2015 Jetta TDI S Airbag light on, passenger airbag light flashing
mikeb787
Andover, Kansas, USA
C?ID=492732
My airbag light came on and also my passenger airbag light between the vents is continually flashing/flickering. I have not tested anything as I am not sure where to start. When I tried to access the airbags module on VCDS it says the module cannot be reached. I have the code 01321 - Control Module for Airbags under ABS. Thanks
Wednesday,30,October,2024,08:31:52:44889
VIN: 3VWLA7AJ4FM293334   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 2E 37 44 56 6C 77
2E-Media Player 3 -- Status: Not registered 0001
37-Navigation -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 016 E    HW: 04L 907 309 K
   Component: R4 2.0l TDI   X20 9465
   Revision: 8AX20---    CVN: 2A6481520000000000000000
   Coding: 011D0012042410084000
   ASAM Dataset: EV_ECM20TDI01104L997016E 004002
   ROD: EV_ECM20TDI01104L997016B.rod
   VCID: 353729EA55CB8332BCD-8060
   VINID: 0E69DC44745A1167422430C310AF4FD2D2
Readiness: 0 0 0 1 1
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4517
   Revision: 05653104    Serial number: 00001411140265
   Shop #: WSC 44551 111 44551
   VCID: 2517F9AAE9EBF3B20CD-8070
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492B00FD850E02E7921D0042A1180012
   Shop #: WSC 00066 123 12345
   VCID: 0451842E4E11EABA7B3-8050
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2045.14.30
                    Time: 11:17:46
                    Count: 2
                    Count: 14
                    Count: 16384
                    Count: 8225
                    Count: 44032
                    Count: 1024
                    Count: 260
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 CG    HW: 5C0 820 047 CG
   Component: J301  Klimaanlage   0208
   Revision: 2001001S    Serial number: 00000002537740
   Shop #: WSC 00066 790 00015
   VCID: 678BB3A2536721A2FE1-8032
   Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
   Component: BCM PQ25 Max3 H78 0725
   Revision: B8078001    Serial number: 78001010150261
   Coding: 7B994B1808AB0B0000382080240884C50F86702E60000050B00010022844
   VCID: 303918FEAA29A61AEFB-8064
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585141118220525
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584141112155712
   Coding: 820000
   Subsystem 3 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Component: E221__MFL-TAT  H04 0019
   Serial number: 3321403435600383AD1B
   Coding: 280000
   Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587141117163127
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14202586141121212935
   Coding: 800000
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD049J7P   Dataset Number: 160003V____ 0313
   Coding: 00004B33
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72BDD2F66425D40A59F-8026
   Serial number: IBH0000J150002928E0K
   Coding: 303142
   Serial number: 3572MSME2B4D7B4AZZZC
   Serial number: 3582MSME444A7B4AZZZ5
   Serial number: 3516KSME25230D33ZZZK
   Serial number: 3526KSME70663033ZZZI
   Serial number: 3556LSME3F760C32ZZZ%
   Serial number: 3566LSME44257631ZZZR
Address 17: Instruments
   Part No SW: 6N0 909 901     HW: 7H0 937 090 A
   Component: GW-K-CAN TP20 H78 0725
   Revision: B8078001
   Coding: 102200
   VCID: 70B9D8FE6AA9E61AAFB-8024
                    Mileage: 316721 km
                    Date: 2045.14.30
                    Time: 11:17:46
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2045.14.30
                    Time: 11:17:51
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2045.14.30
                    Time: 11:17:51
   Component: IMMO          H04 0807
   VCID: 6A8DCA964CF51CCAE1F-803E
Address 2E: Media Player 3
Address 37: Navigation
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F25DA75536752585-806C
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5614
   Revision: --------    Serial number: VWZZZ4H6231957
   Coding: 16000440040005
   Shop #: WSC 00078 790 00236
   VCID: 46D55E2638AD18AA257-8012
00856 - Radio Antenna
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2045.14.30
                    Time: 11:17:45
Address 6C: Back-up Cam.
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666896957 Dataset Number: 5N0035729E  0001
   Coding: 0A10030080010110
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 323D12F6A4A5940A99F-8066
          B104F 13 [00011000] - Short to GND
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2109.14.30
                    Time: 11:17:46
          B104E 13 [00011000] - Short to GND
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2109.14.30
                    Time: 11:17:46
End----------(Elapsed Time: 02:27, VBatt start/end: 12.0V/12.0V)-----------
EuroX
Northern NJ USA
C?ID=208579
According to your scan it can be reached and has zero faults. Maybe its getting ready to go KaboOm!!!! Is there any water in the car?
mikeb787
C?ID=492732
No, the inside of the car is completely dry.
mikeb787
C?ID=492732
Wednesday,30,October,2024,10:02:43:44889
VIN: 3VWLA7AJ4FM293334   Mileage: 316720km-196800miles
   Revision: 00H46001
                    Fault Status: 01101000
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:46
                    Count: 2
                    Count: 14
                    Count: 16384
                    Count: 8225
                    Count: 44032
                    Count: 1024
                    Count: 260
   Coding: 820000
   Coding: 820000
   Coding: 280000
   Coding: 800000
   Coding: 800000
Address 15: Airbags
   Part No SW: 5C6 920 954 A    HW: 5C6 920 954 A
   Component: KOMBI         H04 0807
   Coding: 270A01
   Shop #: WSC 00066 000 00118
   VCID: 2C010C8E8681C2FAD33-8078
   Revision: B8078001
   Coding: 102200
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:46
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:51
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:51
   Revision: 00H22000
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:45
   ROD: EV_UHVUMI.rod
          B104F 13 [00001001] - Short to GND
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2024.10.30.
                    Time: 11:17:46
          B104E 13 [00001001] - Short to GND
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2024.10.30.
                    Time: 11:17:46
End----------(Elapsed Time: 02:21, VBatt start/end: 12.3V/12.2V)-----------
I would be looking at that !
I started searching the forum and it suggested that I access the module directly and I was able to access address 17. There was no codes on 17 or the airbag module. The passenger air bag light stopped flashing. I cycled the key and it started flashing again and now my scan results are different. Now I have
Address 15: Airbags
Dr Sheldon
Windsor UK
C?ID=334979
Then you will need a wiring Diagram to check the wiring and power supplies to the Airbag Module
Those Modules do fail for fun ! Yours is the second one I have seen this week
mikeb787
C?ID=492732
   Revision: 00H46001
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:46
                    Count: 2
                    Count: 14
                    Count: 16384
                    Count: 8225
                    Count: 44032
                    Count: 1024
                    Count: 260
   Coding: 820000
   Coding: 820000
   Coding: 280000
   Coding: 800000
   Coding: 800000
Address 15: Airbags
   Coding: 270A01
   Revision: B8078001
   Coding: 102200
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:46
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:51
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:51
   Revision: 00H22000
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2019.03.23.
                    Time: 11:17:45
   ROD: EV_UHVUMI.rod
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2024.10.30.
                    Time: 11:17:46
                    Reset counter: 203
                    Mileage: 316721 km
                    Date: 2024.10.30.
                    Time: 11:17:46
Dr Sheldon
Windsor UK
C?ID=334979
Strange thing on your latest Scan
Address 15: Airbags
However nothing relating to that in 19: Gateway
I would expect a DTC in there for a missing Airbag Module !!
And some other modules also complaining they're missing messages from the Airbag module.
Strange, this is.
Dr Sheldon
Windsor UK
C?ID=334979
Strange, this is.
At first glance I wonder what someone has been doing - more of a story to this it seems ?!
