04:05
                    Count: 16387
                    Count: 14
                    Count: 12288
                    Count: 55
                    Count: 36752
                    Count: 767
                    Count: 19456
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2019.03.10.
                    Time: 14:12:16
                    Count: 16387
                    Count: 4
                    Count: 12800
                    Count: 16390
                    Count: 51456
                    Count: 3072
                    Count: 256
                    Count: 5632
                    Fault Status: 00101100
                    Fault Frequency: 8
                    Reset counter: 139
                    Mileage: 91588 km
                    Date: 2019.03.09.
                    Time: 11:19:47
                    Count: 16387
                    Count: 12
                    Count: 8192
                    Count: 48
                    Count: 44544
                    Count: 1534
   Part No SW: 5K0 959 434 K    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1403
   Revision: 00093000    Serial number: 0481833558 Dataset Number: V03935267BW 0001
   Coding: 132C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 3D2C51F3EDF972E274D-8068
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0050019092
   VCID: 5AE6FA6F1C97A5DA71F-800E
   Part No SW: 5K0 937 087 AS    HW: 5K0 937 087 AS
   Component: BCM PQ35 H++  122 0193
   Revision: BN122001
   Coding: EF200E1B982B08D4098806013400044800F1000645A00DB0E4806200BC70
   VCID: 065EFE1FF82FF13A657-8052
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 090818 05  50  0106
   Coding: 0038DD
03789 - Terminal 75 Limp Mode Active
                    Reset counter: 139
                    Mileage: 92431 km
                    Date: 2019.03.14.
                    Time: 14:17:06
                    Voltage: 10.50 V
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 55501829414383 Dataset Number: V03935231KQ 0001
   Coding: 0071155011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372043DBCFC558B2AE1-8062
13688835 - Databus
          [Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 2410187453A0D2 Dataset Number: V03935263DJ 0001
   Coding: 01001002FE0739
   ROD: EV_ACCBEGVW361.rod
   VCID: 363E4EDFC8CFA1BAB57-8062
10 Faults Found:
1067 - Brake Temperature
          C10DF 00 [00001000] - -
                    Fault Frequency: 12
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
                    Control Module temperature: 21  C
                    Voltage terminal 15: 14.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Fault Frequency: 12
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Fault Frequency: 12
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
                    Control Module temperature: 22  C
1037 - Databus
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 139
                    Mileage: 92409 km
                    Date: 2024.10.21.
                    Time: 12:25:36
                    Control Module temperature: 19  C
                    Voltage terminal 15: 11.4 V
1544 - Function restriction
          C10C2 00 [00001000] - -
          [FAULT_REFERENCE_VELOCITY_NOT_AVAILABLE]
                    Reset counter: 139
                    Mileage: 92409 km
                    Date: 2024.10.21.
                    Time: 12:25:34
                    Voltage terminal 15: 10.1 V
                    Vehicle speed: 0.33 m/s
1043 - Automatic Distance Control
          B10E7 F0 [00001000] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
1118 - Databus
          [FAULT_CIS_WHEEL_PULSE_FAIL]
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
1119 - Databus
          [FAULT_CIS_WHEEL_PULSE_INVALID]
                    Reset counter: 139
                    Mileage: 92409 km
                    Date: 2024.10.21.
                    Time: 12:25:36
1081 - Databus
          [FAULT_CIS_WHEEL_RPM_FAIL]
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
1082 - Databus
          [FAULT_CIS_WHEEL_RPM_INVALID]
                    Reset counter: 139
                    Mileage: 92409 km
                    Date: 2024.10.21.
