Thursday,31,October,2024,14:19:43:33174
VCDS Version: 24.7.1.0 (x64) HEX-NET CB: 0.4643.4
VIN: WVWZZZ1KZAP180304 License Plate: 87010-D-1
Mileage: 367000km-228043mi Repair Order: VW GOLF6-
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 72
77
VIN: WVWZZZ1KZAP180304 Mileage: 367000km-228043miles
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Malfunction 1010
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 DQ HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9971
Revision: --H23--- Serial number: 00000000000000 CVN: 49E8A84E
Coding: 00114036032401080000
Shop #: WSC 00028 028 00021
ASAM Dataset: EV_ECM16TDI02103L906023DQ 003013
ROD: EV_ECM16TDI02103L906023DQ_003.rod
VCID: F8BCB2E043525D5673-80AC
VINID: 9E69EAAAA05BA918012000C010246DAFD7
8 Faults Found:
6260 - Engine Start Blocked by Immobilizer
P1570 00 [00100000] - -
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:17
Engine RPM: 819.00 /min
Normed load value: 5.9 %
Coolant temperature: 53 °C
Intake air temperature: 25 °C
Voltage terminal 30: 12.085 V
Unlearning counter according OBD: 29
Immobilizer snapshot A: 14
6068 - No Communication with Instrument Cluster
U0155 00 [00100000] - -
Mileage: 367589 km
Date: 2035.01.05.
Time: 19:11:22
Engine RPM: 0.00 /min
Coolant temperature: 62 °C
Intake air temperature: 31 °C
Voltage terminal 30: 12.311 V
Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 36 °C
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [01100101] - -
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:16
Coolant temperature: 60 °C
Voltage terminal 30: 12.198 V
Engine RPM: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 12.2 V
10116 - Fuel Rail/System Pressure
P0087 00 [01100000] - Too Low
Mileage: 367378 km
Date: 2035.01.05.
Time: 15:26:36
Engine RPM: 759.25 /min
Normed load value: 76.9 %
Vehicle speed: 13 km/h
Coolant temperature: 64 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.908 V
Fuel high-pressure: actual value-FUP_FIL: 0.586 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 3 l
Fuel temperature-TFU: 47 °C
Fuel Metering Valve-VCV: 21.089 %
Fuel Pressure Regulator Valve-PCV: 33.879 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 35296.631 kPa
10119 - High Pressure Fuel Rail
P00C6 00 [01100000] - Minimum Pressure Not Reached
Mileage: 367378 km
Date: 2035.01.05.
Time: 15:47:42
Engine RPM: 283.25 /min
Normed load value: 8.6 %
Intake air temperature: 26 °C
Voltage terminal 30: 9.148 V
Fuel high-pressure: actual value-FUP_FIL: 0.140 MPa
Time since engine start: 0 s
Fuel Metering Valve-VCV: 42.464 %
Fuel Pressure Regulator Valve-PCV: 50.351 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 25701.904 kPa
9867 - Coolant Pump 2
P261A 00 [11101100] - Open circuit
Mileage: 361577 km
Date: 2035.01.05.
Time: 13:45:50
Engine RPM: 2147.25 /min
Normed load value: 2.4 %
Vehicle speed: 1 km/h
Coolant temperature: 80 °C
Intake air temperature: 38 °C
Voltage terminal 30: 13.101 V
Coolant temperature at radiator outlet: actual value-TCO_2: 49 °C
Battery voltage: 14.6 V
9870 - Coolant pump 2
P261B 00 [11101101] - Implausible signal
Mileage: 361578 km
Date: 2035.01.05.
Time: 13:50:12
Engine RPM: 1174.25 /min
Normed load value: 20.8 %
Vehicle speed: 33 km/h
Coolant temperature: 86 °C
Voltage terminal 30: 12.875 V
Coolant temperature at radiator outlet: actual value-TCO_2: 74 °C
Battery voltage: 13.7 V
11787 - Start/Stop System; Maximum Time for Restart Exceeded
P167E 00 [01100000] - -
Mileage: 366155 km
Date: 2035.01.05.
Time: 22:55:22
Engine RPM: 267.25 /min
Vehicle speed: 3 km/h
Coolant temperature: 54 °C
Intake air temperature: 29 °C
Unlearning counter according OBD: 14
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Shop #: WSC 00028 028 00001
VCID: FAB8A8E8755E4F4605-80AE
Reset counter: 100
Mileage: 367589 km
Date: 2029.05.28.
Time: 19:11:23
Count: 2
Count: 2
Count: 20992
Count: 8208
Count: 43264
Count: 1
Count: 254
Fault Status: 00100101
Reset counter: 100
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:16
Count: 2
Count: 2
Count: 20992
Count: 212
Count: 43520
Reset counter: 100
Mileage: 367000 km
Date: 2024.10.31.
Time: 00:00:08
Count: 16391
Count: 16384
Count: 195
Count: 43520
Fault Status: 01100101
Reset counter: 100
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:16
Count: 2
Count: 2
Count: 20992
Count: 279
Count: 43520
Reset counter: 89
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:16
Count: 2
Count: 2
Count: 20992
Count: 295
Count: 43520
Reset counter: 100
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:16
Count: 2
Count: 2
Count: 20992
Count: 270
Count: 43520
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000003
VCID: FEB0A4F86176636639-80AA
9481988 - Air Quality Sensor
B10AF 04 [00001000] - Internal System Fault
Reset counter: 140
Mileage: 304027 km
Date: 2035.01.05.
