lexvdpoel
Hello everyone,
Sorry for this very long and chaotic first post
I've recently acquired a very cheap VW EOS 2006 2.0 petrol (€ 1500)
It was cheap because:
What have I done already?
Now for the chaotic part:
The car starts and runs fine, only I screwed up at the first moment I got the replacement cluster by just hooking it up and seeing if it works
(A few months before, I replaced a cluster to a newer one with lcd in our KIA Sportage, that was just plug and play , only needed all key lost and mileage correction. So naturally, I thought this would be the same here.. )
So now I have the ABS and ESP lights on, I can peform Basic Setting on the sensors, only it will keep throwing the "Control Module Incorrectly Coded" error
The coding is correct "0021218", but when I look at the flash status it shows all zeros. I read that this is because the VIN in the cluster and ECU don't match.
So I think (but want some verification of the experts ) that this is my next to do:
-Reflash the cluster so the VIN matches the ECU (possible with my other hardware, I'm fairly certain)
-Relearn the ABS long coding (Havent figuered out how and i'm missing the code, so if you guys could help me i would be really grateful)
-Peform again, the basic setting
And all lights should be off, then I can focus on the correct coding of other parts and maybe lay some extra CAN lines between the cluster and radio (I think these are missing), then some new gen bumpers/lights and a Polo steerring wheel from a 2017 model would make it mint
For info here is the ABS:
Here is the ECU:
Here is the Cluster:
Here is the all important autoscan:
Note: I used my boss his vcds cable, i always work with him on his car projects, hope it's not a problem otherwise i should ask for his account
- From a friend
- LCD in cluster defect
- Dirty because of water leakage
- Roof did not open
- Small crack in front bumper
- Previously had a new engine installed (car has 220k, engine something like 60/70k)
- Fixed the roof with some <€20 parts
- Cleaned the interior and unplugged the drainage holes
- Upgraded the radio with a very modern Discovery Pro unit
- Removed the IMMO from the ECU (couldn't get the new gen cluster to work otherwise)
- Installed a newer gen NEC VDO 24C64 cluster with color LCD (corrected the mileage, doesn't complain over the key because it thinks it has keyless entry)
- Upgraded the CAN gateway to a newer model because the cluster couldn't communicate with the ***** (don't know if it's allowed to mention other diag products) software I used to perform all key lost
Thursday,31,October,2024,08:57:26:30348
VCDS Version: Release 24.7.0 (x64)
Address 03: ABS Brakes
Control Module Part Number: 1K0 907 379 AA
Component and/or Version: ESP FRONT MK60 0102
Software Coding: 0021218
Work Shop Code: WSC 00020
VCID: 71BE2DBA8CAE7242A0D-8024
Advanced Identification
Identification: CTA-000
Revision: 00H13001
Date: 24.03.06
Test stand number: 0102
Manufacturer number: 2496
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: 00.00.00
Misc.
Hardware number: 1K0 907 379 AA
VCDS Info:
Labels: 1K0-907-379-MK60-F.clb
Here is the ECU:
Thursday,31,October,2024,08:59:03:30348
Address 01: Engine
Control Module Part Number: 06F 906 056 GA
Component and/or Version: MED9.5.10 G00 9148
Software Coding: 0000072
Work Shop Code: WSC 98765
VCID: 6E8436C69C906DBABDF-803A
Serial number: VWX7Z0F23NE8QC
Identification: BPG-810
Revision: --H03---
Date: 18.03.06
Test stand number: 1849
Manufacturer number: 0509
Flash Status
Programming Attempts: 3
Successful Attempts: 1
Required Conditions: 00000001
Software
P0000
A00.000
Misc.
Hardware number: Hardware No
Car Info
Chassis Number: WVWZZZ1FZ6V006051 (Same as chasis)
VCDS Info:
Labels: Redir Fail!