                    Time: 12:25:36
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    009 0210
   Serial number: 003RXM0G9BB3 Dataset Number: V03935261GJ 0001
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 6398C78B2BDD6412229-8036
   Serial number: IBH00000000000AJ6JIW
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 003 006 18
   Serial number: 35700000000B8044AE2P
   Subsystem 3 - Part No SW: -----------    HW: 480 001 708 18
   Serial number: 358000000002D155C33H
   Subsystem 4 - Part No SW: -----------    HW: 480 020 409 18
   Component: SideSensor_Dr  003 0148
   Serial number: 3510001C92BD5EC2F29U
   Subsystem 5 - Part No SW: -----------    HW: 480 020 409 18
   Component: SideSensor_Pr  003 0148
   Serial number: 3520001C92BD5EC1443F
   Subsystem 6 - Part No SW: -----------    HW: 480 020 808 18
   Component: FrontSensor_D  003 0189
   Serial number: 3550001C929B7D3306DG
   Subsystem 7 - Part No SW: -----------    HW: 480 020 808 18
   Component: FrontSensor_P  003 0189
   Serial number: 3560001C929B7D33813A
          B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 11
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:12:12
   Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20180829300721
   Coding: 2012C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 0052E807DA8BDF0A5FB-8054
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2391819331201891AE2B
   Coding: 2D0000
   Part No SW: 561 920 981 D    HW: 561 920 981 D
   Component: KOMBI         H03 2030
   Coding: 221E010000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 1D6CB1734D3912E254D-8048
   Part No SW: 7N0 907 530 BQ    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1691
   Revision:   H56       Serial number: 09101803000014
   Coding: 461010
   VCID: 0052E807DA0BDF0A5FB-8054
   Component: IMMO          H03 2030
   Coding: 000007
   VCID: 6A86AAAFCCF7355AE1F-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 18000266361004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 31347DC321A18682E05-8064
   Serial number: 0493771517 Dataset Number: V03935233YJ 0001
   Coding: 02011102
   ROD: EV_HREntryHella_VW41.rod
   VCID: 3C2A5CF7F6E37BEA433-8068
   Serial number: 0495828526
   Coding: 020111
337872 - Databus
          [mBremse_10::B10_QB_Wegimp_VR - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0011152501
   Coding: 0404BD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E6EB67F403F09FA4D7-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746181023213940
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 313    3501
   Revision: 00H22000
   Shop #: WSC 19460 666 12345
   VCID: 392445E3F5514EC2585-806C
02797 - Control Module for Directional Stabilization Assistance (J759)
                    Reset counter: 136
                    Mileage: 91927 km
                    Date: 2019.03.09.
                    Time: 15:44:44
                    Voltage: 14.13 V
                        DU
                    Temperature: 42.0 C
                    RPM: 1152 /min
                    Speed: 13.0 km/h
                    Speed: 13.0 km/h
                    Fault Status: 00101101
                    Fault Frequency: 12
                    Reset counter: 139
                    Mileage: 92438 km
                    Date: 2019.03.16.
                    Time: 11:32:43
                    Voltage: 14.50 V
                        DU
                    Temperature: 16.0 C
                    RPM: 1056 /min
                    Speed: 2.0 km/h
                    Speed: 2.0 km/h
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0163074 Dataset Number: V03935204X  0001
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 280290A7127BC74A37B-807C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1691
   Coding: 01030100
   VCID: 6FB0BBBBF795D072B61-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011819900834
   Coding: 181100
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0011150589
   Coding: 0405BC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F108B7B473500F2461-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747181023181430
   Part No SW: 5C0 035 684 D    HW: 5C0 035 684 D
   Component: MU-S-NS-US    H42 0472
   Serial number: VWZAZ2U1589638 Dataset Number: V03935276K  0001
   Coding: 02140102AA00000041220003001808009F0106D400200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 261E9E9F186FD13A057-8072
   Subsystem 1 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
6145 - Display and Control Head 1 for Information Electronics
          B129E 07 [00001000] - Mechanical Failure
                    Fault Frequency: 8
                    Reset counter: 120
                    Mileage: 89675 km
                    Date: 2024.08.30.
                    Time: 03:07:58
                    Voltage terminal 30: 13.4 V
   Component: Batt.regelung H56 1691
   Coding: E1200859
   VCID: 71B4BDC3E1A1C682A05-8024
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     024 0160
   Serial number: 000003554140569 Dataset Number: V03935212VL 0001
   Coding: 02140102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 147AD457BEF353AAEB3-8040
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 1272
   Serial number: 07081841P10041 Dataset Number: V03935289RM 0001
   Coding: 0004010100010201002213468080480080000E200100
   VCID: 0842F027F2BBE74A17B-805C
0281 - Databus
          [mBremse_3_BR3_Rad_kmh_VR]
                    Reset counter: 139
                    Mileage: 91981 km
                    Date: 2024.10.17.
                    Time: 14:11:56
                    Control Module temperature: 24  C
                    Outside temperature: 19.5  C
                    Vehicle speed: 0.00 km/h
                    System run time: 8.4 s
                    Voltage terminal 15: 14.2 V
                    mid: 02 D9
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
4195331 - Databus
          [LH_EPS_03_EPS_HCA_Status]
                    Reset counter: 136
                    Mileage: 89852 km
                    Date: 2024.09.05.
