2017 VW Jetta - How to diagnose airbag light
jakedrakeblake
C?ID=506253
Hi everyone.
Unfortunately, the airbag light is on in our 2017 Jetta.
The reported code:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001000] - Open or Short to Ground
                    Mileage: 119225 km
                    Date: 2086.14.14
                    Time: 10:02:22
And, suspiciously enough, there's also this CAN-bus code:
                    Date: 2014.14.15
                    Time: 00:00:01
Do you guys have suggestions on how to debug this?
Any suggestions for possible bad contacts I should check first?
Thank you! :thumbs:
The full auto-scan is here:
Wednesday,30,October,2024,21:47:58:30954
VIN: 3VWDB7AJ6HM279729   License Plate:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 3C 44 5F 75
Address 01: Engine (J623-CZTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AL    HW: 04E 907 309 AP
   Component: R4 1.4l TFS   H22 3669
   Revision: X5H22---    CVN: 3BBC5B28
   Coding: 011A0012232400001000
   Shop #: WSC 00066 790 00017
   ASAM Dataset: EV_ECM14TFS01104E906023AL 005004
   ROD: EV_ECM14TFS01104E906023AL.rod
   VCID: 6A8DCD324CF867FAE1F-803E
   VINID: 0E69D448745A1987421C91C2246391823A
   Part No SW: 09G 927 749 AA    HW: 09G 927 749
   Component: AISIN AG6 G3  129 3128
   CVN: 56A8984D
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW31.rod
   VCID: 78A9E77A0254C56A67B-802C
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B400C49290003851202E6922200412010F01A
   Shop #: WSC 00066 000 00000
   VCID: 75B7EE4E15C6B8027CD-8020
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0417798439 Dataset Number: V03935236HT 0001
   Coding: 032C0C
   Shop #: WSC 00066 000 00178
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 392F227E79DE1C62585-806C
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 DA    HW: 5C0 820 047 DA
   Component: J301  Klimaanlage   0211
   Revision: 2001401S    Serial number: 00000003639407
   VCID: 629DA512B8483FBA29F-8036
03984 - Left front heated seat
                    Fault Status: 00111011
                    Reset counter: 131
                    Mileage: 111824 km
   Part No SW: 7E0 937 190 B    HW: 7E0 937 190
   Component: BCM PQ25 Max3 H81 0744
   Revision: B8081001    Serial number: 88007245165712
   Coding: 7B994B9A28230F0008392080240884C54BC672FE600151F0B0A050032844
   Shop #: WSC 01799 002 104857
   VCID: 2B0308368302BEF2DA9-807E
   Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1467
   Serial number: 14102743161011203741
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  022 1467
   Serial number: 14202742161017064728
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST001696DZ00000
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Serial number: 2291607454400845AD2B
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745161015064543
   Subsystem 6 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744161015181106
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM094J7  Dataset Number: 5C6003V____ 0017
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 6393A016ABD236B2229-8036
   Serial number: IBH000000000005YM8UG
   Coding: 303146
   Subsystem 2 - Part No SW: -----------    HW: 480 001 009 16
   Serial number: 35700000000AF829DD10
   Subsystem 3 - Part No SW: -----------    HW: 480 001 009 16
   Serial number: 358000000001E829DD1Y
   Subsystem 4 - Part No SW: -----------    HW: 480 021 309 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001A72319DB1A483
   Subsystem 5 - Part No SW: -----------    HW: 480 020 609 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B72285311F37X
   Subsystem 6 - Part No SW: -----------    HW: 480 020 710 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001A92285325341P
   Subsystem 7 - Part No SW: -----------    HW: 480 020 710 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001A9228532535D$
                    Mileage: 119225 km
                    Date: 2086.14.14
                    Time: 10:02:22
Address 17: Instruments
   Part No SW: 7E0 909 901     HW: 7E0 937 190
   Component: GW-K-CAN TP20 H81 0744
   Revision: B8081001
   Coding: 102201
   VCID: 6889B73A527455EAF7B-803C
                    Date: 2014.14.15
                    Time: 00:00:01
   Component: IMMO          H02 1104
   Coding: 000007
   Shop #: WSC 00066 790 00320
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000162853005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 313F1A5EA1AED422E05-8064
   Serial number: 0417777367 Dataset Number: 5G9764V____ 0027
   Coding: 01011101
   Shop #: WSC 00066 790 00178
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C213B6A76EC294A433-8068
   Serial number: 0417063190
   Coding: 010111
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 305    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F227E755E1C62585-806C
   Part No SW: 5C0 035 200 C    HW: 5C0 035 200 C
   Component: MU-S-S-US     H32 0363
   Serial number: VWZAZ2U1607789 Dataset Number: V03935263MC 0001
   Coding: 02630100AA00000051220001001808009F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 1577CECE350618029CD-8040
                    Reset counter: 106
                    Mileage: 111330 km
                    Date: 2078.14.15
                    Time: 12:01:06
                    Voltage terminal 30: 13.5 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140555 Dataset Number: V03935214WB 0001
   Coding: 02630102C21632107F1606C00000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1471B3CA3EFC010AEB3-8040
End----------(Elapsed Time: 01:39, VBatt start/end: 12.0V/12.0V)-----------
jakedrakeblake
C?ID=506253
Update:
I tried if the passenger detection and the "passenger airbag disabled" light both work and they do.
When I start the car with no passengers inside, the "passenger airbag disabled" light will glow orange.
When someone sits on the seat, the orange light will disappear.
So the seat sensor and instrument light are both working as expected.
Dr Sheldon
Windsor UK
C?ID=334979
Front Passenger's Airbag Disabled Indicator Lamp B1016 14 [10001000] - Open or Short to Ground MIL ON -
That fault description is specific - I would look very closely because the alternative is a new module !! $$
This DTC will clear, it is Intermittent, have you tried ??
Will it clear and stay away ??
EuroX
Northern NJ USA
C?ID=208579
It has a code for the warning light itself. This is your issue.
jakedrakeblake
C?ID=506253
@Dr Sheldon
Good point. I will try to clear the DTC and take it for a test drive.
@EuroX
The warning light seems to work.
Do you have any suggestions?
