Audi A6 C6 ESP MIL comes in
Sheepwolf
Lithuania
C?ID=179265
Hello to everyone.
Made a scan to Audi A6 C6 V8 4.2L, production of 2005. Owner says that sometimes ESP MIL turns on and after sometime turns off itself.
What can cause this issue ?
OFF TOPIC. There are loads of errors in this car and I can't to get rid of them by clearing these in AutoScan. Engine related errors may be explained by the circumstance that car is equipped with LPG system and probably some piggyback LPG ECU makes impact.
I don't know what has been done to this car previously, but no other MIL or errors are visible on dash. Car runs smoothly, ABS's working great..
VCDS Version: Release 15.7.1 (x64) Running on Windows 10 x64
Data version: 20150904
Wednesday,18,November,2015,16:56:36:48017
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUDL94FX6N045614   Mileage: 158420km-98437miles
65-Tire Pressure -- Status: Not registered 0001
   Part No SW: 4F0 910 560 E    HW: 4F0 907 559
   Component: 4.2L V8/5V      G   0010
   Revision: --H01---    Serial number:
   Coding: 0007772
   Shop #: WSC 02325 785 00200
   VCID: 24473B6CE7606E1E19-8070
11 Faults Found:
16839 - EVAP System
            P0455 - 001 - Large Leak Detected
                    Fault Status: 01100001
                    Mileage: 158394 km
                    Date: 2015.11.18
                    Time: 09:55:22
                    RPM: 1190 /min
                    Load: 16.1 %
                    Speed: 51.0 km/h
                    Temperature: 90.0°C
                    Temperature: 13.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
16592 - Injector: Cylinder 8 (N86)
            P0208 - 004 - Circuit Malfunction - Intermittent
                    RPM: 313 /min
                    Load: 58.4 %
                    Temperature: 52.0°C
                    Temperature: 45.0°C
                    Voltage: 9.652 V
16585 - Injector: Cylinder 1 (N30)
            P0201 - 004 - Circuit Malfunction - Intermittent
                    RPM: 313 /min
                    Load: 58.4 %
                    Temperature: 52.0°C
                    Temperature: 45.0°C
                    Voltage: 9.652 V
16588 - Injector: Cylinder 4 (N33)
            P0204 - 004 - Circuit Malfunction - Intermittent
                    RPM: 338 /min
                    Load: 57.6 %
                    Temperature: 81.0°C
                    Temperature: 69.0°C
                    Voltage: 11.049 V
16589 - Injector: Cylinder 5 (N83)
            P0205 - 004 - Circuit Malfunction - Intermittent
                    RPM: 313 /min
                    Load: 58.4 %
                    Temperature: 52.0°C
                    Temperature: 45.0°C
                    Voltage: 9.652 V
16587 - Injector: Cylinder 3 (N32)
            P0203 - 004 - Circuit Malfunction - Intermittent
                    RPM: 313 /min
                    Load: 58.4 %
                    Temperature: 52.0°C
                    Temperature: 45.0°C
                    Voltage: 9.652 V
16590 - Injector: Cylinder 6 (N84)
            P0206 - 004 - Circuit Malfunction - Intermittent
                    RPM: 313 /min
                    Load: 58.4 %
                    Temperature: 52.0°C
                    Temperature: 45.0°C
                    Voltage: 9.652 V
16586 - Injector: Cylinder 2 (N31)
            P0202 - 004 - Circuit Malfunction - Intermittent
                    RPM: 338 /min
                    Load: 57.6 %
                    Temperature: 81.0°C
                    Temperature: 69.0°C
                    Voltage: 11.049 V
16591 - Injector: Cylinder 7 (N85)
            P0207 - 004 - Circuit Malfunction - Intermittent
                    RPM: 338 /min
                    Load: 57.6 %
                    Temperature: 81.0°C
                    Temperature: 69.0°C
                    Voltage: 11.049 V
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
                    Fault Status: 01101000
                    Mileage: 158395 km
                    Date: 2015.11.18
                    Time: 12:12:46
                    RPM: 753 /min
                    Load: 35.7 %
                    Speed: 6.0 km/h
                    Temperature: 94.0°C
                    Temperature: 35.0°C
                    Voltage: 13.462 V
            P1653 - 008 -
                    Mileage: 158395 km
                    Date: 2015.11.18
                    Time: 12:12:48
                    RPM: 753 /min
                    Load: 35.7 %
                    Speed: 6.0 km/h
                    Temperature: 94.0°C
                    Temperature: 35.0°C
                    Voltage: 13.462 V
Readiness: 0010 1100
Address 02: Auto Trans
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0021352
   Shop #: WSC 02327 785 00200
   VCID: 2D51DE48B4AAAF56C6-8078
                    Fault Status: 00101011
                    Fault Frequency: 29
                    Reset counter: 166
                    Mileage: 156703 km
                    Date: 2015.10.09
                    Time: 14:43:06
                    Hex Value: 0x0500
                    Hex Value: 0x4082
                    Hex Value: 0x0004
                    Hex Value: 0xB0AF
                    Hex Value: 0x00FF
                    Reset counter: 144
                    Mileage: 157978 km
                    Date: 2015.11.07
                    Time: 17:09:18
                    Hex Value: 0x00C0
                    Hex Value: 0x0282
                    Hex Value: 0x0013
                    Hex Value: 0x8591