Time: 15:50:53
Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
Component: BCM PQ35 M 103 0575
Revision: 00103 AG
Coding: 40180A3A98251AC040080080640081E443510088636D8560648087200001
VCID: B02C4AC0E3A24516FB-80E4
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 07051 23 0512
Coding: 009795
Component: RLS 200510 05 54 0403
Coding: 0330AD
11 Faults Found:
Fault Status: 00101010
Reset counter: 140
Mileage: 335913 km
Date: 2029.05.28.
Time: 14:48:24
Voltage: 12.20 V
Term 50 On
Fault Status: 01101010
Reset counter: 100
Mileage: 335913 km
Date: 2029.05.28.
Time: 14:48:24
Voltage: 12.20 V
Term 50 On
00061 - Footwell Lights
Reset counter: 100
Mileage: 335913 km
Date: 2029.05.28.
Time: 14:48:24
Voltage: 12.20 V
Term 50 On
Reset counter: 140
Mileage: 335913 km
Date: 2029.05.28.
Time: 14:48:46
Voltage: 12.55 V
Term 50 On
Fault Status: 01101100
Reset counter: 100
Mileage: 367000 km
Date: 2024.10.31.
Time: 00:04:50
Voltage: 12.10 V
Term 50 On
Fault Status: 00100111
Reset counter: 140
Mileage: 335974 km
Date: 2029.05.28.
Time: 13:42:02
Voltage: 13.10 V
Term 50 On
Reset counter: 140
Mileage: 335916 km
Date: 2029.05.28.
Time: 18:12:60
Voltage: 14.35 V
Term 50 On
Reset counter: 140
Mileage: 335916 km
Date: 2029.05.28.
Time: 18:13:06
Voltage: 14.30 V
Term 50 On
Reset counter: 100
Mileage: 353135 km
Date: 2029.05.28.
Time: 13:51:33
Voltage: 11.00 V
Term 50 On
00985 - Right Tail Light (M2)
Reset counter: 129
Mileage: 357688 km
Date: 2029.05.28.
Time: 17:57:41
Voltage: 13.25 V
Term 50 On
Fault Status: 00101110
Fault Frequency: 187
Reset counter: 136
Mileage: 357577 km
Date: 2029.05.28.
Time: 00:10:26
Term 15 Off
Voltage: 12.50 V
Term 50 Off
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88591007053325
Coding: 10020A
VCID: C0CC1A005302D5960B-8094
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 100
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:19
Temperature: 25.0°C
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA7V5MB Dataset Number: 5K0003v____ 0084
Coding: 00003132
Shop #: WSC 01383 790 00001
ROD: EV_AirbaVW10SMEVW360.rod
VCID: BB366DEC32E4B64E5E-80EE
Serial number: 3572MSME3F795252ZZZ+
Serial number: 3582MSME56455352ZZZT
Serial number: 3512QSME180E5B7EZZZ8
Serial number: 3522QSME1C165931ZZZU
12670208 - No Communication with Instrument Cluster
U0155 00 [00001000] - -
Reset counter: 140
Mileage: 367589 km
Date: 2035.01.05.
Time: 19:11:22
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: F8BCB2E08B525D5673-80AC
Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: 00000226
Part No SW: 5K0 920 860 G HW: 5K0 920 860 G
Component: KOMBI H06 0206
Coding: 170B00
Shop #: WSC 00028 028 00318
VCID: B02C4AC0EBA24516FB-80E4
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J1052002E2
Coding: E9A07F06400612040002
VCID: EB969DACCA04E6CE8E-80BE
Reset counter: 140
Date: 2029.05.28.
Time: 18:38:01
Reset counter: 140
Date: 2029.05.28.
Time: 18:38:01
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H06 0206
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [00001000] - -
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:11
9456681 - Key
B104C 29 [00001000] - Implausible Signal
Mileage: 31005 km
Date: 2024.10.31.
Time: 00:00:13
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7668049644
Coding: 020000
VCID: A600AC98D1661BA611-80F2
Address 37: Navigation (J794) Labels:| 3C0-035-270.clb
Part No SW: 3C0 035 270 B HW: 3C0 035 270
Component: RNS310 H15 0351
Revision: 10000000 Serial number: VWZ1Z2K9394865
Coding: 040004010400000000000000
ASAM Dataset: VW_RNS310 A02005
ROD: EV_VWRNS310UDS_VW25.rod
VCID: 997A97649818A45EAC-80CC
1048659 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[CAN TO phone control unit]
Reset counter: 140
Mileage: 305191 km
Date: 2035.01.05.
Time: 14:39:14
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2139
Coding: 0131252
VCID: B32645CCD2B47E0E86-80E6
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: B12A4FC428A84C1EF4-80E4
Fault Status: 11100101
Battery Volts: 12.3 V
PD
Temperature: 25.0°C
Count: 3
Steering Angle: 6.30°
Count: 1
SteerAng n.Init
Reset counter: 140
Mileage: 367589 km
Date: 2029.05.28.
Time: 00:00:03
Voltage: 12.25 V
DD
Temperature: 30.0°C
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Coding: 0131508
VCID: B5227BD4DCC0603EA8-80E0
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J1052002E2
Coding: 030B085A
VCID: E89CE2A01BF2CDD6E3-80BC
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 100
Mileage: 304632 km
Date: 2029.05.28.
Time: 13:38:36
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 00028 028 1012545
VCID: B42446D0D7BA79369F-80E0
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0131216
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07758520
Coding: 012120
VCID: AA1858A8C57E3FC635-80FE
End----------(Elapsed Time: 01:14, VBatt start/end: 12.3V/12.3V)-----------