                    Time: 02:46:27
                    Control Module temperature: 38  C
                    Outside temperature: 28.0  C
                    Vehicle speed: 4.12 km/h
                    System run time: 3.8 s
                    Voltage terminal 15: 13.7 V
                    mid: 02 A7
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
0645 - Windscreen Heater for Front Sensors
          B11CE 15 [00001001] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 92447 km
                    Date: 2024.10.23.
                    Time: 13:25:35
                    Control Module temperature: 67  C
                    Outside temperature: 23.0  C
                    System run time: 1395.5 s
                    Voltage terminal 15: 14.0 V
                    mid: 00 5A
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
End----------(Elapsed Time: 01:34, VBatt start/end: 13.9V/13.7V)-----------
Westbury, UK
problem want accept long coding with new abs controller
Is the part number of the new ABS exactly the same as the old one?
Brd
C?ID=193546
no, old controller # 1K0 907 379CC, new 1KO 907 375CC
EuroX
Northern NJ USA
C?ID=208579
The part number does not change. Therefore this is the wrong part number for the vehicle. Get the correct part. However why was the unit replaced?
Spacewalker
Poland
C?ID=159607
did you mount new ABS completly , or just re-connect connector w/o pipes ? ?
to do bench coding - make sure ABS is a proper position , flat surface 0 degree
and should accept coding
try also re-flash to CC
2kaa52
Ceska Republica, Praha
C?ID=319193
a 2019 NMS Passat dont have a mk60ec1 Abs
From factory is mk100 with 561 PN fitted
EuroX
Northern NJ USA
C?ID=208579
False information. In NAR this original info:
Data source:Vehicle
Hardware part number:1K0907379CC
Part number:1K0907379CC
Hardware version number:H46
Software version number:0175
Production date:
Coding:C5 4B C0 F5 49 22 00 03 A3 0C 03 EC 92 21 00 41 00 F0 F0 1A
Coding:add
Coding:C54BC0F549220003A30C03EC9221004100F0F01A
Ability to flash:Flashable
System name:ESP MK60EC1
Incorrect. The Tennessee built Passat NMS was a "PQ" car right through the end of production in MY 2022.
2kaa52
C?ID=319193
Not true
There was something of a facelift around 2020, which did change the ABS, but in the end, I would still call this a "PQ" car because it still had a 7N0 Gateway and a PQ35 BCM.
2kaa52
C?ID=319193
sure its a PQ car, but with a 561..... ABS
Which is a strange combination. Now there's no doubt that combination exists in some of the last NMS Passats like the 2021 you linked to and another 2022 I found, but I'm questioning it in the OP's 2019.
Interesting discrepancy between PL24 and the info that @EuroX posted, which I'm confident comes from an even more official source.
EuroX
Northern NJ USA
C?ID=208579
Ahh so what your saying is the car was produced and delivered with the wrong ABS unit installed? Got it!!!! NOT!!!
I suspect the data PL24 is providing to @2kaa52 is incorrect. That may be region or language based? I have not tried using a non-English selection in my account but this is what I have based on VIN:
When PL24 can't determine the original unit based on VIN I use the original part number(s) from Item #1, Ctrl-F that into the webpage and let it highlight the most likely correct Item #2. In that case 1K0 907 379 CC circles back to one of the item #2 options.
In conclusion, I think PL24 is providing incorrect info to @2kaa52 even though that was filtered by VIN.
Either way, 1K0 907 375 CC may be a valid part number for accounting reasons but that number would never show up in a scan. The replacement should be showing us 1K0 907 379 CC so it would be most helpful if @Brd posted the scan in the current condition with the all-zero coding.
Brd
C?ID=193546
YES, Dana you are correct. I did get the module to accept long coding string. I started the car before coding to turn the steering right/left/center, then tried to code and refused. Then I realized to code with ignition on, then start procedure, went through the brake ritual, got a leg work out! then went to 44 steering electronics check steering wheel center to make sure it was centered and was 0 degrees, got out (done close controller) tire pressure and ESP lights went out. Thanks to everyone!
Friday,01,November,2024,14:04:32:36288
Gateway Installation List:  7N0 907 530 BQ