                    Hex Value: 0x00FF
02083 - Message for Delay Request
                    Reset counter: 144
                    Mileage: 157978 km
                    Date: 2015.11.07
                    Time: 17:09:16
                    Hex Value: 0x00C0
                    Hex Value: 0x0282
                    Hex Value: 0x002B
                    Hex Value: 0x0591
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0160
   Revision: 27100401    Serial number: 10600500207141
   Coding: 0000015
   Shop #: WSC 02323 785 00200
   VCID: 63C57870A2EE292620-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H44 0070
   Component: FBSAUDIC6 KSG   H26 0080
02764 - Access/Start Authorization Switch (E408)
                    Reset counter: 89
                    Mileage: 157278 km
                    Date: 2015.10.29
                    Time: 13:16:07
00956 - Key 2
                    Fault Frequency: 12
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Reset counter: 138
                    Mileage: 157896 km
                    Date: 2015.11.04
                    Time: 18:11:41
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 S    HW: 4E0 035 729
   Component: Interfacebox    H43 5150
   Revision: 00000000    Serial number: 303FB057502602
   Coding: 0010003
   Shop #: WSC 00000 000 08192
   VCID: 3365C830528EF9A690-8066
   Component: Bedienteil MMIC6H07 0050
   Subsystem 2 - Serial number: 00000000187736
   Subsystem 3 - Serial number: 0124.06.050000000100010718ÿ
   Subsystem 4 - Serial number: 010718ÿ
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 158
                    Mileage: 156734 km
                    Date: 2015.10.19
                    Time: 13:07:33
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000030033267
   Coding: 0008264
   VCID: 5BB540909A9E11E668-800E
                    Reset counter: 144
                    Mileage: 157950 km
                    Date: 2015.11.06
                    Time: 12:47:44
   Part No SW: 4F0 910 279 A    HW: 4F0 907 279 A
   Component: ILM Fahrer      H15 0080
   Coding: 0113121
   Shop #: WSC 02335 785 00200
   VCID: 275D2C60965685063C-8072
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7193744
   VCID: 1C37038CDF1056DEA1-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E5009898
   VCID: 285F2F5C9B488A7E35-807C
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 67 AIRBAG AUDI8RH29 0300
   Revision: 12H29000    Serial number: 00359D0A0KFW
   Coding: 0013879
   Shop #: WSC 02101 444 52615
   VCID: 2A5BD5548544B86E23-807E
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0A6A3968D
   Subsystem 3 - Serial number: 6342CSME0B283814%
   Subsystem 4 - Serial number: 6352QSME02272C7FO
   Subsystem 5 - Serial number: 6362QSME0236776DM
   Subsystem 6 - Serial number: 63734SME022B340BY
   Subsystem 7 - Serial number: 63834SME04413661R
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026051720667
   Coding: 0012141
   VCID: 66C3616451DC5C0EC7-8032
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H15 0630
   Revision: 01000000    Serial number: 4PY355V65
   Coding: 2129163
   Shop #: WSC 00999 444 64523
   VCID: 21493278F8727B3672-8074
                    Fault Frequency: 55
                    Reset counter: 144
                    Mileage: 157950 km
                    Date: 2015.11.06
                    Time: 12:47:33
   Coding: 2129163
                    Fault Frequency: 55
                    Reset counter: 144
                    Mileage: 157950 km
                    Date: 2015.11.06
                    Time: 12:47:33
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 1200805625801F
   Coding: ECFE73CC1B7904
            000 -  -
                    Reset counter: 100
                    Mileage: 148382 km
                    Date: 2015.04.22
                    Time: 13:14:03
                    Reset counter: 161
                    Mileage: 158302 km
                    Date: 2015.11.16
                    Time: 11:22:50
                    Reset counter: 141
                    Mileage: 157950 km
                    Date: 2015.11.06
                    Time: 12:47:32
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 61C97278B8F23B3632-8034
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 C
   Component: MNS ECE         H45 1060
   Revision: 00000000    Serial number: 355F/057549676
   VCID: 3B75E0107ADE31E648-806E
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 161
                    Mileage: 158322 km
                    Date: 2015.11.16
                    Time: 11:54:34
                    Hex Value: 0x5649
                    Hex Value: 0xC3FA
                    Hex Value: 0x0900
                    Hex Value: 0x0508
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00-00000
   Coding: 0051947
   VCID: 29592A588042B3762A-807C
                    Fault Status: 01101100
                    Fault Frequency: 19
                    Reset counter: 126
                    Mileage: 158235 km
                    Date: 2015.11.14
                    Time: 16:26:09
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H19 0140
   Revision: 01400019    Serial number: 01005313160000
   Coding: 4615229
   VCID: 2E53D944B9ACD44EFF-807A
                    Fault Frequency: 53
                    Reset counter: 166
                    Mileage: 156608 km
                    Date: 2015.10.08
                    Time: 13:27:32
01699 - Motor for Central Locking; Hatch/Trunk (V53)
                    Fault Status: 00101001