Readiness: No script available
Thursday,31,October,2024,08:58:32:30348
Address 17: Instruments
Control Module Part Number: 1Q0 920 885
Component and/or Version: KOMBI H03 0206
Software Coding: 071B01
VCID: 72BC22B68428495A597-8026
Advanced Identification/FAZIT
Identification: VD1-048
Date: 15.11.10
Manufacturer number: 7393
Test stand number: 2725
Flash Status
Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
Software
BAP: 01.04.01
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 1Q0 920 885
Workshop System Name: J285
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset: EV_Kombi_UDS_VDD_RM09
ASAM Dataset Revision: A04089
Car Info
Chassis Number: WVWFW7AHXCV006093
VCDS Info:
Labels: 5K0-920-xxx-17.clb-SRI1
Thursday,31,October,2024,08:56:38:30348
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ1FZ6V006051 License Plate:
Chassis Type: 1F-VW36 (7N0)
Scan: 01 03 08 09 0F 15 16 17 19 25 26 37 42 44 46 52 56 62 72 76
77
VIN: WVWZZZ1FZ6V006051 Mileage: 211790km-131600miles
0F-Digital Radio -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 906 056 GA HW: Hardware No
Component: MED9.5.10 G00 9148
Revision: --H03--- Serial number: VWX7Z0F23NE8QC
Coding: 0000072
Shop #: WSC 98765 666 39431
VINID: 9E69EAAAA056A86980006005045F232C21
Readiness: 1000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021218
Shop #: WSC 00020 000 00000
VCID: 71BE2DBA8DAE7242A0D-8024
01487 - System Function Test
01486 - System Function Test Activated
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Q0 907 044 A HW: 1Q0 907 044 A
Component: ClimatronicPQ35 093 0101
Revision: 00093002 Serial number: 00000000000000
VCID: 2B02FFD26F025892DA1-807E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005471580
Coding: 8D8C8F07000415000A0A00000F00000000195D035C0000
Shop #: WSC 00020 123 12345
VCID: 372AD3A2A34AEC72AE9-8062
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 00020
Address 0F: Digital Radio
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 34 Airbag VW8C 0180
Revision: 92009018 Serial number: 003B30005YER
Coding: 0013108
VCID: 3A2CCA969058F11A517-806E
Subsystem 1 - Serial number: 6332SRB403014EA3X
Subsystem 2 - Serial number: 6342SRB403014DB5-
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 634 0070
Coding: 0000041
VCID: 76B41EA6E4C0557A75F-8022
Part No SW: 1Q0 920 885 HW: 1Q0 920 885
Component: KOMBI H03 0206
Coding: 071B01
Shop #: WSC 00020 999 12345
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [10001001] - General Checksum Failure
[Steuergerät defekt (EEPROM-Bereich Gesamtwegstrecke)]
13634048 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Steuergerät für Zugang- und Startberechtigung: keine Kommunikation]
Reset counter: 176
Mileage: 211766 km
Date: 2024.10.30.
Time: 21:38:25
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 190811F2001948
Coding: 355000
Shop #: WSC 01236 758 00200
VCID: 372AD3A2AF4AEC72AE9-8062
02649 - Digital Radio Tuner
Reset counter: 176
Mileage: 211766 km
Date: 2052.14.05
Time: 21:38:28
Component: IMMO H03 0206
VCID: 6A8C3AD6ACF8819AE17-803E
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 C HW: 1Q0 959 255 C
Component: Verdecksteuergeraet 0720
Revision: 0032000L Serial number: 072330924
Coding: 0655362
Shop #: WSC 00020 790 00000
VCID: 3828D09EAE54E30AA73-806C
Address 37: Navigation
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1Q0 959 701 B
Component: Tuer-SG 023 2721
Coding: 0000181
VCID: 3332E7B2B7320052921-8066
014 - Defective
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 98908A000186487F6D04850570084EC6F0BC80
VCID: 03527772A71270D2421-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 1Q0 951 177 A
Component: Innenraumueberw.158 0502
Reset counter: 176
Mileage: 211770 km
Date: 2024.10.30.
Time: 22:00:21
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1Q0 959 702 B
Coding: 0000180
VCID: 3430E4AEB23C076A8BB-8060
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1Q0 959 703
Component: Tuer-SG 020 2704
Coding: 0000128
VCID: 73B227B2F7B24052521-8026
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1Q0 959 704
Coding: 0000128
VCID: 74B024AEF2BC476A4BB-8020
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1Q0 919 283
Component: 30 Einparkhilfe 0702
VCID: 72BC22B688A8495A597-8026
Address 77: Telephone
End----------(Elapsed Time: 01:16, VBatt start/end: 14.0V/14.0V)-----------