                    Reset counter: 129
                    Mileage: 157294 km
                    Date: 2015.10.29
                    Time: 14:20:37
                    Reset counter: 144
                    Mileage: 157950 km
                    Date: 2015.11.06
                    Time: 12:48:11
00892 - Switch for Trunk Closing Cylinder (F248)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 22
                    Reset counter: 126
                    Mileage: 158411 km
                    Date: 2015.11.18
                    Time: 16:04:05
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000791060
   Coding: 0000026
   VCID: 25412668EC5A97160E-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000002580
   Coding: 0012114
   VCID: 5EB34984898C04CE0F-800A
                    Fault Frequency: 55
                    Reset counter: 144
                    Mileage: 157948 km
                    Date: 2015.11.06
                    Time: 12:47:00
                    Voltage: 11.700 V
                    Temperature: 26.0°C
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00-00000
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0006022
   Shop #: WSC 02334 785 00200
   VCID: 5DB14E88848A1FD616-8008
                    Fault Frequency: 48
                    Reset counter: 144
                    Mileage: 157944 km
                    Date: 2015.11.06
                    Time: 12:47:32
                    Voltage: 10.87 V
                    Count: 241
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000016
   VCID: 26432164915C9C0E07-8072
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
02628 - Sensor for Swivel Module Position; Right
                    Fault Status: 00111000
                    Mileage: 148376 km
                    Date: 2015.04.22
                    Time: 13:22:43
                    Fault Frequency: 55
                    Reset counter: 144
                    Mileage: 157944 km
                    Date: 2015.11.06
                    Time: 12:47:32
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394G4057567868
   Coding: 0000001
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000070569
   Shop #: WSC 00000 384 00290
   VCID: 23453870E26E692660-8076
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  1506300036
   Coding: 344630393135313035442056413031353036333030303336
02277 - Quiescent Current Stage 6
            000 -  -  - Intermittent
                    Fault Frequency: 11
                    Mileage: 156734 km
                    Date: 2015.10.16
                    Time: 03:03:41
02273 - Quiescent Current Stage 2
                    Fault Frequency: 21
                    Mileage: 149167 km
                    Date: 2015.05.14
                    Time: 00:37:07
02276 - Quiescent Current Stage 5
                    Fault Frequency: 18
                    Mileage: 149167 km
                    Date: 2015.05.14
                    Time: 17:22:06
02256 - Quiescent Current
                    Fault Status: 00110001
                    Reset counter: 164
                    Mileage: 158278 km
                    Date: 2015.11.15
                    Time: 02:04:30
                    Reset counter: 144
                    Mileage: 157950 km
                    Date: 2015.11.06
                    Time: 12:47:38
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0051754
   VCID: 69D96A5840C27376EA-803C
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000700007550
   Coding: 0062422
   VCID: 60CF777CB3F8323E3D-8034
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000506230091
   Shop #: WSC 12336 024 394758
   VCID: 3467CB2C5780FE9E89-8060
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0051754
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0020
   Revision: 00H09000    Serial number: 11720517400683
   Coding: 0001206
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H11 0950
   Revision: 00000000    Serial number: 00000007504487
   Coding: 0010900
End-------------------------(Elapsed Time: 02:55)--------------------------
kimmy
Europe
C?ID=35265
what a bunch of errors,rare seen! :D
could be the brake light switch...
NZDubNurd
New Zealand
C?ID=230482
This is true - the ESP/ABS DOES like to know when the driver has pressed the brake pedal, so if a fault is reported with it, the ESP/ABS is going to be very angry/confused.
Sheepwolf
Lithuania
C?ID=179265
Not so rare if car's equipped with LPG piggy back system, or any kind of piggy back.
Anyway, back to problem. I've seen this brake light switch error previously as that's not the first time I put this exact car under diagnostics. There were problems with car engine starting earlier.
I know that this switch is kinda import one and even one year ago we did got to that switch as I wanted this pedal related error to go away. The switch appeared to be ok and I did place it back where it belongs to (but did not check wiring that time) as I found problems were in aftermarket alarm system. We solved it and car started with no problems that time (with this error still ON).
This time MIL is not constant, sometimes it comes on or turn off itself. And it started just few weeks ago.
Maybe it may be some inproper plug connection problems ? corrosion of it ?
Sheepwolf
Lithuania
C?ID=179265
Problem solved. Bunch of error still exists, but MIL regarding ESP didn't come anymore since Brake light switch was replaced with a new one.
By eliminating Error:
problem has been solved. Thanks for you concern.
